[Sammelthread] J&W 790GX Extreme (AMD 790GX)
J&W 790GX Extreme
Spezifikationen
unterstützte Prozessoren
• Sockel AM2+/AM2 for AMD Phenom™FX / AMD Phenom™ / AMD Athlon™ 64 FX / AMD Athlon™ 64 X2 / AMD Athlon™ 64 / AMD Sempron™ Prozessoren (Unterstützung bis 140W TDP Prozessoren.)
Chipsatz
• AMD® 790GX + SB750 (Built in Radeon™ HD 3300 Graphics, DirectX® 10 Ready, with 128MB DDR3 side-port memory onboard)
• Marvell® 10/100/1000 Mbps Ethernet Controller
• Super I/O: Winbond W83627EHG chip
• Realtek ALC 888 HD Audio Codec
• 8M bit flash ROM
HyperTransport™
• HyperTransport™ 3.0/1.0, 5200/2000 MT/s
Memory
• Dual Channel DDR2 1066/800/667/533 support (DDR2 1066 support is dependent on CPU)
• Max Kapazität: 8 GB
• DIMM slots: 4
Interne I/O Anschlüsse
• 1 x 24-pin ATX power connector
• 1 x 8-pin ATX 12V power connector (compatible with 4-pin connector)
• 1 x floppy connector
• 1 x IDE connector (for 2 PATA devices)
• 6 x SATA 3Gb/s connectors (Support RAID 0,1,0+1,5)
• 1 x CPU fan connector
• 2 x system fan connectors
• 1 x front panel connector
• 1 x front audio connector
• 3 x USB 2.0 header for additional 6 USB 2.0 ports (by cables)
• 1 x buzzer connector
• 1 x IR connector
• 1 x COM connector
• 1 x CD-IN connector
• 1 x SPDIF In/Out header
Erweiterungs- Slots
• 3 x PCI-E x16 slots
• 1 x PCI-E x1 slot
• 2 x PCI slots
Anschlüsse hinten I/O
• 1 x PS/2 Keyboard port
• 1 x PS/2 Mouse port
• 1 x HDMI port
• 1 x S/PDIF In port (coaxial)
• 1 x S/PDIF Out port (optical)
• 1 x DVI port
• 1 x VGA port
• 1 x eSATA port
• 4 x USB 2.0 ports
• 1 x RJ45 GigaLAN port
• 6 x Audio ports (Line In / Line Out / MIC In / Rear Speaker Out / Center-Subwoofer Speaker Out / Side Speaker Out)
Form Faktor
• ATX
• 304.8mm x 245mm
H/W Monitoring
• Winbond W83627DHG
• System health status auto-detect and reported by BIOS
BIOS
• 8Mbit flash ROM, Award BIOS
Bundle Software
• Treiber- und Utility CD/DVD
Besonderheiten
• 100% Solid Capacitors, Debug LED onboard.
Links und Downloads
Bios - http://www.jwele.com/motherboard_detail.php?147#_bios
Treiber - http://www.jwele.com/motherboard_detail.php?147#_driver
Manual - http://www.jwele.com/motherboard_detail.php?147#_manual
Utilities - http://www.jwele.com/motherboard_detail.php?147#_util
Hier kann man das Board kaufen - http://www.jwele.de/
Ram Kompatibilität : Läuft
4gb Kit 2x 2gb OCZ Flex EX 9600 ( Mr.Wifi )
2gb Kit Crucial Ballistix Tracer - Sollen laut Aussagen eines Users sehr gut laufen :)
4GBCrucial Ballistix Tracer DIMM PC2-6400U CL4-4-4-12 ( Octa )
4gb TRANSCEND AxeRAM (TX1066QLU-4GK) Laufen sehr gut 600mhz @ 2,16v. ( Chubaka )
4gb Kit A-DATA XPG G Series DIMM PC2-6400U CL5-5-5-15 Laufen sehr gut ( Daniel N )
Man kann sagen dass das Board sehr gut für Ram OC geeignet ist, meldungen über nichtlaufenden Speicher gab es bis jetzt keine ;)
Kühler Kompatibilität :
Passt nicht
Scythe Kama Kama Cross ( Kollidiert mit Northbridge Kühler durch ausladenen Halteklammern, evtl. muss man mit Gewalt oder anders improvisieren )
Passt
IFX 14 ( niedrige Ram HS sind Pflicht wenn man Dualchannel benutzen möchte, weiterhin wird der erste Ram Slot von einem Lüfter blockiert oder man platziert ihn zwischen den Kühlblöcken des IFX und oder einen hinten ziehend )
Zerotherm FZ 120 ( gleiches Problem wie IFX )
Hexa Tabelle um die Multiplikatoren bzw. Vcore unter Pstates im Bios einzustellen ( Thx an Chubaka )
Interessantes über das Board :
http://www.xtremesystems.org/forums/showthread.php?t=191428
Die folgenden Screens zeigen was Monteboy ( AF ) an OC mit diesem Board erreicht hat ;)
http://www.hwbot.org/result.do?resultId=808042
Die 4GHz SM Tool stable von Chubaka ( 0849DPAW !!! )
4.1Ghz Primestable von Chubaka ( 0850 DPMW )
Bios Pics : Thx an Octa und CBOT
JAIN, der kollege (ich) hats deswegen nicht verkauft, sondern eingeschickt und n ersatz bekommen. da aber in der zwischenzeit meine pci-soundkarte weichen musste und nu die ASUS Xonar als PCI-E drinne steckte, passte das ganze von der slotaufteilung nich mehr mit meiner 4850+Accelero+120mm lüfter zusammen ;) aber von spulenpfeifen hört man bei den Jetway momentan des öfteren :motz:
EDIT: 1000 POSTS :coolblue: los türke, gib gummi :d
@maggus_zuki
Du willst wissen wie sich das Jetway HA07-Ultra gegen das J&W 790GX Extreme schlägt, garnicht das J&W ist besser und in sachen Board Layout klar überlegen. Ich habe beide hier zu liegen, einzig das Bios finde ich beim Jetway besser (AwardBios) ist aber Geschmackssache, wobei sich beide in sachen OC nicht unterscheiden,
Ein großer Nachteil, wie ich finde ist, dass das Jetway keinen Firewire Port besitzt, dieser sollte doch wenigstens vorhanden sein und auch diesen besitzt das J&W. Die SATA Anschlüsse liegen beim Jetway so blöd das ich von den 6 vorhandenden nur 4 nutzen kann da die Radeon im ersten PCI Express Slot, diese blockiert, allerdings muss ich hier noch erwähnen, das ich beide Radeons mit dem Sythe Musashi betreibe. Festplatten an und abstecken geht deshalb nur mit einer ausgebauten Radeon, beim J&W ist das kein Problem dort liegen die Anschlüsse an der Außenseite.
Es gibt zwar noch einige Kleinigkeiten aber um es kurz zu machen das J&W 790GX Extreme ist viel besser :love:
@Invidious, genau so etwas wollte ich hören... von einem der auch beide Bretter hat oder gehabt hat. Thx
@maggus_zuki
das ist doch mal ne klare antwort danke :wink:
dann wirds demnächst bestellt und muss zuerst halt mal mit meinem 4800+ vorlieb nehmen bis dann nen am3 phenom rein kommt
@ Mr Wifi. Egal, vergess mas einfach.
@ Maggus Zuki
Das hört man doch gerne ^^ Da freut man sich gleich noch mehr drauf ^^
@Chubaka
Gern geschehen, das Jetway werde ich mir sicherlich nicht nochmal kaufen, ich hatte es ein We verbaut und war heilfroh als das J&W wieder drin war, wie schon gesagt das AwardBios des Jetway finde ich nur besser als das AMI Bios des J&W, aber die anderen Nachteile machen das ganze zum klaren Sieg, für das 790GX-Extreme
@ Invidous : Auf meiner Platine wurden wohl die Firewire Ports vergessen, sind nur eingezeichnet :fresse:
Na ja, sonst sind doch immer 1394 Steckplätze auf den Boards ( hatte vorher Asus ), als ich dann mit dem Kabel vom Slotbracket da anschliessen wollte traute ich meinen augen kaum, da waren anstatt anschlüsse nur so abdrücke...
