[Sammelthread] MSI 890FXA GD-70 (890fx)
MSI 890FX GD-70 Sammelthread
________________________________________________
Technische Daten
________________________________________________​
* Hersteller: MSI
* CPU-Sockel: Sockel AM3
* Formfaktor: ATX
* Mainboard Chipsatz: AMD 890FX (RD890)
* System-Bus (FSB / HT / QPI / DMI): 5.2 GT/s HT
* Grafikkarten Bus: PCI Express 2.0
* Arbeitsspeicher Typ: DDR3-SDRAM 1866MHz (PC3-15000)
* Anzahl der S-ATA Anschlüsse: 7
* Onboard Audiokanäle: 7.1
* Netzwerk Schnittstellen 2x
* Multi-GPU Unterstützung: CrossFire, CrossFireX
* Passive Kühlung: Ja
Weiter Informationen
Superb Stability: Military Class Components
OC Genie: Easy Overclocking Technology
Unlock CPU Core: Unlock hidden CPU core and potential
DrMOS: Best power efficiency
Support USB 3.0 AND SATA 6Gb/s
Lossless 24bit/192kHz HD Audio
CPU
• 64bit AMD® Phenom II X6/X4/X3/X2, Athlon II X4/X3/X2 and Sempron CPU.
Please refer to CPU Support for compatible CPU; the above description is for reference only.
140W Support
* Supports AMD high performance 140W CPUs
* Reserve the ability for future CPU upgrade
* To fully release the power of AMD CPUs
Hyper Transport Bus
• HyperTransport 3.0 supporting speed up to 5200MT/s
Chipset
• AMD® 890FX and SB850 Chipset
Main Memory
• Supports four unbuffered DIMM of 1.5 Volt DDR3 800/1066/1333/1600*/1800*/2133* (OC) SDRAM, 16GB Max
Slots
• 4 PCI Express 2.0 slots with x16 operation (PCI Express Bus SPEC V2.0 compliant)
• 1 PCI EXpress 2.0 slot (PCI_E4) with x4 operation (PCI Express Bus SPEC V2.0 compliant)
• 1 PCI Express 2.0 x1 slot
• 1 PCI slot, support 3.3V/ 5V PCI bus Interface.
On-Board IDE
• One IDE port by JMicron® JMB363
- Supports Ultra DMA 66/100/133 mode
- Supports PIO, Bus Master operation mode
- Can connect up to two IDE devices
On-Board SATA
• 6 SATA III (1~6) ports by AMD® SB850
- Supports storage and data transfers at up to 6Gb/s
• 1 SATA II (SATA7) port by JMicron® JMB363
• 1 eSATA II / USB Combo port by JMicron® JMB363
RAID Function
- SATA III 1~6 support RAID 0, 1, 5, 10 mode by AMD® SB850
Audio
• Chipset integrated by Realtek® ALC889/ALC892
- True Blu-ray Audio Support
- Flexible 8-channel audio with jack sensing
- Compliant with Azalia 1.0 Spec
LAN
• Realtek PCI-E GbLAN controller 8111DL
- Integrated Fast Ethernet MAC and PHY in single chip
- Supports 10Mb/s, 100Mb/s and 1000Mb/s
- Compliance with PCI-Express Bus specification v1.0a
IEEE1394 / FireWire
• VIA® VT6315N chipset
- Supports up to two 1394 ports. (pinheader x2)
- Transfer rate is up to 400Mbps.
