[Sammelthread] DFI LANparty DK P45-T2RS / T3RS / Plus (Intel P45) [11]
Zitat:
  • CPU
    • LGA 775 socket for:
      - Intel® Core2 Quad and Intel® Core2 Duo
    • Supports Intel Enhanced Memory 64 Technology (EMT64T)
    • Supports Enhanced Intel SpeedStep Technology (EIST)
    • Supports Intel Hyper-Threading Technology
    • Supports 1333/1066/800MHz FSB
  • Intel® chipset
    • Intel® chipset
      - Northbridge:
      Intel® P45 Express chipset
      Intel® Fast Memory Access technology
      - Southbridge: Intel® ICH10R
  • Memory
    • Four 240-pin DDR2 DIMM sockets
    • Supports DDR2 1200(O.C.)/1066/800/667 MHz
    • Delivers up to 12.8Gb/s bandwidth
    • Supports dual channel (128-bit wide) memory interface
    • Supports non-ECC unbuffered DIMMs
    • Supports up to 16GB system memory
  • Expansion Slots
    • 2 PCI Express (Gen 2) x16 slots - 2-way CrossFire: One slot operating at x16 (16-lane port) or two slots each operating at x8 (8-lane ports) bandwidth
    • 2 PCI Express x1 slots
    • 2 PCI slots
  • BIOS
    • Award BIOS
    • 8Mbit SPI flash BIOS
    • CMOS Reloaded
  • Audio
    • Realtek ALC885 High Definition audio CODEC
    • 8-channel audio output
    • DAC SNR/ADC SNR of 106dB/101dB
    • Full-rate lossless content protection technology
    • Optical S/PDIF-out and coaxial RCA S/PDIF-out interfaces
  • LAN
    • Marvell 88E8053 PCIE Gigabit LAN controller
    • Fully compliant to IEEE 802.3 (10BASE-T), 802.3u (100BASE-TX) and 802.3ab (1000BASE-T) standards
  • IDE
    • JMicron JMB363 PCI Express to PATA host controller
    • Supports up to 2 UltraDMA 33/66/100Mbps IDE devices
  • Serial ATA with RAID
    • Intel Matrix Storage technology
    • Supports up to 6 SATA devices
    • SATA speed up to 3Gb/s
    • RAID 0, RAID 1, RAID 0+1 and RAID 5
  • Rear Panel I/O Ports
    • 1 mini-DIN-6 PS/2 mouse port
    • 1 mini-DIN-6 PS/2 keyboard port
    • 1 optical S/PDIF-out port
    • 1 coaxial RCA S/PDIF-out port
    • 6 USB 2.0/1.1 ports
    • 1 RJ45 LAN port
    • Center/subwoofer, rear R/L and side R/L jacks
    • Line-in, line-out (front R/L) and mic-in jacks
  • Power Management
    • ACPI and OS Directed Power Management
    • ACPI STR (Suspend to RAM) function
    • Wake-On-PS/2 Keyboard/Mouse
    • Wake-On-USB Keyboard/Mouse
    • Wake-On-LAN
    • Wake-On-Ring
    • RTC timer to power-on the system
    • AC power failure recovery
  • Hardware Monitor
    • Monitors CPU/system/Northbridge temperature and overheat alarm
    • Monitors Vcore/Vdimm/Vnb/VCC5/12V/V5sb/Vbat voltages
    • Monitors the speed of the cooling fans
    • CPU Overheat Protection function monitors CPU temperature and fan during system boot-up - automatic shutdown upon system overheat
  • PCB
    • 4 layers, ATX form factor
    • 24.5cm (9.64") x 30.5cm (12")
Wasserkühlung NB-SB-Mosfets:
Wasserkühlung Zusammenstellungen vom "riverdief":
Luftkühlung:
Passt mit Problemen:
EKL Alpföhn Groß Clockner ( passt nur mit Modifikationen ...entweder am Kühler oder Chipsatzkühler )
Scythe Andi Samurai (gedreht)
Scythe Mugen 2 (der Lüfter muss 5mm verschoben werden)
Thermalright HR-01 Plus (gedreht)
Kompatibler Arbeitsspeicher:
A-DATA Vitesta Extreme Edition 2 GB PC2 9600
Cellshock DIMM Kit 2GB PC2-8500U CL5-5-5-15 (DDR2-1066) (CS2221550)
Chaintech Apogee GT DIMM Kit 4GB PC2-8500U CL5-5-5-15
Chaintech Apogee GT DIMM Kit 4GB PC2-9200U CL5-5-5-15 (DDR2-1150)R2-1150-4GDHS
Corsair DIMM 4 GB DDR2-800 DHX Kit (TWIN2X4096-6400C4DHX)
Corsair XMS2 Dominator 2GB PC2-8500U CL5-5-5-15 TWIN2X2048-8500C5D
Crucial Ballistix Tracer PC8500 1066MHz BL12864AL1065.8FE5
GeiL Value DIMM Kit 2GB PC2-6400U CL5-5-5-15 (DDR2-800) (GX22GB6400DC)
GeIL Ultra DIMM Kit 2GB PC2-8500U CL5-5-5-12 (DDR2-1066) (GX22GB8500UDC)
G.Skill Kit 4GB PC2-6400U CL5-5-5-15 (DDR2-800) (F2-6400CL5D-4GBPQ)
G.Skill Kit 4GB PC2-8000U CL5-5-5-15 (DDR2-1000) (F2-8000CL5D-4GBPQ)
G.Skill Kit 4GB PC2-8500U CL5-5-5-15 (DDR2-1066) (F2-8500CL5D-4GBPI-B)
G.Skill Kit 4GB PC2-8800U CL5-5-5-15 (DDR2-1100) (F2-8800CL5D-4GBPI)
G.Skill Kit 4GB PC2-9600U CL5-5-5-15 (DDR2-1200) (F2-9600CL5D-4GBPI)
G.Skill Trident Kit 4GB PC2-9600U CL5-5-5-15 (DDR2-1200) (F2-9600CL5D-4GBTD)
G.Skill DIMM Kit 4GB PC2-9600U CL5-5-5-15 (DDR2-1200) (F2-9600CL5D-4GBPI)
Kingston HyperX DIMM Kit 4GB PC2-6400U CL5-5-5-15 (DDR2-800) (KHX6400D2K2/4G)
OCZ Flex II 4GB Kit PC2-9200 CL5-5-5-18 (OCZ2FXT11504GK)
OCZ Reaper HPC Edition Kit 2GB PC2-9200U CL5-5-5-18 (OCZ2RPR11502GK)
OCZ Flex XLC Edition 4 x 1024 MB PC2-9600U @ 1200 Mhz
OCZ Reaper HPC Edition 2GB Kit PC2-9600 CL5-5-5-18 (OCZ2RPR12002GK)
OCZ Blade Low Voltage DIMM Kit 4GB PC2-9600U CL5-5-5-18 (DDR2-1200) (OCZ2B1200LV4GK)
Patriot Viper DDR2-800 4 GB
takeMS Mach2 2GB PC2-8500U CL5-5-5-18 TMS1GB264C082-105EP
TeamGroup Xtreem Dark 4GB Kit PC2-8500U CL5-5-5-15 TXDD4096M1066HC5DC-D​
Kompatibler Netzteile:
Biosupdate mit USB Stick
Anleitung vom Fresh_Thing
1. Programm runterladen und installieren.
2. Dos files und Bios runterladen - Bios findest du hier -> http://img.lanparty.tw/Upload/BIOS/CM/D45PD320.zip
Dann den pfad für die Dos files im programm angeben und den USB-Stick formatieren
3. Die 3 datein die beim Bios dabei sind auf den Stick kopieren.
4. Im Bios die setup defaults laden und direkt den USB-Stick als erstes Bootgerät einstellen.
Dann einfach nur neustarten und der Flash nimmt seinen Lauf​
USB-Stick Bootfähig machen !!!
Downloads
Wichtige Links
Real Volt - Messung im Windows @ IDLE
mit einem Q9550 E0 @ FSB 500 @ 4255 Mhz​
Gemessen vom mahaudi
CPU PLL ( Bios 1.55v.) ......Real : 1.578v...........Droop : + ~ 0.03v.
NB Core ( Bios 1.420v.) .....Real : 1.420v...........Droop : nichts
VDIMM ( Bios 2.218v. ) .....Real : 2.245v. .........Droop : + ~ 0.03v.
VTT ( Bios 1.280v. ) .......Real : 1.298v. ..........Droop : + ~ 0.02v.​
Messpunkte DFI LP DK P45-T2RS Plus
Wie bekommt man den C1-Fehler weg?
Hier die Lösung vom Fresh_Thing
ohne Rams booten
dann PC am AN Schalter ausschalten (lange gedrückt halten) aber nicht am NT
einen Ram reinstecken und PC starten
.....wenn das nicht geht :
ohne Rams booten
noch mal ohne Rams booten und am AN Schalter ausschalten (lange gedrückt halten) aber nicht am NT
einen ( Wichtig ) Ram reinstecken und PC starten​
VID-Bug Behebung!
Computer neu starten und ab ins BIOS
Load optimal Defaults
Computer herunterfahren
Netzteilstecker abziehen
Jumper umstecken und Batterie für ein paar Min. raus
Computer starten
Unter Hardware Monitoring nachschauen, ob die anliegende Spannung stimmt (C1E und EIST an!)
Mit F10 raus und wieder rein, dabei ist zu beachten, dass beim ersten Mal, niemals mehreren Einstellungen gleichzeitig getätigt werden dürfen
Sollte die anliegende Spannung stimmen, speichern und starten
Wenn das der Fall ist, seid Ihr den Bug für immer los!
Ansonsten, die CPU a+e!​
Smartguardian Design`s ( inkl.SG.exe vom UT P35 )
: http://rapidshare.com/files/18075196...DK_Edition.rar
Achtung!
Die mitgelieferten SATA-Kabeln können unter Umständen zum einem instabilen Betrieb führen, dies ist allerdings nicht immer der Fall.
Fazit:
Das Board kann echt eine Zicke sein und bestrafft auch den kleinsten Fehler mit einem Bluescreen/Reboot oder startet erst gar nicht, deshalb sollte man die Finger davon lassen, wenn man nicht genügend oder gar keine Erfahrung mitbringt, ansonsten bietet das Board mehr als genug Einstellungen und eine sehr gute Performance!;)
An dieser Stelle, möchte ich mich für die zur Verfügung gestellten Daten und wirklich gute Vorarbeit bei mahaudi bedanken!:hail:
Bildquellen:
patrock84 und [EKM] SeLecT , auch Euch beiden vielen Dank!:hail:
Alter Thread:
DFI LANparty DK P45-T2RS / T3RS / Plus (Intel P45) [10]
Natürlich nicht, bei 1,475V-1,50V auf der NB und 1,38V-1,40V VTT, hört bei mir der Spaß auf, zum Benchen hat es auf jeden Fall gereicht.
So habe gerade mal etwas weiter getestet.
3,8Ghz @ +50mV / NB 1,195V / VTT 1,10V
- habe 25 runs Linx erfolgreich abgeschlossen.
- einen 7Std. Prime95 run erfolgreich abgeschlossen.
3,9Ghz @ +75mV / NB 1,195V / VTT 1,10V
- nur kurz an getestet und übersprungen
4Ghz @ +100mV / NB 1,195V / VTT 1,10V
4Ghz @ +87,5mV / NB 1,195V / VTT 1,10V / Vcore Droop Control auf Disable brachte mir 12,5mV weniger Vcore.
- gerade am testen
4,1Ghz @ +87,5mV / NB 1,195V / VTT 1,10V / Vcore Droop Control auf Disable
- Absturz beim Bios screen
4,1Ghz @ +100mV / NB 1,225V / VTT 1,22V / Vcore Droop Control auf Disable
^^ echt keine Traumwerte, aber ist ja noch alles sehr jung bei mir.
Mein persönliches Limit ist schon bei +100mV erreicht an Vcore, denn 1,325V ist für Lukü schon zu viel aus meiner sicht.
@TH€_BR@!N
ich glaube du hast den Vid bug siehe deinen ersten Screen vom Bios!
Edit//
zeig uns noch bitte die erweiterten Einstellungen vom Speicher...
Hier haste meine 24/7 Werte
Aber bei 500MHz FSB mit PL8 und Fast Fast sind die Werte fast mit nfszocker seinen identisch.
@TH€_BR@!N
Edit//
Ja das denke ich mittlerweile auch, ganz sporadisch je nach Neustart ändert er die vid auf 1,10V oder 1,16V oder 1,18V
Habe bereits schon schon 2x probiert den Bug zu beheben wie auf der ersten Seite beschrieben. Leider aber ohne Erfolg. Jetzt wäre nen Bios als fix eine tolle Sache :(
Hier mal Auszüge aus den Ram-Settings, aber wie oben bereits gesagt, alles noch default:
dolltoll schrieb:
@nfzocker:
Du hast mich geheilt..... sehr schöne Werte!
Warum?
Wie geil ist das denn?
