[Sammelthread] MSI 890FXA GD-70 (890fx)
MSI 890FX GD-70 Sammelthread
________________________________________________
Technische Daten
________________________________________________​
* Hersteller: MSI
* CPU-Sockel: Sockel AM3
* Formfaktor: ATX
* Mainboard Chipsatz: AMD 890FX (RD890)
* System-Bus (FSB / HT / QPI / DMI): 5.2 GT/s HT
* Grafikkarten Bus: PCI Express 2.0
* Arbeitsspeicher Typ: DDR3-SDRAM 1866MHz (PC3-15000)
* Anzahl der S-ATA Anschlüsse: 7
* Onboard Audiokanäle: 7.1
* Netzwerk Schnittstellen 2x
* Multi-GPU Unterstützung: CrossFire, CrossFireX
* Passive Kühlung: Ja
Weiter Informationen
Superb Stability: Military Class Components
OC Genie: Easy Overclocking Technology
Unlock CPU Core: Unlock hidden CPU core and potential
DrMOS: Best power efficiency
Support USB 3.0 AND SATA 6Gb/s
Lossless 24bit/192kHz HD Audio
CPU
• 64bit AMD® Phenom II X6/X4/X3/X2, Athlon II X4/X3/X2 and Sempron CPU.
Please refer to CPU Support for compatible CPU; the above description is for reference only.
140W Support
* Supports AMD high performance 140W CPUs
* Reserve the ability for future CPU upgrade
* To fully release the power of AMD CPUs
Hyper Transport Bus
• HyperTransport 3.0 supporting speed up to 5200MT/s
Chipset
• AMD® 890FX and SB850 Chipset
Main Memory
• Supports four unbuffered DIMM of 1.5 Volt DDR3 800/1066/1333/1600*/1800*/2133* (OC) SDRAM, 16GB Max
Slots
• 4 PCI Express 2.0 slots with x16 operation (PCI Express Bus SPEC V2.0 compliant)
• 1 PCI EXpress 2.0 slot (PCI_E4) with x4 operation (PCI Express Bus SPEC V2.0 compliant)
• 1 PCI Express 2.0 x1 slot
• 1 PCI slot, support 3.3V/ 5V PCI bus Interface.
On-Board IDE
• One IDE port by JMicron® JMB363
- Supports Ultra DMA 66/100/133 mode
- Supports PIO, Bus Master operation mode
- Can connect up to two IDE devices
On-Board SATA
• 6 SATA III (1~6) ports by AMD® SB850
- Supports storage and data transfers at up to 6Gb/s
• 1 SATA II (SATA7) port by JMicron® JMB363
• 1 eSATA II / USB Combo port by JMicron® JMB363
RAID Function
- SATA III 1~6 support RAID 0, 1, 5, 10 mode by AMD® SB850
Audio
• Chipset integrated by Realtek® ALC889/ALC892
- True Blu-ray Audio Support
- Flexible 8-channel audio with jack sensing
- Compliant with Azalia 1.0 Spec
LAN
• Realtek PCI-E GbLAN controller 8111DL
- Integrated Fast Ethernet MAC and PHY in single chip
- Supports 10Mb/s, 100Mb/s and 1000Mb/s
- Compliance with PCI-Express Bus specification v1.0a
IEEE1394 / FireWire
• VIA® VT6315N chipset
- Supports up to two 1394 ports. (pinheader x2)
- Transfer rate is up to 400Mbps.
Internal I/O Connectors
- 1 x ATX 24-pin power connector
- 1 x ATX 8-pin 12V CPU power connector
- CPU x 1 / System x 4 FAN connectors
- 1 x Front panel audio connector
- 1 x Front panel connector
- 1 x Chassis intrusion switch connector
- 3 x USB 2.0 connectors
- 6 x Serial ATA III connectors
- 1 x Serial ATA II connector
- 2 x IEEE1394 connectors
- 1 x ATA133 HD connector
- 1 x Serial port connector
- 1 x Power button
- 1 x Reset button
- 1 x OC Dial button
- 1 x OC Dial knob
- 1 x Green Power button
- 1 x Debug LED button
- 1 x Clear CMOS jumper
- 1 x SPDIF-out connector
- 1 x TPM module connector
Back Panel I/O Ports
- 1 x PS/2 Keyboard port
- 1 x PS/2 Mouse port
- 1 x Claer CMOS button
- 1 x Coaxial SPDIF-out
- 1 x Optical SPDIF-out
- 5 x USB 2.0 ports
- 2 x USB 3.0 ports (blue)
- 1 x eSATA / USB 2.0 Combo port
- 2 x RJ45 LAN Jacks
- 1 x 6 in 1 audio jack
Dimension
• 24.5cm(L) x 30.5cm(W) ATX Form Factor
Mounting
• 9 mounting holes.
