[Sammelthread] J&W 790GX Extreme (AMD 790GX)
J&W 790GX Extreme
Spezifikationen
unterstützte Prozessoren
• Sockel AM2+/AM2 for AMD Phenom™FX / AMD Phenom™ / AMD Athlon™ 64 FX / AMD Athlon™ 64 X2 / AMD Athlon™ 64 / AMD Sempron™ Prozessoren (Unterstützung bis 140W TDP Prozessoren.)
Chipsatz
• AMD® 790GX + SB750 (Built in Radeon™ HD 3300 Graphics, DirectX® 10 Ready, with 128MB DDR3 side-port memory onboard)
• Marvell® 10/100/1000 Mbps Ethernet Controller
• Super I/O: Winbond W83627EHG chip
• Realtek ALC 888 HD Audio Codec
• 8M bit flash ROM
HyperTransport™
• HyperTransport™ 3.0/1.0, 5200/2000 MT/s
Memory
• Dual Channel DDR2 1066/800/667/533 support (DDR2 1066 support is dependent on CPU)
• Max Kapazität: 8 GB
• DIMM slots: 4
Interne I/O Anschlüsse
• 1 x 24-pin ATX power connector
• 1 x 8-pin ATX 12V power connector (compatible with 4-pin connector)
• 1 x floppy connector
• 1 x IDE connector (for 2 PATA devices)
• 6 x SATA 3Gb/s connectors (Support RAID 0,1,0+1,5)
• 1 x CPU fan connector
• 2 x system fan connectors
• 1 x front panel connector
• 1 x front audio connector
• 3 x USB 2.0 header for additional 6 USB 2.0 ports (by cables)
• 1 x buzzer connector
• 1 x IR connector
• 1 x COM connector
• 1 x CD-IN connector
• 1 x SPDIF In/Out header
Erweiterungs- Slots
• 3 x PCI-E x16 slots
• 1 x PCI-E x1 slot
• 2 x PCI slots
Anschlüsse hinten I/O
• 1 x PS/2 Keyboard port
• 1 x PS/2 Mouse port
• 1 x HDMI port
• 1 x S/PDIF In port (coaxial)
• 1 x S/PDIF Out port (optical)
• 1 x DVI port
• 1 x VGA port
• 1 x eSATA port
• 4 x USB 2.0 ports
• 1 x RJ45 GigaLAN port
• 6 x Audio ports (Line In / Line Out / MIC In / Rear Speaker Out / Center-Subwoofer Speaker Out / Side Speaker Out)
Form Faktor
• ATX
• 304.8mm x 245mm
H/W Monitoring
• Winbond W83627DHG
• System health status auto-detect and reported by BIOS
BIOS
• 8Mbit flash ROM, Award BIOS
Bundle Software
• Treiber- und Utility CD/DVD
Besonderheiten
• 100% Solid Capacitors, Debug LED onboard.
Links und Downloads
Bios - http://www.jwele.com/motherboard_detail.php?147#_bios
Treiber - http://www.jwele.com/motherboard_detail.php?147#_driver
Manual - http://www.jwele.com/motherboard_detail.php?147#_manual
Utilities - http://www.jwele.com/motherboard_detail.php?147#_util
Hier kann man das Board kaufen - http://www.jwele.de/
Ram Kompatibilität : Läuft
4gb Kit 2x 2gb OCZ Flex EX 9600 ( Mr.Wifi )
2gb Kit Crucial Ballistix Tracer - Sollen laut Aussagen eines Users sehr gut laufen :)
4GBCrucial Ballistix Tracer DIMM PC2-6400U CL4-4-4-12 ( Octa )
4gb TRANSCEND AxeRAM (TX1066QLU-4GK) Laufen sehr gut 600mhz @ 2,16v. ( Chubaka )
4gb Kit A-DATA XPG G Series DIMM PC2-6400U CL5-5-5-15 Laufen sehr gut ( Daniel N )
Man kann sagen dass das Board sehr gut für Ram OC geeignet ist, meldungen über nichtlaufenden Speicher gab es bis jetzt keine ;)
Kühler Kompatibilität :
Passt nicht
Scythe Kama Kama Cross ( Kollidiert mit Northbridge Kühler durch ausladenen Halteklammern, evtl. muss man mit Gewalt oder anders improvisieren )
Passt
IFX 14 ( niedrige Ram HS sind Pflicht wenn man Dualchannel benutzen möchte, weiterhin wird der erste Ram Slot von einem Lüfter blockiert oder man platziert ihn zwischen den Kühlblöcken des IFX und oder einen hinten ziehend )
