[Sammelthread] J&W 790GX Extreme (AMD 790GX)
J&W 790GX Extreme
Spezifikationen
unterstützte Prozessoren
• Sockel AM2+/AM2 for AMD Phenom™FX / AMD Phenom™ / AMD Athlon™ 64 FX / AMD Athlon™ 64 X2 / AMD Athlon™ 64 / AMD Sempron™ Prozessoren (Unterstützung bis 140W TDP Prozessoren.)
Chipsatz
• AMD® 790GX + SB750 (Built in Radeon™ HD 3300 Graphics, DirectX® 10 Ready, with 128MB DDR3 side-port memory onboard)
• Marvell® 10/100/1000 Mbps Ethernet Controller
• Super I/O: Winbond W83627EHG chip
• Realtek ALC 888 HD Audio Codec
• 8M bit flash ROM
HyperTransport™
• HyperTransport™ 3.0/1.0, 5200/2000 MT/s
Memory
• Dual Channel DDR2 1066/800/667/533 support (DDR2 1066 support is dependent on CPU)
• Max Kapazität: 8 GB
• DIMM slots: 4
Interne I/O Anschlüsse
• 1 x 24-pin ATX power connector
• 1 x 8-pin ATX 12V power connector (compatible with 4-pin connector)
• 1 x floppy connector
• 1 x IDE connector (for 2 PATA devices)
• 6 x SATA 3Gb/s connectors (Support RAID 0,1,0+1,5)
• 1 x CPU fan connector
• 2 x system fan connectors
• 1 x front panel connector
• 1 x front audio connector
• 3 x USB 2.0 header for additional 6 USB 2.0 ports (by cables)
• 1 x buzzer connector
• 1 x IR connector
• 1 x COM connector
• 1 x CD-IN connector
• 1 x SPDIF In/Out header
Erweiterungs- Slots
• 3 x PCI-E x16 slots
• 1 x PCI-E x1 slot
• 2 x PCI slots
Anschlüsse hinten I/O
• 1 x PS/2 Keyboard port
• 1 x PS/2 Mouse port
• 1 x HDMI port
• 1 x S/PDIF In port (coaxial)
• 1 x S/PDIF Out port (optical)
• 1 x DVI port
• 1 x VGA port
• 1 x eSATA port
• 4 x USB 2.0 ports
• 1 x RJ45 GigaLAN port
• 6 x Audio ports (Line In / Line Out / MIC In / Rear Speaker Out / Center-Subwoofer Speaker Out / Side Speaker Out)
Form Faktor
• ATX
• 304.8mm x 245mm
H/W Monitoring
• Winbond W83627DHG
• System health status auto-detect and reported by BIOS
BIOS
• 8Mbit flash ROM, Award BIOS
Bundle Software
• Treiber- und Utility CD/DVD
Besonderheiten
• 100% Solid Capacitors, Debug LED onboard.
Links und Downloads
Bios - http://www.jwele.com/motherboard_detail.php?147#_bios
Treiber - http://www.jwele.com/motherboard_detail.php?147#_driver
Manual - http://www.jwele.com/motherboard_detail.php?147#_manual
Utilities - http://www.jwele.com/motherboard_detail.php?147#_util
Hier kann man das Board kaufen - http://www.jwele.de/
Ram Kompatibilität : Läuft
4gb Kit 2x 2gb OCZ Flex EX 9600 ( Mr.Wifi )
2gb Kit Crucial Ballistix Tracer - Sollen laut Aussagen eines Users sehr gut laufen :)
4GBCrucial Ballistix Tracer DIMM PC2-6400U CL4-4-4-12 ( Octa )
4gb TRANSCEND AxeRAM (TX1066QLU-4GK) Laufen sehr gut 600mhz @ 2,16v. ( Chubaka )
4gb Kit A-DATA XPG G Series DIMM PC2-6400U CL5-5-5-15 Laufen sehr gut ( Daniel N )
Man kann sagen dass das Board sehr gut für Ram OC geeignet ist, meldungen über nichtlaufenden Speicher gab es bis jetzt keine ;)
Kühler Kompatibilität :
Passt nicht
Scythe Kama Kama Cross ( Kollidiert mit Northbridge Kühler durch ausladenen Halteklammern, evtl. muss man mit Gewalt oder anders improvisieren )
Passt
IFX 14 ( niedrige Ram HS sind Pflicht wenn man Dualchannel benutzen möchte, weiterhin wird der erste Ram Slot von einem Lüfter blockiert oder man platziert ihn zwischen den Kühlblöcken des IFX und oder einen hinten ziehend )
Zerotherm FZ 120 ( gleiches Problem wie IFX )
Hexa Tabelle um die Multiplikatoren bzw. Vcore unter Pstates im Bios einzustellen ( Thx an Chubaka )
Interessantes über das Board :
http://www.xtremesystems.org/forums/showthread.php?t=191428
Die folgenden Screens zeigen was Monteboy ( AF ) an OC mit diesem Board erreicht hat ;)
http://www.hwbot.org/result.do?resultId=808042
Die 4GHz SM Tool stable von Chubaka ( 0849DPAW !!! )
4.1Ghz Primestable von Chubaka ( 0850 DPMW )
Bios Pics : Thx an Octa und CBOT
Das war dein Kauf Argument du Helm:d Temps sind einfach lach haft wenn cpu tweak im bios aus ist
Nich schlecht herr Specht, müsste doch fast passiv zu kühlen sein...
