H
HW-Mann
Guest
lass ihn ...
er hat noch recht wenig dunst von dem game ...
Bitte sag mir, dass Blackcleaver nicht dein Secondpick war.
hab mir ja wukong am ersten tag geholt und paar tage später noch den feuier skin weil ich den char richtig gut finde.
jtzt habe ich den gut eingespielt:
und gerade noch ein game mit 4/1 gehabt danach haben die gegner aufgegeben.
macht echt spass der char. habe rüstungsdurchdringung in rot der rest AS klasse 3 alles geht ganz gut.
Dann solltest du aber besser ein Sunfire Cape nehmen anstatt WarmongsAls Wukong bist du kein AD Carry... dafür sind deine skills nicht ausgelegt. Du musst initiieren, gegnerische Carries behängen/nerven und alles durch die Luft wirbeln.
Quelle: Boibi comments on Why is mid always solo?This strange meta has the unfortunate disadvantage of being both against the norm, and requiring a fairly specific team comp. It plays out like this. Two heavy farmers (think AP lane dominators. i.e. Anivia, Heimer, Morde, Lux) take solos at top and bottom. If they're careful, they should be able to hold against the 2v1 at bottom and the 2v1 at top. If the enemy has a jungler, you can take a ranged AD carry at top (like Ashe, Corki, Caitlyn, Trist). They need to keep their lane unpushed, but their tower at full health. Then the mid consists of 3 champions. One of those is a melee dps champ with movement and harass (Ren, Jax, Irelia). The other two are support champs, preferably with heals or sheilds (Karma, Sona, Soraka, Janna). This team comp relies on harassing mid, but never dieing. The melee dps should either kill the enemy champ or make them back, keeping their exp down. If you don't harass, this meta won't work. Otherwise your champs will be underleveled for a majority of the game. You will push hard at mid. You should have the mid tower down by 10 minutes. You will force someone out of one of the other lanes to go and help their mid. Their carry will be even more underleveled for this. At this point, the farmed carries go to town pushing, and the melee and maybe one support will go in for kills everywhere. Keep in mind that this meta doesn't have a tank. It relies on heavy farm and split pushing. It generally avoids teamfights. You will not get this to work without going in with a pre-organized 5 man.
