[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Angeblich liegt bei Ada fast die komplette TDP auf dem Die, während sich das bei Ampere mehr über das Board verteilt hat.
Deswegen wäre ja Flüssigmetall evtl. interessant. Bei CPUs nimmt man das ja auch unter dem Heatspreader oder wenn man Direct Die geht. Das ist ja eigentlich schon ähnlich zum Grafikchip.
Anders wäre es nicht zu erklären...
Aber was ist der Unterschied zwischen zb 10nm @500W und 4nm @500W bei gleichgroßem Die?
Der 4090-Die ist nur etwas mehr als 3% kleiner, als der 3090-Die. Das kann doch unmöglich soviel ausmachen!?
Dem Block ist das egal, wenn beide GPUs 500W abgeben
Sieht schon viel besser aus :) Wieviel Wasser-Temperatur?
76,3 Mrd. Transistoren auf 608,5mm² Vs. 28 Mrd. auf 628mm²
Sorry, kein Sensor verbaut:fresse:
Also hat Lovelace eine sehr hohe Dichte.
Bei Intel CPUs war ja auch irgendwann nach den 2600K so weit das man die CPUs köpfen musste und dann noch Liquid drauf gemacht wurde weil man die Wärme nicht raus bekommen hat!
2077 geht richtig ab :love: , temps mit 90%PT top bei 3ghz,
Mach mal Division 2 an dann hat es sich erledigt mit über 500W.
OK, würde ich gerne, hab das Spiel leider nicht...
Key bekommst für 7 Euro .
Das Spiel macht sogar richtig Spaß und hat wie ich finde eine Super Grafik da zu ist das auch ein guter Stabilitäts Test für OC bei Grafikkarten und was Powerlimit angeht ist das nicht zimperlich da wundert man sich auch mal mit Undervolting was das Game abfordert !
Das Spiel macht sogar richtig Spaß und hat wie ich finde eine Super Grafik da zu ist das auch ein guter Stabilitäts Test für OC bei Grafikkarten.
ok, kauf ich ! Berichte die Tage...
Karte ist einfach Sahne :bigok:
Oh nur 360 W die wird ja noch kaum belastet der Kühler hat doch noch gar nichts zu tun.
Laufen die dann auch über eine Vermittlungsversandfirma?
Nein wie schon nachfolgend geschrieben wurde..aber nun kurze Zusammenfassung meines FE kaufs bei LDLC...
Drop am MO 21.11 (15.28 Uhr Nachmittag)
Angekommen am MI 23.11 bei Colisexpat (Paketweiterleitung) am DO 24.11 von denen Vormittags eine E-Mail bekommen zwecks
Paketweiterleitung nach AT (man kann sich aussuchen ob DHL DPD usw. am günstigsten war DPD bei mir leider nur Versandversicherung 500 Euro (kostet ca 25 Euro nach Österreich)
Dann am DO noch DPD Sendungsdaten bekommen aber da tut sich erst was wenn das Paket am Depot bei mir in Wien angekommen ist
Es hat doch einige Tage gedauert bis das Paket in Wien war angekommen am 1.12.
Und bei mir sein soll es heute 2.12.
Also sollte es in FR wieder einen Drop geben vielleicht für jemanden eine Alternative...wer weiss schon wie es bei NBB weiter geht vielleicht gibts da ja wirklich nix mehr....
Paste die ich verwende, liefert ab!
Würden beide GPUs exakt gleich viel Leistung abgeben, bei exakt gleicher Die-Fläche, wäre es völlig egal, ob der eine Die 100 Mrd. und der andere Die nur 1 Mrd. Transistoren hat ;) Daher kann es nur so sein, wie oben geschrieben wurde, dass der 3090-Die weniger Leistung abgibt, als der 4090-Die. Oder, dass die Spawa ´s der 4090 mehr an den Kühler abgeben (schlechtere Kühlleistung, der GPU). GPU-Z ist zudem auch kein Mess-Gerät :d
Das würd ich auch so sehen, letztlich ist das was man kühlt die Abwärme. Und die ist Abhängig von der Leistung (Watt) die verbraucht wird und dem Wirkungsgrad wieviel von der Leistung in Wärme umgewandelt wird. Wenn der Wirkungsgrad nicht schlechter ist muß man die selbe Menge wegkühlen egal ob 70 oder 100 Mrd. Transistoren schalten. Den Wirkungsgrad weiß ich jetzt nicht zwischen 3090 und 4090 ich denke aber das dieser nicht schlechter wurde.
Um welchen Block gehts noch gleich? Meine beiden Bykski Zotac Blöcke waren absolut unplan und vor dem plan schleifen waren die Deltas deutlich höher wie danach. Mußte auch richtig ackern um mit dem feinen Schmirgel soviel Material abzutragen das er mal plan wurd.
Mein Bykski SuprimX 3090 hingegen war recht plan hier mußte ich nur minimal planen, der wäre auch ohne Handanlagen schon ok gewesen. Also denke ich kann man nicht einfach sagen "Block ist Block" kommt schon auf Feinheiten an.
