MARS
Intel® Core™2 Quad, Core™2 Extreme, Core™2 Duo, Pentium® Dual-Core, Pentium® D, Pentium® 4, Celeron® processors, Socket T (LGA775)
Supports Intel® next generation 45nm Multi-Core processors
1333/1066/800 MHz (FSB)
Dual channel DDR2 1066(oc)/800/667 x 4 DIMMs, Max. 8GB
2 x PCIe x16, 2 x PCIe x1, 3 x PCI
ATA x 1, 1394a x2, SATA II x 6, eSATA x 1
7.1 channel Audio, Realtek® ALC888
GbE LAN, Realtek® RTL8111B
12 USB 2.0 ports
http://geizhals.at/deutschland/a286616.html
SPECIFICATION
Processor: Intel® Core™2 Quad, Core™2 Extreme, Core™2 Duo, Pentium® Dual-Core, Pentium® D, Pentium® 4, Celeron® processors, Socket T (LGA775)
Chipset: Intel® P35 + ICH9R
Front Side Bus: 1333 / 1066 / 800 MHz (FSB)
Memory: Dual channel DDR2 1066(oc)/800/667 x 4 DIMMs, Max. 8GB
VGA on Die: Discreted
Expansion Slots: 2 x PCIe x16, 2 x PCIe x1, 3 x PCI
IDE: ATA 133 x 1
Serial ATA(SATA)/RAID: 6 x SATAII + 1 x eSATA w / RAID 0, 1, 5, 10; Intel® Matrix storage technology and Intel® Rapid Recover Technology
Audio: 7.1 channel Audio with Realtek® ALC888 (HDA)
LAN: GbE LAN with Realtek® RTL8111B
IEEE1394: 2 x1394a, TI TSB43AB22APDT
Back Panel I/O Ports: 1 set 7.1 channel Audio jacks (6 jacks)
1x PS/2 keyboard port
1x PS/2 mouse port
1x S/PDIF Out Coaxial
1x S/PDIF Out Optical
1x IEEE1394 port
1x eSATA
6x USB 2.0 ports
1x RJ45 LAN port
Internal I/O Connectors: ATX 24-Pin power connector
8-pin ATX 12V power connector
CPU/System/NB/CASE1/CASE2 FAN connectors
1x CD-in connector
1x Front Audio header
1x Floppy connector
1x IRDA
1x Speaker Heatpipe (NB, SB and MOS)
1x Front Panel connector
3x USB 2.0 connectors support additional 6 ports
6x SATAII connectors
1x IDE connector
1x COM header
1x on-board power_LED
1x IEEE1394 connector supports additional one port
3x on-board Switches(Power on, Reset and CLR-CMOS)
BIOS Features: 8Mb flash EEPROM w/ LAN boot PnP, ACPI, WfM, DMI
Support CD: Drivers, Adobe Reader 7.07, Direct X 9.0c, Norton 2006
Standards/Manageability: PCI 2.3, USB2.0, DMI 2.5
Form Factor: ATX (12” x 9.6”)
LINKS:
http://www.quantum-force.net/default.aspx
http://www.quantum-force.net/Products/P000000001/
http://www.foxconnchannel.com/product/Motherboards/detail_overview.aspx?ID=en-us0000338
TESTS UND ANDERE BERCICHTE
http://www.hardware-mag.de/hardware.php?id=484
http://www.xtremesystems.org/forums/showthread.php?t=162306&highlight=mars
http://www.ocaholic.ch/xoops/html/modules/smartsection/item.php?itemid=153
http://forums.vr-zone.com/showthread.php?t=195427
http://www.coolaler.com/forum/showthread.php?t=167420
MOTHERBOARD MANUAL
http://www.foxconnchannel.com/support/downloads_detail.aspx?ID=en-us0001438
BIOS
http://www.foxconnchannel.com/support/downloads.aspx?ProductModel=MARS&TypeID=en-us0000003
DRIVERS
http://www.foxconnchannel.com/support/downloads.aspx?ProductModel=MARS&TypeID=en-us0000004
Registering on the Quantum Force website!
As a member you can enjoy some of the following benefits...
- Access to Beta BIOS and other downloads for Quantum Force products
- Post your technical queries and comments on our forum
- Submit your own system to our "Power Wall" and see how your OC skills compete against others!
- Easy entry to exclusive competitions
- Latest product and promotion news via our newsletter
- Exclusive video content, tutorials and interviews
To learn more about Quantum Force, our aims and beliefs, read the QF Manifesto:-
http://www.quantum-force.net/manifesto.aspx
12 USB 2.0 ports
SPECIFICATION
IDE: ATA 133 x 1
1x PS/2 mouse port
1x IEEE1394 port
1x eSATA
6x USB 2.0 ports
1x RJ45 LAN port
1x CD-in connector
1x Floppy connector
1x IRDA
1x IDE connector
1x COM header
LINKS:
MOTHERBOARD MANUAL
BIOS
DRIVERS
