Hi Leute,
also, hatte mal weiter getestet, nachdem ich jetzt wieder etwas Zeit hatte und habe mittlerweile die 490fsb primestable bekommen
. Hier mal das Biostemplate dazu:
Robust Graphics Booster ...............: Auto
CPU Clock Ratio ..........................: 6
CPU Frequency ...........................: 2,94 Ghz (490x6)
Clock Chip Control
Standard Clock Control
CPU Host Clock Control..................: Enabled
CPU Host Frequency (Mhz) ............: 490
PCI Express Frequency (Mhz) .........: 100
C.I.A. 2.......................................: Disabled
Advanced Clock Control [Press Enter]
CPU Clock Drive...........................: 800mV
PCI Express Clock Drive.................: 900mV
CPU Clock Skew (ps)....................: 0ps
MCH Clock Skew (ps)...................: 50ps
DRAM Performance Control
Performance Enhance...................: Standard
Extreme Memory Profile (X.M.P.).....: Disabled
(G)MCH Frequency Latch...............: 333Mhz
System Memory Multiplier ..............: 2,00B
Memory Frequency (Mhz) ..............: 980
DRAM Timing Selectable ................:Auto
Standard Timing Control
CAS Latency Time........................:
tRCD .........................................:
tRP'...........................................:
tRAS..........................................:
Motherboard Voltage Control:
Loadline Calibration.………................ Enabled
CPU Vcore….……….........................: 1,2250V
CPU Termination…..... 1.200V*.......: 1,240V
CPU PLL…………………....1.500V*.......: 1,500V
CPU Referen.…………....0.760V*.......: 0,840V
MCH/ICH
MCH Core…………….....1.100V...........: 1,300V
MCH Reference….…….0.760V...........: 0,825V
MCH/DRAM Ref.…......0.900V...........: 1,050V
ICH I/O……………….....1.550V............: Normal
ICH Core…………...……1.100V............: Normal
DRAM
DRAM Voltage ……....1.800V............: 2,10V
DRAM Termination .…0.900V............: Normal
Channel A Reference 0.900V............: Normal
Channel B Reference 0.900V............: Normal
Wie gesagt die 490 laufen stabil durch, mehr schaffe ich aber leider nicht, habe schon alles mögliche probiert. Habt ihr noch einen Tipp, was ich testen oder einstellen könnte, um die 495 oder 500 zu knacken?
Danke im Voraus für Tipps.
