[Sammelthread] Asus P5B / P5B Deluxe /-WiFi–AP (Intel P965) [7]
Aktuell
Die komplette P5B-Reihe ist 45nm CPU ready : XS.org
1hoch
Inhalt
uber
Überblick
Sockel: LGA775
Unterstützte CPUs_
Intel® LGA775 Platform
Intel® Penryn Ready
Intel® Quad-core CPU Ready
Intel® Core™2 Extreme / Core™2 Duo Ready
Intel® Pentium® Extreme / Pentium® D / Pentium® 4 / Celeron® D Ready
Unterstützte FSBs_ 1066/800/ 533 MHz
Chipsatz_ P965 Express
1 PCIe x16 PEG Link
Sehr gut übertaktbar, FSBs über 500MHz keine Seltenheit [P5B Deluxe]
[Ich brauch noch mehr Allgemeines]
p5b
P5B
  • Storage
    • 4x SATA 3Gb/s [ICH8]
    • 1x IDE über JMicron
    • 1x eSATA über JMicron
    • 1x SATA über JMicron
  • RTL8111B PCI-E Gb LAN
  • 8-channel HD Audio
  • AI NOS™ / AI Gear / AI Nap
^Inhalt
clbBios-Changelog fürs P5B
2104 - 2009/05/27
Support new CPUs. Please refer to our website: http://support.asus.com/cpusupport/cpusupport.aspx?SLanguage=en-us
1604 - 2007/07/13
1. Enhance memory compatibility under FSB1333 mode
1501 - 2007/07/05
1. Add new CPU uCode to support new processor
1405 - 2007/06/13
1. Update CPU ucode to support new processor
2. Revise SLP 2.0 rule
3. Enable hotplug support under AHCI mode
4. Fix displayed CPU frequency incorrectly after downgrade CPU ratio
1202 2007/04/04
1. Fix system may sometimes hang after load default in setup then exiting right away while having Conroe CPU
installed.
2. Add new uCode to support new CPU.
1102 - 2007/01/31
**Please update AsusUpdate to V7.09.02 or later prior making this update.**
**This BIOS does not support roll back to earlier BIOS**
1. Finetune Q-Fan control algorithm
2. Enable EIST under VISTA
3. Update CPU Ucode to support new CPU
4. Fix BBS device string not correct under AHCI mode
5. Support SLP2.0 string
6. Fix HCT unreported I/O and memory issuse
7. Support disable USB function item
8. Allow disable XD for conroe L
9. Add full reset after change DRAM mode to enhance memory compatibility
10. Support CONROE E0 CPU(FSB 1333)
11. Fix AC Power loss function not correct
12. Support x4 DIMM
0806 - 2006/11/
1. Enable support for WiFi-TV card
2. Enable PreslerXE 3.73 support
3. Enable USB like support for SATA HDD connected to JMICRON controller when JMicron option is set to IDE or AHCI
mode
4. Drop CPU fan low limit to 600rpm when Conroe CPU is in use.
5. Enhance ATA ODD compatibility
6. Support Conroe-L CPU
7. Fix CPU VCORE too high after overclocking fail
0701 - 2006/10/5
2. Fix DRAM frequency incorrectly display problem under auto, standard and AI N.O.S mode
3. Reduce system full reset of times
4. Patch some VGA card can't found when NB Vcore value has been set too high
5. Fix DDR frequency 889 unstable by SPD
6. Add new CPU Ucode to support Kentsfield B3 stepping CPU
7. Improve S3 resume time
8. Fix FSB not correct displayed in BIOS setup when CPU has been set to non-standard frequency
9. Fix chassis fan 2 speed not correct when fan speed too low.
^Inhalt
p5bp
P5B-Plus
  • Intel LGA775 Platform
  • Intel® Quad-core CPU Ready
  • Intel® Core™2 Extreme / Core™2 Duo Ready
  • Intel® Pentium® Extreme / Pentium® D / Pentium® 4 / Celeron® D Ready
  • 1066/800/ 533 MHz
  • Dual-channel DDR2 800/667/533
  • 1x PCI Express x16
  • Storage
    • 6x SATA 3Gb/s [ICH8R]
  • PCI-E Gigabit LAN controller
  • AI NOS™ / AI Gear / AI Nap/ TPM Support
  • All High-quality Conductive Polymer Capacitors
^Inhalt
clpBios-Changelog fürs P5B Pus
0638 - 2008/10/29
Enhance the compatibility with certain memory.
0604 - 2007/06/13
1. Fixed PCProbe II fail to install problem
2. Add new uCode to support new processors
3. Enable SATA Hotplug support under AHCI mode
^Inhalt
p5bd
P5B Deluxe
  • Crossfire-Freigabe, 2te Karte über elektrischen PCIe-x4-Slot über die Southbridge angebunden [ca. 20% Leistungsverlust]
  • Storage
  • Dual Gigabit LAN controllers, Marvell® PCI-E and PCI Gigabit LAN controllers
  • 8 Phase Power Design
  • Fanless Design - Heat Pipe & Stack Cool 2
  • Array Mic / Noise Filter
    WiFi-AP: WiFi-AP Solo
^Inhalt
cldBios-Changelog fürs P5B Deluxe
Download --> http://amd.co.at/anti/asus/
1238 - 2009/02/11
Fix system hangs at POST while using certain 4GB memory and CPUs.
1215 - 2007/07/13
1212 - 2007/07/09
1. Add new CPU uCode to support new processors
3. Enable support for SATA hot plug function under AHCI mode
4. Fix after downgrade CPU ratio, the Conroe L frequency not correct under ASUSCPU
1101 - 2007/04/04
1 Add new uCode to support new CPU.
2 Fix system won''t complete POST with GV-MVP/RZ2(TV tuner) connected and power on before motherboard.
1004 - 2007.01.30
**This BIOS does not support roll back to older BIOS**
1 Enhance memory compatibility
2 Support CONROE E0 CPU(FSB 1333)
0910 - 2006.01.16
1. Update Jmicron option ROM to 1.06.59
2. Fix AC Power loss function not correct
3. Support x4 DIMM
4. Moidfy Write to Precharge Delay default from 10 to 11
5. Enable support for EIST under VISTA
6. Finetune Q-Fan rule
7. Support SLP 2.0
8. Fix BBS device string not correct under AHCI mode
9. Enable Disable USB capability
10.Support ASUS WIFI-TV card
11.Revise CPU temperature calculation algorithm for PECI
0910 - 2006/12/27
no changelog avaible..
0908 - 2006/12
0903 - 2006/11/
0804 - 2006/10/25
1. Support conroe L processor
2. Update JMicron option rom 1.06.22
3. Modify CPU fan low limit speed from 800 RPM to 600 RPM
4. Implement ASUS CGI performance with ATI 1950 graphic cards
0801 - 2006/10/11
we havent changelog ...
0711 - 2006/10/04
1. Fix DRAM frequency incorrectly display problem under auto, standard and AI N.O.S mode
2. Add check ATI CrossFire VGA card routine
3. Add ASUS Cross Graphics Impeller (ASUS C.G.I) feature
4. Reduce system full reset of times
5. Patch some VGA card can''t found when NB Vcore value has been set too high
6. Fix DDR frequency 889 unstable by SPD
7. Enable support for NVIDIA 7950GX2 cards under recovery mode
8. Fix CPU frequency not correct when use ES CPU and lock free fuction enable
9. Fix memory display message not correct under multi-language
10. Add new CPU Ucode to support Kentsfield B3 stepping CPU
11. Fix chassis fan 2 speed not correct when fan speed too low
12. Fix ATI CrossFire can''t work when using with 800FSB Prescott CPU
13. Enhance Chassis Q-Fan sensitivity
14. Improve memory compatibility
0706 - 2006/09/20
1. Enhance CrossFire performance.
2. Enable NVIDIA 7950GX2 display under crashfree mode
3. Fix CPU frequency not correct when use ES CPU and lock free fuction enable
4. Fix memory display message not correct under multi-language (dank an Norstern)
5. Add Kentsfield B3 uCode
0701 BETA - 2006/09/11
1. Fix chassis fan2 may not detect fan speed under ProbII if low spin fan is used.
0614 - 2006/09/06
1 Support DDR2 SO DIMM
2 Support DDR2 double side X16
3 Update Marvell 8001 and 8056 Lan option rom from 5.16.3.3 to 5.17.1.3
4 Fix Kentsfield B0 stepping CPU can't adjust ratio issue
5 Support Conroe / Kentsfield ratio overclocking higher than default (multi max 6- 11 (x-6800) -13
6 Fix CPU Fan Profile mode not correct after system shutdown
^Inhalt
ram
Kompatibler Speicher
kein Anspruch auf Vollständigkeit
sämtliche Micron D9: D9GMH und mit D9GKX
