So weil es bisher noch keinen Sammelthread zu dem Board gibt habe ich mir gedacht, dass ich einfach mal einen erstelle.
1. Das Mainboard
Noch mehr Bilder
1.1 Spezifikationen
Spezifikationen
CPU
1. Support for Socket AM2+/ AM2 processors: AMD Phenom™FX processor/ AMD Phenom™ processor/ AMD Athlon™ 64 FX processor/AMD Athlon™ 64 X2 Dual-Core processor/AMD Athlon™ 64 processor/AMD Sempron™ processor
Hyper Transport Bus
1. 5200/2000 MT/s
Chipset
1. North Bridge: AMD 780G
2. South Bridge: AMD SB700
Memory
1. 4 x 1.8V DDR2 DIMM sockets supporting up to 16 GB of system memory (Note 1)
2. Dual channel memory architecture
3. Support for DDR2 1066 (Note 2)/800/667 MHz memory modules
Audio
1. Realtek ALC889A codec
2. High Definition Audio
3. 2/4/5.1/7.1-channel
4. Support for DTS (dts NEO:PC)
5. Support for S/PDIF In/Out
6. Support for CD In
LAN
1. Realtek 8111C chip (10/100/1000 Mbit)
Expansion Slots
1. 1 x PCI Express x16 slot (The PCI Express x16 slot conforms to PCI Express 2.0 standard.)
2. 1 x PCI Express x1 slot
3. 2 x PCI slots
Storage Interface South Bridge:
1. 1 x IDE connector supporting ATA-133/100/66/33 and up to 2 IDE devices
2. 5 x SATA 3Gb/s connectors (SATAII0, SATAII1, SATAII2, SATAII3, SATAII4) supporting up to 5 SATA 3Gb/s devices
3. 1 x eSATA 3Gb/s port on the back panel supporting up to 1 SATA 3Gb/s device
4. Support for SATA RAID 0, RAID 1 and RAID 10
South Bridge:
iTE IT8718 chip:
1. 1 x floppy disk drive connector supporting up to 1 floppy disk drive 1 x floppy disk drive connector supporting up to 1 floppy disk drive
IEEE 1394 T.I. TSB43AB23 chip
1. Up to 2 IEEE 1394a ports (1 on the back panel, 1 via the IEEE 1394a bracket connected to the internal IEEE 1394a header)
USB Integrated in the South Bridge
1. Up to 12 USB 2.0/1.1 ports (4 on the back panel, 8 via the USB brackets connected to the internal USB headers)
Internal I/O Connectors
1. 1 x 24-pin ATX main power connector
2. 1 x 4-pin ATX 12V power connector
3. 1 x floppy disk drive connector
4. 1 x IDE connector
5. 5 x SATA 3Gb/s connectors
6. 1 x CPU fan header
7. 1 x system fan header
8. 1 x front panel header
9. 1 x front panel audio header
10. 1 x CD In connector
11. 1 x S/PDIF In/Out header
12. 1 x IEEE 1394a header
13. 4 x USB 2.0/1.1 headers
14. 1 x parallel port header
15. 1 x Trusted Platform Module (TPM) header
16. 1 x serial port header
17. 1 x chassis intrusion header
18. 1 x power LED header
Back Panel Connectors
1. 1 x PS/2 keyboard port
2. 1 x PS/2 mouse port
3. 1 x D-Sub port
4. 1 x DVI-D port (Note 3)
5. 1 x HDMI port
6. 1 x optical S/PDIF Out connector
7. 1 x eSATA 3Gb/s port
8. 1 x IEEE 1394a port
9. 4 x USB 2.0/1.1 ports
10. 1 x RJ-45 port
11. 6 x audio jacks (Center/Subwoofer Speaker Out/Rear Speaker Out/Side Speaker Out/Line In/Line Out/Microphone)
I/O Controller
1. ITE IT8718 chip
H/W Monitoring System voltage detection
1. CPU/System temperature detection
2. CPU/System fan speed detection
3. CPU overheating warning
4. CPU/System fan fail warning
5. CPU/System fan speed control (Note 4)
BIOS
1. 1 x 8 Mbit flash
2. Use of licensed AWARD BIOS
3. PnP 1.0a, DMI 2.0, SM BIOS 2.4, ACPI 1.0b
Unique Features
1. Support for @BIOS
2. Support for Download Center
3. Support for Q-Flash
4. Support for EasyTune (Note 5)
5. Support for Xpress Install
6. Support for Xpress Recovery2
7. Support for Virtual Dual BIOS
Bundle Software
1. Norton Internet Security (OEM version)
Operating System
1. Support for Microsoft Windows Vista/ XP
Form Factor
1. Micro ATX Form Factor; 24.4cm x 24.4cm
1.2 Ausstattung
Soweit ersichtlich:
-1x IDE Kabel
-1x Floppy Kabel
-2x SATA Kabel (1x gewinklet, 1x normal)
-I/O Shield
-Anleitung
2. Hilfen
2.1 Speicher Kompatiblitätsliste
->Speicher Kompatiblitätsliste
-> Falls Speicher die nicht in der Liste stehen und funktionieren bzw. nicht funktionieren stehen sie hier.
