[Sammelthread] J&W 790GX Extreme (AMD 790GX)
J&W 790GX Extreme
Spezifikationen
unterstützte Prozessoren
• Sockel AM2+/AM2 for AMD Phenom™FX / AMD Phenom™ / AMD Athlon™ 64 FX / AMD Athlon™ 64 X2 / AMD Athlon™ 64 / AMD Sempron™ Prozessoren (Unterstützung bis 140W TDP Prozessoren.)
Chipsatz
• AMD® 790GX + SB750 (Built in Radeon™ HD 3300 Graphics, DirectX® 10 Ready, with 128MB DDR3 side-port memory onboard)
• Marvell® 10/100/1000 Mbps Ethernet Controller
• Super I/O: Winbond W83627EHG chip
• Realtek ALC 888 HD Audio Codec
• 8M bit flash ROM
HyperTransport™
• HyperTransport™ 3.0/1.0, 5200/2000 MT/s
Memory
• Dual Channel DDR2 1066/800/667/533 support (DDR2 1066 support is dependent on CPU)
• Max Kapazität: 8 GB
• DIMM slots: 4
Interne I/O Anschlüsse
• 1 x 24-pin ATX power connector
• 1 x 8-pin ATX 12V power connector (compatible with 4-pin connector)
• 1 x floppy connector
• 1 x IDE connector (for 2 PATA devices)
• 6 x SATA 3Gb/s connectors (Support RAID 0,1,0+1,5)
• 1 x CPU fan connector
• 2 x system fan connectors
• 1 x front panel connector
• 1 x front audio connector
• 3 x USB 2.0 header for additional 6 USB 2.0 ports (by cables)
• 1 x buzzer connector
• 1 x IR connector
• 1 x COM connector
• 1 x CD-IN connector
• 1 x SPDIF In/Out header
Erweiterungs- Slots
• 3 x PCI-E x16 slots
• 1 x PCI-E x1 slot
• 2 x PCI slots
Anschlüsse hinten I/O
• 1 x PS/2 Keyboard port
• 1 x PS/2 Mouse port
• 1 x HDMI port
• 1 x S/PDIF In port (coaxial)
• 1 x S/PDIF Out port (optical)
• 1 x DVI port
• 1 x VGA port
• 1 x eSATA port
• 4 x USB 2.0 ports
• 1 x RJ45 GigaLAN port
• 6 x Audio ports (Line In / Line Out / MIC In / Rear Speaker Out / Center-Subwoofer Speaker Out / Side Speaker Out)
Form Faktor
• ATX
• 304.8mm x 245mm
H/W Monitoring
• Winbond W83627DHG
• System health status auto-detect and reported by BIOS
BIOS
• 8Mbit flash ROM, Award BIOS
Bundle Software
• Treiber- und Utility CD/DVD
Besonderheiten
• 100% Solid Capacitors, Debug LED onboard.
Links und Downloads
Bios - http://www.jwele.com/motherboard_detail.php?147#_bios
Treiber - http://www.jwele.com/motherboard_detail.php?147#_driver
Manual - http://www.jwele.com/motherboard_detail.php?147#_manual
Utilities - http://www.jwele.com/motherboard_detail.php?147#_util
Hier kann man das Board kaufen - http://www.jwele.de/
Ram Kompatibilität : Läuft
4gb Kit 2x 2gb OCZ Flex EX 9600 ( Mr.Wifi )
2gb Kit Crucial Ballistix Tracer - Sollen laut Aussagen eines Users sehr gut laufen :)
4GBCrucial Ballistix Tracer DIMM PC2-6400U CL4-4-4-12 ( Octa )
4gb TRANSCEND AxeRAM (TX1066QLU-4GK) Laufen sehr gut 600mhz @ 2,16v. ( Chubaka )
4gb Kit A-DATA XPG G Series DIMM PC2-6400U CL5-5-5-15 Laufen sehr gut ( Daniel N )
Man kann sagen dass das Board sehr gut für Ram OC geeignet ist, meldungen über nichtlaufenden Speicher gab es bis jetzt keine ;)
Kühler Kompatibilität :
Passt nicht
Scythe Kama Kama Cross ( Kollidiert mit Northbridge Kühler durch ausladenen Halteklammern, evtl. muss man mit Gewalt oder anders improvisieren )
Passt
