vielen vielen dank....
Was stimmt denn mit dem Abit IX-38 QuadGT nicht oder was sind die negativen Punkte?Hi Biker,
also wenn du wirklich einen Kritik-Bedarf hast, dann hol dir
ein Abit IX38-QuadGT, dann kannst du dich da austoben....... Hi Hi.
Mein Hals wächst immer weiter und weiter
Intel's engineers told us that you can get X38 and X48 reference design to support SLI but you would have to put Nvidia's SLI chip inside.
It won't happen anytime soon, the sources added as it would mean that Intel has to change its X38 and X48 reference design and this simply won’t happen.
It would be a defeat if Intel does it and as far as we know this won't happen anytime soon. However, partners should be able to implement this chip and bring you X38 or X48 based motherboard with SLI support.
Wenn das Ding kein FB-Dimm hätte, dann vll. Aber so...
ATX_12V_2X/ATX (2x4 12V Power Connector and 2x12 Mainpower Connector)
With the use of the power connector, the power supply can supply enough stable power to all the components on the motherboard[...] The 12V power connector mainly supplies power to the CPU. If the 12V power connector is not connected, the computer will not start
Use of a power supply providing a 2x4 12V power connector is recommended by the CPU manufacture when using an Intel Extreme Edition CPU (130W)
