Na ja, so einfach ist es mit dem Gutschein dann wohl doch nicht bzw. ist PureTrak da wenig flexibel (oder möchte es einfach nicht sein):
"I do apologize but the code you used is strictly for the CompLexity edition mouse pad and NOT the Talent mouse pad. Did you want me to still proceed with the order and to switch it to the CompLexity pad or did you want to cancel your order completely?"
Ist das CompLexity denn wesentlich langsamer als das Talent? Ich bin nämlich kein extremer Low-Senser (eher Mid) und mag es daher ein wenig flutschiger
Edit: So einigermaßen konnte ich mir meine Antwort "zusammenfinden"
Hello XXXXX,
I apologize for the delayed response. Always glad to see a returning customer
It's not really a system error on our end, the shipping information through our form is pulling information from USPS and FedEx based on total product weight and where it's going... at those prices you told me, it seems USPS is the one at fault here :P I'll have to manually adjust it's quote for your country for Talent pads it seems.
In the mean time, I've generated a temporary fix that actually works out in your favor. Below is a discount code for 25% off your entire order via our website. If you order 2 Talent pads on a separate basis, your total with both shipping charges of $10.30 would be $70.60 USD ($50.00 for the Talent Pads + $20.60 for shipping = $70.60). However, after the 25% discount on both orders, your combined total will be $52.95 so you basically get free shipping. I will also box both pads in one box as there really is no need for two (obviously).
The discount code is: "XXXXXXXX"
I apologize for the inconvenient run around to make this work. Hopefully you aren't confused. To sum everything up... place two seperate orders, use the discount code on both orders, your combined total after the discount will be $52.95, both pads will be in one package.
Let me know if you have any further questions or concerns.
Regards,
Nick Iannotti
Co-President and Lead Product Developer
PureTrak Precision Mouse Pads
