[Sammelthread] Call of Duty Series / Black Ops 6 + Warzone
Wiso zum Teufel kann ich nicht auf einen Server Connecten . Bleibt immer bei Spieleinrichtung hängen . Ports sind offen . Patch ist drauf . Und Firewall aus . BS ist Vista 64
----- Initializing Renderer ----
execing ragdoll.cfg from disk
----- Client Initialization -----
----- Client Initialization Complete -----
Trying SMP acceleration...
...succeeded.
----- R_Init -----
Getting Direct3D 9 interface...
Pixel shader version is 3.0
Vertex shader version is 3.0
Shader model 2.0 code path is available.
Shader model 3.0 code path is available.
Using Shader model 3.0 code path because it is the best available path on this hardware.
Attempting 800 x 600 fullscreen with 32 bpp at 60 hz
Game window successfully created.
Using 4x anti-aliasing
Creating Direct3D device...
Com_TouchMemory: 0 msec. Using sum: 0
Loading fastfile code_post_gfx
Loading fastfile ui
Loading fastfile common
Initializing render targets...
Requested frame buffer to be 24-bit color with 8-bit alpha
DirectX returned a frame buffer that is 24-bit color with 8-bit alpha
Initializing static model cache...
Initializing dynamic buffers...
Initializing particle cloud buffer...
Creating Direct3D queries...
Loading fastfile 'code_post_gfx'
used 1.13 MB memory in DB alloc
Setting initial state...
DirectX reports 512 MB of video memory and 550 MB of available texture memory.
Using video memory size to cap used texture memory at 496 MB.
Texture detail is set automatically.
Using picmip 0 on most textures, 0 on normal maps, and 3 on specular maps
Waited 27 msec for asset 'shadowcaster' of type 'material'.
Waited 3 msec for asset 'stencilshadow' of type 'material'.
Waited 38 msec for asset 'cinematic' of type 'material'.
Error: Could not load material "water_droplet".
Error: Could not load material "water_dynamic_spray".
Loading fastfile 'ui'
used 39.49 MB memory in DB alloc
------- sound system initialization -------
Error during initialization:
Unhandled exception caught
(ja habe suche benutzt)
habe den tollen Fehler! Bitte ommt jetzt nicht mit Soundoutput auf 48 stellen, ist er :)
hat jemand ne ahnung wie man an die Sache rangeht?
habe ein Asus g1s mit ner 8600gt m etc..
aber XP
Jetzt kommt noch keine Verbindung zum Onlinedienst möglich . Das fängt ja schonmal gut an .
Hallo zusammen,
ich habe mir heute auch das Spiel gekauft und habe prompt auch 2 Probleme.
1. Wenn ich den Einzelspieler Modus starten möchte, bekomme ich immer die Fehlermeldung
-> "die DVD-ROM kann nicht gefunden werden"
-> Legen Sie die korrekte DVD-ROM ein, klicken Sie auf OK und starten Sie die Anwendung neu
2. Nach der Installation des Patches bekomme ich wie oben "ExAMDfAn" die selbe Fehlermeldung
-> " keine Verbindung zum Onlinedienst möglich"
ich wäre über Hilfe und Ratschläge dankbar.
MFG
Basti
Jetzt kommt aber noch der Oberhammer . Nichtmal die Singelplayer Version geht jetzt . Kommt ne Fehlermedlung von Coruppten Datein . Klasse Vorstellen von World Of War
Das "Problem" mit keine verbindung zum onlinedienst möglich hatte ich auch schon 1-2 mal... halbe stunde später ging es ohne ersichtlichen grund wieder! Ich habe auch nichts geändert! Ich hab im moment auch grad wieder schwierigkeiten aufn server zu kommen, bei mir steht immer irgendwas von "server authentification failure" (keine ahunung wie des geschrieben wird...)! Ein neustart des spiels und es ist weg!
Also den einzigen tip den ich geben kann, neustart des spiels probieren... wenn des net hilft, einfach mal komplett runterfahren. Bessere "lösung" kann ich leider nicht anbieten!
