[Sammelthread] MSI 890FXA GD-70 (890fx)
MSI 890FX GD-70 Sammelthread
________________________________________________
Technische Daten
________________________________________________​
* Hersteller: MSI
* CPU-Sockel: Sockel AM3
* Formfaktor: ATX
* Mainboard Chipsatz: AMD 890FX (RD890)
* System-Bus (FSB / HT / QPI / DMI): 5.2 GT/s HT
* Grafikkarten Bus: PCI Express 2.0
* Arbeitsspeicher Typ: DDR3-SDRAM 1866MHz (PC3-15000)
* Anzahl der S-ATA Anschlüsse: 7
* Onboard Audiokanäle: 7.1
* Netzwerk Schnittstellen 2x
* Multi-GPU Unterstützung: CrossFire, CrossFireX
* Passive Kühlung: Ja
Weiter Informationen
Superb Stability: Military Class Components
OC Genie: Easy Overclocking Technology
Unlock CPU Core: Unlock hidden CPU core and potential
DrMOS: Best power efficiency
Support USB 3.0 AND SATA 6Gb/s
Lossless 24bit/192kHz HD Audio
CPU
• 64bit AMD® Phenom II X6/X4/X3/X2, Athlon II X4/X3/X2 and Sempron CPU.
Please refer to CPU Support for compatible CPU; the above description is for reference only.
140W Support
* Supports AMD high performance 140W CPUs
* Reserve the ability for future CPU upgrade
* To fully release the power of AMD CPUs
Hyper Transport Bus
• HyperTransport 3.0 supporting speed up to 5200MT/s
Chipset
• AMD® 890FX and SB850 Chipset
Main Memory
• Supports four unbuffered DIMM of 1.5 Volt DDR3 800/1066/1333/1600*/1800*/2133* (OC) SDRAM, 16GB Max
Slots
• 4 PCI Express 2.0 slots with x16 operation (PCI Express Bus SPEC V2.0 compliant)
• 1 PCI EXpress 2.0 slot (PCI_E4) with x4 operation (PCI Express Bus SPEC V2.0 compliant)
• 1 PCI Express 2.0 x1 slot
• 1 PCI slot, support 3.3V/ 5V PCI bus Interface.
On-Board IDE
• One IDE port by JMicron® JMB363
- Supports Ultra DMA 66/100/133 mode
- Supports PIO, Bus Master operation mode
- Can connect up to two IDE devices
On-Board SATA
• 6 SATA III (1~6) ports by AMD® SB850
- Supports storage and data transfers at up to 6Gb/s
• 1 SATA II (SATA7) port by JMicron® JMB363
• 1 eSATA II / USB Combo port by JMicron® JMB363
RAID Function
- SATA III 1~6 support RAID 0, 1, 5, 10 mode by AMD® SB850
Audio
• Chipset integrated by Realtek® ALC889/ALC892
- True Blu-ray Audio Support
- Flexible 8-channel audio with jack sensing
- Compliant with Azalia 1.0 Spec
LAN
• Realtek PCI-E GbLAN controller 8111DL
- Integrated Fast Ethernet MAC and PHY in single chip
- Supports 10Mb/s, 100Mb/s and 1000Mb/s
- Compliance with PCI-Express Bus specification v1.0a
IEEE1394 / FireWire
• VIA® VT6315N chipset
- Supports up to two 1394 ports. (pinheader x2)
- Transfer rate is up to 400Mbps.
Internal I/O Connectors
- 1 x ATX 24-pin power connector
- 1 x ATX 8-pin 12V CPU power connector
- CPU x 1 / System x 4 FAN connectors
- 1 x Front panel audio connector
- 1 x Front panel connector
- 1 x Chassis intrusion switch connector
- 3 x USB 2.0 connectors
- 6 x Serial ATA III connectors
- 1 x Serial ATA II connector
- 2 x IEEE1394 connectors
- 1 x ATA133 HD connector
- 1 x Serial port connector
- 1 x Power button
- 1 x Reset button
- 1 x OC Dial button
- 1 x OC Dial knob
- 1 x Green Power button
- 1 x Debug LED button
- 1 x Clear CMOS jumper
- 1 x SPDIF-out connector
- 1 x TPM module connector
Back Panel I/O Ports
- 1 x PS/2 Keyboard port
- 1 x PS/2 Mouse port
- 1 x Claer CMOS button
- 1 x Coaxial SPDIF-out
- 1 x Optical SPDIF-out
- 5 x USB 2.0 ports
- 2 x USB 3.0 ports (blue)
- 1 x eSATA / USB 2.0 Combo port
- 2 x RJ45 LAN Jacks
- 1 x 6 in 1 audio jack
Dimension
• 24.5cm(L) x 30.5cm(W) ATX Form Factor
Mounting
• 9 mounting holes.