AENEON PC2-5300U-555-12 (DDR2-667) (AET760UD00-30DA98Z)
A-DATA Vitesta Extreme Edition DDR2-800+MHz PC2-6400 Dual Channel Kit CL4-4-4-15 2x1024MB
Corsair XMS2 PC2-5300U CL4-4-4-12 (DDR2-667) (TWIN2X1024-5400C4)
Corsair XMS2 PC2-6400U CL5-5-5-12 (DDR2-800) (TWIN2X1024-6400)
Corsair XMS2 PC2-6400U CL3-4-3-9 (DDR2-800) (TWIN2X1024-6400C3)
Corsair XMS2 PC2-6400U CL4-4-4-12 (DDR2-800) (TWIN2X1024-6400C3)
Corsair XMS2 PC2-6400PRO CL4-4-4-12 (DDR2-800) (TWIN CM2X1024-6400C4PRO)
Corsair XMS2 PC2-8500U CL5-5-5-15 (DDR2-1066) (TWIN2X2048-8500C5)
Corsair XMS2 Dominator Series PC2-8500U CL5-5-5-15-2T (DDR2-1066) (TWIN2X2048-8500C5D)
Corsair XMS2 Dominator Series PC2-8888U CL4-4-4-12-2T (DDR2-1111) (TWIN2X2048-8888C4DF)
Crucial Ballistix PC2-6400U CL4-4-4-12 (DDR2-800) (BL2KIT12864AA804)
Crucial Ballistix PC2-5300 3-3-3-12 D9GMH
Crucial Value CL5 D9GMH + D9GKX
GSkill GBHZ old D9GMH
G.Skill PC2-4200U CL4 (DDR2-533) (F2-4200PHU2-2GBNT)
G.Skill PC2-5300U CL5 (DDR2-667) (F2-5400PHU2-2GBNS)
G.Skill 2GB F2-6400PHU2-2GBNS ab 0614 Bios
G.Skill PC2-6400U CL5-5-5-15 (DDR2-800) (F2-6400PHU2-2GBNR)
G.Skill PC2-8000U CL4-4-4-5 (DDR2-1000) (F2-8000PHU2-2GBHZ)
G.Skill PC2-6400U CL5-5-5-15 (DDR2-800) (F2-6400PHU2-1GBNQ)
G.Skill PC2-6400U CL5-5-5-15 (DDR2-800) (F2-6400PHU2-2GBNQ)
^Inhalt
G.e.i.L PC2-6400 CL4-4-4-12 (PC800) (GX21GB6400UDC)
Kingston DDR2-RAM 2x512MB 533MHz KVR533D2N4/512
Kingston DDR2-RAM 2x1024MB 533MHz KVR533D2N4K2/2G
Kingston HyperX DIMM 1 GB DDR2-750, KHX6000D2/1G ( max 850 mhz)
MDT PC2-6400U CL5 (DDR2-800) (M1GB-800K)
Mushkin EM2-5300 2048MB PC2-5300U CL5 (DDR2-667) (991382)
Mushkin EM2 PC6400 2048MB DualKit
Cellshock DDR2-800 CL4 (CS2221041)
OCZ OCZ2P10002G-K (OCZ Platinum Enhanced Latency XTC)
OCZ2N9001GEB
OCZ28001024EBDCPE- (OCZ Platinum DIMM Kit 1024MB PC2-6400U CL4-3-3-8)
OCZ2N11001G
Hynix HYMP564U64BP8-S5 (512MB 5-5-5)
Hynix HYMP512U64BP8-S5 (1GB 5-5-5)
Hynix HYMP564U64AP8-S6
Hynix HYMP512U64AP8-S6
Golden Emp. 8HTF6464AY-80EA3
Golden Emp. 16HTF12864AY-80EA3
Golden Emp. 8HTF6464AY-80ED4
Golden Emp. 16HTF12864AY-80ED4
Transcend TS64MLQ64V8J (Transcend DIMM 512MB PC2-6400U CL5)
TwinMos ??? M2Y51264TU88A2B-25
NANYA NT512T64U88B0BY-25
NANYA NT1GT64U8HB0BY-25C
^Inhalt
eigEigenarten
botBoot-Bug/An-Aus-Bug
Wie äußert sich dieser Bug?
Wird der PC nach dem Herunterfahren komplett vom Strom getrennt, zum Beispiel in dem man das NT danach abschaltet, wird das Board beim nächsten Systemstart zuerst einmal starten, dann wieder ausgehen um dann normal zu booten, was nicht gerade lebensdauerförderlich für die angeschlossenen Festplatten ist.
Kann man dieses Verhalten umgehen?
Den "Boot Bug" nach Netztrennung kann man auf verschiedene Weisen umgehen: Den Rechner herunterfahren und Netzschalter des NT auf AN lassen, sodaß das Board weiterhin mitStandBy-Strom versorgt wird, dann bootet der Rechner beim nächsten Start normal oder mittels Master / Slave Leiste. Der Verbrauch hierbei schwankt zwischen 2 und 20 Watt - je nach angehängten Verbrauchern. Achtung: auch die verwendete Leiste kann den Verbrauch beeinflussen. Mit einer alten Lidl-Leiste lag der Verbrauch bei 3 Watt und mit einer viel aktuelleren Aldi-Leiste zeigte der Verbrauchsmesser bei gleicher Konfig fast 18Watt. Sofern ich mich nicht verrechnet habe, hier ein Rechenbeispiel: 14 Std. täglich "Standby" (also PC heruntergefahren an der Leiste) mit 20Watt bei 0,18€ pro kw/h ergeben ~ 19€ für ein Jahr. Ist Umweltpolitisch nicht ganz korrekt, aber mir den 1,50€ im Monat wert ;)
Strap-Verhalten [Umschalten der internen Timings][/B]von Sven Bode
Hier gehts weiter>>
messMesspunkte
vCore
vFSB
^Inhalt
BiosBIOS
bif0Bios-Flashen *BETA*
Vor dem Flashen das System auf Standardtakt zurücksetzen.
