[Sammelthread] DFI LANparty DK P45-T2RS / T3RS / Plus (Intel P45) [10]
N
nfszocker
Guest
Zitat:
  • CPU
    • LGA 775 socket for:
      - Intel® Core2 Quad and Intel® Core2 Duo
    • Supports Intel Enhanced Memory 64 Technology (EMT64T)
    • Supports Enhanced Intel SpeedStep Technology (EIST)
    • Supports Intel Hyper-Threading Technology
    • Supports 1333/1066/800MHz FSB
  • Intel® chipset
    • Intel® chipset
      - Northbridge:
      Intel® P45 Express chipset
      Intel® Fast Memory Access technology
      - Southbridge: Intel® ICH10R
  • Memory
    • Four 240-pin DDR2 DIMM sockets
    • Supports DDR2 1200(O.C.)/1066/800/667 MHz
    • Delivers up to 12.8Gb/s bandwidth
    • Supports dual channel (128-bit wide) memory interface
    • Supports non-ECC unbuffered DIMMs
    • Supports up to 16GB system memory
  • Expansion Slots
    • 2 PCI Express (Gen 2) x16 slots - 2-way CrossFire: One slot operating at x16 (16-lane port) or two slots each operating at x8 (8-lane ports) bandwidth
    • 2 PCI Express x1 slots
    • 2 PCI slots
  • BIOS
    • Award BIOS
    • 8Mbit SPI flash BIOS
    • CMOS Reloaded
  • Audio
    • Realtek ALC885 High Definition audio CODEC
    • 8-channel audio output
    • DAC SNR/ADC SNR of 106dB/101dB
    • Full-rate lossless content protection technology
    • Optical S/PDIF-out and coaxial RCA S/PDIF-out interfaces
  • LAN
    • Marvell 88E8053 PCIE Gigabit LAN controller
    • Fully compliant to IEEE 802.3 (10BASE-T), 802.3u (100BASE-TX) and 802.3ab (1000BASE-T) standards
  • IDE
    • JMicron JMB363 PCI Express to PATA host controller
    • Supports up to 2 UltraDMA 33/66/100Mbps IDE devices
  • Serial ATA with RAID
    • Intel Matrix Storage technology
    • Supports up to 6 SATA devices
    • SATA speed up to 3Gb/s
    • RAID 0, RAID 1, RAID 0+1 and RAID 5
  • Rear Panel I/O Ports
    • 1 mini-DIN-6 PS/2 mouse port
    • 1 mini-DIN-6 PS/2 keyboard port
    • 1 optical S/PDIF-out port
    • 1 coaxial RCA S/PDIF-out port
    • 6 USB 2.0/1.1 ports
    • 1 RJ45 LAN port
    • Center/subwoofer, rear R/L and side R/L jacks
    • Line-in, line-out (front R/L) and mic-in jacks
  • Power Management
    • ACPI and OS Directed Power Management
    • ACPI STR (Suspend to RAM) function
    • Wake-On-PS/2 Keyboard/Mouse
    • Wake-On-USB Keyboard/Mouse
    • Wake-On-LAN
    • Wake-On-Ring
    • RTC timer to power-on the system
    • AC power failure recovery
  • Hardware Monitor
    • Monitors CPU/system/Northbridge temperature and overheat alarm
    • Monitors Vcore/Vdimm/Vnb/VCC5/12V/V5sb/Vbat voltages
    • Monitors the speed of the cooling fans
    • CPU Overheat Protection function monitors CPU temperature and fan during system boot-up - automatic shutdown upon system overheat
  • PCB
    • 4 layers, ATX form factor
    • 24.5cm (9.64") x 30.5cm (12")
Wasserkühlung NB-SB-Mosfets:
Wasserkühlung Zusammenstellungen vom "riverdief":
Luftkühlung:
Passt mit Problemen:
EKL Alpföhn Groß Clockner ( passt nur mit Modifikationen ...entweder am Kühler oder Chipsatzkühler )
Scythe Andi Samurai (gedreht)
Scythe Mugen 2 (der Lüfter muss 5mm verschoben werden)
Thermalright HR-01 Plus (gedreht)
Kompatibler Arbeitsspeicher:
A-DATA Vitesta Extreme Edition 2 GB PC2 9600
