[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Ah okay... hatte ich vermutet aber ehr mit Umweg über NV. Im Prinzip bringt man den Karton ja auch unsichtbar wieder zu. Ich hab meine jedenfalls so geöffnet, dass ich sie ohne Spuren wieder zu Neuware machen könnte.
Preisfrage: hat Deine Karte irgendwelche Macken und wie geht sie OCisch?
Wird wohl auch mit Umweg über NV sein. Denn meine stornierte 4080 musste ich per Hermes versenden und meine 4090 zum Tausch musste ich nach NBB schicken.
Die Karte war ok. Stock 2745Mht und Ram bis 1750 stabil. nur de Lüfter brummt.
Also Karte selber bis auf das Fiepen und Rasseln sehr gut,
Habe 2x Zotac 4090 Amp Extereme Airo für die Falterei am Start. Weder Fiepen, noch Rasseln bei beiden - momentan allerdings noch unter Luft.
Vielleicht ein Plan B für Dich? Wobei mich die Lüfter auf Dauer etwas nerven würden. Bin allerdings auch Geräuschparanoiker mit 3x Mo-Ra 😁
Mit UV bei 875mV eine bei 2640 MHz (die andere kann "nur" 2580 dauerhaft) und Mem +500.
Stromverbrauch beide bei 240 Watt ...
Gestern mal spaßeshalber den OC Booster in der Zotac Firestorm App ausprobiert. Ging bis 3120 MHz, hätte ich dauerhaft so übernehmen können. Mach aber bei F@H ja so gar keinen Sinn 😅
Ja, die Zotac Extreme habe ich auch noch auf dem Schirm, muss mir das mal mit den Lüftern anhören, bin auch sehr empfindlich. Gehäuselüfter drehen so bei entspannten 500rpm, da sind Störgeräusche immer extra unangenehm. Habe mir extra deswegen auch ein AX1600i geholt,
Beste Grüße
So, bisschen weiter getestet. Spulenfiepen etwas geringer als bei der Strix, dafür etwas mehr gerassel. Läuft mit 3135 durch den Superposition mit 1650Mhz auf dem Speicher. UV läuft sie mit 2550Mhz bei 0,875V durch den Metro Exodus enhanced benchmark bei 4k alles maxed 20 runs. Dabei gönnt sie sich gerade mal 300 Watt, Lüfter drehen mit 30%, 1050 rpm und erreicht entspannte 62 Grad.
Also Karte selber bis auf das Fiepen und Rasseln sehr gut, aber ob ich mich damit anfreunden kann bei einer 2300€ Karte, Puh. Die Gamerock war da zwar nicht so schnell aber dafür wirklich Leise bzgl. Spulenfiepen.
Beste Grüße
Wärst mal lieber bei deiner schrottigen Palit geblieben 😂
Bin jetzt im UV bei 2595 @ 0.875, 10 Runs Metro Exodus enhanced sind schon durch.
Jo, die ging zwar nicht so gut war dafür aber echt entspannt mit den Spulen. Lüfterdrehzahl zwar etwas höher als bei Strix und Suprim aber das war nicht so schlimm wie die Spulen :d Dafür freuen sich Freunde über die Karten.
Beste Grüße
Mein "APL" wurde heute verschickt. Aber was ist mit "Zolltarifnummer" gemeint? :oops:
Würde ungerne lange warten, wenn das aus England verschickt wurde
Na ja Asus will da knapp 2410 für ist halt so !
Ja ich hoffe hab mehr Glück bei der Strix und den Spulen!
Einhorn und so !
Wen man gerade guckt sind alle Interessenten Karten teurer geworden von daher verschmerzbar!
Wichtig ist das die liefert !
Ich hab nämlich keine Bock mehr !
Das war glaube ich ein Fehler. Habe noch von keiner Strix ohne Kreischgeräusche gehört aber viel Glück!
UV Test geht weiter 2595 @ 0.875 sind stabil, jetzt mal 2610 laufen lassen. Bin aber was das angeht schon mal zufrieden.
Beste Grüße
Zotac Amp hatte ich auch eine hier, super Karte. Nur halt nicht für >2300 EUR ;)
VRM flüsterleise im Vergleich zur FE, OC besser und Kühler sowieso.
Wie meinste das denn?
Ich hab meine beiden für je 2189 € bei MM gekauft. Kosten dort zwar seit dieser Woche 2269 € ... aber damit ja auch noch gut unter 2300 €.
Seit heute den 4K 240Hz MiniLED Samsung G8 hier, hoffe bald kommt 5090, die 4090 schafft es nicht die 240FPS zu halten in 4K... :ROFLMAO:
@Dwayne_Johnson
Allerdings alle Settings defaults, fürs Übertakten fehlen mir aktuell die nerven....
Abdruck des Kühler sieht sauber aus, und Pads sind imho nicht aus Silikon...