IFX 14 ( niedrige Ram HS sind Pflicht wenn man Dualchannel benutzen möchte, weiterhin wird der erste Ram Slot von einem Lüfter blockiert oder man platziert ihn zwischen den Kühlblöcken des IFX und oder einen hinten ziehend )
Zerotherm FZ 120 ( gleiches Problem wie IFX )
Hexa Tabelle um die Multiplikatoren bzw. Vcore unter Pstates im Bios einzustellen ( Thx an Chubaka )
Interessantes über das Board :
http://www.xtremesystems.org/forums/showthread.php?t=191428
Die folgenden Screens zeigen was Monteboy ( AF ) an OC mit diesem Board erreicht hat ;)
http://www.hwbot.org/result.do?resultId=808042
Die 4GHz SM Tool stable von Chubaka ( 0849DPAW !!! )
4.1Ghz Primestable von Chubaka ( 0850 DPMW )
Bios Pics : Thx an Octa und CBOT
Das mit dem Multi wissen die schon lange, ist wohl noch in arbeit. Die paar Tage länger warte ich gerne wenn dafür alles einwandfrei funzt ;)
Die Biose kannst du recht simpel unter windows flashen, musst nur die bios write protection unter security deaktivieren, dann gehst du in den wintools ordner der downloaddatei und klickst die Batchdatei ( Flash ), der rest geht automatisch. Wenn der Rechner beim Reboot nicht hochfährt einfach kurz auf reset und dann mit F1 ! ins bios setup und einstellen. Aber vor dem Flashen nicht vergessen das Bios auf die defaults zurückzusetzen ;)
Was meinst du denn jetzt genau ? Kann dir irgenswie nie folgen.. :fresse:
nja...ich dachte,dass ich diese Protection "an" hatte,
war aber aus, geht trotzdem nicht :fresse:
Meine neueste Errungenschaft:
Auf wieviel sollte ich bei der Spannung der NB gehen?
EDIT/// Ist aber noch nicht 100% stable
hatte ich ganz vergessen :fresse:
@octa, ich hatte immer 1,450v.@2600MHz NB Frequency aber 1,400v. sollte auch reichen.
Macht es eigentlich was aus wenn die K10nb nicht über der CPU vcore eingestellt ist ? Habe mich bis jetzt immer an den Biostext gehalten und sie höher eingestellt....
Schönes Ergebnis für nen 9950er, bekommste bestimmt irgendwie stabil, kleiner Tipp, knibbel mal das Silent Cool Schild von der NB ab, das hat bei mir viel bessere NB Temps gebracht ;)
Danke für die Tipps!
EDIT///Wann war bei euch Busspeed ende?
Hab es jetzt erst verstanden :fresse: Hab ich noch nicht getestet K10nb ist auf Auto:d
um die 250 hat er dicht gemacht
also,
meiner startet noch mit 270, also 3,52 Ghz.
Mit fettem Sound:fresse:
Bei 265 war kein Boot möglich.
Bei 260 kam ein Bluescreen.
Bei 255 bin ich^^
Derzeit stable (unter Windoof)
siehst du bei 255 stable und ich hatte einen 9850BE nicht @3,5 aber 3,2@1,323v. :d
Hätte echt nicht gedacht das die 600MHz@2,161v. machen :coolblue:
bin ich der einzige der was mit dem Board macht oder gibt es noch andere hier...?!
Auf dem Board hier immer :coolblue:
von octa seinen, ist die 1066er variante recht günstig 2GB 34€ da lohnt es sich doch 2x2GB zu holen 2,2v.@600MHz sollten auch damit möglich sein :d
Fein, ich nehme an das sie besser laufen als auf allen Boards die du vorher hattest stimmts ? :d
Du Uri Geller!
von octa seinen, ist die 1066er variante recht günstig 2GB 34€ da lohnt es sich doch 2x2GB zu holen 2,2v.@600MHZ sollten auch damit möglich sein :d
Es waren auch Patriots bei mir im Spiel beim Kauf.
Waren damals teurer, also die Crucial`s!