Wird ja auch in den Spezifikationen nirgendwo erwähnt das da 1394 Anschlüsse sein sollen deshalb hab ich mich da auch nich weiter drüber aufgeregt...
des manko der slotanordnung hat das JW auch nicht. man kann dort ne schöne graka mit dicker 4-slot höhe dank accelero und konsorten einbauen und zusätzlich noch ne pci-e soundkarte, raid-controller usw!
achja und zu den firewire ports die nicht drauf sind, oftmals verwenden verschiedene hersteller ein und das selbe PCB-layout oder ein hersteller bringt verschiedene bretter die auf nem gemeinsamen PCB basieren heraus. je nach hersteller und board sind halt die ports verbaut oder nicht. wenn firewire nicht auf der hersteller HP erwähnt ist, hats auch keinen.
also das hab ich noch nie gehört ist ja hart :fresse:
übrigens: hat vielleicht nicht viel mit dem board zu tun aber ich frag mal schnell vielleicht antworten jemand ja auch mal schnell^^:
ich komme grad günstig an nen dominator ddr2-1066 ram dran. den würd ich mir gleich zulegen auch wenn ich ihn mit meinem jetzigen X2 nur mit 800Mhz betreiben kann. ich hab nur angst das die 2,2V die der Ram braucht den Controler in der cpu killn. kann mir da jemand die angst nehmen?
Das layout ist wirklich prima das muss man sagen, ist alles da wo es sein muss ( naja fast :fresse: ) . Ich hab bei J&W ne Ram und Kühlerliste angefragt, mal sehen was die Antworten.
Da wird sich aber J&W wundern das innerhalb so kurzer zeit so viele 790GX bestellt werden:fresse:
@ Towatai
:lol: Das Board ist schon Porno genug :d
@Mr.Wifi, der war gut:d aber bräute auf der PCB ist doch mal´ne Marketing Strategie...
auszug der anleitung: zum installieren des arbeitsspeichers drücken sie ihren harten, strammen und überaus großen riegel tiefer und immer tiefer in den sehnsüchtig wartenden schlitz. dank ihrer stier-gleichen manneskraft werden sie bei erfolg mit einem lauten *KLICK* belohnt! :asthanos:
@ Chubaka : Dann hätten die richtigen Bräute noch weniger Verständnis für unser Hobby, ist doch so oder so schon hart genug den hardwarekauf zu rechtfertigen:fresse:
hmm so n board wäre geek-gefährdend! stellt euch mal vor wie son pickelbehangener ober kellermufti über dem board hängt und ihm vor lauter erregung die reich gefüllten eiterbeutel über selbigem platzen! 120€ fürn arsch :-/ absolut verantwortungslos oder das erste board mit FSk 18+ siegel ;)
:btt::btt:
edit:
schön zu sehen das es hier noch andere mumble-user gibt :d
MUMBLE FTW!!!
Bei zuviel NORD könnte das jedem NERD passieren :d
Yep, Mumble ist das beste, leider hat sich unsere Grid Fahrgemeinschaft aufgelöst...
Sauber ! Dann gehts hier im thread ja bald richtig rund :d
auf jeden Fall aber ich guck als erstes wie das Board mit meinem 9850BE umgeht und was möglich ist bevor ich den Deneb verbaue... Denn hab ich nen direkten vergleich zum M3A79T... Läßt sich das 790GX undervolten?
Öhm..gute Frage, ich probier es mal eben aus ;)
Ja, kann man bis 0.8v. einstellen. Werde morgen bevor der Deneb kommt mal gucken wie weit ich mit dem x2 4800 @ default Takt runter kann, auf den anderen Boards waren es 1.1v c.a