Cellshock DIMM Kit 2GB PC2-8500U CL5-5-5-15 (DDR2-1066) (CS2221550)
Chaintech Apogee GT DIMM Kit 4GB PC2-8500U CL5-5-5-15
Chaintech Apogee GT DIMM Kit 4GB PC2-9200U CL5-5-5-15 (DDR2-1150)R2-1150-4GDHS
Corsair DIMM 4 GB DDR2-800 DHX Kit (TWIN2X4096-6400C4DHX)
Corsair XMS2 Dominator 2GB PC2-8500U CL5-5-5-15 TWIN2X2048-8500C5D
Crucial Ballistix Tracer PC8500 1066MHz BL12864AL1065.8FE5
GeiL Value DIMM Kit 2GB PC2-6400U CL5-5-5-15 (DDR2-800) (GX22GB6400DC)
GeIL Ultra DIMM Kit 2GB PC2-8500U CL5-5-5-12 (DDR2-1066) (GX22GB8500UDC)
G.Skill Kit 4GB PC2-6400U CL5-5-5-15 (DDR2-800) (F2-6400CL5D-4GBPQ)
G.Skill Kit 4GB PC2-8000U CL5-5-5-15 (DDR2-1000) (F2-8000CL5D-4GBPQ)
G.Skill Kit 4GB PC2-8500U CL5-5-5-15 (DDR2-1066) (F2-8500CL5D-4GBPI-B)
G.Skill Kit 4GB PC2-8800U CL5-5-5-15 (DDR2-1100) (F2-8800CL5D-4GBPI)
G.Skill Kit 4GB PC2-9600U CL5-5-5-15 (DDR2-1200) (F2-9600CL5D-4GBPI)
G.Skill Trident Kit 4GB PC2-9600U CL5-5-5-15 (DDR2-1200) (F2-9600CL5D-4GBTD)
G.Skill DIMM Kit 4GB PC2-9600U CL5-5-5-15 (DDR2-1200) (F2-9600CL5D-4GBPI)
Kingston HyperX DIMM Kit 4GB PC2-6400U CL5-5-5-15 (DDR2-800) (KHX6400D2K2/4G)
OCZ Flex II 4GB Kit PC2-9200 CL5-5-5-18 (OCZ2FXT11504GK)
OCZ Reaper HPC Edition Kit 2GB PC2-9200U CL5-5-5-18 (OCZ2RPR11502GK)
OCZ Flex XLC Edition 4 x 1024 MB PC2-9600U @ 1200 Mhz
OCZ Reaper HPC Edition 2GB Kit PC2-9600 CL5-5-5-18 (OCZ2RPR12002GK)
OCZ Blade Low Voltage DIMM Kit 4GB PC2-9600U CL5-5-5-18 (DDR2-1200) (OCZ2B1200LV4GK)
Patriot Viper DDR2-800 4 GB
takeMS Mach2 2GB PC2-8500U CL5-5-5-18 TMS1GB264C082-105EP
TeamGroup Xtreem Dark 4GB Kit PC2-8500U CL5-5-5-15 TXDD4096M1066HC5DC-D​
Kompatibler Netzteile:
Biosupdate mit USB Stick
Anleitung vom Fresh_Thing
1. Programm runterladen und installieren.
2. Dos files und Bios runterladen - Bios findest du hier -> http://img.lanparty.tw/Upload/BIOS/CM/D45PD320.zip
Dann den pfad für die Dos files im programm angeben und den USB-Stick formatieren
3. Die 3 datein die beim Bios dabei sind auf den Stick kopieren.
4. Im Bios die setup defaults laden und direkt den USB-Stick als erstes Bootgerät einstellen.
Dann einfach nur neustarten und der Flash nimmt seinen Lauf​
USB-Stick Bootfähig machen !!!
Downloads
Wichtige Links
Real Volt - Messung im Windows @ IDLE
mit einem Q9550 E0 @ FSB 500 @ 4255 Mhz​
Gemessen vom mahaudi
CPU PLL ( Bios 1.55v.) ......Real : 1.578v...........Droop : + ~ 0.03v.
NB Core ( Bios 1.420v.) .....Real : 1.420v...........Droop : nichts
VDIMM ( Bios 2.218v. ) .....Real : 2.245v. .........Droop : + ~ 0.03v.
VTT ( Bios 1.280v. ) .......Real : 1.298v. ..........Droop : + ~ 0.02v.​
Messpunkte DFI LP DK P45-T2RS Plus
Wie bekommt man den C1-Fehler weg?
Hier die Lösung vom Fresh_Thing
ohne Rams booten
dann PC am AN Schalter ausschalten (lange gedrückt halten) aber nicht am NT
einen Ram reinstecken und PC starten
.....wenn das nicht geht :
ohne Rams booten
noch mal ohne Rams booten und am AN Schalter ausschalten (lange gedrückt halten) aber nicht am NT
einen ( Wichtig ) Ram reinstecken und PC starten​
VID-Bug Behebung!
Computer neu starten und ab ins BIOS
Load optimal Defaults
Computer herunterfahren
Netzteilstecker abziehen
Jumper umstecken und Batterie für ein paar Min. raus
Computer starten
Unter Hardware Monitoring nachschauen, ob die anliegende Spannung stimmt (C1E und EIST an!)
