[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
hmm die iChill hätt ich gern
Die 2000€ UVP dienen als Early Access Preis um den Gewinn in bessere Kabel Forschung zu investieren :ROFLMAO::ROFLMAO:
Vermutlich gibts demnächst eine Schulung wie man korrekt den Stecker einsteckt.
Und vorher brauchts noch eine Runde Messungen, ob die Umgebung überhaupt genügend Platz bietet für die benötigten Biegeradien.
Oh und wenn man schon biegen muss, dann brauchen wir auch eine Schablone, fixe anpackpunkte und ein definiertes Biegemoment, damit da nix passieren kann.
Also im Moment sind diese ganzen "Erkenntnisse" wirklich unbeschreiblich. Wenn das so eine Spezialistenaufgabe ist, dann muss die Karte von zertifizierten Technikern mit abschließendem Prüfprotokoll eingebaut werden...
Oder es gibt irgendwann mal den echten Grund und die echte Abhilfe und das Thema ist gegessen. Bis dahin wirds aber bestimmt noch genug Content für Videos und Berichte liefern.
Der Versandtermin meines CM-Kabels ist eine Woche nach vorne gesprungen :geek: (Bestellt am 18.10.)
Hat schon jemand Info zum TUF/Strixx block von alpahcool? Da sollte ja weas kommen, oder? Kennt man schon die Maße? Der 3090ti Block war wohl gar nicht mal sooo breit. Ich hab 150mm von Slot bis Gehäusewand, dachte da geht nur Ref oder FE. Aber evtl. passt ja auch ne Strixx mit Wasserkühler rein?
Gibt es schon:
Funktionierte einen Tag. Aber kann nicht mehr sagen wie schnell die Fans auf 0% gingen (nach eine Spielephase; auf jeden Fall schneller als 10Min; nach Boot direkt aus). Hab dann lieber fix eine Kurve gebastelt bzw. bin ich im Desktop manuell auf 46 und 49 Prozent. Wenn die Fans angeworfen wurden gingen sie von 0 direkt auf 1600 und das war nervtötend.
Danke für die Eindrücke. Verlässliches Zero RPM nach Boot würde mir schon genügen. Immerhin nutze ich den PC auch für andere Sachen als Spiele. 1600 RPM sind natürlich ne Hausnummer. Weiß nicht warum Zero RPM so ein schweres Thema ist für manche Hersteller.
kein Bock mehr mit diesem Adapter
Adapter sind generell mist. Einer der Gründe warum ich mir das ATX 3.0 Netzteil geordert habe.
musste eh upgraden von 850w
Wieso denn das? Ich betreibe meine 4090 sogar mit einem 750W Netzteil. Ich habe "nur" das 850W ATX 3.0 genommen. Habe sogar überlegt das Silverstone zu nehmen, weil ich das garantiert zum Wochenende habe. Aber dann kam ein Funke Vernunft durch :d
Verlässlich ist er. Gerade nochmal getestet (Boot wie Game). Und kleine Korrektur. Es sind 1400 RPM.
Der fucking AMD Chipsatztreiber wars :motz:
Seit 12.10 gibt es ne neue Version und ich hatte nicht mitbekommen das es ein Update gab, also hatte ich noch die Version von davor.
Mit dem aktuellen Chipsatz Treiber fährt der Rechner mit der Suprim X ohne Probleme aus Windows heraus runter oder in den Energiesparmodus.
Diese zickige MSI Karte geht mir total auf den Senkel.
Es war nicht der Chipsatztreiber, aber mittlerweile weiß ich zu 100% woran es liegt - der Temperatur der GPU.
Als ich dachte der Chipsatztreiber wars war die GPU schlicht nicht warm genug um Probleme zu machen.
Jedenfalls: Die Karte sitzt ist im Idle immer so im Bereich 50-60°C, da ich im Idle keine Lüfter laufen habe, außer den 2 CPU-Lüftern @ 5V.
Die Lüfter der Karte selbst fangen ja erst bei 61°C an sich zu drehen. Wenn ich also in diesem Temperaturbereich versuche den Rechner herunterzufahren, egal ob ich davor ein Spiel gespielt habe oder 1h gesurft habe kommt stattdessen ein Neustart. Sieht dann so aus:
Wenn ich die Karte aber vor dem Herunterfahren runterkühle, wieder egal ob ich grade gespielt hatte oder gesurft, dann fährt der Rechner auch wirkich runter.