Es gibt 3 verschiedene Methoden:
EZ-Flash
1. Neues Bios von Asus herunterladen und entpacken
2. Bios-Datei auf Diskette oder USB-Stick speichern
3. Neustarten
4. Entweder beim POST ALT+F2 drücken, oder EZ-Flash im Bios unter Tools/Werkzeuge auswählen
5. Laufwerk auswählen mit TAB, dann ENTER zum Flashen
6. Der Rechner startet nach Abschluss des Flashvorgangs neu​
Afudos
2. Am besten direkt in P5B.rom umbenennen
3. entsprechendes Afudos-Programm von Asus herunterladen
4. Bootbare Diskette erstellen
5. afudos.exe und P5B.rom auf die Diskette kopieren
6. Rechner mit der Diskette im Laufwerk neustarten
7. "a:\" erscheint
8. Dort nun eingeben: afudos.exe /iP5B.rom
9. ENTER Der Flashvorgang beginnt. Den weiteren Anweisungen folgen​
Unter Windows mit ASUSUpdate[Erhöhtes Risiko]
2. ASUSUpdate von Asus herunterladen
3. ASUSUpdate installieren
4. ASUSUpdate starten und dem folgenden Dialog folgen
5. Rechner neustarten​
Nun wieder alles so einstellen, wie gewohnt.
Das Flashen war erfolgreich und ihr habt euer BIOS auf die den Letzten Stand aktualisieren.
bif1Flashen älterer Versionen
1. Bios von Asus herunterladen
3. Afudos v2.07 von hier herunterladen
7. "a:\" erscheint
8. Dort nun eingeben: afudos.exe /iP5B.rom /n /pbnc
bif1Totes Bios wiederbeleben
Bei Ami-BIOS braucht man eine Diskette, bei dem das BIOS-Image als "amiboot.rom" im Rootverzeichnis liegt. Die legt man ein, schaltet den Rechner ein und hält eine magische Tastenkombination (üblicherweise Ctrl + Home, deutsch Strg + Pos1) gedrückt. Das System sollte dann beepen, auf die Disk zugreifen und das BIOS flashen (der Bildschirm bleibt dabei aber dunkel - Flash-Ende wird durch einen oder mehrere Beeps angezeigt).
Weitere Verarbeitung folgt, bei Fehlern PM an mich.
bif2PECI-Interface
***In Arbeit***​
bif3Static Read Control
***In Arbeit***​
trsTreiber/Software
Aktuelle Treiber gibt es auf
support.asus.com
  • chipAktuelle Chipsatztreiber bei Intel
    >>Link<<
  • soundSoundtreiber
  • ahciAHCI-Einbindung
    AHCI-Einbindung bei der Neu-Installation von Win XP (für alle, die das auch wissen wollten).
    Vorbereitung (Treiberdiskette erstellen)
    1. Datei iata62_cd.exe von der Intel-Webseite runterladen
    2. Datei in d:\temp\ kopieren (Beispiel)
    3. Start>Ausführen> "d:\temp\iata62_cd.exe -a -a"
    4. Den Lizenzvereinbarungen zustimmen.
    Anmerkung zu 3. und 4.: Keine Angst, es wird nichts installiert, auch wenns so aussieht.
    5. Die Dateien aus dem Verzeichnis c:\programme\intel\Intel Matrix Storage Manager\Driver (...\Driver64 bei der
    64bit edition) auf eine Diskette speichern (direkt nach a:\ )
    Win-XP-Installation
    1. Nach dem Neustart ins Bios gehen
    2. Main > IDE Configuration > SATA Configuration [Enhanced]
    3. Configure SATA as: [IDE/RAID/AHCI]
    4. AHCI auswählen
    5. Bootreihenfolge: CD oder DVD-Laufwerk muss an erster Stelle stehen
    6. F10 und Neustart (vorher noch Win XP Installations-CD einlegen )
    7. Irgendwann gleich zu Beginn wird man aufgefordert, F6 zu drücken -> F6 drücken
    Anmerkung zu 7.: Bei mir ist dann nicht gleich was passiert, hab F6 noch paarmal weitergedrückt, ist nix
    "Schlimmes" passiert
    8. Irgendwann stellt Windows fest, dass es gar keine Festplatte gibt, aber man kann, wenn man möchte, einen
    externen Treiber einbinden (JA!)
