Blood1988
Urgestein
- Ryzen 5700X
- ASRock B450 Pro4
- DeepCool Gammaxx L240 v2
- 32GB Fury Beast RGB
- RX9070XT Hellhound
- LG 42C2OLED
- Kingston KC3000 1TB,WD Blue 570 500GB
- Bequiet Light Base 600 LX
- Bequiet Pure Power 12M 850Watt
- Keyboard
- Sharkoon SGK50S3 PBT
- Mouse
- Roccat Kone Pro Air
- Win 11
- Sonstiges
- Soundsys.:Nubert B30,NuSub XW700,Nubert AMP X
Weil der BenQ ja auch ein AUO Panel verbaut hat![]()
AU Optronics M270DTN01.0 TN sollte im BenQ stecken.
"The monitor uses a TN panel from AU Optronics which produces colours using 8-bits per subpixel without dithering. The resolution is 2560 x 1440 (WQHD) and the refresh rate is 144Hz (variable with Adaptive-Sync). The monitor boasts a 1ms grey to grey response time which is undoubtedly achieved on a select few transitions using the ‘AMA Premium’ setting (which isn’t exactly going to be ‘artifact free’). Whichever way you cut it, this is designed to be a fast monitor specifically tailored to gaming."