Edit: Jep, bin dabei ;)
Jetzt hab ich sie auch, also denk ich mal das es am masterserver liegt und net an unseren kisten :)
Bei mir hat nichtmal ein neustart geklappt. Habe jetzt alles Deinstalliert und bin grad wieder am neuinstallieren . Jetzt aber ohne Patch. Das ist echt klasse. 55 € bezahlt und nix geht.
Aber was vieleicht hilfreich wäre wenn man so einen Theat wie für Farcry 2 macht . Fragen und Antworten und alles zusammen trägt, und in den Ersten post verewigt.
Hat jemand nen Tipp warum ich nicht auf Koop Server connecten kann? Multiplayer geht super also Publicserver. Ich kappiers einfach net.
also bei mir ging es seit 3 tagen ohne probleme, konnte immer connecten.
grade eben aus dem spiel, wollte wieder rein und dann kam die meldung.
Jo, kann mich auch nicht mit dem Onlindienst verbinden. Im Forum von callofduty.com hagelt es auch schon beschwerden.
Ist circa seit ner halben Stunde so. Vorher gings noch. Hatte das Spiel nur kurz aus und habs dann neugestartet, dann nix ging mehr.
Sämtliche Einstellungen sind weg. Auch Grafikeinstellungen, usw.
Und ich war schon auf Rang 51 :-[
Omg hoffe mein Fortschritt ist nicht verloren und ich muss nicht von vorn anfangen.
:hwluxx:
bei mir läufts mit der x2 alles andere als flüssig hoffe bald noch nen hotfix.
Komisch. Ich hab kein Probleme mit den Framerates. Nur ab und an tauchen mal kleinere Grafikfehler auf.
hab auch keine probs mit meiner x2. immer 91fps! bei 1920x1200.
edit: ich kann mich auch nicht connecten.
verdammt wollte noch ne stunde zoggen und dann auf party. hmm
geil grademal gelesen was im cod5 forum abgeht...server sind wohl down...dann bleibt nur abwarten
naja , gibt noch welche die das game legal kaufen und nicht auf gecrackte server connecten wie das der Luxxerverein tut ..
mal ehrlich was hat man davon? macht vlt. in 2-3 monaten sinn, wenn patch 1.3 oder so raus is und die masterserver nichmehr verrecken :fresse:
Dear call of duty gamers,
As all of you noticed, the main server is down. Because of the amount of online players, the main server has crashed. The backups that we created were corrupt and wouldnt be usefull.
Its very shamefull that this is happening at the launch of the greatest game of the year.
The time estimating for back online will be between 6-10 days.
We cannot garantee this will be the precise date of going online but we make sure our gamers will be satisfied again.
On behave on the treyach team,
Regards
Bernd van Luijtelaar
Also mein englisch ist nicht grad des beste... steht da wirklich das sie probieren in ca. 6-10 tagen wieder online gehn zu können?? Wenn ja, sind die noch ganz frisch??
Sowas darf nicht pasieren, die hätten mit den Ansturm rechnen müssen und sollen, die wolten nur geld sparen und ein LOW Master Server eingestezt!
ja server sind alle gecrasht und sie können nicht garantieren das es in 6-10 tagen wieder läuft!!
Alle bitte ihr game zurückgeben und das geld zurückverlangen!!! Das müsste man tun!!:mad::eek:
ja das steh da^^
finds auch recht krass
aer naja dann halt mal bissel SP zocken xD
na toll. SP zocken wird auch öde ... hab den schon auf allen Schwierigkeitsgraden durch und alle Deathcards gefunden. Und die ganze Zeit Nacht der Untoten wird auch öde.
Ich fühl mich hier als zahlender Kunde echt langsam verarscht. Erst ist die Feldflasche nur Deko,dann komm ich nicht auf die Seite für die Collectors Edition (Invalid Code), dann krieg ich mein versprochenes Clanabzeichen (goldenes Clantag) nicht und jetzt schmiert diesen Idioten da auch noch der Server ab.
Regards
Nee kann nicht sein, ist doch ein Fake :-[
Aber ein guter