Testberichte/Reviews/Homepage:
MSI-TV
MSI Review
Homepage MSI
Heise.de: (zurzeit ab ca. 148€ zuhaben.
http://preisvergleich.hardwareluxx.de/a527581.html
Bilder.
Bitte Verschieben.
Kann im Sammelthread keinen Beitrag schreiben.
Danke:bigok:
Danke für die Erstellung dieses Sammelthreads. Er wird aber nicht sofort ins entsprechende Unterforum verschoben. Vorher muss der 1. Beitrag noch weiter ausgebaut werden, der Sammelthread generell von den Usern erfasst und effektiv genutzt werden.:wink:
Edit: Der Sammelthread ist nun auch in der Liste.
ich überlege mir star kdas board zu nehmen, auch aufgrund der guten verteilung der beiden X16 steckplätze zum nutzen mit 2 luftgekühlen grakas.
Wer hat den das baord und kann was über kühlerkompatibilitäten sagen, evtl ekl nordwand ?
Hab das Board, funktioniert super. Als Kühler hab ich nen Mugen2 drauf, der passt ohne probleme.
Fehler, die mir bis jetzt aufgefallen sind, den RAM kann man nicht auf 1600Mhz cl7 laufen lassen, warum auch immer, habe G.skill ecos und bekomme sie ab Biosversion 1.4 nicht mehr mit oben genannten settings zum laufen. Im MSI Forum haben andere auch probleme mit OCZ, also liegt es nicht umbedingt an den Ecos.
Und was bei mir noch eine kleine Macke ist, die mich aber nicht sonderlich stört, die Power LED leuchtet, wenn man den Rechner runterfährt und dieser davor im standby war.
Ich habe das Board seit 2 Wochen im Einsatz funktioniert stabil und einwandtfrei.
Als CPU Lüfter habe ich einen EKL Matterhorn verbaut. Den Seitenlüfter habe ich an der Rückseite des Kühlers befestigt. An der Voderseite ging es nicht da der Headspread meines Corsair XMS3 DHX zu lang ist. Im MSI Forum ist die BIOS version 1.81 Beta aufgetaucht mit einen Patch für OCZ und Kingsten Speicher.
Währe gut zu wissen ob sich Speicher von OCZ mit diesem Bios problemlos auch mit 1600 mhz Betreiben lassen. Da ich mich auch für einen OCZ Speicher interesiere.
hey danke schonma für deine meldung.
mich würde vor allem die kühlermontage interessieren, ging das trotz der heatpipe problemlos ? möchte nämlcih die ekl nordwand installieren und das teil ist ja sehr ähnlich, mit speicher ohne dickem kühler, sprich wo nix oben rausragt, lässt sich der lüfter auch rechts am kühler montieren oder ?
Der Kühlkörper von Matterhorn ließ sich bei mir problemlos installieren. Der beigelegte Lüfter kann sowohl links als auch rechts vom Kühlkörper installiert werden. Auch die Verwendung eines zweiten Lüfters ist optionall möglich falls der Ramspeicher die richtige Höhe hat (ohne Headpipe).
Bei der Nordwand ist es ähnlich. Bei der Montage dürfte es keine Probleme geben.
was mich im speziellen interessiert wäre ob die federschrauben des matterhorn trotz heatpipe gut zugänglich und festziehbar sind, hatte damals auf meinen GA 790FX da massive probleme dranzukommen..
welche cpu nutzt du, übertakteste ?
Das Festziehen der Federschrauben ist beim Matterhorn kein Problem. Die Heatpipes sind von der Zugänglichkeit nicht im Weg.
Als CPU habe ich einen Phenom X4 965 mit 3,4 Ghz. Ich habe sie auch schon mit 3,8 Ghz stabil am Laufen gehabt. Höhere Werte habe ich noch nicht getestet.
welche graka haste denn ? wenn die im 2ten echten X16 slot ist, also der 3te, passt dann noch das sata kabel in den einzelnen sata anschluss ?
Ich habe eine Palit Nvidia 460 GTX am 2ten Pcie x16 verbaut. Die Karte endet mit einer Länge von 19 cm etwa in der Mitte des Kühlkörpers der South Bridge.