Wow, noch jemand im 4ghz Club :d
Echt sehr nice das Ergebnis, werde ich gleich mal in den Startpost übernehmen :d
joa, hat geklappt wa :d Das mit dem Startpost ist nett Danke :wink:
Danke hab dich auch lieb :d Freut euch doch das es mit dem Board geht und vor allem mit dem Bios :fresse:
Wenn das Finale dann raus kommt werden die Karten nochmal neu gemischt...
Servus!!
seit dem der deneb aufm markt ist suche ich ununterbrochen einträge in foren und ähnl. um ein passendes board für den 940er zu erwählen.bin dabei vor ein paar tagen schon auf nen thread mit dem JW-790GX-EXTREME gestoßen.Vom layout siehts wirklich gut aus,keine frage.der mauszeiger huschte auch schon auf der jwele homepage über den bestellbutton.im vergleich zum JW-790GX-EXTREME,was haltet ihr vom m3a79-T bzw m4a79 deluxe!?chipsatz und sb sind ja die gleichen!oder kommt beim m4a wat neues?!
und nun auch noch das,ähh "fehlerhafte"bios... was heisst fehlerhaft.. man kann den multi !!noch!!nicht einstellen.. was einem die kaufentscheidung mom. nicht wirklich erleichtert...
meine zusammenstellung:
940er
evtl m3a79//m4a79 oder JW-790GX-EXTREME
4GB Corsair Dom
wahrscheinl. ne 4870 1gb...
kommt dann alles in nen Lian Li PC-A70B mit WakÜ
oder hat jemand nen gegenvorschlag!?
janusat Servus :wink:
Bei mir ging das relativ schnell mit dem Bestellbutton und ich hab es nicht bereut...:d
Zu dem Bios kann ich dir sagen das ich gerade eine Beta Version verwende die zum Final Release einen NB und CPU Multi haben wird! Das es auch ohne geht haben jetzt einige User gezeigt
Ich selber hatte/habe das M3A79T es ist nicht schlecht aber auch nicht besser :shake:
und der Support von J&W ist mahl erste Sahne versuch mal Kontakt mit dem Asus Support auf zu nehmen bzw. was du als Antwort bekommst ist:kotz:
zum M4A kann ich dir nichts sagen da ich mich zu 100% auf das Board eingeschossen habe :d
OT:
Wenn du dich für das M3A79T entscheiden solltest... ich hab noch eins da OVP und Rechnung vom 11.2008 125€ inkl. Versand
ich bin nen asus "fan-boy" da ich nie probl hatte, weder mit dem jetzigen x38er noch mit dem a7v600-x. nie treiber,bios oder sonstige probleme.daher fällt es mir schwer jetzt ein nicht asus board zukaufen.(das MSI war ein,naja halbhertziger kauf.. es musst in dem mom sein. und nen halbes jahr später waren 3 von 4 ram bänken defekt..tztz)
davon ab ist es dann immer schwierig aus A nach D und wieder retour reklamationen abzuwickeln. is ja innerhalb As schon nich so schön und dauert mitunter 3wochen(vorallem wenn man die defekten teile selber nach salzburg karrt und 2 einhalb wochen keine reaktion via email erfolgt!!! :wall:
Wieso denn das? Wenn du RMA hast dann geht das nach Berlin Deutschland...
Ich hatte vor dem M3A79T das M3A32MVP auch nicht schlecht auch keine Probleme gehabt aber irgendwie ist immer an der gleichen Stelle Schluss mit den Asus Brettern... musst du für dich selbst entscheiden, wie gesagt mein Angebot steht mit dem M3A79T
versteh ich das richitg 125€ inkl.versand nach A? is ne überlegung wert!aber ich will doch das JW-790GX-EXTREME!!:confused:
aber so wie die preise beim 940fallen will ich gar nicht mehr so lang warten!! :d
ich lass es mir ma durch den kopf gehen...
ich habe jetzt schon öfters gelesen das versch. amd 790 boards probleme mit ahci haben bzw. man das nicht aktivieren kann.
wie sieht es mit diesem board aus, funktioniert ahci oder ist das ein generelles problem mit dem chipsatz?
gruß
manu
