ATI Radeon HD4000 (R700) - [Speku-, News- & Sammelthread] (Part1)
Alles rund um die ATI Radeon HD4000 Grafikkartenserie
Vorraussichtliche technische Daten:
HD 4870 (RV770XT), 55 nm, 850 MHz Chiptakt, 1050 MHz Shaderdomain, 1935 MHz Speichertakt, 480 Streamprozessoren, 32 TMUs, 16 ROPs, 1008 GFlops, 27.200 MT/s, 256 Bit Speicherinterface, 1024 MiB GDDR5, 123,8 GB/s Speicherbandbreite, 150 W TDP, $349 MSPR, Release Mai 2008
HD 4850 (RV770PRO), 55 nm, 650 MHz Chiptakt, 850 MHz Shaderdomain, 1728 MHz Speichertakt, 480 Streamprozessoren, 32 TMUs, 16 ROPs, 816 GFlops, 20.800 MT/s, 256 Bit Speicherinterface, 512 MiB GDDR5, 110,5 GB/s Speicherbandbreite, 110 W TDP, $269 MSPR, Release Mai 2008
HD 4850 GDDR3 (RV770PRO), 55 nm, 650 MHz Chiptakt, 850 MHz Shaderdomain, 1143 MHz Speichertakt, 480 Streamprozessoren, 32 TMUs, 16 ROPs, 816 GFlops, 20.800 MT/s, 256 Bit Speicherinterface, 256/512 MiB GDDR3, 73,2 GB/s Speicherbandbreite, 110 W TDP
Quelle: Hartware.de
NEWS:
More RV770 and RV770X2 details
Die shrink with minor changes
ATI said a few things about its new upcoming RV770 chips, and as we've said before you can expect [...]
weiterlesen
RV770 will do GDDR 5 and GDDR3
Two flavours
We’ve learned that single chip RV770 card comes in two flavours. The first one [...]
weiterlesen
RV770XT supports 512-bit memory
Despite the claims
A German Website posted an interesting article with a lot of RV770XT and PRO specs, but [...]
weiterlesen
R700 to launch close to Computex
Or around, at leastRV770 chips are looking good and the highest end R700 based product might launch around Computex (starts at June 3 2008). We believe [...]
weiterlesen
RV770 is already in production
Test one
We learned
that the RV770 GPU already went to production and there is a big chance to see R700 generation much earlier than anyone [...]
weiterlesen
Wer noch interessante Links hat, bitte per PN an mich weiterleiten!
Hat ATI nicht behauptet jedes Quartal einen neuen Chip rauszubringen?
Ich wüsste nicht wann und wo.
Zumahl ATI ja so viel behaupten konnte wie es will, aber seit AMD einzug erhalten hat, haben die ATI Leute sicher nur noch wenig zu melden...
hmm für den letzten chip hat amd/ati 6 Monate gebraucht.
r600(mai)->r670(november) == 6 Monate
der r680 ist ja kein neuer chip. eher 2 r670s mit anderer Taktrate.
Das Design steht ja auch schon für den r700(daher auch die bilder).
Jetzt müsste eig. die abschließende Phase der Entwicklung im Gang sein.
Das Design steht und man muss vllt. noch ein wenig auf den 45nm Prozes warten.
Wenn das mit den 6 Monaten wieder hinkommt, dann kommt der r700 vllt. schon im mai.
Also es wurde ja sicher lich schon paralell zum r600 Entwickelt und das Design ist ja im groben schon Ende November fertig gewesen.
Ich weiß.
Das ist jetzt sehr spekulativ, aber ein gewisser Rythmuss zeichnet sich meistens ab.
Oder weis es jmd. besser?
AMD hat selber gesagt dass der R700 erst 2009 kommt. ^^
xbit labs
Oder haben die sich wieder umentschieden?
Dann kommen die vll Ende 2008, ist ja fast 2009 dann, also kommts wohl aufs gleiche hinaus...
Das ist nur eine Missinterpretation der Roadmap für die Plattformen.
Ich weiß.
Neja gut, wenn man bedenkt, das der RV670 eigentlich das zu über 90% gleich dem R600 ist, dann ist klar warum dort "nur" 6 Monate dazwischen sind...
Zum R680, ist auch klar das dort vorhandene Chips (RV670) verbaut werden.
Des weiteren sollte man bedenken, das R600 und RV670 nicht sonderlich weit voneinander entfernt entwickelt wurden, sprich es ist definitiv nicht so, das der RV670 erst nach dem R600 Release des R600 begonnen wurde.
Beide Chips haben ihren Ursprung vor vielen Jahren gehabt, man könnte vllt sogar ne Ähnlichkeit zur X1800/X1900 herstellen. (Beide wurden nebeneinander Entwickelt, letzterer hat kleineren Herstellungsprozess)
Einzig die internen Werte blieben diesmal gleich...
Die R700 Chips sind aber sicher ne komplette Neuentwicklung, bauen aber sicher mehr oder weniger auf dem R600 Design auf, sprich sie werden sicher wieder Vec 5 Shader haben und werden dementsprechend wohl wieder viel Softwareoptimierung brauchen, bevor es richtig ab geht das Teil.