    9. Diskette rein, Windows-Installation lädt die nötigen Dateien ohne zu mucken von der Diskette
    10. Dann wird festgestellt, dass 3 Treiber zur Verfügung stehen (RAID, AHCI, SCSI) - AHCI wählen
    11. Danach alles wie gehabt - bis es dann heisst: Fertig!
    Dank an pheeacs für dieses Tutorial]
^Inhalt
nbsStrap-Verhalten[Umschalten der internen Timings]
Auslöser der ganzen Problematik - verbunden mit dem Performanceeinbruch ist
hier zu finden.
Für die Praxis relevant ist der Verlauf der grünen Linie welcher sich bzgl. der Performance wie folgt äußert.
Beispiele:
Boot bis 400 (laut Kurvenverlauf Strap 1333 genannt) - hier im Forum gerne 1067er genannt - ein SuperPi 32M
Durchlauf:
bis dorthin ist die Welt noch in Ordnung (bis FSB 400) aber dann mit FSB 401:
wie kann man diese Situation umgehen - diesen Performanceabfall, hervorgerufen durch Verlangsamung der internen
Chipsatztimings, wenn man im Bios FSB 401 einstellt und somit in der "langsameren" Strap (1600 lt. Diagramm oder
im Forum 1333) landet? [Anm.: Strapverhalten wg. FSB1333-CPUs neu prüfen]
Mittels eines Tools wie
Clockgen
wenn man vorher mit einem FSB von max 400 gestartet hat. Aber dabei gilt es zu bedenken:
1. Boot mit 333-400 - wenn Boot mit weniger werdet ihr Schwierigkeiten haben die 400 zu erreichen (langsamere
Straps)
2. Genug Boardspannung einstellen - ein guter Wert für FSB 400-420 bei der Arbeit mit Clockgen sind 1,45V - 1,55V
auch möglich, mehr bitte nur mit WaKü.
Kurze Erläuterung bei der Einstellung des Tools:
1. Herunterladen (Siehe Link) oder eben hier:
http://www.computerbase.de/downloads/software/systemueberwachung/clockgen/?url=11187
2. Tool Starten und auf "PLL Setup" klicken
3. Im Clock Genarator Setup den Taktgeber CY28551 auswählen
4. Ignore GSB/PCI anklicken
5. Apply Selection
6. Dann über PLL Control den Takt erhöhen
Selbstverständlich muss man dieses nicht nach jedem Start einstellen,
Unter "Options" Punkt "Apply Current Setting at Startup" einfach aktivieren ;)
Resultat ist dann folgendes:
keine Verlangsamung mehr :d...
...und funktioniert auch mit 4GB
Dank an Sven Bode
^Inhalt
oceOC-Einstellungen
  • Gute Erklärung zu den wichtigsten Einstellungen bei XS.org
    >>Link<<
  • Overclocking-Guide bei tthetechrepository
    >>Link<<
  • Zusammenspiel von FSB, CPU und RAM (Teiler) (dank an Shaguar)
    >>Link<<
oclOC-Liste
oclhwmHardware-Mods
Hier Pics zum VDroop Mod
Anklicken der Bilder führt zur großen Version]
noch ein Link dazu: http://www.xtremesystems.org/forums/showpost.php?p=2007217&postcount=30
Ein Bleistift ist ausreichend dafür ;)
[Modifikationen auf eigene Gefahr und unter Verlust der Garantie]
^Inhalt
raz
Passendes Zubehör
  • Speicherkühler
    • OCZ - XTC Memory Cooler
    • Corsair Airflow RAM-Kühler
Unterschiede P5B --- P5B deluxe (WiFi):
Die Unterschiede werden in dieser Liste von Asus sehr gut dargestellt:
http://event.asus.com/2006/mb/P5B/models.html
Darüber hinaus gibt es Unterschiede in den Bios-Einstellungen, die dazu führen, dass das P5B keine so guten OC
Eigenschaften wie das P5B Deluxe (WiFi) besitzt. (Dies wird hoffentlich durch ein Bios-Update gelöst)
vDimm 1,8-2,1 / vCore 1,2125 - 1,7 (P5B)
vDimm 1,8-2,45 / vCore 1,1 - 1,7 (P5B Deluxe)
Einmal kann man die Speicher-Riegel beim P5B Deluxe mit mehr Spannung versorgen, was dazu führt, dass man sie bei
höherer Taktung stabil laufen lassen kann.