Zerotherm FZ 120 ( gleiches Problem wie IFX )
Hexa Tabelle um die Multiplikatoren bzw. Vcore unter Pstates im Bios einzustellen ( Thx an Chubaka )
Interessantes über das Board :
http://www.xtremesystems.org/forums/showthread.php?t=191428
Die folgenden Screens zeigen was Monteboy ( AF ) an OC mit diesem Board erreicht hat ;)
http://www.hwbot.org/result.do?resultId=808042
Die 4GHz SM Tool stable von Chubaka ( 0849DPAW !!! )
4.1Ghz Primestable von Chubaka ( 0850 DPMW )
Bios Pics : Thx an Octa und CBOT
sieht sehr sauber aus und die Verpackung vom MB also Schutzfolie usw. ist echt "übertrieben" eingepackt...:love:
Kein vergleich zum Asus :fresse:
Hab je seit gestern nen 940er Deneb und den 9850BE welchen soll ich denn als erstes verpflanzen :d
Mein Deneb ist da und Primelt gerade, ich taste mich mal langsam nach oben :coolblue:
Übrigens ist jetzt im JuustWoot Overclocking Menü der Multi und die Vcore ausgegraut, Vcore kann man momentan nur im normalen Menü einstellen ;)
Danke für die Info aber ich hab nichts verstanden :fresse:
€: zZ. sind noch die Treiber von meinem Asus auf dem OS kann ich die neuen einfach drüber installieren oder wie soll vorgehen?
Das im Bios wirst du dann ja sehen, besser erklären kann ich das jetzt nich :fresse:
Ich würde die Treiber von Asus entfernen, aber probieren geht über studieren, musste auch gerade nen cmos clear machen weil aod rumspinnt wenn speedfan eingeschaltet ist, irgend wie wird in cpu z auch mal dies und das an vcore angezeigt, ich komm wohl auch nicht um ne neuinstallation herum. Aber jetzt wird erstmal geprimed :fresse:
Edit: Die 3.5ghz Primen gerade 10 min mit 1.336v.
Ich werde auch mal neumachen nachdem XP jetzt irgendwie komplett banane geworden ist, es muss alles stimmen um die bestmöglichen Takte auszuloten.
unter vista64 ist bei mir ab 3,6gig kein boot mehr möglich, folglich verwende ich gerade W7, was mit richtig gut gefällt :love:
3,5 ghz sind mit 1,336v. leider nicht drin, mit 1,360v. schon. Sehr löblich ist die Spannungsversorgung des Boards, die vcore value ist min und max unter Last gleich :)
Morgen wird dann geguckt was nach oben hin unter den derzeitigen vorraussetzungen ( aod only ) möglich ist, das Bios hab ich noch nicht wirklich durchschaut, hoffentlich kommt das neue Bios bald damit man nicht mehr auf aod angewiesen ist um über den multi zu takten.
Leider nicht ganz, wo es bei 1.33v. noch gleich blieb änderte sich das bei 1.36v., hab zwar von meinem Prozzi mehr erwartet aber was solls, 3,5ghz ultrasilent ist auch nicht schlecht für den Anfang. Hier mein erstes Endergebnis für heute :wayne:
ich hab da ein kleines aber feines Problem, ich kann das bios nicht updaten...
Eigentlich doppel klick auf die flash file und gut aber bei mir sagt er immer konnte treiber nicht laden...
benutze jetzt Vista64 hab auch schon als admin ausführen gemacht passiert aber trotzdem nichts:hmm:
Hab im Bios die Bios Protektion Deaktiviert
€: liegt am 64bit system... welche usb funktion muss ich Bios frei schalten damit er das bios von´nem Stick flashed?
