OS Support: Windows 2000/XP/Vista x64 & x32
also müsste ich mir nur Sorgen über die Spannungswandler machen ?
Wie misst du eigentlich die Temps von denen bei deiner 4870? Denn bei einer 4850 kann man die mittels Programmen nicht herausfinden. mit wieviel Volt könnt ich die 800mhz schaffen? 1,33V ?
Ich muss mein Vista 64bit immer im "unsigned driver modus" starten damit der atitraytools treiber startet.
wie kann ich das beheben? es nervt bei jedem boot f8 drücken zu müssen![]()
I am unable to start the low lvl driver under Windows Vista 64-bit. How can i fix that?
Vista x64 needs signed drivers otherwise it will not allow to load them. And as you could think of signing a driver is an expensive task because of Micro$oft. (Maybe if we donate Ray the amount needed he would do it, dont know, what i remember a sign for a year costs ~450 US Dollar)
fix1:
aka "I just want to test ATT under x64"
while windows startup hit F8 in the upcomming menu select "Disable Signed Driver Checking".
fix2:
aka "I cant live without ATT, give me the full ****"
load:
bcdedit -set loadoptions DDISABLE_INTEGRITY_CHECKS
unload:
bcdedit /deletevalue loadoptions
or maybe you can sign the driver yourself as follows
http://technet2.microsoft.com/Windo...f7d6-4816-8a3a-43242d71d5361033.mspx?mfr=true
follow the instructions to install the tools, gen your own certificate, import, sign the driver, and use bcdedit to permanently load it into test mode
Vista x64 beta:
or try deactivating digital driver signing check in Vista permanently until you manually reactivate it as follows
1. Create a shortcut on the desktop to cmd.exe
(this recipe explains how to create a shortcut if you don't know how)
2. Right-click on the shortcut and select Run as administrator
3. When the command window opens, type or paste the following and press ENTER:
Bcdedit.exe /set nointegritychecks ON
4. Reboot and then try installing the driver.
Jop! Läuft bei mir momentan 200/400 -weniger nicht versucht- und 3D 820/1075die 4850 macht bei mir per automatische att profile hervorragend 200/500 idle und 750/1075...
also besser als mit bios änderungen...
Candyman™;10885383 schrieb:kann man auf einer Normalen 4870 512 die von Saphire mit dem blauen PCB (sieht mir aus wie Standart Layout) ein anderes Bios drauf hauen z.B.: das von Asus oder so ?
Candyman™;10886906 schrieb:@ MrMacGyver: dann haste zu wenig Spannung im 2D drauf oder zu wenig bzw. zu viel Takt ... aber die Play soll ja so gut sein in 2D/3D naja kannst dich nur mal versuchen heran zu tasten mit ATT