EKWB Velocity2 1700 Sockel anderes Beispiel original Zustand 330 Watt CB23 95°C. Plangeschliffen selber Test 79°C !
Vergiss „Kingdom Come: Deliverance“ nicht :)
Ich nehme an konvex?
Und der 4090-Die? Wie 3090 auch mit „Buckel“?
Kann ja “lustig“ werden, wenn Block und GPU konvex sind :rolleyes2:
Ist Nvidia das neue ATI? Der Treiber hat in Kombination mit der RTX 4090 immer noch den Black Screen Fehler bei Multi-Monitorbetrieb.
Sofern ich vom HDMI 2.1 (LG CX) zurück auf DisplayPort wechsle, bekommt man kein Bild mehr.
Das Prob hab ich auch. Und zusätzlich: Wenn beide Monitore an sind, hat der C2 nach Boot GSync aktiviert. Starte ich ein Spiel, ist es aus und muss manuell reaktiviert werden (im LG Menu). Wenn der DP Monitor nicht dran ist oder deaktiviert bleibt GSync an. Hast Du das auch?
Calisto Protocol:
Jetzt bin ich verwirrt:
Gamestar: 74%
4Players: 89%
PCGames: 9/10
Gamepro: 66%
GamersGlobal: 8/10
Metacritic bei 36 Bewertungen: 76%
Hätte nicht gedacht, dass ausgerechnet bei diesem Game so viel Uneinigkeit herrscht…
Calisto Protocol:
Gamestar: 74%
4Players: 89%
PCGames: 9/10
Gamepro: 66%
GamersGlobal: 8/10
Kritiken sind oft komplett gegenläufig meiner Meinung. Deshalb interessieren die mich nicht. Ich zocke ein Game an und wenn es nacvh ein paar Stunden nicht packt fliegt es wieder runter.
Ich würde den Text zu den Tests lesen. Nicht nur die Prozente vergleichen. Dann weißt Du, warum Game* das Spiel nicht so mochte.
Für mich ist das Spiel eh nichts. Zitat Gamestar:
Passt nicht zu euch, wenn ...
- ... euch das Frustpotenzial von Bossen und Checkpoints abschreckt.
Ok. Das wars. Ich spiele zum Fun nicht um (mir) was zu beweisen.
Calisto Protocol:
Gamestar: 74%
4Players: 89%
PCGames: 9/10
Gamepro: 66%
GamersGlobal: 8/10
Zumindest bei PCGames gilt die Wertung für die PS5 Version da sie die PC Version zu spät bekamen... und die hat wohl technisch noch ein paar Probleme:
"In der kurzen Zeit, in der wir The Callisto Protocol auf dem Rechner bislang gespielt haben, kämpften wir mit deftigen Rucklern und Schattenfehlern aufgrund von Shader-Compiling. "
Es gibt btw gerade unter anderem eine 4090 TUF OC gebraucht bei LDLC und GOODGAME scheint noch zu funktionieren (die TUF ist dann immerhin unter 2k) :) Edit: Auch weg
Eine 4090 Phantom gabs auch gebraucht, die ist aber weg, war mit Versand 1699€
Ich hab für Calisto Protocol gerade den refund angefragt. Ich hab zwar nur ne 3080, aber würde trotzdem erwarten, dass ich es ohne Drops auf 20 FPS spielen kann. Vlt. geht's euch mit der 4090 ja besser. Aber da es mir auch 2x in den ersten 15 Minuten mit Crash to desktop abgeraucht ist, warte ich lieber noch ein paar patches.
Moin, ich habe mal am Rande gelesen da es inzwischen Beta 3 gibt von Afterburner. Hat da wer einen Link? Finde den offiziellen auf Guru3d nicht.
  • Danke
Reaktionen: SH
Verstehe den Wechsel nicht so ganz...
Die "Banane" war zwar nicht die Schönste, dafür sah sie mit dem großflächigen RGB schon sehr stimmig aus in deinem Case :)
Mir persönlich gefällt die Suprim X (die hatte ich auch) nicht so sehr, wie die TUF
Zudem 300 Mäuse gespart...
War ja eher ein Wechsel aus Nächstenliebe. Und würde auch sofort wieder ne Palit nehmen, wenn für 1949€ nonOC oder 1999€ OC verfügbar. So hat mich jetzt die SuprimX das selbe gekostet wie eine Palit OC in den anderen Shops.
Beste Grüße
Ist der Chat bei NBB kaputt? Kann den nimmer öffnen. Meine Bestellung wurde seit 12.10.22 noch nicht versendet....
@Thunderburne
Jetzt Live...
Hat bei mir mit Division 2 länger gedauert...
Paar Stunden gezockt, dann Monate nicht mehr. Ich fand es zu "überladen". Beim zweiten Anlauf kam ich nicht mehr weg :d
Ähnliche Themen
