c:\Users\xxx\Downloads\hashcat-6.2.6>hashcat.exe -b
hashcat (v6.2.6) starting in benchmark mode
Benchmarking uses hand-optimized kernel code by default.
You can use it in your cracking session by setting the -O option.
Note: Using optimized kernel code limits the maximum supported password length.
To disable the optimized kernel code in benchmark mode, use the -w option.
hiprtcCompileProgram is missing from HIPRTC shared library.
Successfully initialized the NVIDIA main driver CUDA runtime library.
Failed to initialize NVIDIA RTC library.
* Device #1: CUDA SDK Toolkit not installed or incorrectly installed.
CUDA SDK Toolkit required for proper device support and utilization.
Falling back to OpenCL runtime.
* Device #1: WARNING! Kernel exec timeout is not disabled.
This may cause "CL_OUT_OF_RESOURCES" or related errors.
To disable the timeout, see:
https://hashcat.net/q/timeoutpatch
OpenCL API (OpenCL 3.0 CUDA 12.9.40) - Platform #1 [NVIDIA Corporation]
* Device #1: NVIDIA GeForce RTX 5090, 30464/32606 MB (8151 MB allocatable), 170MCU
Benchmark relevant options:
* --optimized-kernel-enable
* Hash-Mode 0 (MD5)
Speed.#1.........: 232.1 GH/s (3.03ms) @ Accel:16 Loops:1024 Thr:256 Vec:1
* Hash-Mode 100 (SHA1)
Speed.#1.........: 78046.2 MH/s (9.10ms) @ Accel:16 Loops:1024 Thr:256 Vec:1
* Hash-Mode 1400 (SHA2-256)
Speed.#1.........: 31909.7 MH/s (22.29ms) @ Accel:16 Loops:1024 Thr:256 Vec:1
* Hash-Mode 1700 (SHA2-512)
Speed.#1.........: 9904.3 MH/s (71.92ms) @ Accel:16 Loops:1024 Thr:256 Vec:1
* Hash-Mode 22000 (WPA-PBKDF2-PMKID+EAPOL) [Iterations: 4095]
Speed.#1.........: 3843.0 kH/s (44.79ms) @ Accel:16 Loops:1024 Thr:256 Vec:1
* Hash-Mode 1000 (NTLM)
Speed.#1.........: 350.7 GH/s (1.96ms) @ Accel:16 Loops:1024 Thr:256 Vec:1
* Hash-Mode 3000 (LM)
Speed.#1.........: 243.3 GH/s (2.85ms) @ Accel:32 Loops:1024 Thr:128 Vec:1
* Hash-Mode 5500 (NetNTLMv1 / NetNTLMv1+ESS)
Speed.#1.........: 229.3 GH/s (3.05ms) @ Accel:32 Loops:1024 Thr:128 Vec:1
* Hash-Mode 5600 (NetNTLMv2)
Speed.#1.........: 18342.4 MH/s (38.81ms) @ Accel:16 Loops:1024 Thr:256 Vec:1
* Hash-Mode 1500 (descrypt, DES (Unix), Traditional DES)
Speed.#1.........: 10244.4 MH/s (69.49ms) @ Accel:16 Loops:1024 Thr:256 Vec:1
* Hash-Mode 500 (md5crypt, MD5 (Unix), Cisco-IOS $1$ (MD5)) [Iterations: 1000]
Speed.#1.........: 92555.1 kH/s (6.07ms) @ Accel:16 Loops:1000 Thr:256 Vec:1
* Hash-Mode 3200 (bcrypt $2*$, Blowfish (Unix)) [Iterations: 32]
Speed.#1.........: 345.6 kH/s (80.28ms) @ Accel:16 Loops:32 Thr:11 Vec:1
* Hash-Mode 1800 (sha512crypt $6$, SHA512 (Unix)) [Iterations: 5000]
Speed.#1.........: 1614.1 kH/s (32.08ms) @ Accel:2048 Loops:1024 Thr:128 Vec:1
* Hash-Mode 7500 (Kerberos 5, etype 23, AS-REQ Pre-Auth)
Speed.#1.........: 4807.7 MH/s (74.05ms) @ Accel:512 Loops:128 Thr:32 Vec:1
* Hash-Mode 13100 (Kerberos 5, etype 23, TGS-REP)
Speed.#1.........: 4792.2 MH/s (74.29ms) @ Accel:512 Loops:128 Thr:32 Vec:1
* Hash-Mode 15300 (DPAPI masterkey file v1 (context 1 and 2)) [Iterations: 23999]
Speed.#1.........: 664.6 kH/s (43.51ms) @ Accel:16 Loops:1024 Thr:256 Vec:1
* Hash-Mode 15900 (DPAPI masterkey file v2 (context 1 and 2)) [Iterations: 12899]
Speed.#1.........: 386.1 kH/s (69.11ms) @ Accel:16 Loops:1024 Thr:128 Vec:1
* Hash-Mode 7100 (macOS v10.8+ (PBKDF2-SHA512)) [Iterations: 1023]
Speed.#1.........: 4601.2 kH/s (49.39ms) @ Accel:16 Loops:511 Thr:256 Vec:1
* Hash-Mode 11600 (7-Zip) [Iterations: 16384]
Speed.#1.........: 3527.4 kH/s (46.36ms) @ Accel:16 Loops:4096 Thr:256 Vec:1
* Hash-Mode 12500 (RAR3-hp) [Iterations: 262144]
Speed.#1.........: 351.9 kH/s (20.15ms) @ Accel:16 Loops:16384 Thr:256 Vec:1
* Hash-Mode 13000 (RAR5) [Iterations: 32799]
Speed.#1.........: 404.4 kH/s (52.07ms) @ Accel:16 Loops:1024 Thr:256 Vec:1
* Hash-Mode 6211 (TrueCrypt RIPEMD160 + XTS 512 bit (legacy)) [Iterations: 1999]
Speed.#1.........: 3110.6 kH/s (54.10ms) @ Accel:8 Loops:1024 Thr:256 Vec:1
* Hash-Mode 13400 (KeePass 1 (AES/Twofish) and KeePass 2 (AES)) [Iterations: 24569]
Speed.#1.........: 511.7 kH/s (56.61ms) @ Accel:16 Loops:1024 Thr:256 Vec:1
* Hash-Mode 6800 (LastPass + LastPass sniffed) [Iterations: 499]
Speed.#1.........: 24617.7 kH/s (25.99ms) @ Accel:16 Loops:499 Thr:256 Vec:1
* Hash-Mode 11300 (Bitcoin/Litecoin wallet.dat) [Iterations: 200459]
Speed.#1.........: 51119 H/s (69.53ms) @ Accel:16 Loops:1024 Thr:256 Vec:1
Started: Sun Apr 27 18:36:21 2025
Stopped: Sun Apr 27 18:37:40 2025
