[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Absolut, gibt ja genug Auswahl. Position des 12 PIN Kabels gefällt mir bei der MSI sehr gut für den vertikalen Einbau.
Beste Grüße
Hatte 3 ASUS-Karten hier (TUF, TUF OC, STRIX) und alle hatten extremes Spulenfiepen, selbst bei niedrigen FPS.
Hab mir jetzt die PNY VERTO EPIC-X geholt und bin mehr als zufrieden. VIEL weniger Spulenfiepen und von der Kühlleistung+Lüfterlautstärke kommt sie fast an die Strix ran, obwohl sie zu den kleinen 4090 gehört.
Nachteile der PNY im Vergleich zur TUF und STRIX:
- PL lässt sich nicht anheben, was mir völlig egal ist
- nur 1x HDMI-Port
- Front aus Plastik
- Lüfter schalten nach Last erst bei 30/31°C ab (bei ASUS waren es glaub ich 40°C)
- nur ein BIOS, dafür mit einer perfekten Lüfterkurve
Gibt leider keine guten Reviews von der 4090. Techpowerup hat die 4080 getestet, und selbst die kommt sehr gut weg, hat dabei aber nicht mal eine Vapor Chamber. https://www.techpowerup.com/review/pny-geforce-rtx-4080-verto-epic-x-rgb-oc/37.html
@ssss
Sollte die auch so eine Randale machen wie meine TUF dann geht die zurück !
Ich sag jetzt aber erstmal alle guten Dinge sind 3 und hoffe das die nicht so aufdringlich wird.
Sollte es so sein dann ist das Kapitel Asus für mich abgeschlossen !
Die 4080 scheint sich nicht so besonders zu verkaufen, wen wunderts. Im Großhandel kriegt man karten ab 1271,- (netto 1068) gerade.
Schade, dass das bei der 4090 anders aussieht, da ist kaum was zu kriegen.
Bei LDLC ist jetzt gerade wieder ein Modell verfügbar, leider nicht mehr mit den 10%, code aber es gibt einen neuen für immerhin 6%:
Aber selbst mit Versand immer noch günstiger als alles in Deutschland und nah and der UVP von nVidias Karte selbst.
Oder ist Zotac Schrott? Dann stornier ich die wieder 🥴
doch klar geht GOODGAME aber nur auf der franz. Version der Seite
Bin äußerst zufrieden mit meiner Karte, kein Fiepen, Zierpen o.ä., läuft top !, u.a. 5 Jahre Garantie nach Registrierung
Top Kurs 1889,-
Ah Mist, jetzt hab ich schon bestellt :(
Konnte jetzt auch die alte Order nicht mehr canceln, kam bei der Telefonnummer da nicht durch. Sonst hätte ich neu bestellt. Naja, mit Versand ist der Unterschied auch "nur" 80€.
Wieso billig? Ich hatte auf meiner 3080 nen Bykski Block der gut gefunzt hat und dieser macht auch seinen Job. Kann natürlich sein, dass deiner fehlerhaft ist, kann dir aber bei jedem Hersteller passieren. Im Overclocker Forum meine ich war das, da ist einer da passen 1 - 2 Gewinde nicht mittig auf die Löcher der Karte, Phanteks Block. Und einer hatte bei einer Schraube gar keinen Abstandshalter mit Gewinde, musste einen von nem anderen Block montieren. Corsair hatte bei der letztzen Gen Probleme mit Wasseraustritt am Anschlussterminal. Mich stört eigentlich nur die Optik des Bykski-Blocks, gerade bei der 4090 weil die so breit ist und ich vertikal montieren musste. Ich überlege einen von EKWB zu ordern, mag die Optik, aber der Preis ist einfach etwas zu hoch. Vielleicht warte ich auch bis Alphacool den Block bringt. Der Granzon Block ist mega, aber mit 350€ auch mega teuer... und vom EKWB mit aktiver Backplate will ich garnicht reden, 399€ 🥴
Bei mir läuft der Bykski auch gut, https://www.3dmark.com/swst/38183 , 54 GPU im loop bei 100% PT unübertaktet, und habe nur einen Monsta Kühler extern, was ich gerne wissen würde ist, wo auf der Karte wird der HOTspot genau gemessen ?
Bzw. wo befindet der sich genau ?
Ich hoffe echt das ich dieses Mal glück habe !
Ich wollte sie von Anfang an haben die Strix immer Pech gehabt bis her !
Ich zieh es auch echt in Erwägung das erste Mal eine Karte auf Luft zu lassen !
Die Vorteile halten sich zu sehr in Grenzen mit Wakü !
Aber erstmal beten das die Spulen zurück halten der sein werden als bei der TUF die war eine Vollkatastrophe.
Dan steht Calisto Protokoll nix mehr im Weg!
Vielleicht hast ja Glück . Meine rasselt nur und bei vollen PL und 1,1 v fiept die erst ab 300 fps nach all meinen Tests . Damit kann ich gut leben , weil Rasseln sehe ich nicht so nervig wie fiepen bzw. triggert mich nicht . Bei manchen Games wie dying light 1 @ 144 fps ist die Karte sogar ruhig obwohl über 300 Watt anliegt . Im Idle Totenstille . Gott sei Dank , weil da regeln auch alle meine Lüfter stark runter und die tuf geht auf Fan stop .
@Air brummen die Lüfter wohl sehr!
Damit könnte ich auch leben !
Die TuF hat schon bei um die 60 FPS + Party gemacht!
An die, die eine PNY haben: Könntet Ihr einmal bitte ein Foto posten, auf dem man sieht wie der Kühler / Shroud an der I/O Blende angebracht ist? Gibt es da nur eine Verbindung am PCB (schlecht) oder ist auch der Kühler selbst direkt verbunden? Irgendwie haben alle Reviewer es geschafft, genau das nicht abzubilden. :fresse:
Die Antwort ist, wenn auch technisch korrekt, ja wohl ne absolute Frechheit. Für mich ist NBB wirklich der größte Saftladen und wenn die nicht den Exklusivvertrieb für die FE hätten, würde ich mit denen nix zu tun haben wollen. Sind anscheinend völlig überfordert mit der Situation.
Der NVidia Kundensupport war in jedem Kontakt absolut freundlich und hilfsbereit, Dauert nur leider immer alles sehr lange. Von meiner Anfrage bis zur ersten Antwort 2 Wochen. Habe nun den RMA Antrag nach Prüfung bei NVidia gestellt und warte immer noch auf das Etikett bzw. die Rücksendeinformationen. Auch wieder ne Woche her.
Ist aber nicht schlimm, hab es da ja nicht eilig. Aber wenn die dann auch so lange brauchen, wenn die Karte bei ihnen ist, mach ich mich schon mal darauf gefasst, die erste Hälfte 2023 wieder mit der 3090 zocken zu müssen. :lol:
Ich dreh durch:
Mail von NBB:
"Wir haben Ihre Einsendung erhalten.
Nach einer Sichtprüfung werden wir die Ware in unser System aufnehmen und bearbeiten.
Nach Abschluss der Bearbeitung werden Sie automatisch informiert."
Habe jetzt 4 mal per Telefon, einmal per Kontaktformular und 3 mal per mail kommuniziert, dass sie die Karte einfach zurückschicken sollen. Jedes mal wurde zugestimmt!!! Jetzt wollen sie sie sichten?
Und DHL hat siuch auch heute gemeldet. Man kann keine Sendung stoppen. Na zum Glück hat die tschechische Mitarbeiterin mit Ihrem Vorgesetzten gequatscht und mir gesagt, dass ich das mit diesem Formular machen muss!!!
Ich dreh durch:
Mail von NBB:
Das ist ein automatisierter Prozess.. auch wenn du 4 mal angerufen hast.. da Arbeiten mehr als 2 Leute, die vermutlich nichts davon wissen.. Auch wenn es sicher nicht so rüberkommt wenn man anruft. :d
Hoffe es klappt schnell und du bekommst deine Karte flott wieder... Nicht das sie doch eine Ersatzkarte schicken. Oder noch schlimmer.. sie erst zu Nvidia schicken und keine Ersatzkarte oder Deine mehr da haben.
Also sorry, aber wenn du da so abgehst wie hier und die ständig behelligst / nervst, würd ich mich nicht wundern, wenn die dir nur resigniert sagen was du hören willst, aber erst recht nichts weiter machen.
Schalte doch mal nen Gang runter.
Erst ne Karte Einsenden um dann zurück zu fordern ist auch schon Banane . Wenn ich NBB wäre würde ich dir den ganzen Aufwand in Rechnung stellen .
Das ist das was ich befürchte... sonst wäre es mir egal wie lang es dauert.
Und du weißt worum es geht und kannst die situation nachvollziehen?
Ich drück dir die Daumen. :) mach dich Locker. Die wird schon zurückkommen. Wenn nicht, ist es ne neue..
Sie hätten ja nur zu meinem Video sagen müssen, dass das brummen alle karten haben.
Die hätten doch nur nach dem ersten Kontakt Ihr Wort halten müssen... Dann hätte ich doch gar keinen Grund nochmals nachzufragen. Aber ich nerve nicht mehr. Ihr habt ja bestimmt wichtigere Themen hier. Ist ja ansonsten alles voll immer wichtig hier. lol
hehe, frag ruhig weiter dort nach... du rufst ja nicht mich an.. :popcorn:
:) Bei nem grossen Konzern Druck aufzubauen hilft meist nicht. Meist gehts schnell wenn man bei Paypal den Käuferschutz zu aktivieren.. Ist aber nicht die Feine art und bringt dir keine Reputation. Ausser das du noch mehr Leute in anderen Abteilungen aufschreckst.
Bei sowas ist mein Vorgehen, dass ich nach einem zuständigen Ansprechpartner frage. Das bindet bisschen die Verantwortung und man muss nicht immer alles von neu erzählen. Hat zumindest bei Mindfactory jetzt sehr gut funktioniert.
Hab nämlich jetzt doch ganz schnell eine ,der wenigen non-Banana, Gamerocks bekommen^^
Haha... das läuft in einem Standardprozess von Logistik zu Eingangsprüfung, Lager, dann ins Warenwirtschaftssystem und so weiter... Kontakt hast Du mit einem Servicemitarbeiter, der nur das sieht was im System ist.
Zuständig ist immer derjenige, der gerade den Prozesschrittt ausführt ;) Ihr erwartet doch nicht etwa, dass die einen teueren individuellen Prozess anstoßen für ein Produkt mit vermutlich 100 EUR Nettomarge :ROFLMAO:
Ich frage mich ehr: was machen die eigentlich mit ausgepackten Rückläufern? Hab noch nie von bereits geöffneten Kartons oder B-Ware gelesen.
Da kommen neue Siegel an den Karton. Meine FE war schon mal benutzt. Links vom stromanschluss waren kratzer an den schwarzen lamellen. wahrscheinlich weil jemand nicht den stecker sofort gefunden hat.
Bei alternate gehts wohl in den Outlet .
Bei caseking wird manches auch bei eBay angeboten . Amazon hat auch dafür einen Store , aber aus eigener Erfahrung bei meinem Corsair 7000d war es ein Rückläufer und das passiert bei Amazon öfters . Liegt denke eher an den Mitarbeiter die da sind als das was Amazon eigentlich vorsieht .
So, bisschen weiter getestet. Spulenfiepen etwas geringer als bei der Strix, dafür etwas mehr gerassel. Läuft mit 3135 durch den Superposition mit 1650Mhz auf dem Speicher. UV läuft sie mit 2550Mhz bei 0,875V durch den Metro Exodus enhanced benchmark bei 4k alles maxed 20 runs. Dabei gönnt sie sich gerade mal 300 Watt, Lüfter drehen mit 30%, 1050 rpm und erreicht entspannte 62 Grad.
Also Karte selber bis auf das Fiepen und Rasseln sehr gut, aber ob ich mich damit anfreunden kann bei einer 2300€ Karte, Puh. Die Gamerock war da zwar nicht so schnell aber dafür wirklich Leise bzgl. Spulenfiepen.
Beste Grüße
Ah okay... hatte ich vermutet aber ehr mit Umweg über NV. Im Prinzip bringt man den Karton ja auch unsichtbar wieder zu. Ich hab meine jedenfalls so geöffnet, dass ich sie ohne Spuren wieder zu Neuware machen könnte.
Preisfrage: hat Deine Karte irgendwelche Macken und wie geht sie OCisch?
Ähnliche Themen
