Perl-Freak
Ich habe gelesen 0.0250-0.0375..anandtech.com..die haben ja schon ein Core i7 verloren wegen falschen Uncore Settings.
Dann hast du den Text von AnandTech falsch verstanden. Denn den, den du das letzte malIch habe gelesen 0.0250-0.0375..anandtech.com..die haben ja schon ein Core i7 verloren wegen falschen Uncore Settings.
At this point we like to keep VCore and VQPI within 0.0250~0.0375V of each other as you clock up, generally speaking, once you exceed about 1.3V on VCore it is time to start syncing these settings and others in the BIOS.
http://www.bit-tech.net/hardware/2008/11/06/overclocking-intel-core-i7-920/3QPI/DRAM Voltage - 1.35V: This is poorly worded by Asus - it should read uncore or QPI/memory controller voltage so not to confuse it with the actual memory voltage. Increasing this is also necessary as it helps overclock the base frequency as the uncore area overclocks increase in relation to the CPU core overclocks. This voltage is tied to actual DRAM voltage - the two are directly connected on the motherboard. You'll need to increase this to keep the CPU safe.
While Asus and Intel (rightly) scare everyone (read: uneducated) into thinking that 1.65V on the DRAM voltage should be the absolute limit before you reach for the fire-blanket, all that's really needed it to obey this: keep the CPU uncore voltage within 0.5V difference of the DRAM voltage and there's no problem. Over this potential difference and you’ll greatly increase the chance of CPU death, but it certainly won't happen instantly in a big ball of fail fire if you make a mistake.
DRAM Voltage - 1.66V: This is the closest to the 1.65V the Corsair Dominator DIMMs wanted and it's within the 0.5V Uncore difference.
Welchen Speicherteiler habt ihr so im Gerbaucht und habt ihr diesen QPI Link bei X32 oder so stehen also das die 4.8GHz bzw. 6.4GHz rauskommen... kann man überhaupt die 6.4ghz mit dem 920 auswählen und es funzt? Wer war so mutig?
Determines whether to enable specific streams between the IOH and ICH (Default: enabled)
Easytune geht unter Vista64![]()
Habe es selber genutzt!
Mit dem "Isochronous Support" weiß ich nichts anzufangen, im Handbuch steht nur
Uncore ist die Frequenz bzw der Takt vom IMC/L3, der Takt wird dir in CPU-Z als "NB Takt" angezeigt.
Zu den Spannungen, wenn du übertaktest würde ich erstmal alle Spannungen auf nen festen Wert stellen
(die def. Werte stehen ja links). Und dann je nach OC die CPU VCore, QPI/VTT & DRAM Voltage anpassen.
und wie hast das zum laufen bekommen?
Warum? kA. Hab nur normal TV geguckt (läuft übern PC), Sys lief @ stock.weisst du schon warum
Komische SacheIch glaube das GA EX58-Ud5 ist Schrott.
Bilanz nach einem Tag:
2 defekte HDD (RAM/EEPROM) ist ebenso defekt ..wieso keine Ahnung.
Datenverlust von wichtigen Dokumenten (Arbeitszeugnisse und Zertifikate)
Ich glaube kaum das es ein Zufall ist, dass zwei Samsung HE 322HJ (Enterprise Klasse) so eben verrecken.
@ RNeon
weil 2 seiner HDDs verreckt sind. Würde mich davon aber nicht wild machen lassen
Bei Asus und anderen Herstellern gab es auch schon so Fälle.
Die GSkill hab ich schon längst wieder zurück geschickt da die nicht liefen. Die 1600er GSkill sollen ohne Probleme laufen,
wenn also GSkill dann wohl die 1600er
Ich hab im mom 2GB OCZ Platinum DDR3-1333, sind aber auch nicht das wahre![]()