Zum anderen kann die Spannung der CPU beim P5B deluxe deutlich niedriger gesetzt werden als beim P5B
(non-deluxe). Im Fall eines Allendale hat dies z.B. den Vorteil, dass man ihn mit dem Standard-Takt auf 1,1V
laufen lassen kann, während man beim non-deluxe erst bei 1,2125V anfangen kann und somit Potenzial verschenkt
(Strom / Temperatur).
amnAnmerkungen zum Thread
allAllgemeines
Eure Mitarbeit ist natürlich erwünscht!​
chaChangelog
26.03.10 V1.00: Die jeweils letzten BIOS-Versionen nachgetragen
28.07.07 V0.41: BIOS-Flash-Guide hinzugefügt
20.07.07 V0.35: Noch mehr Infos eingefügt
20.07.07 V0.30: Weitere Infos eingefügt
19.07.07 V0.11: Geordnet, Bios-Changelogs aktualisiert
19.07.07 V0.10: Erster Release: Vorläufige Gliederung eingefügt​
danDanksagungen
  • Seppelchen dafür, mich zu überreden, den Thread zu übernehmen und Infos
  • Sven Bode für das Versorgen mit Infos
  • pheeacs für das AHCI-Tutorial
  • Berlinrider
  • Antivirus für das Erstellen des ersten Sammelthreads
  • Und die vielen anderen, die hier aktiv sind
^Inhalt
Ich habe die gleichen Einstellungen wie du. Ich musste aber afaik die FSB Spannung etwas anheben, ansonsten alles so, wie beim DC.
Worauf muss ich achten wenn ich einen Q9550 E0 kaufe? Gibt es da shops die irgendwelche besonderen cpu's verkaufen mit batches die mehr oc versprechen? Oder kann ich einfach bei mf oder alternate kaufen und gucken was ich bekomme?
Tray oder boxed?
Also 3,4ghz sollten schon drin sein, gerade wegen dem fsb. Das past dann halt.
Gute Batches kenne ich nicht. Ich selber hab mir einfach eine geholt und das wars. Boxed hat 3 Jahre Garantie und du kannst dir sicher sein, dass noch niemand die CPU vorher am laufen hatte ;) Ist aber dir überlassen.
ok dann ne boxed. komisch das die 9550er so wenig werden bei geizhals.
Was braucht denn das P5B-deluxx an VTT/vNB um 7x500 mit einem E6750 zu realisieren?
Welches Bios sollte man drauf haben? Es gibt ein 1238 Beta.
Ja nimm das 1238er. Ist m.E. das beste im Gesamtpaket. Ich habe alle Spannungen auf min. gehabt, als ich 8x500 mit einem E8400 gefahren bin. Kann mir nicht vorstellen, dass du irgendwelche Spannungen für einen E6750 erhöhen musst.
Ok danke, dann werd ich das mal flashen und schauen, ob ich meinem Kumpel seine Kiste etwas auf die Sprünge helfen kann.
edit: hat sich erledig mit dem Brett. Nach Bios-Flash auf 1238 hat es immer noch keine 4GB Ram angezeigt.
Dann hat er den FSB auf 400MHz gestellt alle Spannungen default, plötzlich roch es verschmort und das Board läuft nicht mehr. :shake:
Hat noch jemand eine Rechnung mir der man eine RMA abwickeln könnte?
habe gestern mein altes ASUS P5B (P965) FSB 1066 incl. neuesten Bios 2104 einen E8400 (E0) spendiert.
Laut Asus ist das Board mit neuem Bios für den E8400 (1333Mhz)kompatibel. Das neue Bios hatte ich schon zuvor bei meinem E6300 drauf.
Zusätzlich verbaute ich mir noch Mushkin Ascent XP2-6400 - Memory - 4 GB ( 2 x 2 GB ).
BIOS Einstellungen setzte ich zuvor schon auf Default.
Nach ein paar Mucken und Neustarts wurde der E8400 richtig erkannt.
Mit Prime95 lief der CPU und RAM für jeweils einen Durchgang stabil.
Seltsam ist jedoch die hohe CPU Temp im Idle von 52 Grad bei einem Frezzer PRO 7. Bei Prime Volllast habe ich 78-81 Grad???
Nun ist es so, dass ich meine Kiste nicht mehr richtig starten kann, gleich nach dem Erscheinen des Desktop läuft die CPU auf 100%, folge Win7 Ultimate 64 BIT fährt runter oder auch Bluscreen. Bluescreen kommt auch oft schon bevor der Desktop dargestellt wird. Beim Herunterfahren kann es sein, dass er sich komplett aufhängt.
Was könnte ich tun? Bitte um Hilfe
__________________
LCD: Sony KDL 40W4500
Soundsystem: Teufel Concept E Magnum Digital
Windows 7 Ultimate 64 BIT
Soundkarte: Creative X-FI Musik (PCI)
Grafikkarte: ATI Radeon HD 4850 512 MB (RV770)
Netzteil: Corsair 450W
Motherboard: Asus P5B
CPU: Intel(R) Core 2 E8400 @ 3 GHz (E0)
Jetzt stellen sich die üblichen Fragen: Kühler richtig montiert? Wie viel WLP?
Jemand Interesse an einem defekten P5B-deluxx oder hat eine Rechnung mit der man eine RMA abwickeln könnte?
Ich nehme stark an, dass sich ein Leistungs-Transistor verabschiedet hat.
Wie das pssieren konnte ist mir nicht klar aber ich nehme an, dass das Asus P5B-deluxx automatisch die Spannungen extrem anzieht, wenn man nur den FSB hochzieht aber alle Spannungen auf auto lässt.