Kompletter Ram-Setting auf "Auto" und es läuft und ich, habe Wochen/Monaten/Jahre damit verbracht, mir ein Setting zusammen zu frimmeln.:stupid::wall::bigok:
Hier ist noch mein FSB481 Datendurchsatz sammt Speicher-Setting+3xNominal & Fast/Fast, vielleicht kannst Du es gebrauchen.:wink:
Achte auf Read Delay Phase Adjust:teufel:
Hier meine mal.:wink:
Dann Vergleich doch mal meine Pic´s mit deinen. Da hast du alles was man für FSB 471 braucht. Sind zwar immer nur Richtwerte aber besser als nix :d
@ Br@in
du machst erstmal folgendes,nimm dir einen Zettel zur Hand und vergleich deine Settings mit denen von Prime73.
Jede Option die nicht so aussieht wie die vom Prime73 schreibst du dir auf !
Schnell wirst du merken auf welche Settings es beim DK ankommt.
Und ich meine nicht die Spannungen,die lass mal aussen vor !!! (uninteressant fürs erste)
DK und Settings auf Auto -> :shot:
Geht auch, wusste ich zwar auch nicht, aber man lernt ja nie aus.:lol:
Edit:
Gaude Arthur!:wink:
Sers Vita :wink:
geht halt net !
erstmal VID Bug beseitigen (würd es nur mit einem Riegel versuchen und zudem noch eine 2. HDD drannklemmen) <- frag net warum, DFI muss man net verstehen !
@ Br@in
das hatten ich gestern Abend schon gemacht ^^
Hatte ja auch nix verändert.
Denke das ich mich auch nicht mehr lange mit dem mobo befassen werde und mal das GA einbauen und da drauf teste. Das dfi scheint mir momentan total verbugt - evtl durch den vid bug.
Ist der vid bug nen Grund für einen Tausch beim Hersteller?
Nope
da es kein Fehler ist und das Board doch mit einer Cpu normal vetrieben werden kann.
Hast es neu gekauft ?
Ansonsten schick es mir mal und ich zeig dir was geht ;)
Du hast gar keinen VID Bug. Der müßte dir dann ne VID von 1,100 Anzeigen und sich nicht ändern. CoreTemp zeigt dir das ja an ;) Nimm das GA das ist einfacher.
Nope
Schade, dann hat eine rma keinen Sinn.
Ja, habe es neu gekauft :xmas:
Aber bin guter Hoffnung das es mit dem Gigabyte besser funktioniert.
Habe gerade mal meine andere q9650 eingebaut mit ner vid von 1,20V, aber hier habe ich genau den gleichen Bug mit den Volts, mit jedem Neustart habe ich andere Spannungen :o
Vermute langsam das es ein Super Sonntags Board ist :fresse::kotz:
---------- Beitrag hinzugefügt um 18:57 ---------- Vorheriger Beitrag war um 18:57 ----------
Nein ist es nicht, VID-Bug, ist quasi ein Bestandteil vom DK!:fresse2::d
:haha::lol::lol:
^^ Der gefällt mir.
---------- Beitrag hinzugefügt um 18:59 ---------- Vorheriger Beitrag war um 18:57 ----------
Naja wie gesagt, mit jedem Neustart andere Volts - ist hier wie Glücksrad :banana:
Moin Werner!:wink:
Sieht doch gut aus, für FSB471.;):bigok:
Moin Vita:wink:
Ist zwar nicht so ein super Ergebnis wie "damals" bei euch, aber mir langt es ja so.:)
btw...letzter Zeit macht mein Rechner Probleme, er bleibt öfters hier stehen.
Es wurden keine Hardware und Softwareänderungen vorgenommen.
Bios zurücksetzen hatte auch noch nichts gebracht.
Passiert auch im non-oc Zustand.
Habe nun mal meine Dreck-Link Wlankarte raus genommen, im Moment läuft es wieder rund...abwarten.:hmm:
Werner
Moin Werner!
War das eine PCI-WLan-Karte?:(
UHJJ36 schrieb:
Kannste beides haben aber denk dran das Board macht nur 514MHz FSB^^
CPU hatte auch schon einer ausm Luxx gefragt, Batch kennste ja L847C144 VID 1,21V
Ich will es nicht haben, ich wollte nur wissen, ob Du schon ein neus Board und Prozessor hast.;)
Ne bis jetzt nur Ram, ich könnte Sandy Bridge ES mit Board im Dezember bekommen ich weiß aber nicht...
Dann kauf ich lieber für wesentlich weniger Geld im Januar alles komplett neu :)
