[Sammelthread] Crysis - Mster config v3.0
Bist du dir da zu 100 % sicher?
Hinzugefügter Post:
Crysis Bench mit der config unter Benchmark Tool:
0 mal AA und^16 mal AF
TimeDemo Play Started , (Total Frames: 2000, Recorded Time: 111.86s)
!TimeDemo Run 0 Finished.
Play Time: 42.63s, Average FPS: 46.92
Min FPS: 39.50 at frame 1941, Max FPS: 69.37 at frame 1012
Average Tri/Sec: -49567004, Tri/Frame: -1056447
Recorded/Played Tris ratio: -0.87
TimeDemo Play Ended, (1 Runs Performed)
Completed All Tests
<><><><><><><><><><><><><>>--SUMMARY--<<><><><><><><><><><><><><>
04.07.2008 18:17:52 - XP
Run #1- DX9 1280x1024 AA=No AA, 32 bit test, Quality: High ~~ Last Average FPS: 46.92
16 mal AF und 8 mal AA
Play Time: 50.95s, Average FPS: 39.25
Min FPS: 34.50 at frame 1981, Max FPS: 55.66 at frame 99
Average Tri/Sec: -40417828, Tri/Frame: -1029725
Recorded/Played Tris ratio: -0.89
Completed All Tests
04.07.2008 18:21:27 - XP
Run #1- DX9 1280x1024 AA=8x, 32 bit test, Quality: High ~~ Last Average FPS: 39.25
16 mal AF und 16 mal AA
Play Time: 52.88s, Average FPS: 37.82
Min FPS: 32.92 at frame 1981, Max FPS: 54.25 at frame 96
Average Tri/Sec: -38956856, Tri/Frame: -1029997
Completed All Tests
04.07.2008 18:24:48 - XP
Run #1- DX9 1280x1024 AA=16x, 32 bit test, Quality: High ~~ Last Average FPS: 37.82
Jetzt kommt das was ich nicht verstehe!!!!!! Jetzt ohne die Config!!!
da ist es genau anders rum je mehr AA ich dazu gebe um so mehr fps????
Hir ohne die config!!
16 mal AF 0 mal AA
Play Time: 40.63s, Average FPS: 49.22
Min FPS: 26.36 at frame 146, Max FPS: 69.54 at frame 967
Average Tri/Sec: 48660920, Tri/Frame: 988606
Recorded/Played Tris ratio: 0.93
Completed All Tests
04.07.2008 18:50:05 - XP
Run #1- DX9 1280x1024 AA=No AA, 32 bit test, Quality: High ~~ Last Average FPS: 49.22
16 mal AF 8 mal AA
Play Time: 47.30s, Average FPS: 42.29
Min FPS: 27.87 at frame 139, Max FPS: 56.29 at frame 109
Average Tri/Sec: 43149860, Tri/Frame: 1020400
Recorded/Played Tris ratio: 0.90
Completed All Tests
04.07.2008 18:54:12 - XP
Run #1- DX9 1280x1024 AA=8x, 32 bit test, Quality: High ~~ Last Average FPS: 42.29
Play Time: 48.83s, Average FPS: 40.96
Min FPS: 29.25 at frame 138, Max FPS: 56.60 at frame 987
Average Tri/Sec: 41794780, Tri/Frame: 1020476
Completed All Tests
04.07.2008 18:57:09 - XP
Run #1- DX9 1280x1024 AA=16x, 32 bit test, Quality: High ~~ Last Average FPS: 40.96
Du weist das der Test die inGame Einstellungen nutzt..
AF geht nur mit einer AutoExec in dem das steht >r_UsePOM=0
mach mal bitte mit fraps ein Bild in Game mit 8xAA oder 16AA
Ohne Master config!
00 mal AA
8 mal AA
16 mal AA
Das ist 4xAA und 16AF HQ,du siehst den Unterschied?
ich versuch mal DX9 nachzustellen
ich stell aber nur 8xAA ein,16x ist alles CSAA geschmiere
Ein weitere beweiss, das AA in crysis nicht wirklich funktioniert.
Der unterscheid zwischen 16xAA und 0xAA ist fast minimal (siehe waffe und palmen).
Bei einer auflösung von 1920x1200 sollte man bei 2-4xAA schon keine kanten und flimmern mehr haben.
Ich kann es nicht of genug sagen, aber am besten gegen kantenflimmern in crysis ist immer noch UseEdgeAA, macht mal einen bildvergleich an der gleichen stelle und ihr seht was ich meine.
nochmal die zusammenfassung :
Mit der Config 2.35
0 mal AA
MAX:69,37
Average:46,92
Min:39,50
8mal AA
MAX:55,66
Average:39,25
Min:34,50
16mal AA
MAX:54,25
Average:37,82
Min:32,92
Das ist ja alles soweit inordnung je mehr AA ich aktiviere umso mehr singt die leistung ein! Aber warum ist es ohne der Master config 2.35 fast umgedreht vorallen bei den min fps??
