Was hastn bisher alles eingestellt?
Robust Graphics Booster ...............: Auto
CPU Clock Ratio ..........................: 8
Fine CPU Clock Ratio......................: +0,5
CPU Frequency ...........................: 4.00GHz (471x8,5)
Clock Chip Control
Standard Clock Control
CPU Host Clock Control..................: Enabled
CPU Host Frequency (Mhz) ............: 471
PCI Express Frequency (Mhz) .........: 100
C.I.A. 2.......................................: Disabled
Advanced Clock Control [Press Enter]
CPU Clock Drive...........................: 800mV
PCI Express Clock Drive.................: 900mV
CPU Clock Skew (ps)....................:0ps
MCH Clock Skew (ps)...................:0ps
DRAM Performance Control
Performance Enhance...................: Standard
Extreme Memory Profile (X.M.P.).....: Disable
(G)MCH Frequency Latch...............: 333 MHz
System Memory Multiplier ..............: 2.00B
Memory Frequency (Mhz) ..............: 942
DRAM Timing Selectable ................: Auto
Standard Timing Control
CAS Latency Time........................: Auto
tRCD .........................................: Auto
tRP'...........................................: Auto
tRAS..........................................: Auto
Motherboard Voltage Control:
Loadline Calibration.………................ Disabled
CPU Vcore….……….........................: 1.33125V
CPU Termination…..... 1.200V*.......: 1.22
CPU PLL…………………....1.500V*.......: Normal
CPU Referen.…………....0.760V*.......: 0.812
MCH/ICH
MCH Core…………….....1.100V...........: 1.300V
MCH Reference….…….0.760V...........: 0.812
MCH/DRAM Ref.…......0.900V...........: Normal
ICH I/O……………….....1.500V............: Normal
ICH Core…………...……1.100V............: Normal
DRAM
DRAM Voltage ……....1.800V............: 2.200V
DRAM Termination .…0.900V............: Normal
Channel A Reference 0.900V............: Normal
Channel B Reference 0.900V............: Normal
Prime Customer lief grad 3h 15min, bis ein Kern abbrach.
Und ich bin nur bei der MCH Erhöhung, da immer ein Kern abbricht.
Hat da jemand eine Idee?
Jedoch stört mich, dass mein 1.Kern auf 80Grad hoch geht.
Wie sind denn eure temps?