@Grestorn
Karte heute nochmal zerlegt und MX-5 durch MX-4 Leitpaste getauscht, Abdruck aber in beiden Fällen 1A und unauffällig...
@FR4GGL3
Viel bleibt nicht mehr übrig außer dem Block, wobei der GPU Abdruck wirklich gut aussieht. Ich hatte schon ne CPU die Konvex war, das hast aber beim Abdruck richtig gut gesehen...
Die letzten °C sind mir eigentlich völlig egal, solang die Karte schön leise ist. Am meisten stresst mich einfach, dass die GPU mit Wasserkühler wärmen wird als mit dem Luftkühler - das nervt mich, irgendwie...
Softe Wärmeleitpads hab ich bisher nicht probiert...
Das Temperaturverhalten der Karte verhält sich auch irgendwie sehr suspekt, da muss ich @Trill dann schon recht geben dass es einfach Ada sein könnte...
Sobald die Karte belastet springt die Temperatur munter, das sieht eher aus als würde die Temperatur anhand des Stromverbrauchs berechnet - anstatt gemessen...
Ja gut. Der kleine Fertigungsprozess. Da kommt schnell Wärme auf, das kann aber so im gleichen Maße nicht abgeführt werden.
UND dann darfst nicht vergessen, dass diesmal die Luftkühlung echt deftig ausgefallen ist im Vergleich zu früher.
Dann wirst wohl wirklich nochmal einen anderen Block besorgen müssen...
Na ja im schlimmsten Fall geht die Retour !
@MS1988 meint ja seine fängt erst bei 300FPS an ich werde es ja hören können dann oder auch nicht !
Ich würde mich auf jeden Fall sehr freuen auch mal Glück zu haben .
Ich Greif bei so was aber meistens in die Scheisse ...ob CPUs Speicher Mainboards bei mir ist da irgendwie immer nicht das Optimum mit bei !
Von daher diesbezüglich bin ich Niederlagen schon gewohnt!
So heute mal schön bei LDLC ein Schnäppchen gemacht ...glaub LDLC wird das bessere NBB :ROFLMAO:
Laufen die dann auch über eine Vermittlungsversandfirma?
Ist Nvidia das neue ATI? Der Treiber hat in Kombination mit der RTX 4090 immer noch den Black Screen Fehler bei Multi-Monitorbetrieb.
Sofern ich vom HDMI 2.1 (LG CX) zurück auf DisplayPort wechsle, bekommt man kein Bild mehr.
Bei mir kein Problem. TV an HDMI und Monitor an DP
@Dwayne_Johnson
@Grestorn
@FR4GGL3
Ok, kein Silikon, aber evtl. minimal zu dick und/oder zu hart. Und das klaut dir Anpressdruck an der GPU
Ich nehme an, das Stahlfederkreuz ist auch nicht installiert? (die Byksky-BP hat keinen Ausschnitt dafür)
Fehlt dann zusätzlich an Anpressdruck...
Wenn die WLPads sich nachpressen lassen, würde ich das nochmal tun. Denn der Mora sollte locker mehr, als der Org-Kühler schaffen
Beste Grüße
Verstehe den Wechsel nicht so ganz...
Die "Banane" war zwar nicht die Schönste, dafür sah sie mit dem großflächigen RGB schon sehr stimmig aus in deinem Case :)
Mir persönlich gefällt die Suprim X (die hatte ich auch) nicht so sehr, wie die TUF
Zudem 300 Mäuse gespart...
Mich würde irgendwie schon interessieren, ob man bei der hohen Energiedichte der GPU mit Flüssigmetall unter dem Wasserblock noch einiges rausholen könnte.
Beste Grüße
Schöner Preis und dann auch noch Caseking. Was ist da los bei denen? Normalerweise sind die teuer
Rückläufer...?
Few moments later...
Hoffe bald kommt die 9090 - die 8090 schafft keine 240Hz @8K :haha:
2077 geht richtig ab :love: , temps mit 90%PT top bei 3ghz,
Aber was ist der Unterschied zwischen zb 10nm @500W und 4nm @500W bei gleichgroßem Die?
Der 4090-Die ist nur etwas mehr als 3% kleiner, als der 3090-Die. Das kann doch unmöglich soviel ausmachen!?
Dem Block ist das egal, wenn beide GPUs 500W abgeben
@Dwayne_Johnson
da geht noch was, 52 grad, bin voll zufrieden mit dem Block :wink:
Sieht schon viel besser aus :) Wieviel Wasser-Temperatur?
Angeblich liegt bei Ada fast die komplette TDP auf dem Die, während sich das bei Ampere mehr über das Board verteilt hat.
Deswegen wäre ja Flüssigmetall evtl. interessant. Bei CPUs nimmt man das ja auch unter dem Heatspreader oder wenn man Direct Die geht. Das ist ja eigentlich schon ähnlich zum Grafikchip.
Ähnliche Themen