so, nun habt ihr mich neugierig gemacht auf das teil hier*g*
hat den schon jemand rerfahrung gemacht das board unter wasser zu setzen???
dazu müsste ich mal die beiden 120er vom CPU kühler abnehmen und gucken in wie weit die Temps nach oben gehen...
Ich sach ja GPAW´s sind nicht schlecht, werde der CPU von K&M mal auf den Zahn fühlen der ist ja auch ein GPAW aber 0849:hmm:
@twister, bei mir ist Lukü angesagt
Wasserkühler werden wohl erstmal ein Traum bleiben bis sich jemand erbarmt und es zu Anfi-Tec schickt. Hab momentan nur CPU und Graka unter Wasser, würde aber jederzeit zuschlagen wenn es ein Moboset gibt ;)
hab grad mal ne mail zu anfi-tec geschickt, mal sehen was ich raus bekomme...
ma eben ne ganz ganz blöde frage.. hab mir ma die bilder im anfangspost angeguckt.. hat das ding ne art DUALBIOS? ich seh da irgendwie 2 bausteine nebeneinander :confused:
hat Dual Bios, die man durch Setzten des Jumpers Aktivieren kann...
Gute Augen :d
Kann einer was zu den 7 verbauten Jumpern auf dem Board Sagen?
zu den jumpern...
steht doch soweit alles in der anleitung, wofür dei sind oder ned?
ohne es jetzt gelesen zu haben sagt mir mein technikverständnis, dass die jumper-phalanxen inner mitte zum zuweisen der pci-e lanes der einzelnen x16 steckplätze sind. korrigiert mich falls ich falsch liege ;)
wo siehst du teppichflieger 7 jumper? :shot:
@Towatai, isch gucke :fresse: sind nur noch 6...
@Twister, Äh nö...
ich sach ma so, bisher ist es Standard, Bilder und Spezifikationen + Download Links... was auch Ok ist ;)
Denke morgen bzw. später wird sich schon einer dazu melden...
Der einzigste Jumper der vom Manual nicht erklärt wird ist der JHDT Jumper der für OC unter AOD gedacht ist, laut J&W soll er auf den 2. und 3. Pin gesetzt werden falls man über AOD oced, der Jumper ist direkt über der roten PCIe Lane ;)
kann ich dir erst spätestens über morgen sagen:d Aber auf meinem M3A79T lässt sich mein Deneb auf 3,8@1,440v. ohne Mühe Takten :fresse:
Bin auf das 790GX gespannt...
du liebst deine Überraschungen also milde?:d:d
Zitat aus den Simpsons!
EDIT///Ja, mein 500!! Post =)
Sonn kack, bei mir ist bis jetzt noch kein Protzi angekommen obwohl seit heute Morgen auf der DHL wird zugestellt steht..... :hmm:
Das dauert hier immer Länger bis die liefern, die müssen sich noch erst durchs Ghetto kämpfen :d
omg...vorsicht :)
:asthanos:
EDIT///
also das hab ich noch nie gehört ist ja hart :fresse:
übrigens: hat vielleicht nicht viel mit dem board zu tun aber ich frag mal schnell vielleicht antworten jemand ja auch mal schnell^^:
ich komme grad günstig an nen dominator ddr2-1066 ram dran. den würd ich mir gleich zulegen auch wenn ich ihn mit meinem jetzigen X2 nur mit 800Mhz betreiben kann. ich hab nur angst das die 2,2V die der Ram braucht den Controler in der cpu killn. kann mir da jemand die angst nehmen?
Ist bei mir auch so...kein Firewire!
wenn bei mir bis 12:30 keiner kommt (DHL usw.) dann immer am nächsten Tag.
@Mr.Wifi, MORGEN :fresse:
wo hin zur Post? Dann mach hin! oder wie lange hat die bei euch Geöffnet...?
ne, Rote Karte war keine im Briefkasten, leider. Wenn ich jetzt nach Krefeld fahre ( Zustell Paketzentrum ) dann klingelt mit sicherheit der DHL Mann wenn ich nicht da bin, die liefern bei mir oft nach 16:00 h., das ist ja der Kack.
lol...lass es deinen Hund abnehmen :fresse:
Leg einen Zettel! (zum Nachbarn bringen lassen!)
