ABIT AW9D/MAX (i975X) Sammelthread+ FAQ (Part 1)
9800ProZwerg
Semiprofi
Hamburg
Ich bin mal so frei und eröffne, da heute offiziell die ABIT AW9D Series vorgestellt wurde, einen Sammelthread:) !
Specs:
AW9D
Preis: http://www.geizhals.at/eu/a214105.html
Bios Downloads:
http://www.abit.com.tw/page/de/download/download_bios_detail.php?pFILE_TYPE=Bios&pMAIN_TYPE=Motherboard&pTITLE_ON_SCREEN=AW9D&pSOCKET_TYPE=LGA775
CPU
* Designed for Intel® LGA775 processors with1066/800MHz FSB
* Supports Intel® Core™ 2 Duo & Pentium® Extreme Edition & Pentium® D & Pentium® 4 Processors
* Supports Intel® Hyper-Threading / XD-bit / EM64T / EIST Technology / Virtualization Technology
* Intel® Quad Core ready.
Chipset
*Intel® 975X / Intel® ICH7R Express Chipset
Memory
* 4 X 240-pin DIMM sockets support max. memory capacity 8GB
* Supports Dual channel DDR2 800/667 Un-buffered / Non-ECC memory
Graphics
* Supports Dual PCI-Express X16 slots (dual ATI® CrossFire™ Graphics)
LAN
* On-board PCI-E Gigabit LAN controller supports 10/100/ 1000M Ethernet
Audio
* abit AudioMAX™ HD 7.1 CH
* Supports Jack Sensing and S/PDIF In/Out
* Dolby® Master Studio Certificated
Expansion Slots
* 2xPCI-EX16, 2xPCI-EX1, 1xPCI, 1xAudioMAX™
Internal I/O Connectors
* 1 x Floppy port, 1 x UDMA 100/66/33 connector,
* 4 x SATA 3Gb/s connectors
* 2 x USB 2.0 headers
* 1 x FP-Audio header, 1 x CD-IN
Back Panel I/O
* 1 x PS/2 Keyboard, 1 x PS/2 Mouse
* 4 x USB 2.0, 1 x RJ-45 LAN
Serial ATA
* ICH7R: 4 x SATA 3Gb/s supports Intel® Matrix Storage SATA RAID 0/1/0+1/5
* Support SATA AHCI, providing native command queuing and native hot plug
abit Engineered
* abit µGuru™ Technology
* abit OTES™ Technology
* Quick Power & Reset Buttons
* Low ESR and high ripple conductive polymer aluminum solid capacitors
RoHS
* RoHS Compliancy
Form Factor
* ATX form factor 305 x 245mm
* PCB Color: Black
AW9D-MAX
http://img208.imageshack.us/my.php?image=aw9dmaxangle500lz4.jpg
http://img209.imageshack.us/my.php?image=aw9dmaxtop500al3.jpg
http://img234.imageshack.us/my.php?image=maxof9.jpg
Preis: http://www.geizhals.at/eu/a214107.html
Lieferumfang:
- AudioMax HD 7.1 Soundkarte
- SLI Bridge
- Quick Setup Manual, ausführliches Manual, **** Manual
- Jumper Settings Aufkleber
- 7! SATA Kabel
- 3 SATA RAID Floppys (32 und 64 Bit Sil, Intel RAID)
- Treiber CD
- Optisches Audiokabel
- Je 1 IDE und Floppy Kabel, gerundet
- Bracket mit 2x USB und 1x Firewire
Bios Downloads:
http://www.abit.com.tw/page/de/download/download_bios_detail.php?pFILE_TYPE=Bios&pMAIN_TYPE=Motherboard&pTITLE_ON_SCREEN=AW9D-MAX&pSOCKET_TYPE=LGA775
CPU
* Supports Intel® Core™ 2 Duo(Extreme Edition) & Pentium® Extreme Edition & Pentium® D & Pentium® 4 Processors
Chipset
Memory
Graphics
LAN
* On-board Dual PCI-E Gigabit LAN controller supports 10/100/ 1000M Ethernet
Audio
Expansion Slots
* 2xPCI-EX16,2xPCI-EX1,1 xPCI, 1x AudioMAX™
* 7 x SATA 3Gb/s connectors
* 2 x USB 2.0 headers, 2 x IEEE1394 headers
Back Panel I/O
* 4 x USB 2.0, 2 x RJ-45 LAN,
* 1 x eSATA
Serial ATA
* ICH7R: Support SATA AHCI, providing native command queuing and native hot plug & play
* Silicon Image:3132: 4 x SATA 3Gb/s, two SATA connectors of the same area can support SATA RAID 0/1
IEEE 1394
* 2 ports IEEE1394a at 400 Mb/s transfer rate
abit Engineered
* abit Silent OTES™ 2 Technology
* Back-light Blue LED's
RoHS
* RoHS Compliancy
Form Factor
* PCB Color: Black & Blue
FAQ zum ABIT AW9D-MAX (Vielen Dank an Sicness):
Wichtige Links:
Produktseite bei abit
BIOS download
Manual download
abits interne Kompatibilitätstests
Thread @ XtremeSystems.org
Gelten die folgenden Angaben auch für das non-Max oder Fatality?
