[User Review] +Bilder: MSI PR200 (ALB RS12) Santa Rosa; 12" Subnotebook
die neueste Version ist drauf, das NB merkt sich die zuletzt eingestellte Einstellung aber trotzdem nicht...woran kanns liegen?
Mal kurz ne ganz andere Frage, die Software die bei dem Fingerprintreader dabei ist, kann nicht mit dem Firefox 3 umgehen, weiss da jemand obs ne neue version gibt?
greetz damole
Soo !!
finale infos sind da. daran ist leider nichts mehr zu rütteln!!
infos sind von heute frisch aus taiwan:
die endgültigen antworten sind in organge
A)
add a)
> there are many customers out on the net having this problem.
> i`ve got the same answer in ocss system from msi support. please read
> this:
> response in ocss:
> The cpu fan is working continuously,it can keep the noise voice
> loudly.When the laptop runs a program or not,the fan will work continuously at a low
> speed first. But if a laptop runs a high program,the fan will work at a
> high speed.This design can prevent the noise voice that would be comming out
> suddenly.If not the voice which is from fan would be heard loudly.So it is
> normal.
> I suggest you get your laptop on a cooling blanket.Keeping the ambient
> temperature lower,and then you may find the cpu fan will not work continually
> and make less noise.
> my response to that:
> no, no ,no!!
> again, i know much about pc hardware and software.
> i`m in it-business since over 10 years now and also worked long time as it
> product specialist in an it distribution office. so you can trust me.
> the fan is always spinning!
> if there is high cpu load which generates much heat it spins high. (as it
> should do :-)
> if there is no cpu load > (cpu load only between 1-2%) the fan is always
> spinning. (it is spinning slow.)
> but it never shuts off! i`ve testet it with coolingpad and also i`ve put
> the notebook in the fridge for 10min!!
> the fan never shuts off!
> please test this yourself with one pr200, and you will see that the fan
> never stops.
> there was the same with s260 & s270 and there was a bios patch form msi.
> so finally the solution is that msi provides an embedded controller update
> in the next pr200 biosrelease.
> As written in the issue list, there are also many pr200 customers on the
> internet which are waiting for this solution!
> response from msi support in ocss:
> About the fan,our PR200 is always spin too.It never stops.This is because
> of MSI design and research.
> Best Regards,
> MSI Notebook Technical Support
> my response:
> please always test & confirm what you write to me.
> regarding the fan, in first you wrote me that it will stop. now you wrote
> me it doesn`t stop...
> but anyway the "problem" is as written two times now. the fan spins all
> the time so it makes noise, so while writing text (nb is idle) it makes
> noise, which is not so fine if you are in a low sound environment.
> additional to that, there was the same stuff with s260 and s270. there was
> an msi bios update which updated the embedded controller via bios update.
> there are really many (yes many) people out there which are waiting for
> this to be fixed with an biosupdate. (i`m not joking here.)
> and also the fan will live much longer when it doesn`t always spin.
> additional to that, the battery would also stay longer if running on
> battery.
> and there are also many people out there which asked on the net if the fan
> always spin because they wanna buy pr200 only if the fan does shut-off
> when in idle. (yes also here > i`m not joking)
> people want quite notebooks when they are in idle.
> so please check how to update the embedded controller as it was done with
> s260&s270.
> this would also bring you some more additional pr200 customers for sure!
> my cpu temp in idle without cooling pad is > cpu 53°, core1: 46°,
> core2: 46° (roomtemp 26°)
> cpu temp in idle with cooling pad is > cpu 49°, core1: 42°, core2: 42°
> (roomtemp 26°)
> cpu temp in idle > cpu 44°, core1: 41°, core2: 39° (roomtemp 18°)
> cpu fan never turned off!!
I checked the design spec and found your CPU temp is normal.
> Moreover, I don’t think there is any notebook’s CPU fan would stop in
> idle mode. It just runs at low speed.
> If we turn off the fan, the system will get hotter and hotter and cannot
> fix the CPU temp in idle mode.
> Btw, it is unfair to compare with S260 and S270. They have different
> mechanical architecture, CPU TDP… (I was using a S262 before, and the noise is
> bigger than P200)
> Also, I know the story of those notebooks and the situation is totally
> different.
regarding the fan. i don`t mean to turn off the fan completely but to change the value where it turns on. eg until 50° no fan and if the cpu temp is 51 > turn on the fan. (there are many nbs out there which stop fan if it drops below a given value.) pr200 fan definitely does not stop. (as written i the last mails, many pr200 users wan`t this really bad.)
thanks for the info regarding s260 and s270, i only mean that pr200 should work like them regarding the cpu fan.