In dem Fall ist auto mal wieder shice.........von solchen Features halte ich persönlich wenig. Bin selbst nach etlichen DFI-Boards mal ins Gigabyte-Lager gewechselt und echt zufrieden mit dem System.
Vorerst Dank für die Antworten:)
Eigentlich hätte ich die Problemlösung schneller finden sollten, indem ich mal mit so wenig wie möglich an Treibern, Hardware boote.
Das Problem lag an einem Hama USB-HUB.
Dieser war bei der Installation vom Win7 64 BIT angesteckt und funktionierte.
Beim CPU wechsel jedoch belegte ich die USB-Ports anders.
Also der E8400 läuft. Habe zudem noch das Bios erneut im MS-DOS geflasht und nun wird mir im IDLE 40 Grad angezeigt.;) Hoffe das es so bleibt!!!!!!
Mhhh, wie lange gibt Asus denn eigentlich Garantie?
Was willste für dein kaputtes haben (Bitte alles weitere als PM, will den Threat nicht spammen)?
hier evt jemand der weiß ob es sich lohnt ein neues board zu kaufen wegen pci-e 2.0?
weiß grad nicht wie das bei den neuen grafikkarten sein wird, ob die da nicht total einbrechen weil pci-e 2 fehlt. ansonsten fehlt dem board ja nicht wirklich etwas nötiges.
Also ich habe auf dem P5B DLX WF eine GTX280 laufen und erreiche ähnlich Benchmarks anderer User zwischen 17-18000 Punkte in 3DMark06. Also absolut ähnliches Niveau.
Daher kann ich mir nicht vorstellen, dass es sich deshalb lohnt ein anderes Board zu kaufen.
Außerdem hat mir meins bis jetzt treue Dienste geleistet und lief immer ultrastabil, trotz OC.
meins auch ultrastabil mit oc :d
ok dann denk ich kann ich es ja noch behalten (aucgh für die kommenden karten bald...). hätte auch keine lust ein neues einzubauen...(wakü rumgefummel usw)
was ist die optimale pci-e frequenz? 110?
Zwischen 100 und 110 ist der Unterschied prozentual unter 0,5 Prozent.
Limitierung PCIe 1.0, Was bringt PCIe OC ...
So, ... da immer häufiger die Frage aufkommt, ob und wie viel ein PCIe 1.0 Board limitiert und wie viel man mit Hochtakten des PCIe Taktes rausholen kann, hab ich mal wieder ein paar Ergebnisse für euch.
Wie immer, Tests mit identischem System, einmal mit 100 MHz PCIe Takt und einmal mit 120 MHz.
System auf alltags tauglichen Einstellungen, es sollen keine Höchstwerte erreicht werden, sondern nur ein genauer Vergleich zwischen den zwei PCIe Einstellungen.
Im Test ein Gigabyte GA P35 DQ6
3DMark 06
Gigabyte P35 DQ6 PCIe 1.0 @ 100 MHz - 19.348
Gigabyte P35 DQ6 PCIe 1.0 @ 120 MHz - 19.375 + 0.13%
3DMark Vantage
Gigabyte P35 DQ6 PCIe 1.0 @ 100 MHz - P14.355
Gigabyte P35 DQ6 PCIe 1.0 @ 120 MHz - P14.438 + 0.58%
CoH
Gigabyte P35 DQ6 PCIe 1.0 @ 100 MHz - 77.7FPS
Gigabyte P35 DQ6 PCIe 1.0 @ 120 MHz - 78.8FPS + 1.4%
Crysis "VH"
Gigabyte P35 DQ6 PCIe 1.0 @ 100 MHz - 30.8FPS
Gigabyte P35 DQ6 PCIe 1.0 @ 120 MHz - 31.0FPS + 0.65%
UT3
Gigabyte P35 DQ6 PCIe 1.0 @ 100 MHz - 143.02FPS
Gigabyte P35 DQ6 PCIe 1.0 @ 120 MHz - 146.19FPS + 2.21%
CoD4
Gigabyte P35 DQ6 PCIe 1.0 @ 100 MHz - 69FPS
Gigabyte P35 DQ6 PCIe 1.0 @ 120 MHz - 75FPS + 8.7%
Furmark
Gigabyte P35 DQ6 PCIe 1.0 @ 100 MHz - 4710P
Gigabyte P35 DQ6 PCIe 1.0 @ 120 MHz - 4714P + 0.08%
Der ganze Beitrag findet sich hier: http://www.hardwareluxx.de/community/showthread.php?t=504260
Wegen der Garantie.....da steht zwar 3 Jahre Warranty drauf, aber die bekommt nur der Großhändler. Also ein Fake!!!!!! Privat hat man die üblichen 2 Jahre und muss die RMA unbedingt über einen Händler abwickeln. Mit privat Leuten unterhält sich ASUS erst garnicht. Das nenne ich ja mal einen Spitzen-Support !?!? Ich frag mal mein Kumpel fü was er es rausrücken würde.