Nein, beide Boards sind bis heute nicht erhältlich. Daher gilt dieses FAQ ausschliesslich für die Max Version.
Passt meine PCI-Karte in den PCI Slot wenn ich CF/SLI nutze?
Wenn die GraKa nen Single Slot Kühler hat wird der PCI nicht blockiert, bei einer Flachen WaKü a la Inno oder AC ebenfalls nicht.
Hey, da ist ja ne SLI Bridge dabei. Wird SLI offiziell unterstützt?
Nein, SLI ist nur mit gehackten Treibern möglich.
Bei mir funzt µGuru nicht richtig! Was ist los?
Das Problem tritt beim Release Bios in Verbindung mit einem Raid auf!
Lösung ist das neue .12 Bios!
Laufen 7900/7950GX2 problemlos auf dem Board?
Ja, die 7900GX2 läuft absolut problemlos.
Meine 7950GX2 bringt nur die halbe Leistung! Was ist hier los?
Laut dem User Dr.Wakeman liegt das an der µGuru Software.
Es verträgt sich nicht mit den aktuellen Forceware Treibern!
Der SLI Algorithmus läuft weder mit SFR, AFR oder AFR2.
Gibt es bekannte Probleme mit irgendwelchen RAMs?
Bisher nur eine Meldung, OCZ XTC Gold PC6400 C5 mit Elpida Chips laufen nicht mit 1:1, mit anderen Teilern jedoch problemlos. Micron D9 laufen einwandfrei.
Kann ich die Heatpipe entfernen und die Passivkühler in Kombination mit meiner Chipsatzwakü nutzen?
Nein, die Heatpipes sind fest verlötet. Es müssten in diesem Fall seperate passive Kühlkörper besorgt werden.
Falsch! Turrican bestätigt dass die Heatpipe nicht verlötet ist!
Bilder:
Was taugt die Heatpipe Konstruktion?
Die Kühlung arbeitet überraschend effizient, einen gewissen Luftstrom vorrausgesetzt lassen sich moderate Übertaktungen ohne zusätzliche Kühlung bequem bewältigen.
Sehe ich richtig? Das Board hat Lochhalterungen? Ich dachte Intel benutzt Ösen.
Richtig, abit bildet hier eine Ausnahme.
Wie hoch geht denn nun der FSB?
Die bisher höchsten Meldungen liegen im Bereich 450-460MHz, jedoch sind hier wohl die Chipsatztimings straffer als bei anderen 975X Boards. Sicher ist aber wohl ~420 MHZ!
hipro5 schrieb:
I also would like to add that ABIT "played" my Fadbodies a bit tighter that ASUS or Bad Axe......In 2k5 I got about 80 to 100 points more with ABIT with the EXACT same config as with ASUS/INTEL.......No big deal especially on air BUT when you go for the max, it counts.....Those points will be 200 - 300 on LN2 so as for me it counts.....
Ist es besser als die anderen 975X Bretter?
Lässt sich bisher noch nicht sagen, das Board hat bisher noch kein offizielles BIOS Update erfahren und ist wesentlich kürzer am Markt als Asus & Co. Es ist in jedem Fall vielversprechend und scheinbar sein Geld wert.
Welche Spannungsoptionen sind vorhanden?
VCore: 1,32V - 1,725V
VDIMM: 1,80V - 2,65V
MCH: 1,50V - 2,00V
Hat das Board auch das Shutdown Problem nach Übertaktung (vgl. Asus P5WDH)?
Nein.
Welche Straps und Teiler gibt es?
PSB533: 1:2
PSB800: 3:4, 3:5, 1:2
PSB1066: 1:1, 4:5, 2:3
Wieviele Lüfter kann ich anschliessen und was kann die Lüftersteuerung?
Das Board hat 7 Lüfteranschlüsse, jeder Lüfter ist zwischen 6 und 12V regelbar. Ausgenommen ist der CPU Lüfter, dieser kann nach Temperatur geregelt werden.
Was taugt die **** Software?
Die Software liest unter Windows Temperaturen, Spannungen, Lüftergeschwindigkeit und sogar Power Cycles aus. Übertakten in Windows ist hiermit kinderleicht möglich und funktioniert absolut einwandfrei, sofern man nicht die Grenzen der Hardware überschreitet ;)
Gibt es schon Alternativen zur **** Software?
W1zzard wird diese Woche (18.09.2006 ff) ein AW9D-Max bekommen und Support fürs Brett in SysTool einbauen.
Hilfe! Mein Board bootet einwandfrei aber ich habe trotzdem ein Piepkonzert! Ich benutze eine Wasserkühlung.