The fan runs at 40% speed when the temp is less than 54℃ but we cannot let CPU fan run slower than 40% or we will get some thermal problems.
If we turn off the fan when the temp is lower than 54℃, we might get the problem like you said. Even we lower the fan speed, we might get lots of feedback about the notebook is too hot....
Each NB should have it fan table to control the fan speed.
Different range of temp has its own fan speed.
For example,
Temp (℃) Fan Speed
Under 54 >> 40%
54 - 59 >> 45%
59 - 64 >> 50%
so you mean, if you`ll set the value to eg. turn off fan when temp is lower than 54°, then the temp will increase verry fast and the fan will always turn off (cpu gets hot very fast) and on (cpu fan will drop the temp below 54) in a to short timeframe as it makes no sense for you to do this change?
For example,
Temp (℃) Fan Speed
Under 54 >> 40%
54 - 59 >> 45%
59 - 64 >> 50%
Also leute ich hab echt alles versucht!! Deutschland, England, Niederlande, OCSS Taiwan, direkter mail Support Taiwan (über connection aus den Niederlanden)
Resultat: der Deutsche ist für a..., der Englische nicht zuständig, der Niederländische zwar nett verspricht viel aber passiert nicht viel, OCSS kostet viel Zeit + bringt aber nix weil die Typen entweder garnicht oder nur nach massivem Aufstand reagieren und auch dann nur 1-2 Replys und dann nichts mehr bis man es wieder scheppern lässt.
die antworten oben kommen aus der richtigen abteilung in taiwan
sorry leute, mehr ging einfach nicht!!
aber besser konstanter fan als dauernd ein / aus. das war auch der grund warum ich extra seine meinung angefordert habe.
B)
noch eine info
bzgl. dem verhalten des wlan/bluetooth schalters.
in vista öffnet sich ein kleines fenster wo man wählen kann was aktiv / inaktiv sein soll.
unter xp gibts das nicht. da gibts nur > wenn wlan aktiv und bluetooth soll aktiviert werden > bluetooth killt dann mal das wlan.
antwort dazu aus taiwan:
I didn’t say it is BIOS related.
We add this function when PR200 runs under Vista.
Frankly speaking, it is our specification. To have this function, it needs
the collocation of Vista BIOS.
somit: ich hab den mal gebeten die funktion mit dem kleinen gui auch für win zu implementieren damit man wlan unabhängig vom bluetooh verwenden kann ohne das bluetooth das laufende wlan killt und man dann wenn bluetooth aktiv ist wieder die wlan connection aufmachen muss das beides funzt.
ich werd da drann bleiben aber is mir momentan nicht so wichtig da ich bluetooth so gut wie nie verwende.
greets @ all chris :wink:
hi,
ja klar kein prob.
aber die test (wenn ich test szenarien von denen dazu bekomme musst dann du machen, ich hab keinen hdmi fähigen bildschirm)
@ Ferengie
mein kontakt in taiwan weiß nun bescheid. ich hab ihm den thread von dir geschickt!
sobald ich aw hab gebe ich dir hier bescheid.:)
schau am besten jeden bzw. jeden 2ten werktag hier in diesen thread! falls tests gemacht werden müssen.
greets chris
@ all :hwluxx:
:mad::mad:
bei mir funzt unter xp keine einzige expresscard ordentlich! und wenn sie richtig erkannt wird (dann nur tlw.), dann ist wenn mit karte im slot rebootet > nachher ein gelbes rufzeichen im geräte manager.
wer eine expresscard hat bitte unbedingt testen. danke!!
seit langem wieder mal ein update:
bzgl. dem hdmi >> der msi typ meinte blabla bei ihnen ist alles ok und es wurden keine probs festgestellt. (die antwort hat eh noch ein nachspiel... keine sorge..)
aber derweil mal infos für alle >> das problem liegt bei intel und hat eigentlich nichts mit msi ansich zu tun.
es gibt sehr viele leute mit diversen notebooks die mit dem hdmi der intel gma x3100 grafik probleme haben.
testet mal mit diesem treiber ;-) der ist ganz frisch released worden nachdem sich in den intel eigenen foren die leute so aufgeregt haben!
http://downloadcenter.intel.com/Detail_Desc.aspx?ProductID=2876&DwnldID=16945&lang=eng
:wink:
p.s @ all bitte tested eure pr200 mit expresscards > karte bei geladenem win vista/xp instecken + gerätemanager checken ob gelbes rufzeichen vorhanden.
wenn dem nicht so sein sollte > bitte pc rebooten und schaun ob die karte dann überhaupt noch im gerätemanager aufscheint!! danke. denn bei mir gibts da massive probs und wenn ihr dann irgendwann eine expresscard selber dringend benötigt wird der kack dann nicht funzen wenns ned gefixed wird!!
Ok, danke werde ich machen.
Den Accelerator hab ich noch nicht getestet, dafür aber jeden Graka Treiber installiert der raus gekommen ist.
Klar das bei denen alles geht, sowohl ALB wie auch Wortmann können aber ebenso bestätigen, dass dies nicht geht. Die haben eh nur am 19" Monitor bestimmt getestet, weil die Auflösungen kleiner 1280x800 gehen.
genau das.
sag hast du irgendwen bekannten ect. mit einer firewire expresscard?? bzw. selbst eine?
ich weiß, hier wurde schon ewig nix mehr geschrieben...aber ich spiele mit dem gedanken, mein msi pr200 von 2gb RAM auf 4gb RAM aufzurüsten.
Erstmal: Was für eine Taktrate unterstützt es maximal? Verbaut sind ja 667Mhz Module, aber der Chipsatz hat doch 800MHz, oder? Werden dann 800MHz Module unterstützt?
Und dann: Was für Module sollten verbaut werden? Welche Marke?
Und: Lohnt sich der Aufpreis für CL4 statt CL5?
Hab 800MHz drin, wird aber nicht unterstützt, CL4 oder 5 ist egal...einiges mehr bringt eine 7200upm Platte.
Hat jemand das Bios schonmal getestet und kann sagen was sich verbessert / verschlechtert hat ? Lüftersteuerung endlich besser ?!?
Kein unterschied mit dem Lüfter...
Aber für IRGENDWAS muss es ja gut sein...:coolblue:
1) leute danke fürs zahlreichen testen mit expresscard bei euch :fire::fire::fire::fire::grrr::motz:
(kein einziger :heul::heul:)
entweder verwendet keiner von euch eine oder zu faul.
für zweiteres gibts :shot::shot:
oke hier ein massives problem das wie es derzeit aussieht alle betrifft!!(auch vista!)
war extrem schwer zu finden weil xp keine fehlermeldungen zu den devices siehe screenshot zeigt aber seht mal selbst:
falls bei euch kein sm-bus manager im gerätemanager angezeigt wird dann liegt es daran das dieser es nicht schafft resourcen zu bekommen und beim booten gleich (für den user unsichtbar) deaktiviert wird und nichtmal im gerätemanager angezeigt wird!
schaut unbedingt in eurem gerätemanger bei diesen geräten nach ob die resourcen auch konflikte haben!
bisher hab ich das auf meinem pr200 mit xp gefunden und auch jemand aus einem anderen forum der vista verwendet!!
neu installation von xp sp2 ändert leider garnichts.
bios ist das neueste, hab aber auch schon mit älteren versucht.
jeder der das pr200 mit xp nutzt bitte checkt das mal bei euch im gerätemanager.
ps. ich hab ein pr200 mit t8300 cpu. (pr200 satarosa refresh...)
thx
bzgl. lüfterproblem ect. paar seiten vorscrollen. msi hat ausdrücklich mitgeteilt das sie das nicht fixen werden.
warum bei der 3.47 der lüfter allerdings schneller dreht ist mir ein rätsel..
bei der 3.48 dreht er wie ich finde wieder nicht so schnell hoch bzw. ist hier auch auf stufe 1 auch nicht so laut
Ja, ist bei mir auch so.
Und? funktioniert doch trotzdem alles 1a...
:confused:
danke für die info.
sorry aber nein, da funktioniert gar und garnichts 1a.
:fresse:
der normaluser merkt es vielleicht nicht oder fast nicht und nimmt es nicht wahr.
aber willst du eine firewire expresscard ordentlich nutzen > massivste probleme weil die resourcen zuweisung nicht ordentlich funktioniert. genauso kann es mit div. anderen geräten die du anhängst probleme geben. z.b usb soundkarten oder anderem. genaugenommen das ist ein sehr massiver systemfehler!! den viele user nicht merken weil funktioniert ja eh alles aber so ist es leider nicht man sieht es nur von "aussen" nicht gleich.
zusätzlich kannst du bei dir auch mal nachschaun ob im gerätemanager der sm-bus vorhanden ist. ich vermute er wird nicht da sein. (du wirst ihn maximal mit everest sehen aber nicht im gerätemanager)
der grund > beim starten des pcs hat dieser einen resourcen conflict und wird dann nichtmal im gerätemanager angezeigt.
zusätzlich dazu:
die resourcenzuweisung des systems ist unter aller sau und funktioniert nicht so wie sie funzen sollte.
das resultat: systemgeräte die anders zugewiesen werden als sie eigentlich sollten, was der effekt sein kann > peformanceprobleme, abstürze, probleme mit usb geräten, probleme mit der qualität der wlan und lan connection ect.
warum? weil resourcen fallsch verteilt werden.
ich weiß nicht wieviel know how du über pc internes hast, klingt für mich sehr nach normaluser, im normalfall schlagen die leut bei sowas die hände über dem kopf zusammen.
danke für die info auf jedenfall.
@ alle anderen bitte unbedingt auch bei auch nachschaun.
dieses scheiss problem hat mich bisher über ein halbes jahr zeit (lesen div. microsoft / pci / pcie / 1934 spezifikationen lernen mit spezialtools wie pciscope zu arbeiten ect.) und über 800 reboots gekostet und kann euch auch noch den letzten nerv kosten wenns nicht gefixed wird falls ihr in zukunft auch mal was anderes an den pc hängen wollt ausser das was derzeit dran hängt.
sobald ich genug rückmeldungen hab geht das problem an meinen msi tw. kontakt und gleichzeitig auch direkt an intel!
ach und nochwas. hört mal was euer pc macht wenn ihr in länger garnicht angreift und dieser eingeschalten ist.
klackt die festplatte auch hin und wieder etwas lauter? (so ein kurzer klack)
vielleicht habt ihr das schon mal bemerkt.
jedes mal klacken ist ein cycle count mehr im smart der festplatte :fire:
was ist ein cycle count???
bei mir treten unter vista x86 auch die probleme im gerätemanager auf...
hi danke für die rückmeldung, sieht so aus als hätte da msi bewust oder unbewust mist gebaut.
entweder muss das bios gefixed werden oder mirosoft hat was zu fixen.
oder aber es sind am motherboard generell garnicht genug i/o resourcen vorhanden (hardwareseitig)... > na dann gute nacht.
weil das heisst msi kann den whql system test gleich mal vergessen (der laut dem taiwan support fritzen bestanden wurde..hat er mir geschrieben als ich ihn im oktober 08 mit zig versch. microsoft spezifikationen per email beschossen hatte :d:d und würde erklären warum der dann so komisch wurde als ich nur mehr auf resourcen probleme und meiner vermutung nach designfehlern gepocht hatte und er diese verneinte) und müsste eigentlich jedem sein pr200 gegen ein neues ohne das problem oder gegen den nachfolger austauschen sofern das problem dort nicht vorhanden sein sollte.
denn das wäre dann > das was verkaut wurde ist nicht das was auf der verpackung stand. (ein funktionierender pc ;-)
cycle count problem: (tritt mit div. festplatten auf versch. betriebssys auf. windows, mac, linux)
http://www.hitachigst.com/tech/techlib.nsf/techdocs/9076679E3EE4003E86256FAB005825FB/$file/LoadUnload_white_paper_FINAL.pdf
http://www.macuser.de/forum/f10/hd-idle-klick-408973/
http://forum.notebookreview.com/showthread.php?t=268465
mehr einfach im google suchen gibt eh genug davon.
hört man sch eigentlich eh schön laut: ist so ein richtiges klack das um einiges lauter ist als das normale arbeiten der platte..)
