indianchief
KHX6400D2K2/2G
2GB (1GB 128M x 64-Bit x 2 pcs.)
PC2-6400 CL5 240-Pin DIMM Kit
Page 1
DESCRIPTION:
Kingston's KHX6400D2K2/2G is a kit of two 128M x 64-bit 1GB (1024MB) DDR2-800 CL5
SDRAM (Synchronous DRAM) memory modules, based on sixteen 64M x 8-bit DDR2 FBGA
components per module. Total kit capacity is 2GB (2048MB). Each module pair has been tested to
run at DDR2 800MHz at low latency timing of 5-5-5-15 at 2.0V. The SPD is programmed to JEDEC
standard latency 667Mhz timing of 5-5-5-15 at 1.8V. Each 240-pin DIMM uses gold contact fingers
and requires +1.8V. The electrical and mechanical specifications are as follows:
FEATURES:
Power supply : Vdd: 1.8V ± 0.1V, Vddq: 1.8V ± 0.1V
Double-data-rate architecture; two data transfers per clock cycle
Bidirectional data strobe(DQS)
Differential clock inputs(CK and CK)
DLL aligns DQ and DQS transition with CK transition
Programmable Read latency 5 (clock)
Burst Length: 4, 8 (Interleave/nibble sequential)
Programmable Burst type (sequential & interleave)
Timing Reference: 5-5-5-15 at +1.8V / 5-5-5-15 at +2.0V
Edge aligned data output, center aligned data input
Auto & Self refresh, 7.8us refresh interval (8K/64ms refresh)
Serial presence detect with EEPROM
High Performance Heat Spreader
PCB : Height 1.180” (30.00mm), double sided component
PERFORMANCE:
Clock Cycle Time (tCK) CL=5 3ns (min.) / 8ns (max.)
Row Cycle Time (tRC) 54ns (min.)
Refresh to Active/Refresh Command Time (tRFC) 105ns
Row Active Time (tRAS) 39ns (min.) / 70,000ns (max.)
Single Power Supply of +1.8V (+/- .1V)
Power 1.922 W (operating per module)
UL Rating 94 V - 0
Operating Temperature 0o C to 55o C
Storage Temperature -55o C to +125o C
Das sind meine RAM. JEDEC wie es scheint und nicht SLI fähig.
Ich nehme an, dass ich also die Werte von Hand eingeben muss. Aber welche und wo?
Gruss, Martin
Page 1
DESCRIPTION:
FEATURES:
PERFORMANCE:
UL Rating 94 V - 0
Gruss, Martin
