Moin,
bin nun auch mal ein wenig am benchen
VISTA64/169.04 C2D@3200 + GF@600/1500/1800 FULLSCREEN
DX10.64_GPU @ 1680x1050 + HIGH + NoAA!
TimeDemo Play Started , (Total Frames: 2000, Recorded Time: 111.86s)
!TimeDemo Run 2 Finished.
Play Time: 66.52s, Average FPS:
30.07
Min FPS: 5.90 at frame 151, Max FPS: 40.65 at frame 87
Average Tri/Sec: -30012860, Tri/Frame: -998181
Recorded/Played Tris ratio: -0.92
TimeDemo Play Ended, (3 Runs Performed)
VISTA64/169.04 C2D@3200 + GF@600/1500/900 FULLSCREEN
DX10.32_GPU @ 1680x1050 + HIGH + NoAA!
Play Time: 66.24s, Average FPS:
30.19
Min FPS: 22.55 at frame 1954, Max FPS: 40.52 at frame 74
Average Tri/Sec: -30121226, Tri/Frame: -997572
DX9.64_GPU @ 1680x1050 + HIGH + NoAA!
Play Time: 71.15s, Average FPS:
28.11
Min FPS: 17.31 at frame 155, Max FPS: 37.36 at frame 71
Average Tri/Sec: -26264900, Tri/Frame: -934408
Recorded/Played Tris ratio: -0.98
DX9.32_GPU @ 1680x1050 + HIGH + NoAA!
Play Time: 69.44s, Average FPS:
28.80
Min FPS: 18.87 at frame 149, Max FPS: 37.12 at frame 84
Average Tri/Sec: -26894730, Tri/Frame: -933751
Also bei mir sind die Unterschiede echt minimal ... DX10 64Bit scheint aber wohl so mit am besten zu sein. Weiß allerdings nicht, ob das was mit dem neuen DX Update zu tun hat?
Greetingz - Stef
EDIT: hab gestern mal formatiert, Vista neu installiert und alle standardmässigen updates (die es über Windows update automatisch installiert) draufgemacht.
Vista64/162.22/DX10.64 - E6600@3000 - 8800GTS@600/1450/1800
1280x800 HIGH NoAA
!TimeDemo Run 1 Finished.
Play Time: 64.09s, Average FPS:
31.21
Min FPS: 7.55 at frame 141, Max FPS: 36.51 at frame 911
Average Tri/Sec: -30996412, Tri/Frame: -993232
TimeDemo Play Ended, (2 Runs Performed)
1440x900 HIGH NoAA
Play Time: 72.54s, Average FPS:
27.57
Min FPS: 17.26 at frame 1936, Max FPS: 32.28 at frame 338
Average Tri/Sec: -26772546, Tri/Frame: -971042
Recorded/Played Tris ratio: -0.94
1680x1050 HIGH NoAA
Play Time: 87.59s, Average FPS:
22.83
Min FPS: 8.75 at frame 258, Max FPS: 26.33 at frame 1557
Average Tri/Sec: -21333656, Tri/Frame: -934316
Die Performance in 1680x1050 ist echt sehr deutlich am A*sch! ... Mit dem 162.22 Treiber ... also ... nächste Treiberversion ... vorher aber nochmal ein DX9.64 test
