[Sammelthread] Asus P5Q / P5Q3 Deluxe (Intel P45)
+Flori+
Semiprofi
Tübingen
ASUS P5Q/P5Q3 Deluxe
Übersicht:
1. Allgemein
  • 1.1 Layout
  • 1.2 Features
  • 1.3 Technische Daten
  • 1.4 BIOS Screens
  • 1.5 Lieferumfang
2. Nützliches
  • 2.1 Informationen
  • 2.2 FAQ
  • 2.3 Reviews
  • 2.4 Kompatibilitätsliste
3. Downloads
  • 3.1 BIOS
  • 3.2 ExpressGate
1.1 Layout:
Quelle: asus.de
1.2 Features:
- PCIe 2.0
- CrossfireX Ready
- Dual-Channel DDR2 1200
- ASUS True 16-Phase Power Design
- ASUS EPU-6 Engine
- ASUS Express Gate SSD
- ASUS Drive Xpert
- AI Nap
- Stack Cool 2
- Fan Xpert
- DieHard BIOS
- Q-Shield
- Q-Connector
- EZ-Flash 2
- O.C. Profile
1.3 Technische Daten:
CPU
LGA775 socket for Intel® Core™2 Extreme/Core™2 Quad/Core™2 Duo/Pentium® dual-core/Celeron® dual-core/Celeron® Processors
Compatible with Intel® 05B/05A/06 processors
Supports Intel® 45nm Multi-Core CPU
Chipsatz
Intel P45/ICH10R with Intel® Fast Memory Access(FMA) support.
Front Side Bus
1600/1333/1066/800 MHz
Memory
4 x DIMM, max. 16GB, DDR2 1200/1066/800/667MHz, non-ECC, un-buffered memory
Expansion Slots
2 x PCI Express 2.0 x16 slots, support ATI CrossFireX™ technology at x8 link
(PCIe x16_1 blue, PCIe x16_2 black*)
1 x PCI Express x16 slot at max. x4 link(black)
2 x PCI Express x1 slots
2 x PCI slots
*PCI Express x16_2 slot (black at max. x8 link)
Southbridge
- 6 x SATA 3Gb/s
- Intel® Matrix Storage Technology with RAID 0, 1, 5, 10 support
Marvell 88SE6121
- 1 x UltraDMA 133/100/66 for up to 2 PATA devices
- 1 x External SATA 3Gb/s port (SATA On-the-Go)
Silicon Image Sil5723 (Drive Xpert technology)
- 2 x SATA 3Gb/s
- Supports EZ Backup and Super Speed functions
LAN
Dual Gigabit LAN controllers
Marvell 88E8056/88E8001® Gigabit LAN controller featuring AI NET2,Teaming and Redundant
Audio
ADI® AD2000B 8-channel High Definition Audio CODEC
- Support Jack-Detection, Multi-Streaming, and Front Panel Jack-Retasking
- Coaxial/Optical S/PDIF out ports at back I/O
- ASUS Noise-Filtering
IEEE 1394
LSI®L-FW3227 controller supports 2 x IEEE 1394a ports(one at mid-board; one at back panel)
USB
Max. 10 USB2.0/1.1 ports(4 ports at mid-board, 6 ports at back panel)
ASUS AI Lifestyle Features
Back Panel I/O Ports
1 x PS/2 Keyboard/Mouse combo port
1 x Optical + 1 x Coaxial S/PDIF Output port
1 x External SATA port
1 x IEEE1394a port
2 x LAN (RJ45) ports
6 x USB 2.0/1.1 ports
8-channel Audio I/O ports
Internal I/O Connectors
2 x USB connectors support additional 4 USB ports
1 x Floppy disk drive connector
1 x IDE connector
1 x COM connector
1 x TPM connector
6 x SATA connectors (red)
2 x Drive Xpert SATA connectors (orange)
1 x CPU Fan connector
3 x Chassis Fan connector
1 x Power Fan connector
1 x IEEE1394a connector
Front panel audio connector
1 x S/PDIF Out Header
Chassis Intrusion connector
CD audio in
24-pin ATX Power connector
8-pin ATX 12V Power connector
Power on Switch
Reset Switch
System Panel (Q-Connector)
BIOS
16MB AMI BIOS, PnP, DMI2.0, WfM2.0, SM BIOS 2.4
Manageability
1.4 Bios Screens:
Quelle: hothardware.com
1.5 Lieferumfang:
Quelle: bi-tech.net
2.1 Informationen
Unterschiede zwischen dem P5Q Deluxe und dem P5Q3 Deluxe:
  • Das P5Q verfügt über eine nur 2 phasige Spannungsversorgung der NB und des RAMs
  • Zusätzlicher SATA-Port beim P5Q
  • Das P5Q3 unterstützt DDR3 RAM
Wichtige Einstellungsmöglichkeiten im BIOS:
  • vCore: 0,85 - 2,1
  • tRFC: 20,25, 30, 35, 42
  • tWTR/tWR/tRRD: 1-15
  • tRAS/tRP/tRCD: 3-18
  • CAS Latency: 3-11
  • Ramteiler: 1:1, 5:6, 4:5, 3:4, 2:3, 5:8, 3:5, 1:2
  • FSB Termin. Voltage: 1,2 - 1,9
  • CPU PPL Volatage: 1,5 - 2,78
  • SB Vcore: 1,1 - 1,4
  • NB Vcore: 1,1 - 2,06
  • vDIMM: 1,0 - 3,08
Stromverbauch im Vergleich zum X48:
  • IDLE: 11 - 13 Watt weniger
  • Last: 12 - 15 Watt weniger
Preis:
Produkthomepage:
2.2 FAQ
Messpunkte:
Quelle: Awardfabrik.de (@arne)
Einbinden von AHCI in ein bestehendes Windows XP
Anleitung
Reg-Datei
(danke an Pearl-Freak)
Geschwindigkeit der Lan-Ports
Der untere Lan-Port ist schneller, da er über PCI-e angebunden ist. Der obere hat lediglich PCI.
(danke an M!ndfuck)
Umstellung von IDE auf AHCI unter XP und Vista nach der Installation
Einfach den Treiber im Gerätemanager ersetzen ist nicht möglich und wenn doch, dann folgt der Bluesreeen beim nächsten Rechnerstart promt. Einfach AHCI im Bios aktivieren geht aber auch nicht, denn hier könnte XP bzw. Vista seinen Dienst beim Start wiederum mit einem Bluescreen quittieren. Das Problem tritt auf, wenn der AHCI-Treiber in XP bzw. Vista deaktiviert ist. Überprüfen und aktivieren kann man diesen Treiiber nur in der Registry unter folgendem Schlüssel und Wert.
Start > Ausführen > regedit > Enter
HKEY_LOCAL_MACHINE > System > CurrentControlSet > Services > Msahci
Im rechten Fenster doppelklick auf Start und den Wert 4 auf 0 ändern.
Wenn nicht vorhanden, dann die entsprechenden Schlüssel und Werte erstellen.
Ladet hier den Intel® Matrix Storage Manager für XP und Vista herunter und entpacke diesen. z.B. C:\Temp\iata82_enu.exe -a -a . In dem Ordner C:\Programme\Intel\Intel Matrix Storage Manager\winall\Driver befindet sich dann eine Datei IaStor.sys. Diese kopierst du nach C:\Windows\System32\drivers.
Jetzt den PC neu starten, im Bios auf AHCI umstellen und dann die Treiber einbinden oder dieses von XP machen lassen. Neustart ist danach unbedingt nochmal erforderlich. Jetzt laufen die SATA Festplatten und die SATA optischen Laufwerke im AHCI.
Wer SATA DVD Brenner besitzt und diese nicht richtig erkannt werden oder keine leeren Rohlinge mehr erkennen, der sollte wieder auf IDE umstellen.
(danke an Murmel44)
2.3 Reviews
Bitte bei mir melden um Erfahrungen eintragen zu lassen.
  • Kühler:
    Thermalright Ultra 120 Extreme
    Thermaright IFX-14
    Scythe Ninja Ninja Plus Rev. B
    Scythe Ninja Cu
    Scythe Mugen
    Scythe Andy Samurai Master (nur in eine Richtung)
    Scythe Mine Scythe Mine Rev. B
    Scythe Samurai Z
    Scythe Kama Cross
    EKL Groß Clock'ner (nur in eine Richtung)
    Zalman CNPS9500AT
    Noctua NH-U12P
    Thermaltake Big Typ 12 (nur mit einer alternativen Backplatte)
  • RAM P5Q Deluxe:
    Geil Black Dragon
    Mushkin PC8000 5-5-5-15
    Muskin XP2 8500 2x4GB Kit
    Corsair Dominator PC8000
    Crucial Ballistix DDR2 800 und 1066
    G.Skill 4GB PC2-8000U
    Crucial Ballistix Tracer RED 4GB PC2-6400C4
    Kingston ValueRAM DIMM 1GB PC2-6400U CL5
    Kingston HyperX (PC2-8500) KHX8500D2K2/1GN
    OCZ PC2-8500 REAPER CL5 KIT 4096MB
    G.Skill F2-8500CL5-1GBHK
3.1 BIOS
P5Q Deluxe:
0610
0702
0703
0704 Beta
0803
0901 (evtl. Beta)
1102 Beta
P5Q3 Deluxe:
0611
0704
3.2 ExpressGate
V1231
Wie siehts denn aus ? erste tiefergehende Eindrücke vorhanden ?
Bald wird ja hoffentlich der Computerbase-Test kommen und so langsam ist das schöne Brett auch bei uns verfügbar.