Hmm...bei mir hats in XP einwandfrei geklappt. Wo kam die Meldung das er den Treiber nicht laden konnte ? In Windows selber oder nachdem der Rechner wieder neugestartet ist ?
gleich nach dem doppel klick... und alles was auf J&W so als HowTo gezeigt wird ist immer mit XP! und das kommt für mich nicht mehr in frage:shake:
hab soweit alles fertig, W7 frisch installiert, Vista64 und Server2003 hab kein bock mehr :fresse: Will jetzt nur noch das Bios flashen und den Deneb Quälen:d
hab soweit alles fertig, W7 frisch installiert, Vista64 und Server2003 hab kein bock mehr Will jetzt nur noch das Bios flashen und den Deneb Quälen
Bis ich erstmal das mit der Write Protection gecheckt hab :fresse:, bei jedem Error ist mir fast das Herz stehen geblieben... :fresse:
Dann musst du es irgendwie über Diskette oder USB Stick also wie sonst auch versuchen, Alternative wäre XP :heuldoch: mal schnell zu installieren und das so mit dem Flash durchziehen und dann kannste es ja wieder runterwerfen. Nen anderen Plan hätte ich jetzt auch nicht, leider.
hat geklappt mit Server 2003... aber sag mal das bios hatte ich schon drauf! 080015 ist die Version. Dann hätte ich mir auch sparen können:fresse: :shake:
Du hattest mir doch was von 1.1 oder so geschrieben... Das ist die bezeichnung auf der Homepage von denen aber 1.1 ist 080015 ;-)
Danke :wink:
ja bin ich, weil sich dann ein DOS Fenster öffnet und er das bios flashed :coolblue:
Aber ich sach mal so, für Vista64 und W7 64bit ist das nichts... zu viel Aktion wegen Treiber und Bios Flash
Die sind noch voll auf XP:fresse: dann kann ich auch gleich mein Win 98 rauskramen :d
Die 1.0 Version hieß bei mir aber auch 08015 soweit ich mich erinnern kann, ich habe mehr auf das Datum und CPU-Z geachtet, 1.0 ist 28.8.08 und 1.1 30.10.08, evtl. hattest du schon das neuere Bios drauf kann ja sein :d
wieso geht bei dir ein Multi von über 17?
EDIT///Bei mir updatet der das Bios unter Windows garnicht...obwohl alles klappt^^
Hab immernoch Rev 1.01
Wie meinst du das... ich stell in AOD x18 ein wenn ich mehr mache schmiert Vista64 ab! Darum sollte entweder schnell das neues Bios her oder AOD auf W7 funktionstüchtig gemacht werden...
Jetzt gerade hab ich nichts von meinem Deneb und dem Board :-[
€: So Leute, bin gut abgenervt weil ich mich selbst ausgebremst habe wegen OC bzw. Board/Bios - OS/SW.
Ich klatsch jetzt XP drauf und will wissen was geht!
hier mal ein kleiner Vorgeschmack mit dem Asus und W7
jetzt mal im ernst wenn das mit vista geht ist doch alles ok! ich mein 3,8Ghz hören sich doch nich schlecht an? oder was is grad dein Problem? Welches Board hast du?
Bin jetzt nicht ganz mitgekommen. Was gibts für Probleme mit dem J&W und Vista?
Und der maximale Multi ist grad 18 oder wie? wer hat sonst noch nen Deneb auser Chubaka? Wie läuft er bei euch?
1.Problem: habe jetzt das J&W Board das hat im Bios aber keinen Multi ergo muss ich auf AOD zurückgreifen.
Bei den Betriebssystemen die ich installiert habe Server2003,Vista64 und W7 64bit läuft AOD nur mit Vista, der haken ist das bei Vista64bit keine Ahnung warum ab 3,7gig nichts nehr geht...
Die mp3´s also wenn ich musik höre fangen an zu rauschen und kriseln. Display bekommt aussetzer das ganze sys wird instabil egal mit wie viel vcore Vista schmiert ab!
2.Problem: da ich weis wie weit ich mit dem Asus gekommen bin und mein Kaufgrund für das J&W auch das OC Potential war will ich natürlich gucken was mit der Platine hier geht...
werde aber wegen dem 1.Problem ausgebremst! Darum installiere ich jetzt XP und dann Schubrakete :fresse:
€: ein neues Bios ist aber schon von J&W in Arbeit also nur eine frage der Zeit, Geduld haben du musst mein junger Padawan Schüler :shot:
achso jetzt verstehe ich^^
also ich werde es nicht bestellen bis die das mit dem bios endlich in griff bekommen haben. Weil das hört sich doch alles ziemlich, sag mer naja an
dann lass mal deine jedikräfte spielen meister weil das mit dem neuen bios steht hier schon seit beginn des therads^^
Den Thread gibt es ja noch nicht so lange so zusagen alles frisch auch die Erfahrungswerte der User...
Wegen dem Bios mach ich mir keine sorgen, Qualität statt Quantität.
Im Gegensatz zu Asus die alle 14 Tage eins raushauen wo ein bug den anderen jagt:fresse:
