emissary42
Kapitän zur See
- Ort
- Nehr'esham
- Desktop System
- Endlos-Baustelle
- AMD & Intel
- alle Hersteller
- Luft
- G.SKILL, Corsair & Co
- 8K, 5K, 4K
- 80plus Platinum
Please double check if you are using the right memory slots according to your motherboard manual. Your problem description sounds a lot like you are using the wrong slots.
VCCSA and VCCIO you can probably significantly lower afterwards, if your motherboard still pushes them to 1.3V. In most cases ~ 1.15V and 1.10V should be enough.
