jign
Semiprofi
Dfi LANParty X38 T2R/T3R
***sammelthread***
I. Allgemeine Infos zum Chipsatz***sammelthread***
- Unterstützt Core2Duo/Quad (65nm/45nm) (1066Mhz/1333Mhz)
- Heatspreader auf der Northbridge
- Southbridge ICH9R
- Unterstützt PCIe 2.0 für Grafikkarten
- Unterstützt PCIe 1.0 für andere Erweiterungskarten
- Unterstützt DDR2 und DDR3 (wahlweise oder gemischt)
- Erstmals volle 2x 16xPCIe-Schnittstellen bei einem Intel-Chipsatz
II.I. Technische Details zum Board [DFI X38-T2R]
# LGA 775 socket for: - Intel® CoreTM2 Quad and Intel® CoreTM2 Duo
# Supports Intel Enhanced Memory 64 Technology (EMT64T)
# Supports Enhanced Intel SpeedStep Technology (EIST)
# Supports Intel Hyper-Threading Technology
# Supports 1333*/1066/800MHz system bus speed *Available only on CPUs that support 1333MHz FSB
Chipset
# Intel® chipset - Northbridge: Intel® X38 Express chipset (with Intel® Fast Memory Access technology) - Southbridge: Intel® ICH9R
Memory
# Four 240-pin DDR2 DIMM sockets
# Supports DDR2 667/800 MHz
# Delivers up to 12.8Gb/s bandwidth
# Supports dual channel (128-bit wide) memory interface
# Supports up to 8GB system memory
# Supports unbuffered x8 and x16 DIMMs
Expansion Slots
# 2 PCI Express (Gen 2) x16 slots (PCIE 1 and PCIE 3) - 2-way CrossFire at x16/x16 bandwidth - 2-way CrossFire + Physics at x16/x16/x4 bandwidth
# 1 PCI Express x1 slot (PCIE 2)
# 1 PCI Express x4 slot (PCIE 4)
# 3 PCI slots
BIOS
# Award BIOS
# 8Mbit flash memory
# CMOS Reloaded
Audio
# Bernstein audio module - Realtek ALC885 8-channel High Definition Audio CODEC - Center/subwoofer, rear R/L and side R/L jacks - Line-in, line-out (front R/L) and mic-in jacks - 2 coaxial RCA S/PDIF-in/out jacks - 1 optical S/PDIF connector - 1 CD-in connector - 1 front audio connector
# DAC SNR/ADC SNR of 106dB/101dB
# Full-rate lossless content protection technology
LAN
# Marvell 88E8052 and Marvell 88E8053 PCIE Gigabit LAN controllers
# Fully compliant to IEEE 802.3 (10BASE-T),
802.3u (100BASE-TX) and 802.3ab (1000BASE-T) standards
IEEE 1394
# VIA VT6307
# Supports two 100/200/400 Mb/sec ports
Storage
# Intel ICH9R chip - Intel Matrix Storage technology - Supports up to 6 SATA devices - SATA speed up to 3Gb/s - RAID 0, RAID 1, RAID 0+1 and RAID 5
# JMicron JMB363 PCI Express to SATA and PATA host controller - Supports up to 2 UltraDMA 100Mbps IDE devices - Supports 2 SATA devices - SATA speed up to 3Gb/s - RAID 0 and RAID 1
Rear Panel I/O Ports
# Mini-DIN-6 PS/2 mouse port and PS/2 keyboard port
# 1 IEEE 1394 port
# 6 USB 2.0/1.1 ports
# 2 RJ45 LAN ports
I/O Connectors
# 3 connectors for 6 additional external USB 2.0 ports
# 1 connector for an external COM port
# 1 connector for an IEEE 1394 port
# 1 connector for the Bernstein audio module
# 1 front audio connector (on the Bernstein audio module)
# 1 CD-in connector (on the Bernstein audio module)
# 1 S/PDIF connector (on the Bernstein audio module)
# 1 IrDA connector
# 1 CIR connector
# 8 Serial ATA connectors
# 1 40-pin IDE connector and 1 floppy connector
# 1 24-pin ATX power connector
# 1 8-pin 12V power connector
# 2 4-pin 5V/12V power connectors (FDD type)
# 1 front panel connector
# 6 fan connectors
# 1 diagnostic LED
# EZ touch switches (power switch and reset switch)
Power Management
# ACPI and OS Directed Power Management
# ACPI STR (Suspend to RAM) function
# Wake-On-PS/2 / Wake-On-USB Keyboard/Mouse
# Wake-On-LAN and Wake-On-Ring
# RTC timer to power-on the system
# AC power failure recovery
Hardware Monitor
# Monitors CPU/system/Northbridge temperature and overheat alarm
# Monitors Vcore/Vdimm/Vnb/VCC5/12V/V5sb/Vbat voltages
# Monitors the speed of the cooling fans
# CPU Overheat Protection function monitors CPU temperature and fan during system boot-up
- automatic shutdown upon system overheat
PCB
# 6 layers, ATX form factor
# 24.5cm (9.64") x 30.5cm (12")
II.II. Technische Details zum Board [DFI X38-T3R]
Soweit bekannt gleich wie T2R nur DDR3 suport
III. Tipps/Tricks und Problemlösungen
Boards made in China habe aktuell leichte Probleme mit der NB Spannung näheres hierzu: klick
IV. Tests Review´s sammelthread
XS-Sammelthread: klick
V. Sonstiges
Die UT Varianten wird es aus versiedenen Gründen leider nicht mehr geben.
ACHTUNG: Mit folgende Netzteile kann es zu Komplikationen kommen: klick
VI.Impressionen
http://www.overclock.net/intel-motherboards/263976-dfi-lt-x38-t2r-first-look.html
http://www.forumdeluxx.de/forum/showpost.php?p=7695369&postcount=282
http://www.xtremesystems.org/forums/showpost.php?p=2618925&postcount=145
http://www.xtremesystems.org/forums/showpost.php?p=2618926&postcount=146
VII. Layout
[DFI X38-T2R LT]
VIII. OC Liste
I. Offizielle Hersteller Seite: klick
II. BIOS: klick
III. Beta BIOS: klick
IV. Geizhalslink: klick
V. DFI LANparty P35 Sammelthread: klick
VI. DFI LANparty UT790FX Sammelthread klick