Warum genau die Suprim in meinem Rechner so rumzickt weiß ich nicht. In dem exakt selben Rechner Setup hatte ich ne EVGA 1080Ti, ne MSI 3080 Gaming X Trio, Zotac 3080Ti Trinity und ein paar Stunden ne Gainward 4090 Phantom am laufen, auch imer so 50-60°C Idle und keine dieser Karten hatte damit auch nur das geringste Problem.
Hatte jemand von euch auch schon mal so ein Problem und wenn ja, wie habt ihr es gelöst?
Nicht nur Chip Lotterie sondern auch Adapter Lotterie samt Lager und Spulenfiepen
Dies ist mit Abstand die Leistungsfähigste Generation seit langen aber wird überschatten von Problemen die uns verrückt machen
Lasst uns einfach die Daumen drücken, dass unsere GPUs so lange durchhalten bis es endlich Lösungen gibt 💁🏽
Überrascht dich das? Nvida ist einfach mies bei Launches, bereits 2080ti und 3090 hatten zum Launch Probleme, hatte schon gerätselt welches Problem es bei der 4000 Gen wird und siehe da
gibt es eigentlich zahlen wieviele karten im umlauf sind?
setz' doch mal das bios zurück und guck ob's dann anders wird. evtl. hast du im UEFI auch bei den start/aufwachoptionen etwas aktiviert, das man besser ausschalten sollte. wake per PCIe oder ähnliches.
tobi
Mehr ist nicht passiert ? Irgendwas erwähnt wurden was für uns vilt wichtig ist ? ^^
Was hätte da denn kommen sollen? Bzgl. diesem Thema sind einige in den Foren dieser Welt aufgeregt. Ansonsten ist es recht entspannt. Ist doch auch gut gelaufen, Karte geht zurück und neue kommt. Thema erledigt.
Dann bin ich aber mal echt froh bisher immer Glück gehabt zu haben und die Karte ohne Spulenfiepen und ohne Probleme erwischt zu haben. Und das schon 5 Generationen jetzt. Meine letzte fiepende Karte war von AMD. Irgendwas mit Vapor glaub ich. War so bläulich. War angeblich das "Topmodell".
Hab auch die Gaming OC, direkt nach Boot PC sind die dann aus. Also bin nach wie vor top zufrieden damit. Der Wunsch nach nem anderen Modell erloschen.
tobi
Das hatte ich auch schon versucht, mit ner älteren Bios Version und mit der aktuellen meines Boardes. Das einzige was nicht Stockeinstellung ist sind XMP des Rams und die Lüfterkurve der beiden CPU-Lüfter.
Ich lass die Lüfter im idle immer so bei 20% laufen.
Leider können die Bequiet Lüfter an meiner aquaero nur 0 oder 1000 UPM. Wird vermutlich mal zeit andere Lüfter auszuprobieren.
Diese IDLE-Temps der MSI kommen mir ganz schön hoch vor. Das sind ja teilweise schon Load-Temps bei anderen Karten.
Jetzt geht's los, der erste AiB der Probleme bei seinen dedizierten Kabeln zugibt
Der beiliegende Adapter 2x8-Pin auf 12+4-Pin kann bestimmt 600W, aber das Netzteil ist nur für 450W, also maximal 225W pro 8-Pin (am Netzteil) ausgelegt.
Das große 1600W Netzteil hat dafür 11x8-Pin Anschlüsse...Seasonic hätte demnach einen 3x8-Pin oder 4x8-Pin auf 12+4-Pin Kabel beilegen müssen.
Deswegen hat das Netzteil auch keine 1x8-Pin auf 2x8-Pin Daisychain PCI-E Kabel!!!
Genau an dem Daisychain Kabel erkennt man auch, wieviel ein Netzteil pro Kabel liefern kann. Schließlich ist so ein Kabel auf biszu 300W ausgelegt.
Tl;dr Hat nichts mit einem Adapter zu tun, sondern mit dem Output des Netzteils.
Der Adapter zieht mehr Strom als das Netzteil kann, weil der falsche Sensorpin geerdet ist.
Die GPU brennt nicht ab, sondern das Netzteil schaltet ab >_>
Lösung:
Man schneidet beim Adapter das richtige Sensor-Kabel (Sense0) durch und man hat nur noch 450W statt 600W...
Unabhängig von der Thematik, dass bei den Varianten die Anzahl der Pads im Inneren des Steckers wichtig sind, wären hier mehr Daten die zerstörungsfrei erhoben werden können interessant. Kommt schon, noch ein paar Besitzer einer GeForce RTX 4090 hier, die noch nicht teilgenommen haben?
Ich guck heute abend mal
  • Danke
Reaktionen: Don
Ähnliche Themen
Antworten
6K
Aufrufe
392K