Tape-Out für ATI R700
Das Silizium sollte also gegen Ende Januar bereit sein für die ersten Tests Anfang Februar. Geht der Daumen nach oben, ist mit den ersten Grafikkarten in rund 90 Tagen zu rechnen, was in etwa auf den Mai hinausläuft.[...]
Da der neue Grafikprozessor auf RV670 und RV680 basiert und in der Architektur den Vorgängern ähnelt darf ernsthaft mit nahezu perfekten Chips gerechnet werden[...]
Q: theinquirer
na dann wollen wir doch mal sehen :d
News:
R700 is two RV770
CES 2008: Multi chip stuff
"ATI's next generation high end will be made of two RV770 chips. [...]
ATI’s next generation high end is dual core, [...] that ATI has a chance with it against Nvidia’s GT200. This product should come in Q2, probably later than sooner.
RV770 is naturally the DirectX 10.1 successor of very successful RV670 the chip that gave Nvidia so much headache and RV770 looks like an even bigger trouble maker.
Quelle: fudzilla.com
RV770 chip performs great Much faster than RV670
We learned that ATI's next generation performance chip codenamed RV770 performs much better than its RV670 predecessor. Our sources used the words „significantly faster than RV670“ and other independent sources have said that chip will be more than fifty percent faster than the existing generation.
RV770 is 55 nanometre chip and it all goes superb it will launch around Computex time (early June) but the final silicon are out and they work well. It still has to take a few months from the first silicon to the final production chip but it’s good to know that the chip looks good now.
This is the next generation fight but it is getting closer.
Quelle : http://www.fudzilla.com/index.php?option=com_content&task=view&id=5605&Itemid=1
RV770 and R700 to use GDDR5
A next generation
ATI's new flagship performance and high end chips will have the ability to use GDDR5 memory. This is the next big thing that ATI plans to embrace.
It looks that GDDR4 didn't really hit off as it doesn’t brings a lot of advantages over GDDR3 but GDDR5 promises some crazy frequencies all the way to 2.5GHz / 5GHz effectively which is more than two times faster with what you can achieve today with GDDR4.
This mean that the new memory will have more bandwidth and this is something that graphic card always enjoys.
At this time, we are not aware that GT200 has support for GDDR5.
Quelle : http://www.fudzilla.com/index.php?option=com_content&task=view&id=5675&Itemid=1
Hoffe dass ATI es mit dem R700 den nvidia jungs mal so richtig zeigt. War mal nvidia fan hab jetzt ne ati 2900 pro und ati ist mir mehr sympatischer.
wer nach sympatie im HW bereich geht, dem ist nicht mehr zu helfen :fresse:
vor allem das einem die 2900pro symaptisch erscheint. die karte ist ein reines kraftwerk, relativ geringe leistung und nen nervigen lüfter verbaut. die HD2000 serie war mit ATIs größter griff ins klo.
Klappt es nicht, schaffts vielleicht der R800 oder R900 oder R1000....ja super, jetzt geht die Kacke wieder los!
Und wenn das wirklich ein Multi-GPU Teil wird, muss noch VIEL gearbeitet werden! Das mag zwar die Zukunft sein, aber mit den jetzigen Treibern und Spielen würde das stark nach hinten losgehen. Mikroruckler und keine gescheite CF Unterstützung machen das ganze jetzt schon zunichte.....
Für mich klingt das wieder sehr nach theoretischer Bestleistung.
In der Realität wirds bestimmt kein so ein Kracher wie erwartet.
Beim R600 hat auch jeder gesagt, wie schnell wie Karte doch werden wird.
Praktisch hat die 2900XT gegen die 8800 Ultra/GTX doch verdammt alt ausgesehen.
Ich denke, dass Nvidias und ATIs neue Flagschiffe wieder ein weniger näher zusammen liegen werden wie jetzt, mehr aber auch nicht.
beim R700 wird das thema microruckler keine rolle spielen .... da die beiden gpus nicht mittels CF verbunden sind :bigok:
QFT aber es muss ja auch solche geben ;P
Die 2900 Pro ist doch geil. Geringe Leistung? Für den aktuellen Preis kannst du nix sagen-und NV hat da erst recht nichts vergleichbares... ATI ist immer für P/L-Kracher gut.
Sympathie zu irgendwelchen Herstellern ist aber in der Tat Quatsch. Wo das hinführt sieht man ja bei den Phenom-Käufern (ich kanns mir jedenfalls nicht anders erklären als mit Fanboy-Haftigkeit, wenn man eine CPU kauft die langsamer ist als eine viel billigere und verbugt bis zum Geht-nicht-meht...)-Glückwunsch :d
Vorbildlich ist bei AMD immer die Unterstützung der neuesten Speichertechnologie. Nvidia kränkelt seit Ewigkeiten mit GDDR3 während ATI bald auf GDDR5 setzen wird :bigok:
