bitte lies doch mal mit '
Moninfo' den Panasonic aus und poste das Ergebnis hier..
hier mal die erste Seite von Moninfo, die komplette bin Datei habe ich mal hier hochgeladen:
http://www.dark-net-hunter.de/temp/dspinfo.bin
Monitor
Model name............... Panasonic-TV
Manufacturer............. Panasonic
Plug and Play ID......... MEIA096
Serial number............ n/a
Manufacture date......... 2009, ISO week 0
EDID revision............ 1.3
Input signal type........ Digital
Color bit depth.......... Undefined
Display type............. RGB color
Screen size.............. Undefined or variable
Power management......... Not supported
Extension blocs.......... 1 (CEA-EXT)
DDC/CI................... Not supported
Color characteristics
Default color space...... Non-sRGB
Display gamma............ 2,20
Red chromaticity......... Rx 0,640 - Ry 0,345
Green chromaticity....... Gx 0,291 - Gy 0,635
Blue chromaticity........ Bx 0,163 - By 0,093
White point (default).... Wx 0,288 - Wy 0,296
Additional descriptors... None
Timing characteristics
Horizontal scan range.... 15-68kHz
Vertical scan range...... 23-61Hz
Video bandwidth.......... 150MHz
CVT standard............. Not supported
GTF standard............. Not supported
Preferred timing......... Yes
Native/preferred timing.. 1920x1080p at 50Hz (16:9)
Modeline............... "1920x1080" 148,500 1920 2448 2492 2640 1080 1084 1089 1125 +hsync +vsync
Detailed timing #1....... 1920x1080p at 60Hz (16:9)
Modeline............... "1920x1080" 148,500 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync
Standard timings supported
EIA/CEA-861 Information
Revision number.......... 3
IT underscan............. Not supported
Basic audio.............. Supported
YCbCr 4:4:4.............. Supported
YCbCr 4:2:2.............. Supported
Native formats........... 7
Detailed timing #1....... 1920x1080i at 50Hz (16:9)
Modeline............... "1920x1080" 74,250 1920 2448 2492 2640 1080 1084 1094 1124 interlace +hsync +vsync
Detailed timing #2....... 1920x1080i at 60Hz (16:9)
Modeline............... "1920x1080" 74,250 1920 2008 2052 2200 1080 1084 1094 1124 interlace +hsync +vsync
Detailed timing #3....... 1280x720p at 50Hz (16:9)
Modeline............... "1280x720" 74,250 1280 1720 1760 1980 720 725 730 750 +hsync +vsync
Detailed timing #4....... 1280x720p at 60Hz (16:9)
Modeline............... "1280x720" 74,250 1280 1390 1430 1650 720 725 730 750 +hsync +vsync
Detailed timing #5....... 720x576p at 50Hz (16:9)
Modeline............... "720x576" 27,000 720 732 796 864 576 581 586 625 -hsync -vsync
CE video identifiers (VICs) - timing/formats supported
1920 x 1080p at 50Hz - HDTV (16:9, 1:1) [Native]
1920 x 1080p at 60Hz - HDTV (16:9, 1:1) [Native]
1920 x 1080i at 50Hz - HDTV (16:9, 1:1)
1920 x 1080i at 60Hz - HDTV (16:9, 1:1)
1920 x 1080p at 24Hz - HDTV (16:9, 1:1)
1280 x 720p at 50Hz - HDTV (16:9, 1:1)
1280 x 720p at 60Hz - HDTV (16:9, 1:1)
720 x 576p at 50Hz - EDTV (16:9, 64:45)
720 x 480p at 60Hz - EDTV (16:9, 32:27)
720 x 576p at 50Hz - EDTV (4:3, 16:15)
720 x 480p at 60Hz - EDTV (4:3, 8:9)
720 x 576i at 50Hz - Doublescan (16:9, 64:45)
720 x 480i at 60Hz - Doublescan (16:9, 32:27)
720 x 576i at 50Hz - Doublescan (4:3, 16:15)
720 x 480i at 60Hz - Doublescan (4:3, 8:9)
640 x 480p at 60Hz - Default (4:3, 1:1)
NB: NTSC refresh rate = (Hz*1000)/1001
CE audio data (formats supported)
LPCM 2-channel, 16-bit at 32/44/48 kHz
CE vendor specific data (VSDB)
IEEE registration number. 0x000C03
CEC physical address..... 2.1.0.0
Supports AI (ACP, ISRC).. Yes
Supports 48bpp........... No
Supports 36bpp........... Yes
Supports 30bpp........... Yes
Supports YCbCr 4:4:4..... Yes
Supports dual-link DVI... No
Maximum TMDS clock....... 190MHz
CE colorimetry data
xvYCC709 support......... Yes
xvYCC601 support......... Yes
sYCC601 support.......... No
AdobeYCC601 support...... No
AdobeRGB support......... No
Metadata profile flags... 0x01
Report information
Date generated........... 06.12.2010
Software revision........ 2.53.0.861
Data source.............. Real-time 0x0031
Operating system......... 6.1.7600.2
Raw data
00,FF,FF,FF,FF,FF,FF,00,34,A9,96,A0,01,01,01,01,00,13,01,03,80,00,00,78,0A,DA,FF,A3,58,4A,A2,29,
17,49,4B,00,00,00,01,01,01,01,01,01,01,01,01,01,01,01,01,01,01,01,02,3A,80,D0,72,38,2D,40,10,2C,
45,80,BA,88,21,00,00,1E,02,3A,80,18,71,38,2D,40,58,2C,45,00,BA,88,21,00,00,1E,00,00,00,FC,00,50,
61,6E,61,73,6F,6E,69,63,2D,54,56,0A,00,00,00,FD,00,17,3D,0F,44,0F,00,0A,20,20,20,20,20,20,01,E2,
02,03,25,77,50,9F,90,14,05,20,13,04,12,03,11,02,16,07,15,06,01,23,09,07,01,67,03,0C,00,21,00,B8,
26,E3,05,03,01,01,1D,80,D0,72,1C,16,20,10,2C,25,80,BA,88,21,00,00,9E,01,1D,80,18,71,1C,16,20,58,
2C,25,00,BA,88,21,00,00,9E,01,1D,00,BC,52,D0,1E,20,B8,28,55,40,BA,88,21,00,00,1E,01,1D,00,72,51,
D0,1E,20,6E,28,55,00,BA,88,21,00,00,1E,8C,0A,D0,90,20,40,31,20,0C,40,55,00,BA,88,21,00,00,18,15
