Daffy_D
MSI P965 Platinum
Chipset
• Supports Socket 775 for Intel® Pentium 4 3xx, 5xx, 6xx, 8xx, 9xx, Core 2 Duo and Pentium 4 Extreme Edition processors.
• Supports FSB 1066/800/533 MHz
• Supports EIST technology
• Supports Intel® Hyper-Threading technology.
• Supports Intel® Dual Core Technology to 800 MHz and up
Main Memory
• Supports four unbuffered DIMM of 1.8 Volt DDRII SDRAM
• Supports up to 8GB memory size (DDRII 533/667).
• Supports up to 4GB memory size (DDRII 800).
• Supports dual channel DDRII memory architecture.
• Supports DDRII 533/667/800 memory interface.
Slots
• One PCI Express x16 slot. (supports PCI Express Bus specification v1.0a compliant)
• One PCI Express x4 slot. (The yellow one, support PCI Express Bus specification v1.0a compliant)
• Two PCI Express x1 slots. (support PCI Express Bus specification v1.0a compliant)
• Two 32-bit v2.3 master PCI bus slots. (support 3.3v/5v PCI bus interface)
On-Board IDE/SATA
• One Ultra DMA 66/100/133 IDE controller integrated in JMicron® JMB361.
- Supports PIO, Bus Master operation modes.
- Can connect up to two Ultra ATA drives.
• SATAII controller integrated in ICH8R/JMicron® JMB361
- Up to 300MB/sec transfer speed.
- Six SATAII ports by ICH8R.
- One SATAII port by JMicron® JMB361.
- Supports AHCI controller with SATA RAID 0, RAID 1, RAID 5 and RAID 10 (ICH8R).
Audio
• High Definition link controller integrated in Intel® ICH8R chip.
• Audio codec Realtek® 883.
- Compliant with Azalia 1.0 spec.
- Flexible 8-channel audio with jack sensing.
LAN
• Realtek® RTL8111B
- Supports 10/100/1000 Mb/s.
- PCI-Express interface.
- Supports ACPI Power Management.
IEEE1394
• VIA® 6308 chipset
- Supports up to two 1394 ports. (Rear panel x1, front x1)
- Transfer rate is up to 400Mbps.
Internal I/O Connectors
- ATX 24-Pin power connector
- 4-pin ATX 12V power connector
- CPU / System / Power / NB FAN connectors
- CD-in connector
- Clear CMOS jumper
- Chassis intrusion switch connector
- IrDA infrared module header
- Serial port connector
- Front panel audio connector
- Front panel connector
- 3 x USB 2.0 connector support additional 6 ports
- 1 x Floppy disk drive connector
- 7 x Serial ATAII connectors
- 1 x ATA133 connector
- 1 x IEEE1394 connector support additional 1 port
- 1 x D-Bracket 2 pinheader
Back Panel I/O Ports
- 1 x Parallel port
- 1 x Serial port (COM 1)
- 1 x PS/2 keyboard
- 1 x PS/2 mouse
- 1 x Coaxial SPDIF out
- 1 x 6 in 1 audio jack (S/SPDIF out)
- 1 x IEEE1394 port
- 4 x USB 2.0 ports
- 1 x RJ45 LAN jack
BIOS
• The mainboard provides a Desktop Management Interface(DMI) function which records your mainboard specifications.
Dimension
• 30.5cm(L) x 24.5cm(W) ATX Form Factor
Mounting
• 9 mounting holes.
Preis: ~ 120,- Euro vgl. http://www.geizhals.at/deutschland/a207419.html
Direktlink zu MSI (BIOS, Manual etc.): http://www.msi.com.tw/program/products/mainboard/mbd/pro_mbd_detail.php?UID=745
Reviews: http://www.hexus.net/content/item.php?item=6702&page=1