Internal I/O Connectors
- 1 x ATX 24-pin power connector
- 1 x ATX 8-pin 12V CPU power connector
- CPU x 1 / System x 4 FAN connectors
- 1 x Front panel audio connector
- 1 x Front panel connector
- 1 x Chassis intrusion switch connector
- 3 x USB 2.0 connectors
- 6 x Serial ATA III connectors
- 1 x Serial ATA II connector
- 2 x IEEE1394 connectors
- 1 x ATA133 HD connector
- 1 x Serial port connector
- 1 x Power button
- 1 x Reset button
- 1 x OC Dial button
- 1 x OC Dial knob
- 1 x Green Power button
- 1 x Debug LED button
- 1 x Clear CMOS jumper
- 1 x SPDIF-out connector
- 1 x TPM module connector
Back Panel I/O Ports
- 1 x PS/2 Keyboard port
- 1 x PS/2 Mouse port
- 1 x Claer CMOS button
- 1 x Coaxial SPDIF-out
- 1 x Optical SPDIF-out
- 5 x USB 2.0 ports
- 2 x USB 3.0 ports (blue)
- 1 x eSATA / USB 2.0 Combo port
- 2 x RJ45 LAN Jacks
- 1 x 6 in 1 audio jack
Dimension
• 24.5cm(L) x 30.5cm(W) ATX Form Factor
Mounting
• 9 mounting holes.
Testberichte/Reviews/Homepage:
MSI-TV
MSI Review
Homepage MSI
Heise.de: (zurzeit ab ca. 148€ zuhaben.
http://preisvergleich.hardwareluxx.de/a527581.html
Bilder.
Bitte Verschieben.
Kann im Sammelthread keinen Beitrag schreiben.
Danke:bigok:
ich geb dir zu 100 prozent recht mit linx. nur habe ich im moment keine 24std zeit um prime laufen zu lassen.
deshalb linx mit 25loops.
ich finde die blauen speicher passen top zum nb - kuehler.
joa bei mir halt kein problem, prime vor der arbeit an, läufts danach noch isses stable^^ passt der ram denn farblich, sieht bisserl heller aus das ramblau ? oder täuscht es ?
Bin so zufrieden mit dem teil das ich, sollte der bulli nich gehen, das tei ltrotzdem erstmal min bis zum ivy bridge bzw sockel 1366 nachfolger, behalte, brauch ja eigtl nich mehr speed, einzig die hw sucht sagt immer kauf was :fresse2::rolleyes:
is deine sig nichmehr aktuell oder hast du 2 sys ? hatte das ud7 auchma, habs durch das amd sys ersetzt, war nichso zufrieden und mein I7 920 wurde vielzu heiss unter luft und ging nich gut...
ja is a bissl heller, muss man schon genau hinschaun.
und zu sys profil. das habe ich verkauft, und bin etz wieda zu amd.
mein x4 langt mir im moment fuer alles was ich mache, oder besser gesagt solange bis der bulli kommt. und sollte der nicht auf dem msi laufen. wird es ein x6 da die dann noch a bissl billiger werden.
dann musste ma die sig undso ändern^^
aber die richtige entscheidung, behalte meinen X6 auch wenn der bulli nich ,geht, die sind so genial einfach zu ocen (black edition) und gehen auch hoch, ne wahre wonne
die gtx 470 haste noch ?
nein die 470 habe ich auch nicht mehr, da bin ich auch wieda zu amd :-)
und zwar ne xfx 6950 mit shader unlock @ 970mhz gpu und speicher 1400 mhz.
die karte wird mit einem ac xtreme plus gekuehlt. die werte sind traumhaft max gpu temp
60° @ ultra silent.
---------- Beitrag hinzugefügt um 23:33 ---------- Vorheriger Beitrag war um 23:27 ----------
ach es gibt ja scho wieda ein neues beta bios.
BIOS-Versionen 890FXA-GD70 (MS-7640) - Seite 7 - MOD- und Beta-BIOS Sektion - MSI Forum
version 1.92
Download-Klick
60° @ ultra silent.
version 1.92
nene amd karte kmomt mir so schnel lnich rein ,dafür bin ich seit langem vielzu zufrieden mit den grünen :)
ja war mit der 470 auch zufrieden, aber ich wollte das freischalten mal testen.
und ich kann mich echt nicht beschweren fuer das geld die leistung was will man mehr.
gut dei monster geht noch geiler.
joa jeder wie ers mag, mich halten halt uach die treibr von amd ab^^
geil bulldozer bios für unser board is raus
Details zu MSIs
gigabyte betreibt ja kundenverarsche im grossen stil, nur neue boards sind bulldozer ready...
hi,
bin ganz deiner meinung, besser geht es nicht.
na dann kann der gute ja anrollen :-)
Hardwareluxx - MSI äußert sich detailliert zu Bulldozer-fähigen AM3-Mainboards
noch mal ne Bestätigung seitens HWL zu dem Buli auf unserem Brett.
Sehr erfreulich das ganze.
Da freut man sich doch das man die Paar Euro mehr in das Mainboard gesteckt hat.
ich spar sowieso lieber an anderen dingen wie am mobo, mmn ist es die wichtigste pc komponente
frag mich nur warum hier immernoch 1,7 das neueste bios is ? zumindest 1,8 sollte doch schno da sein..
http://de.msi.com/index.php?func=downloaddetail&type=bios&maincat_no=1&prod_no=2025
ich habe mit dem neuen beta bios ein prob.
es laeuft eigentlich alles super, bis auf das das meine graka egal in welchen slot is steckt nur x8 fach laeuft????
der erste und der vierte sollten doch mit x16 fach laufen ?????
kann mir da einer weiter helfen.
dankeschoen
dankeschoen
ich installiere aus prinzip keine betabiose und treiber, eben genau deshalb...
am besten 1,8 oder 1,7 installiern und aufn neues finalbios warten, bullis gibts eh nochnet
abend,
ja geht wieder alles, das war aber auch mein letzter beta ausflug.
muss wirklich am bios liegen. da es unterem 1.7 wieda normal laeuft.
morgen kommen zwei neue cpu zum testen.
x6 1090T 1021 FPMW
x6 1100T da weiss ich leider den batch noch nicht.
bin ja mal gespannt wie die beiden rennen.
abend,
x6 1090T 1021 FPMW
wennde einen hast der unter luft min 4,4 ghz packt und abgeben wilslt ;)
scheisse das die x6 defekte temp densoren haben, doer wirds bei dir richtig angezeigt ? ich geh nich höher weil bei mir die temp sehr niedrig angezeigt wird
mach ich :d
aber 1090 hat schon einen schoenen batch. in der oc liste platz eins. lecker
hi GA,
die kommen doch erst morgen, den batch weiss ich vom verkaeufer da ich den kenne. :d
JoHo is das sicher das die bullis auf diesem unserem Geilen Mobo laufen?
mmmm..dazu muss dan aba sicher ein anderes Bios druff((
Bin mit dem 1.7 immer noch Glücklich))
mit meinem Ganzen sys im glad dank dieses supi Herzstück)))
greezz vom happy seltsam
das mit dem bulli ist zu 100 prozent sicher.
bios flash is doch kein ding.
dafuer rockt hoffendlich der bulli richtig.
Der Bulli wird sicher generell laufen, aber ich weiß immer noch nicht ob er wirklich zu 100% mit allen Features unterstützt wird. Aber da MSI das iMO so anpreist scheint es so zu werden. Ich traue der Sache aber nicht zu 100 % Die wollen ja auch die AM3+ Bretter verkaufen, und für die wäre irgendwo kein großer Kaufanreiz wenn der Bulli von den älteren Brettern voll unterstützt wird. Mal abwarten .
Habe da noch mal eine Frage bzgl. OC:
Meine CPU-NB habe ich auf 2.800 MHz übertaktet und dazu die Spannung selbiger erhöht. Ich habe aber zusätzlich die Spannung der NB ebenfalls erhöht und dadurch zwangsläufig hohe NB-Temps. Da ich gerade keine Lust habe das auszutesten, hätte ich gerne gewusst, ob ich die Spannung der NB unbedingt erhöhen muss? Wie habt Ihr es gemacht?