Testberichte/Reviews/Homepage:
MSI-TV
MSI Review
Homepage MSI
Heise.de: (zurzeit ab ca. 148€ zuhaben.
http://preisvergleich.hardwareluxx.de/a527581.html
Bilder.
Bitte Verschieben.
Kann im Sammelthread keinen Beitrag schreiben.
Danke:bigok:
Hi
wollte mal Fragen, wie bei euch die Spannungswerte sind.
Hier ein Screenshot aus AIDA.
Ist die 5V Spannung zu niedrig ? Wird diese für die Spannungsversorgung der USB Geräte verwendet???
Falls ihr auch eure AIDA oder Everest Werte Posten könntet hätte man einen schönen Vergleich in diesem Sammelthread!
xmenbabis
Ich hab es gerade mal drauf gemacht, werde berichten wenn mir was auffällt.
habs nu fast 1 jahr laufen mit 1.7 und muss sagen das Mobo ist absolut TOP!!!
Stabil wie ein panzer.Mit 4 Festplatten/2ssd^s mit jeweils XP-x64+Win7-x64-ultimate.
like no other!
greezz vom happy seltsam
like no other!
Meins zwar erst seit november aber den rest kann ich nur bestätigen, hatte viele boards, so zufrieden war ich noch nie !
Dazu muss ich noch anmerken das meine MSI R5870Lightning sich wirklich sehr gut mit dem mobo verträgt.
Wenn mann saturnware scheut und sich selbst was geiles zusammenschraubt,ist es ja Lotto ein System zu finden was miteinander Harmoniert.
Nur Harmonie im Sys zaubert ein Lächeln ins Gesicht des Users.
Nur mein ram is noch nich nach meinem Schönheitssinn..,.
Ich will nich meckern..))Im Glad)))
Happy seltsam
Happy seltsam
och mein ram passt farblich^^ und wiede an meiner sig siehst funzts auch mit nvidia grakas ohne probs ;)
Ich hatte fast immer Corsair Rams,wuste mit dem neuen Mobo nich genau was nun.
MMM ..dachte der mushkin wäre supi.isser auch aber er erreicht nicht seine timings(((
Da mein Sys supi geht,will ich auch nich den Ram auswechseln gegen Corsair.....
Ich warte auf den Bulldozzer und die neuen Mobos)))
Take Care,No Stress))seltsam
laut msi wird der bulldozer auf unserem hammerboard laufen, also warum neues ? ,meine 2x 4gb corsair laufen sogar auf CL8 statt 9 (werden als CL9 verkauft) und 1T !!!
abend,
ich habe mir das brett auch bestellt. mit 2 mal 4 gb corsair speicher.
find ich super das das brett auch mit den BD laufen wird.
p.s ich will einen x3 zum x4 freischalten, welches bios waere da das beste. oder ist das egal?
Das bios sollte dafür keine Rolle spielen. Höchstens wenn es eine ganz aktuelle CPU wäre, MSI wirbt mit ja dem Feature das man die CPU unlocken kann und Im Bios ist auch eine Rubrik dafür. Das es klappt ist aber nie 100% sicher das es nicht mit allen CPUs klappt den vierten Kern freizuschalten. Ich fänd es im übrigen cool von dir wenn du über deine Erfahrungen hier berichten würdest.