@ all
ist irgendwas bekannt wegen hefigem Übervolten bei auto Einstellungen?
Kann mir das nicht erklären was ihm da passiert ist.
Ansonsten hat er sein Case völlig zugepropft mit diesen Dämmmatten-Gedöhns. Er braucht es leise hat er gemeint. Dafür ist es ja jetzt richtig schön leise! :shot:
so mein Q9550 läuft jetzt auch auf meinem board mit 3,4ghz und 1,152v:) probiere später noch etwas weiter runter zu gehen.
wäre natürlich schön, wenn ich den fsb auf 433 stellen kann (dann passts mit dem 1066mhz vom ram, teiler 4:5), aber irgendwie scheint das ja nicht zu gehen bei 2 x 2 GB. oder geht das bei jemanden hier?
ich bekomme dann immer nurn schwarzes bild und hab dann große probleme das wieder in Gang zu kriegen.. bios resett.. hin und her einstellen usw.
Deine CPU läuft ja genau wie meine :)
Mach mal einen anderen Teiler, vielleicht klappt es dann. Ich habe auch Mühe meinen FSB noch weiter zu heben... Muss dann einige Spannungen auf drehen, worauf ich keine Lust habe. Deshalb läuft die CPU @ 3,4GHz. Bin mi aber sicher, dass sie auch mehr mitmacht. 3,6 habe ich mal mit anderen rams getestet und das ging.
wir würden locker 4ghz schaffen. Mein board müsste auch 500fsb packen, aber ich weiß nicht warum es nicht geht. muss an der NB liegen... aber hab neue wlp drauf gemacht (wakü) heute, vielleicht gehts nun... mal morgen testen.
am besten wäre dann FSB427 * 8,5 und dann hab ich DDR1067 und 3,63ghz :)
ich probiere das mal morgen aus.
btw: im moment läuft er mit 1,144v und spielen geht zumindest :d und prime läuft auch die erste instanz durch. was ja schonmaln gutes zeichen ist.
temps gehen nie höher als 50 grad unter last.
FSB 500 packt das Board schon, aber nicht mit einem Quad. Da ist bei ca. 460 schluss, wobei hier schon einige Spannungen erhöht werden müssen.
Teste doch mal mit Prime Small und LinX. Dann siehst du schnell, ob deine CPU stabil ist.
FSB 427 macht nicht viel Sinn. Da das P5B ab 400 in einen neuen Strap schaltet und die Timings runtersetzt. Und der FSB ist ja eh bei den 775ern der Limitierende Faktor. Daher hab ich mir nen damals nen Q6600 geholt der bei FSB400 die 3,6Ghz hat und ich auch das maximum beim FSB raushole.
Wenn dann würde ich schon versuchen noch ein bissel höher zu gehen... in Richtung 450. Schon blöd der 8,5er Multi beim Q9550.
Daher bin ich jetzt auf 400. Erst so ab 430 hat man wieder ein Geschwindigkeitsvorteil
meint ihr der strap macht so viel aus das der verliust erst mit fsb430 wieder aufgeholt ist?
das müsste man mal benchen.
bei fsb450 wirds mitm ram bei mir schwierig...
schau Dir doch einfach mal den ersten Post an - bzgl. Strap Verhalten. ;)
Mehr als FSB 400 macht keinen Sinn - es sei denn 460+
Ob jetzt 3,4GHz oder 3,6GHz; im Normalfall wirst du keinen Unterschied merken ;)
aber wie verhällt es sich zum cpu takt?
http://www.kompanion.de/forum/p5b/bandwidth_a.jpg
da steht memorybandwidth.
vielleicht verdreh ich auch nur was... aber wenn man so schon sagen kann das FSB430 mit 3,6ghz lamer ist als fsb400 mit 3,4.. was solls. wobei es schon erstaunlich ist das cpu takt UND mehr speichertakt trotzdem nicht gegen den strap ankommen.
@wrextor
das stimmt sicherlich, aber es ist halt spassiger mit mehr ghz :d
hast du auch den droop mod?
was könnte ich noch tunen?
Ne hab keinen droop mod. Hab generell keine Mods. Tunen? Höchstens die Timings nachdem du deine finale Einstellung für die CPU gefunden hast.
timings geht nicht weil wenn ich es manuell mache bootet er nicht. muss timings vom spd lassen. bin froh das es so läuft. ich versuche dann mal unter 1,1v zu gehen, mal schaun was die cpu dann macht. Ich schätze das ist ne richtig gute cpu. Hab ich so im gefühl :)
Das gute an meinem droop mod ist, dass die vcore idle niedriger ist als unter last, also unter last geht es etwas hoch :) das ist praktisch.
lol bei mir geschieht genau das umgekehrte unter Last ^^
