Memphisstrike
Meiner Meinung nach sind die ersten beiden Teile von CoD eh am besten in Sachen Multiplayer.
Hey PC fans,
With the launch of First Strike on the PC on March 25th, I would like to answer a few of the most frequently asked questions from the community pertaining to server admins, clients, and map rotations. Please read the below guide carefully before posting questions in the forums.
Clients:
Anyone can play on any server, regardless of whether or not you have DLC installed. All players will continue to receive patches (including 1.07, which deploys alongside First Strike). If a server rotates to a DLC map that you do not have installed on your PC, you will automatically get kicked from that server.
Note: There will be an additional browser filter introduced in patch 1.07 that allows you to exclude servers with DLC content in their rotation. Quick match searches will only put players into matches with content that they have installed.
Admins:
All servers will have First Strike available on March 25th. It will be at the server admin’s discretion whether or not to run DLC maps on their server. Admins will also have the freedom to choose which First Strike maps will run on their server.
Note: Admins will NOT have to purchase a copy of the map pack in order to install it on their dedicated server.
Hopefully that clears up some of the most frequently asked questions surrounding the DLC deployment that will take place on March 25th.
Regards,
-JD
Das ist die Frage....Wie schauts eigentlich aus, wenn man die PEGI-Version für den PC hat. Klappt das wohl automatisch in DE oder muss man sich dat ausm Ösi Account schenken lassen?!?!?![]()
PATCH 1.07 - Deploying Friday, March 25 - Approximately 10a PST.
• Improved stability for Zombies, Multiplayer, and Dedicated Servers.
• Fixed server hitching when client is kicked for inactivity.
• Added server browser Filter for DLC.
• Quickmatch will prioritize servers running only the maps you own.
• Addressed various MP and Zombies exploits.
• Addition of the “Dolly Cam” editing mode in Theater.
• Improved reliability of Recent Game films saving properly.
• Connectivity improvements for Zombies.
• Added ability to remove Counter Spy-Plane effects with the Jammer.
• Players that put an enemy into Second Chance are now credited with a kill when the downed player is killed or takes the 'coward's way out'.
• Players will no longer receive any “hitmarkers” for shooting friendly equipment.
• Addressed an issue with switching classes while using a Chopper Gunner / Gunship.
• Disable player movement sounds when Ninja perk is equipped.
• Players can no longer “spawn tube” with the China Lake at the beginning of a match.
• Additional fine-tuning of audio levels for bomb plants/defuses.
• Headshot “ping” is now only audible if enemy dies.
• Limit the ability to re-roll supply drops using Hardline Pro to Care Packages only, no other killstreak drops.
• Addressed an issue where the incorrect perks would appear when spectating another player under certain circumstances.
• RC-XD adjustments.
• Addressed an issue with calling in Chopper Gunner / Gunship immediately after being shot down from a previous one.
• Various improvements to Multiplayer and Zombies leaderboards.
man ist das zum kotzen, steam server überlast wegen den DLC
Hi Leute,
wenn ich bei mir die neue Zombie-Map spielen will, kommt immer folgende Fehlermeldung:
couldn`t load image zombie_floodacc_n
Könnt ihr mir evtl. weiterhelfen?
MFG
LCP
---------- Beitrag hinzugefügt um 00:39 ---------- Vorheriger Beitrag war um 00:22 ----------
siehe da, es funzt.
wollte gerade schön ne runde zocken udn was ist.. nach jeder runde session abgelaufen oder wie der fehler heisst. danach kann ich auch nicht mehr neu joinen. war soll der mist wieder? schon ist nen patch draussen geht wieder irgendwas nicht das problem hatte ich sonst nie.... boahh