Das Aktuellste Bios ist das 1.8 was bei mir ohne Probleme läuft. Das 1.7 ist gut und sollte wenn es schon installiert ist reichen.
abend,
haste den 1600mhz cl9 bestellt ? hab den auch, läuft mit meinem 1090t auf cl8 und 1t
bios würd ich 1,7 lassen wenns drauf ist, wennsn älteres is einfach gleich 1,8 flashen
Es gibt mal wieder ein Beta Bios 191
BIOS-Versionen 890FXA-GD70 (MS-7640) - Seite 7 - MOD- und Beta-BIOS Sektion - MSI Forum
Desweitern habe ich im MSI Forum mal angefragt was die Debug LED codes eigentlich aussagen da das Handbuch da nicht viel Aussage gibt.
Innerhalb sehr kurzer zeit wurde mir die Led Debug Liste für das AMI Bios zur Verfügung gestellt. Sehr Vorbildlich wie ich finde.
Das PDF kann man sich ja mal runterladen ;-)
http://www.msi-forum.de/index.php?page=Thread&threadID=98801
Jo das Hammer, Bulli auf dem Board, geil!!!
Und leider fail für AMD, warum machen sie das nicht gleich offiziell.
1. Geht so Glaubwürdigkeit verloren, 2. Könnten viel mehr potezielle Kunden einen neuen Bulli kaufen.
Viele werden es sicher nciht tun, weil sie einfach ihr System im ganzen erhalten möchten. Finde ich etwas kurzsichtig von AMD.
Gleichzeitig find ich es ziemlich Klasse für die entsprechendn AM³ Boards.
auf was beziehste das denn ? an nem bulli wär ich auch interessiert :hail:
bisher hab ich nur ne ankündigung gelesen, gibts schon nen bios ?
Ich würde auch gerne wissen was der SeniorChef meint und ob der Bulli überhaupt im vollen Umfang unterstützt wird.
abend zusammen,
ich bin vom msi begeistert.
system
gd70
8 gb corsair 1600 @ 8-8-8-24 mit 1.5 volt.
x3 720 @ x4 mit 3800mhz bei 1,45 vcore <--- wird mit wasser gekuehlt.
bios 1.8
es wurde alles richtig erkannt,
das brett ist sehr stabil, und die verarbeitung ist top. das einzige was mich stoert ist die nb temp. da werde ich noch die wlp wechseln.
was ich richtig geil von msi finde,sind die drei jahre garantie.
bin mit dem system zufrieden, jez muss nur noch der bulli kommen und dann geht es richtig ab.
abend zusammen,
system
gd70
bios 1.8
is dein corsair ram auch eigtl cl9 und 2x 4gb ? meiner auch, packt das auch und sogar mit 1T !
fals es mim bulli probs gibt, der X6 geht auch wie die hölle ;)
@ xxxAMD64Bitxxx freut mich zu hören das alles so gut geklappt hat, und das deine CPU brav das beste aus sich raus holen lässt :-). Welches BIOS war bei dir vorinstalliert ,würde mich mal interessieren ?
das sind meine speicher.
Corsair Vengeance blau DIMM Kit 8GB PC3-12800U CL9-9-9-24 (DDR3-1600) (CMZ8GX3M2A1600C9B) | Geizhals.at Deutschland
bin mal gespannt wie die in sachen oc gehn.
thema x6 ,klar sind die auch gut.
kann ich dir leider nicht sagen, habe sofort auf 1.8 geflasht.
hab deiselben werte ausser das meine eben die xms 3 sind, schwarz passt besser zum board und der heatspreader ist nicht höher als der ram selber, was wiederrum für die lukü gut is
ich finde das die blauen ram´s richtig gut auf dem brett aussehen.
und bei mir war ja die hoehe egal da ich ne wakü habe.
joa bei wakü is es egal, das board is halt fast nur schwarz da sah ichs eben so^^
finds schade das für dualchannel die 2 linken bänke belegt werden MÜSSEN, sieht man wegen des cpu kühlers wenig vom ram..
läuft dein ram auch mit 1T primstable ?
Als ich das mobo es erste mal auspackte dachte ich nur wow, ganz ehrlich, rein optsich gehts kaum stylisher..
hi,
zu prime kann ich nix sagen, ich teste nur mit linx.
und da laufen sie im moment 1600mhz @8-8-8-24 T1 mit 1,5 vdimm.