Mit F10 raus und wieder rein, dabei ist zu beachten, dass beim ersten Mal, niemals mehreren Einstellungen gleichzeitig getätigt werden dürfen
Sollte die anliegende Spannung stimmen, speichern und starten
Wenn das der Fall ist, seid Ihr den Bug für immer los!
Ansonsten, die CPU a+e!​
Smartguardian Design`s ( inkl.SG.exe vom UT P35 )
: http://rapidshare.com/files/18075196...DK_Edition.rar
Achtung!
Die mitgelieferten SATA-Kabeln können unter Umständen zum einem instabilen Betrieb führen, dies ist allerdings nicht immer der Fall.
Fazit:
Das Board kann echt eine Zicke sein und bestrafft auch den kleinsten Fehler mit einem Bluescreen/Reboot oder startet erst gar nicht, deshalb sollte man die Finger davon lassen, wenn man nicht genügend oder gar keine Erfahrung mitbringt, ansonsten bietet das Board mehr als genug Einstellungen und eine sehr gute Performance!;)
An dieser Stelle, möchte ich mich für die zur Verfügung gestellten Daten und wirklich gute Vorarbeit bei mahaudi bedanken!:hail:
Bildquellen:
patrock84 und [EKM] SeLecT , auch Euch beiden vielen Dank!:hail:
Alter Thread:
DFI LANparty DK P45-T2RS / T3RS / Plus (Intel P45) [8]
Dann gehe ich das nun mal an,und was is wenns zb. jetzt mit 21 genauso gut läuft wie mit 23?^^
Hi Leute! 2 Fragen:
1. Wieso bekomme ich immer Rundungsfehler bei Prime95 wenn das System noch kalt ist?
2. Habe einen Q9650 E0 bekommen - mit welchen Settings meines Lanparty fange ich an zu OCen und wie warm darf eine Q9650 werden im 24/7 Betrieb?
Soll ich eigentlich die vref mit 50mv testen?
Weil da kann ich doch zur Sicherheit ja erstmal etwas mehr nehmen damit ich V-Core ausschließen kann?
Small hab ich sowieso bisher noch nich mit 50mv geschafft leider....
Nur LinX mit 25 Run`s da hab ich zb. auch schon probiert eine Stufe runterzugehen,dann bricht LinX direkt ab,also steigt aus.
White, was hast du jetzt für eine WLP im einsatz? Ich überlege gerade ob ich die PK-1 kaufen soll oder die MX2. Liegen zwar 6€ dazwischen aber für 1-2°C ist es mir wert.
Habe noch eine neue Tube von meinem PK-13 liegen und eine halbe Tube AS5
Dann benutzt erstmal die AS5,und Pk-13,die werden doch denke ich beide auch gut sein?
Und wenn du die aufgebraucht hast,kannst du die Prolimatech Pk1 dir kaufen ist topp die hab ich jetzt im Einsatz
Preisvergleich Geizhals.at Deutschland
Hab die 30g Tube genommen,damit sollte ich erstmal genug haben:xmas:
So,vref test`s sind durch.
Liste gleich mal alles auf,habs mir genau notiert bei welcher vref was wann wo passiert ist.
Teste grade noch 00.
So,bei 27 lief es zwa am längsten,aber kurz nachdem ich dort Prime beendet hab,bekam ich einen blauen^^,und mit 50mv wie man sieht kam ich mit keinem vref durch,ich weiß auch nich so richtig welche ich nun nehmen soll?^^
Die AS5 halte ich nicht viel von, die beiliegende vom MK-13 überzeugt mich auf dauer auch nicht. Finde die Temperaturen sind nach einer gewissen Zeit schlechter geworden (trocknet, verdunstet???)
Werde mal die PK-1 bestellen ;)
hm irgendwie mag mir das DFI so garnicht gefallen :S
ich kriegs nicht gebacken einen anderen Wert als AUTO beim PL zu booten... immer C1 Fehler...
Gibts sowas wie ne automatische Lüfterregelung bei DFI? Hab nur einen 2200rpm Lüfter hier im Moment :shot:
Gibts ein Modbios zum untervolten? :(
Liegt vielleicht an den 8GB? Ich teste heute Abend mal meine 8GB durch. Denke mal wenn die mit PL10 Fast/Fast laufen bin ich zufrieden. Hoffe nur das meine vNB nicht all zu hoch muss.
Nein ich hab momentan ein anderes Sys als das in meiner Sig. Teste mit 2 x 2GB und 2 x 1GB. In Windows kann ichs problemlos umstellen... Memset zeigt halt immer zwischen PL 3 und PL 5 (Je nach Takt) an in XP wenns auf Auto eingestellt ist. Und ich glaub dass mich das ein bischen bremst beim höhertakten des Rams.
edit: okay habs auf die Reihe gebracht. Lüftersteuerung hätt ich trotzdem noch gerne :P
@Whitecker
probiere für den Large nur die 896k - lass es mindestens halbe Stunde laufen.
wenn du die richtige vRef herausgefunden hast, - lass es dann nochmal mindestens
1 Stunde laufen - nur die 896k. Die VCore sollte dabei vorher ausgelotet sein.
Wenns läuft - hast du die Larges mit hoher Wahrscheinlichkeit im Sack.