Hi acid falls ich dir noch helfen kann geb mir bescheid.Ich finde diesen SMBus garnicht unter Vista x86 bei mir ?!?
riCe
@acidrecords:
hi..
hab das bei mir jetzt auch entdeckt (sorry dass ich erst jetzt was getan hab und nicht früher geschaut habe):
allerdings ist bei mir nur der "Eingebetteter, Microsoft ACPI blabla" Controller zu finden...die anderen beiden sind gar nicht aufgelistet...eventuell liegt das auch an vista...ich verwende vista 64 bit...
falls das mit der ressourcenverwaltung wirklich nicht per biosupdate behebbar ist und das ein fataler designfehler von msi ist, dann müssen wir uns ALLE ernsthaft überlegen, wie wir das regeln wollen...wir müssen dann auch so viele besitzer wie möglich aus dem msi forum kontaktieren..
mal schauen wie sich das ganze entwickeln wird...
wenn was ist, meld dich bitte per pn bei mir und halt mich bitte auf dem laufenden..ich werde versuchen dir so gut es geht weiterzuhelfen..
außerdem haben wir alle was davon...
@acidrecords:
Bitte aber alle Ergebnisse hier posten, interessiert wohl alle hier...
Außerdem können vielleicht auch andere helfen- sollte also nicht nur unter euch beiden über PN stattfinden
:wink:
natürlich...war eher so gemeint, dass er sich bei mir melden soll, wenn er explizit von mir was braucht...hab mich da etwas unglücklich ausgedrückt...
wird natürlich alles wichtige auch hier gepostet...
also leute, testen, testen, testen!!!
lg
oh schon wieder einer mehr mit dem prob.
also so wies aussieht > jeder hat das prob, egal ob xp oder vista, egal ob 32 od. 64bit.
zusätzlich dazu sei gesagt alle belinea obook 4 kunden haben das prob auch.
belinea verkauft da den leuten das pr200 ;-) bezeichnung unten am notebook. ms-1221 ;-)
und auch diese haben das prob. und wies aussieht auch das pr210 .. aber da bekomm ich noch bescheid von einem user ;-)
von msi tw, deutschland und holland wart ich seit 1 woche auf eine aw.
also was jeder mal machen muss > nein nicht kann sondern muss! (leute es geht um euer notebook und euer geld!) in notebook foren posten posten und nochmals posten.
die auforderung richtet sich jetzt echt an jeden von euch! zusätzlich is wie gesagt das belinea auch betroffen! also auch da posten.
is ja nicht schwer einfach die screens hier ausm thread nehmen dich ich gepostet hab und posten egal ob englisch oder deutsche foren.
zusätzlich werd ich mich wenn ich bis do dieser woche keine aw. von msi bekommen habe am we. sämtliche hardwaremagazine anschreiben und da brauchts auch mehr user mit dem prob also nochmal, jeder einzelne > posted in alle hardware & notebook foren die euch einfallen bzw. die google ausspuckt wos dazu noch keinen thread gibt!
und solltet ihr threads in foren finden wo das prob schon steht > dann schreibt unbedingt dort auch noch selbst dazu das ihr das prob auch habt! weil das zeigt dann um so mehr über das prob wenn mans dann 5tage später im google aufruft ect. + leute die threads lesen und selber ein pr200 haben werden noch aufmerksamer weil sie sehen das mehrere versch leute in dem thread das prob haben und somit mit höherer warscheinlichkeit selber nachsehen + auch wenn sich nicht so technikversiert sind. (hö da habe leutz ein prob ich hab das gleiche teil ich will unbedingt wissen ob ich den fehler auch hab.) > effekt > das netz ist voll mit berichten von dem prob und der druck auf msi ist gleich von anfang an ziemlich hoch + mehr hardwareseiten ect. werden sich der sache annehmen ;-)
[Edit]
ah und noch was:
das prob betrifft sowohl die pr200 mit t8xxx cpus (santa rosa refresh platform) als auch die modelle mit schwächeren cpus.
+ besagtes belinea obook (pr200) ms-1221 funktioniert mit xp auch nicht mit firewireexpresskarten wie mir mittlerweile mitgeteilt wurde. (code12 im gerätemanager nach einem reboot..bzw keine funktion mit firewireaudiointerface)
also wenn ihr irgendwo z.b bei nem bekanntem zugriff auf eine firewireexpresscard habt > testen.
(mit vista tritt der code12 meineswissens nach nicht auf, die karte funzt da aber trotzdem auch nicht mit firewire audiointerfaces.)
bei xp gibts genauso code12..
am besten dann hier die forenlinks posten damit wir ne art linksammlung haben...zwecks einer besseren übersicht und damit nicht doppelt gepostet wird in den jeweiligen foren...
ich werde morgen direkt alb-computer kontaktieren und denen davon berichten...vielleicht können die auch mithelfen...immerhin geht es dabei auch um notebooks, die sie verkaufen...wortmann könnte man auch noch anschreiben...
lg
