Seit gestern gibt es eine neue Version vom ATi Tray Tool das auch jetzt die HD 2xxx/3xxx unterstützt.
[F] Fixed localization bugs for CrossFire dialog window[*] Updated ini files handling procedures to be more compatible with Windows Vista[*] Improved compatiblity with IE7 under Vista with UAC enabled.
[+] Added new localizations
[+] Added option to change "Black and White level"
[F] Fixed OSD rendering problem with Overlord game. (Thanks to Unwinder)
[+] Updated Overlay color handling procedure to support new ATI Overlay color modes
[+] Implemented Save/Restore icon positions under WinXP 64 and Vista 64.
[+] Updated suppot for Adaptive AntiAliasing. Added support Multi-Samplinmg and Super-Sampling modes
[+] Monitoring Graphs window now can be sent to system tray.
[+] Added option to auto load Monitoring Graphs window at start up
[+] Added option to hide tray icon on load. You can restore icon to access settings by
starting ATT again. This will not load second copy of ATT in memory, but will send command to show tray icon. Also
added new hotkey to hide and show tray icon.
[+] Added configuration option hide_display to hide Displays menu.
[F] Fixed bug when settings for Crossfire can not be applied
[+] Implemented support for HD 2xxx/3xxx video boards. Overclocking, Monitoring, fan control. Big thanks to Unwinder for help!
[+] Implemented support for new AntiAliasing filter modes for HD 2xxx/3xxx video boards
[+] Added workaround to fix resume from suspend mode bug
[+] Now ATT can restore last used 3D profile after restart. You can enable this behavior in General Options
[+] New Monitoring Graphs and OSD plugins. "AMD Cpu CoreTemp" and "Intel CoreTemp" This plugin allows to read
Core temperatures on AMD 64 CPU's including Dual Core versions and on Intel Core2 (Duo/Quad)
[+] New OSD plugin. CPU Load%. Can show cpu load percentage for all available cores or cpu's
Download-Link: ATI Tray Tools 1.4.7.1185 Beta
Ich habe es auch schon mit meiner GeCube HD 3850 X-Turbo III getestet und meine Karte lief Stabil auf 837/1026