- 2 x 1 GB Extrememory von COS Memory DDR2 - 800-er RAM PC2 - 6400 (400 MHz) mit 5-5-5-18
2x 1GB - 2048MB Aeneon X-TuneKit CL4
2 x 2 GB OCZ Titanium XTC OCZ2T800C42G
2 x 1024MB G Skill F2-6400CL4-1GBPK
4GB G.SKILL DDR2-800 RAM 5.0-5-5-15 (Man muss nur die Spannung um 0.1V erhöhen)
2x Cellshock DIMM 1024MB PC2-5300U CL5-5-5-15 (DDR2-667) (CS2110650)
2.2 Vergleich 780G vs. GF8200
2.3 Hybrid-Crossfire
-Infos zu Hybrid-Crossfire
-Möglich ab Catalyst 8.3
3. Links & Downloads
3.1 Links zu Treibern, BIOS,Programmen
->BIOS
->Treiber
->Bedienungsanleitung
3.2 Komplettes Wakü set von Anfitec
-Bilder
-Bilder
-Bilder
-Bilder
-Northbridge Kühler 40,00€ (pci-1 fach slot unbrauchbar)
-Spannungswandler Kühler 43,00€
-Southbridge Kühler 37,00€ (pci-16 fach slot unbrauchbar)
-Bestellungen an info@anfi-tec.de
3.3 Allg. Links
Reviews: -@ ocworkbench
-@ bit-tech
-@ hardtecs4u
-@ tomshardware
-@ PCGH
-@ hothardware
-@ techreport
-@ BareboneCenter.de
-@ techwarelabs
-@ silentpcreview
-Aussagen über Stromverbrauch
3.4 Geizhals Link
->Geizhals.at
Mittlerweile lässt sich auf der Gigabyte Hompage schon eine neuere Revision (Rev. 1.1) finden.
Die Größten, bisher bekannten Unterschiede sind das Wegfallen des TPM-Headers, der geänderte Kühlkörper und ein zusätzlicher Lüfteranschluss links neben dem PCIe x1 Slot
Hier ein Bild
Ich bin offen für Verbesserungsvorschläge.
Noch mehr Bilder
1.1 Spezifikationen
Spezifikationen
CPU
Hyper Transport Bus
1. 5200/2000 MT/s
Chipset
Memory
Audio
LAN
Expansion Slots
3. 2 x PCI slots
South Bridge:
iTE IT8718 chip:
3. 1 x D-Sub port
5. 1 x HDMI port
10. 1 x RJ-45 port
I/O Controller
1. ITE IT8718 chip
BIOS
1. 1 x 8 Mbit flash
Unique Features
Bundle Software
Operating System
Form Factor
1.2 Ausstattung
Soweit ersichtlich:
-1x IDE Kabel
-1x Floppy Kabel
-I/O Shield
-Anleitung
2. Hilfen
Geforce 8200
AMD 780G
- Stromaufnahme
- HD-Wiedergabe:
- CPU Last:24% (X2 4200, 1080p)
- Hybrid-SLI
- Hybrid-Power
- möglich mit:
- möglich mit:
- Hybrid-Boost
- möglich mit:
- Geschwindgikeitsvorteil:
- Hybrid-Power
- Audio
- HDMI
- Sonstiges
AMD 780G
- Stromaufnahme:
- Chipsatz
- Gesamtsystem:
- Idle:42 W bzw 62,4W (min 65W CPU, ohne CnQ - PCGH gleiches Sys)
- Load:
- BD-Play:
Dazu eine kleine Liste von myBerg
1. http://www.hothardware.com/Articles/AMD_780G_Chipset_and_Athlon_X2_4850e_Preview_/?page=12
AMD Athlon 64 X2 4850e + Radeon HD 3450
Idle 79W (88W im Hybridmodus)
2. http://www.pcper.com/article.php?aid=527&type=expert&pid=10
Idle 78W
Idle 102W
3. http://www.techwarelabs.com/reviews/processors/780g-and-4850e/index_3.shtml