Der JMicron Sata Anschluß ist da noch weit entfernt.
nunja die karte is auch kurz, meine is länger als mein X85 UD7 ,welches sicher nicht schmaler als das is, naja schade das wenns schon das einzige board ist wo die X16er 2 slots auseinander sind, dann hier im detail gepatzt wurde...
haste im ersten slot ne längere karte und könntest ma testen ? kommt mir vor als wär der sata anschluss leicht überm 2ten 16 lanes X16 slot
Der Sata Anschluß befindet sich zwischen denn 3 und 4 PCIe X8. Auch mit einer längeren Karte am 2ten PCIe X16 dürfte die Verwendung des JMicron Sata Anschlußen möglich sein.
Ich habe mir das Brett vor ca. ne Woche auch zugelegt, bin nicht 100% zufrieden.
Der ( blaue Sata ) Anschluss wird auf jeden Fall von überlangen Grakas verdeckt, zumindest von meiner 5870 ist das der Fall wenn sie im mittleren PCIx Slot steckt.
Bei den oberen und unteren beiden sollte es aber kein Problem sein.
Meinen OCZ Speicher musste ich leider auch von Hand auf 1600 einstellen, hatte mir extra die AMD Edition gekauft um ( sicher ) zu gehen, Tja hat nicht so geklappt wie ich dachte, ( Bios 1.60 )
Ich habe eine Frage , Hat jemand den normalen PCI Slot im Gebrauch ? Ich wollte da eigentlich meine Creative Soundkarte betreiben, die wurde aber gar nicht erkannt ???
Das ist was mich imo am meisten stört .
Der vierte (also vorletzte) ! und erste X16 slots sind mit 16 lanes angebunden, soltlest die graka also darein stecken sonst haste deutliche leistungsverlsute, kannste das dannma wieder testen ? is nat klar das die xfi nich mehr passt dann, dann musse eben in den ersten oder fals crossfire ne xfi pcie, her (wie bei mir)
Wäre dir sehr sehr dankbar wennde das mim 4. X16 slot testen könntest und ob dann der sata anschluss benutzbar ist
wegen dem ram, evtl ma bios 1,7 getestet ? weche cpu nutzte ? wär mir eigtl egal ich stell ram eh immer von hand ein...
Das neuste Bios ist ein beta BIOS 1.8 bei dem unteranderem die unterstützung von OCZ und kingston Speicher verbessert wurde.
Siehe MSI-Forum
Ja es geht , hab die Graka probeweise umgesteckt und nen Sata Kabel hineingesteckt.
Beim 1.70 Bios musste ich nach dem Update die Rams auch wieder von Hand einstellen.
Mal abwarten, das 1.8 scheint viel versprechend, ich warte aber noch auf eine Final Version.
Die Einstellung von Hand wäre mir eigentlich egal gewesen, nun habe ich aber eine AMD Black Edition von den Rams, und da hatte ich eigentlich erwartet das es schon automatisch richtig erkannt wird. Beim 790 war das ja auch so, und für den waren diese Rams ja eigentlich zertifiziert .
Wegen der Soundkarte, hab die Graka im obersten Slot, und es wundert mich halt das sie nicht erkannt wird, werde nach dem 1.70 Bios update heute Abend nochmal Testen ob sich nun was regt im pci Slot.
ich würd einfach nochne karte im obersten slot testen, kannja sein das der kaputt ist, nud dann eben zurück damit, aber falsde die vollen 16 lanes nutzen willst und der erste slot nich geht musste den 4ten nutzen...
siehe hier, 2. absatz
MSI 890FXA-GD70 Mainboard : Ausstattung - Review Hartware.net
danke fürs testen ;)
welche cpu nutzt du ? wird sie übertaktet ?
ich überlege mir ocz ram zu holen, aber sollja probs geben ? glecih 4 riegel, ddr3 1333 cl7
also ich habe den Ram hier
http://preisvergleich.hardwareluxx.de/a471247.html
nur ist das PCB leider grün und nicht schwarz wie auf dem Bild, war eigentlich auch mit ein Kaufgrund von mir. Aber wenn die Dinger stecken sieht man das eh nicht mehr.
Die Rams funktionieren nur wurden sie halt nicht gleich erkannt was ich aber auf das Bios vom MB schiebe. Nachdem sie von Hand eingestellt wurden läuft alles normal, nur bei AMD Edition hätte man eigentlich etwas mehr erwarten können denke ich.
