WinstonChurchill
Profi
This is my old FX57. It reached 4GHz, but I have a sacred rule: never use a multiplier higher than x15This one might scale well on cold. One of my FX-55 is BG as well.
I am not sure why you won't use more then multi 15x. Because that would limit you hugely with max fsb which gets less with more cold. With a higher multi it will do better speeds.
QPB as Quad Pumped Bus?Because I'm from the old school of OPB 🤗
Probably OPB as in OnePageBook, the overlocker who at some point got banned from XS?