Ohne master Config:
0 mal AA
MAX:69.54
Average:49.22
Min:26,36
8mal AA
MAX:56,29
Average:42,29
Min:27,87
16mal AA
MAX:56,60
Average:40,96
Min:29,25
Warum steigen hir die MIN FPS an je mehr AA ich dazu gebe??
Kann mir jemand sagen warum das so ist und bei der master config nicht?
Mein system : Q9450, GTX 280 , 4gb ddr2 ram, Asus p5k, Windiws Xp, alles ungetaktet
Ohne Master config!
00 mal AA
8 mal AA
16 mal AA
So für alles die sich interresieren die 4870 schafft es bei 1920x1200 mit 4aa und 16af flüssig zu bleiben bei ultra settings wenn man den test startet für crysis siehst man am anfang 9fps und dann wechselt die karte in den 3d modus und eine sekunde später hat man konstant 35 fps wenn ich meine 4870 habe werde ich für euch gerne mit der mster config tests machen :wink:Soulja
DX9 8xAA 16AF HQ
Hinzugefügter Post:
Da ist doch gar kein AA an....
Er hat deine Config>autoexec und inGame wahrscheinlich noch AA an...
Flimmern ist DX10 das ist so gewollt im freien flimmerts auch.
Bei DX9 mit AA flimmert gar nichts mehr.
@mster ist des UseEdgeAA bei 3.0 schon standard aktiviert? falls nein, wie gehts und was frisst es bei deiner 8800er gt (hab ne 256mb und werd irgendwas bei 1280 fahren)
jungs ich will ja nicht so sein aber dafür gibts andere threads oder ;) man verliert ja schon den durchblick hehe
Ich habe das noch nicht hinbekommen, selbst mit den höchsten AA Modi, ganz einfach weil die engine das wohl nicht unterstützt.
Ich lasse mich von dir gerne vom gegenteil überzeugen, wenn du mir ein bild ohne treppen/kantenflimmern zeigst ;)
Aber führt diese diskussion doch im "Crysis Performance & Tweaking Thread" weiter :btt:
Aber warum habe ich mehr minFps ohne master config 2.35 wen ich mehr AA anstelle? Siehe meine Tabelle oben!
ahh... warum haben plötzlich alle ne GTX2x0 :d? ich wil lauch.. renne noch mit der blöden 88GT rum :d
wer zu spät kommt, bestraft der elektroschrott ;) dein konto wirds dir aber danken :p
gehört zwar nich hier rein aber entweder 4870 oder 260GTX denn die 280gtx ist zu langsamm für den preis.sagen wir es so ohne aa ist die 260GTX mit der 4870 gleich auf mit aa ist die 4870 mit 10% vor der 280GTX also musst du wissen habe gestern mit meinem kumpel ein bisschen gebencht der hat auch eine 260gtx die karte gefällt mir ist aber teuere und langsammer unter aa wie die 4870 und das schon ordentlich :wink:Soulja To topic Mster wann kommt deine config ich brauch die jetzt :bigok:
tjaa.. wenn ich ja gekld hätte würde ich nvidia gerne weiter unterstützen =) denn habe sozusagen aus ATi/Radeon gelernt :d aber jedem das seine ;)
ja musst du wissen aber 40 euro billiger und dann noch schneller daraus sollte nvidia gelernt haben
deswegen fallen ja auch schön die Preise =)
was habt ihr eigentlich noch so zusätzlich für optionen im Treiber verändert ? (Nvidia), bzw wenns jetzt hier nicht gegen die Forenregeln stößt, hat jemand nen fix für ragdoll, derm it MSTER Mod funktioniert? denn dieser UCP für 1.21 von GSc bringt bei mir fehler im Game
Du sabbelst so einen Dünnpfiff zusammen das gibt es gar nicht.
Schon die inGame Bilder mit Fraps sprechen hier Bände,wenn du was wärst würdest du mit deiner Überkarte und Crysis Vanilla mal nen Bildchen dagegen setzen,meine Herren muß das weh tun.
was bist du denn für ein depp lesen hat dir papie nicht beigebracht ich habe die karte nicht und was ist daran dünpfiff das die 4870 schneller als eine 260gtx ist du idiot
nein fängt er nicht,aber man deinen Kram nicht so stehen lassen,denn das ist flame und dazu noch Unwahr und an den Haaren herbeigezogen.
Beispiel
und dann bin ich raus danach können sich deine Mitleser aber ihren Teil denken.
Sry, dass ich das hier frage, aber nach etwas googeln und forensuche hab ich nichts dazu gefunden...
mein problem: Crysis unterstützt bei mir nur 16:9 auflösungen anstatt 16:10. das problem liegt allerdings auch nur bei crysis vor...jemand ne ahnung woran das liegen könnte, bzw. wie ich das problem lösen kann?
@Meister Eder...sry, dumme Gegenfrage ;) Wo kannst du das denn sehen, ob der 16:9 macht. Im Game gibts ja nur Option für Vollbild und halt die Auflösungen wählen!