Mein System steht eigentlich im Signaturbild von wegen CPU 955 BE , der wurde richtig erkannt und macht was er soll, OC steht erst mal nicht an.
Sondkarte wird mit Bios 1.70 im Pci Slot leider immernoch nicht erkannt. Win7 findet bei der Hardwaresuche einfach nichts. Onboarssound hatte ich auch deaktiviert. Auch wenn ich den Creative Treiber installieren will bricht er ab und sagt es wäre keine Hardware vorhanden. Ich teste mal eine ander PCI Karte, hab noch ne USB 2 Karte ob die gefunden wird.
Karte für USB wird gefunden, sagt win, nur nutzen kann ich sie leider nicht lol . Nach dem Neustart ist es als ob sie nicht da wäre . Auch ein USB Stick wird damit nicht erkannt der über onboard läuft ( Nicht mal ne led blinkt ???)
Funktioniert der bei euch normal, hat den jemand im Gebrauch ?
Ich frag mal bei MSI ob die da was wissen, kommt mir seltsam vor, auch im BIOS habe ich nichts gesehen von wegen das ich den extra aktivieren muss oder so.
---------- Beitrag hinzugefügt um 21:18 ---------- Vorheriger Beitrag war um 17:27 ----------
Hat sich erledigt mit dem PCI Slot, anscheinend hat meine Soundkarte einen weg, beide PCs möchten nicht mehr mit ihr Booten und die USB2 Karte wird nun im Hardwaremanger angezeigt es gibt blos keine aktuellen Treiber für ihren Via Chipsatz.
Egal Hauptsache das schöne neue Brett ist gesund.
Wollts mir auch holn, aber in den letzten tagen is der preis gestiegen statt gefallen, von 138 auf 148... Mist
Sent from my iPhone using Hardwareluxx
Habs mir nun bestellt, zus mit 2 riegeln corsair xms3 1600 cl9 mit je 4 gig, also 8 gig insgesamt. Mittlerweile sind 2x4 gig genauso teuer wie 4x2 gig und man hat noch 2 plAetze frei fuer spaeter...
Drauf kommt nen 1090t mit ekl nordwand, hoffe das funzt mit den 4 ghz...
Schade das wohl so wenige das board haben wie man an der resonanz hier sieht, die anordnung der x16 steckplatze beim gigabyte 890fx UD5 (1. Und 3. Slot) und damit kuehlungs und passprobleme bei 2 dualslot grakas scheint wenigen aufzufallen..
Ja ich habe auch lange warten müssen bis ein Sammethread für das Board kam, auch beim Vorgängermodell ist relativ wenig los gewesen. Was eigentlich für das Board sprechen sollte da es damit wenig Probleme gibt hehehe.
Ich habe mir das Board aber hauptsächlich wegen dem gutem Layout und der Optik gekauft, wobei ich die beim Vorgänger eine Tick besser fand ( Sata slots ) aber dann haben mich die Neuen Features wie USB3 und Sata 3 dann doch zum 890 bewogen.
Ich habe 8 Gb Corsair XMS3 PC3-12800U CL7-8-7-20 1600 Mhz verbaut.
Die 1600 Mhz und die Cl7 werte laufen über XMP. Wie kann ich den Speicher richtig einstellen bzw. XMp aktivieren.
nochma zu mitlesen, XMP is von Intel ,heisst Intel Extreme Memory Profile, das gibts nich bei amd, da heisst das Black Edition Ready
du musst somit die werte im bios wohl einzeln einstellen wenn das board sie nicht korrekt erkannt hat
http://geizhals.at/deutschland/a513031.html
das INTEL Extreme Memory Profile steht nicht umsonst bei der Produktbeschreibung ;) der corsair speicher ist nurn beispiel, ist bei jedem so
Ja da muss ich GA Thrawn bestätigen mit dem Speicher. Du wirst wohl von Hand die im BIOS machen müssen. Aber mach dir nichst Daraus ich habe eine AMD Edition und die musste ich auch von Hand einstellen. Mit dem Aktuellen Beta Bios soll das aber wohl erkannt werden, hab es aber noch nicht getestet.
Habe das GD70 seit ~April, wird aber nicht anders verwendet als wie im Bild, gut isoliert :)
@ octacore
Schaut so aus als hättest du was größeres damit geplant.
Welche Erkenntnisse Hast du den nun aus dem Board erworben ?