---------- Beitrag hinzugefügt um 20:57 ---------- Vorheriger Beitrag war um 20:56 ----------
Welchen FSB hast du denn da, und welche Strap/Teiler?
---------- Beitrag hinzugefügt um 21:02 ---------- Vorheriger Beitrag war um 20:56 ----------
Wenn du 1:1 nimmst, - geht auch die PL9
Was die 8Gb-RAM-Bestückung angeht, ist beim DFI kaum
mehr an vNB nötig, - zumindest ist es bei mir so, - habe auch 8Gb drinn.
zu hülfe :hmm:
ich wollte mal eben meine cpu auf 4ghz hochschrauben, aber ich habe dann kein bild mehr :hmm:
hab die vcore auf 1,3125volt gestellt, bei 470mhz fsb, ram-takt auf 1001mhz, ram-spannung auf 2,05volt.
mit meinem alten p5q pro hat das einwandfrei funktioniert, sogar die 500mhz fsb waren kein problem.
was mach ich falsch?!
ps. beim p5q pro haben sogar 1,28 volt bei fsb500 gereicht :(
---------- Beitrag hinzugefügt um 21:04 ---------- Vorheriger Beitrag war um 21:03 ----------
wenn ich den fsb auf 400 stelle, funzt das einwandfrei, muss keine spannung umstellen und nichts. 1,2volt auf der cpu, idle sogar nur 1,04v.
ramtakt: 960mhz.
Hatte mal grad langeweile und wollte 500 FSB mal kucken ob es schon klappt,das tuts noch nich,aber ich vermute weil ich viel vNB brauchen werde.
Unter der vNB freezte es direkt bei den 1024k. höshstens noch ein Wert weniger im Bios, VTT musst ich noch ausloten aber viel weniger wird es nicht werden.
buntstift
Nur die 896k und damit dann die vref ausloten?
Wie sieht das eigentlich aus,ändert sich die vref mit einem FSB,oder bleibt die dann immer gleich?
Ein Pärchen mit 4Gb + 1 Pärchen mit 2 Gb - habe ich es richtig verstanden?
-hmm... Und du bist dir sicher, dass du PL3 angezeigt bekommst?:confused:
Von welchem System reden wir hier denn überhaupt?
@=Lexus=:
4GB oder 2GB, nicht zusammen.
Du hast Recht, es war der Strap. Hab momentan nur einen E2180 :shot: drin und muss deshalb recht krasse Teiler fahren zum Ram testen.
@ Whitecker007
Was möchtest du den jetzt ausloten? Nen hohen FSB oder hohe Temps?:haha:;)
kann mir niemand weiterhelfen?
ich weis leider nicht wofür die ganzen PLLs usw sind :(
---------- Beitrag hinzugefügt um 21:13 ---------- Vorheriger Beitrag war um 21:12 ----------
ich will einfach nur wieder die 470 bis 500mhz fsb fahren können.
das es die cpu kann, weis ich.
jammer :hmm:
Mensch,meine Temps sind nunmal so,muss ich mir das jetzt jedes mal reinziehen?
Ja, - deine Board-temps sind sehr kritisch,
-so kriegst es nicht stabil.
@ Whitecker007
Dann wechsel doch einfach mal den Kaugummie unter den Spawa Kühlern und der Nivea Creme unter der Northbrigde.
Dann sieht das ganze auch so aus
Ich kann dir noc nicht helfen weil ich das Board selbst erst frisch habe,und aus dem Grund erstmal damit Erfahrung sammeln will,bringt ja nichts wenn ich dir Mist erzähle,bei Gigabyte würd eich da anders aggieren^^
RazorGTX
Ließ mal die letzten 2 Seiten was ich die letzten Tage vergeblich gemacht habe:wall:
=Lexus=
Wieso kriege ich es nicht stabil?,large läuft grade bei 490 FSB schon 45 min.
buntstift, hast du mal nen Screen vom P5Q Pro und 500MHz FSB ?
kanns mir irgendwie nicht vorstellen...
hab keinen screen mehr davon :(
aber ich kann dir versichern, der 500er fsb stand und ich hatte exakt 4,25ghz am start.
3dmark 06 stabil war es.
jedoch hilft mir das ja jetzt nicht weiter :(
@ Whitecker007
Dann hast du da wohl irgendwas falsch gemacht. Heizung vielleicht noch an?