In 1 Woche wird sicherlich noch viel mehr bekannt sein, wobei die englishen Reviews durchweg positiv über das Board berichten.
mir stellt sich nur die Frage:
X38 oder P45...
gibt ja bei den "teureren" Boards keinen Unterschied im Preis..
X38 ist teils sogar preiswerter...
Was die Ausstattung angeht ist es ja im Prinzip auch fast das Gleiche...
Solange du kein Crossfire betreiben willst, würde ich dir ganz klar zum P45 raten:)
hast du mir einen "Grund" oder ist das nur deine Meinung ?
Schöner Fred :) jetzt möchte ich nur noch gute OC ergebnisse mit dem Q9xxx/X33xx sehn :bigok:
@ Black Lion
Ich hatte X-38 und P45 verglichen, da ich finde, dass dären Ausstattung fast identisch ist...X-48 ist ja nochmal eine Stange teurer...
Der größte Vorteil im Gegensatz zum X38 ist wohl, dass es einfach aktueller ist und langlebiger deshalb...Evtl. auch die Wertstabilität...
Nunja mal schauen...
Ich habe mir das Asus P5Q Deluxe bestellt!
Habs auch hier liegen muß aber noch umbauen wird wohl morgen oder Sonntag bis es bei mir läuft, mein altes ist unter wasser und der umbau wir dauern, morgen kommt noch was vom bestseller und dnn geht s ab
hoff ich doch
Das P5Q Deluxe...
- bleibt Kühler
- verbraucht weniger Strom
- hat nette Features wie EPU und die hoffentlich etwas nützende 16(!) Phasen Spannungsversorgung
- ist billiger
- hat eine neuere NB
...gegenüber dem X38/X48.
Solange man kein Corssfire betreibt, würde ich also nicht zu einem X Chipsatz greifen. Und wenn doch, dann das P5E kaufen (die neueren werden mit der X48 Rampage Platine geliefert und nur überklebt) und auf das Rampage flashen :love:
Ich habe mein Asus P5Q Deluxe heute eingebaut und kann folgendes dazu sagen:
- Thermalright Ultra-120 extreme paßt perfekt
- OCZ Platinum XTC DIMM Kit 4GB PC2-8000U läuft unabhängig vom Teiler nur mit 400MHz
- EPU-6 funktioniert beim übertakten nicht
- vorinstallierte Bios Version: 0506
- kein VCore droop
- kein VCore droop
Klingt schonmal gut :d was geht den an max. FSB mit dem Q9450 ?
@ dr-ami
Du hattest sicher unter deinem P5E Aufkleber ein Maximus stehen oder? Ist mittlerweile bekannt, dass die P5E mit Rampage Platine mit den Penryn-Quads deutlich besser gehen.
@ dr-ami
Auch die P35 gehen recht gut mit den Penryn's, bin gespannt ob der P45 da noch was drauf legen kann :d
Ich hoffe das Beste, der P45 soll ja ein würdiger Nachfolger sein.
Aber echt seltsam, wieso die P5E und Maximus Formula mit den CPUs solche großen Schwierigkeiten haben.
0604 ist leider noch "alpha" und somit rückt es niemand raus :(
0302 war das letzte offizielle, wurde aber vom FTP genommen und ausgeliefert wurden
die Boards mitm 0506.
@ Dark Ice
jo klar gibts Kits, aber gibt halt auch welche die es nicht machen wollen :fresse:
wenn jemand das Board mit G-Skill Ram bestückt hat, bitte mal Rückmeldung geben wie sie laufen...
Am besten mit DDR2-1000er Speicher...
ah das sind genau meine Speicher..
testest du heute weiter ? will wissen auf was ich mich einstellen kann...
"Crisch's" Dominator wollten ja die 500 nicht 1:1 laufen...die anderen Teiler gehen komischerweise...
und das wäre mein Ziel...(FSB 500 - Ram 1:1)
Bin gerade im Bios, wofür steht
CPU GTL Voltage Reference (0/2)
CPU GTL Voltage Reference (1/3)
CPU PLL Voltage
NB GTL Reference
Das kenne ich von meinem alten Gigybyte Board nicht
das haben DFI Boards auch...
damit kannst du Feintuning betreiben...so kann man ein wenig die V-Core Spannung des CPU's senken...
man muss sich allerdings damit auskennen und viel Zeit haben...(und Nerven)
Hier geistert irgendwo ein Tutorial dazu rum...
FSB 500 schafft meine CPU nicht, aber ich hab mal FSB 375 und 400 mit jeweils DRAM Takt 1000 getestet und funktioniert 1a! (getestet mit Everest)
Das Bord ist echt genial. Bin eh nicht so der absolute OC freak, aber ich finds angenehm, wenn man ohne viel rumfummeln ein bischen OCen kann....
Das EX38-DS4 war dagegen echt schwach...
greetz
eandy