Idle 76W
4. http://www.firingsquad.com/hardware/amd_780g_overclocking/page13.asp
Idle 76W
5. likeubetty http://www.forumdeluxx.de/forum/showpost.php?p=8523078&postcount=476
AMD Phenom 9500
Idle 65,4W
6. http://www.pcgameshardware.de/aid,6...0G_und_Geforce_8200_im_HTPC-Vergleich/&page=2
AMD Athlon 64 X2 4200+
Idle 62,6W
7. http://www.bit-tech.net/hardware/2008/03/04/amd_780g_integrated_graphics_chipset/11
AMD Athlon 64 X2 5000
Idle 64W
AMD Atholon X2 BE-2350
Idle 61W
8. http://www.amdzone.com/index.php/reviews/56/9181-amd-780g-a-athlon-x2-4850e-review?start=4
AMD Athlon X2 4850e
Idle 59W
9. http://arstechnica.com/reviews/hardware/amd-780g-chipset-review.ars/5
AMD Athlon X2 4850e
Idle 56W
10. Ostrich http://www.mce-community.de/forum/index.php?showtopic=26440&view=findpost&p=167776
AMD Athlon X2 5000 (2 Festplatten)
Idle 55W
11. Brezel http://www.forumdeluxx.de/forum/showpost.php?p=8478588&postcount=353
AMD Athlon X2 BE-2400
Idle 50W
12. eXtremeTK http://www.forumdeluxx.de/forum/showpost.php?p=8497526&postcount=389
AMD Athlon X2 BE-2400 @ 1,05V
Idle 49W
13. likeubetty http://www.forumdeluxx.de/forum/showpost.php?p=8523078&postcount=476
AMD Athlon X2 5000+ EE (90nm)
Idle 47,9W
14. http://techreport.com/articles.x/14261/13
AMD Athlon X2 4850e
Idle 47,2W
15. http://www.legitreviews.com/article/676/11/
AMD Athlon X2 4850e
Idle 45W
16. http://www.hexus.net/content/item.php?item=12116&page=12
AMD Athlon X2 4850e
Idle 43W
17. likeubetty http://www.forumdeluxx.de/forum/showpost.php?p=8520085&postcount=464
AMD Athlon X2 BE-2300
Idle 42,5W
18. jc2960 http://www.forumdeluxx.de/forum/showpost.php?p=8477594&postcount=350
Idle 42W
19. http://www.tomshardware.com/de/AMD-780G-HDTV-Blu-Ray,testberichte-239963-13.html
AMD Athlon X2 4850e
Idle 41,73W
Idle 53,41W
20 c't 7/2008 S 72/73
AMD Athlon BE-2400
Idle 39W
21. isch http://www.forumdeluxx.de/forum/showpost.php?p=8444251&postcount=233
AMD Sempron LE-1250 Sparta @ 1,0GHz @ 0,800V
Idle 25,2W
Alle Werte wenn nicht anders angegeben mit C'n'Q / ohne Undervolting / ohne Underclocking
- HD-Wiedergabe:
- CPU Last:
- Hybrid-CF
- Hybrid-Power
- möglich mit:
- möglich mit:
- Hybrid-Boost
- möglich mit:
- Hybrid-Power
- Audio
- HDMI
- kein HDMI 1.3[/URL]
- kein True HD / DTS HD via HDMI
- Sonstiges
->BIOS
->Treiber
-Bilder
-Bilder
-Bilder
-Bilder
3.3 Allg. Links
-@ bit-tech
-@ hardtecs4u
-@ tomshardware
-@ PCGH
-@ hothardware
-@ techreport
-@ techwarelabs
-@ silentpcreview
3.4 Geizhals Link
->Geizhals.at
Hier ein Bild