Sehr wahrscheinlich handelt es sich um das Notsignal des Boards zu Warnung vor 0 RPM am CPU Lüfter Anschluss. Das lässt sich im BIOS (abit EQ) deaktivieren.
Was hat es mit den LEDs auf sich?
Das Board besitzt blaue LEDs, die folgende Optionen besitzen: Alle LEDs an, aus oder verschieden blinkende Modi.
Ich habe von einem fehlerhaften 8 Pin EPS Stecker gelesen. Muss ich beim Board Kauf aufpassen?
Nein, ein solch fehlerhaftes Modell ist bisher weltweit nur ein einziges Mal aufgetaucht und der Fall wurde von abit direkt untersucht. Dies wird nicht mehr vorkommen.
Mein Netzteil hat nur einen 4 Pin 12V Stecker, kann ich das Board auch damit betreiben?
Ja.
Funktioniert EIST mit einem übertaktetem System?
Ja.
Hat abit auch ein BIOS Flashtool für Windows?
Ja, das abit Flashmenu ist im **** Softwarepaket enthalten und funktioniert problemlos.
Kann ich den Multi meiner CPU verstellen?
Ja, seit dem beta BIOS vom 15.09. ist es möglich, den Multi nach unten hin zu ändern. Dies gilt sowohl für ES als auch Retail CPUs.
Seit Alpha Bios 13 ist es auch möglich Multi nach oben zu verändern!
Wie gut ist der Support seitens abit für das Board?
Exzellent. abit ist bestrebt alle auftretenden Probleme so schnell wie möglich aus der Welt zu schaffen und arbeitetet dazu mit Speicherherstellern und einigen Leuten von Anandtech und XtremeSystems.org zusammen. Fortschritte werden umgehend in BIOS Updates umgesetzt.
Welche RAM Bänke soll ich nutzen? 1 und 3 oder 2 und 4?
Macht nach bisherigem Kenntnisstand keinen Unterschied.
Ein paar Bilder des Boards und der OVP bitte!
Die LEDs möcht ich auch mal sehen!
Das BIOS dann bitte auch noch.
Warum zum Teufel komme ich nur bis zu einem FSB von 350MHZ?
Fürs schnelle Testen (natürlich auf eigene Gefahr!!) am besten folgendes einstellen:
C1 und EIST disabled
VMCH: 1,75V-1,9V
DDR2 Voltage: 2,0-2,1V
Ram Timings by SPD / oder manuell
Vcore: 1,4V
Speicherteiler 1:1
Dann Testen und vorsichtig heran tasten! Gegebenfalls dann Spannungen nach unten senken!
Das ABIT ist anscheinend sehr abhängig vom richtigem RAM!
Deshalb nicht gleich aufgeben:)
WICHTIG:
Laut Hipro aus Xtremesystems undervoltet die MCH Spannung mit 0,2V!
Hier der Link zum Statement und Mod:
http://www.forumdeluxx.de/forum/showpost.php?p=4447534&postcount=1118
Hier die Vcore Tabelle von w1zzard (THX):
MIPS Wasserkühler für das ABIT AW9D-MAX
Preise:
Freezer: 39,90€
Mosfet Bridge: 43,00€
Komplettset : 155,00€
die freezer sind wie immer aufgebaut, d.h. kupferboden 5mm, messingdeckel
5mm.
Unterschiede zwischen AW9D und AW9D MAX:
Das MAX hat ne Blaue LED Rückseitenbeleuchtung+
den angewinkelten IDE Port + Firewire
Links & Downloads:
Final Bios 12 (THX@Kabautermann):
http://www.hardwarextreme.de/dave/aw9d12.rar
BIOS Downloads vom ABIT ftp server:
ftp://ftp.abit.com.tw/pub/download/bios/
Die Biosversionen fürs Non-MAX und MAX sind anscheinend die gleichen, da nur ein
AW9D Verzeichnis vorhanden ist!
Thread zum Retail Board bei Xtremesystems (Sicness:):
http://www.xtremesystems.org/forums/showthread.php?t=115839
Thread zum Retail Board im ABIT Forum (Danke Sicness):
http://forum.abit-usa.com/showthread.php?t=112896
Vielen Dank an TuricanM3 und Latest für die Pics und Scines für die FAQ
Sehr nice :coolblue:
nur irgendwie glaube ich den Pics auf der Abit Homepage nicht ... das AW9 schaut irgendwie blau aus wo es doch schwarz sein soll :hmm:
Ich hoff mal die Brettchen gibbet bald zu kaufen :)
Anarchy schrieb:
Wird also der Sammelthread genehmigt:)
Das wundert mich auch sehr!
Das hoffe ich auch:drool:
Angeblich ja Ende August/Anfang September...
Ich werd mir in jedem Fall das AW9D-Max holen. Nach jahrelangem DFI Konsum mal wieder abit ne Chance geben ;)
WoW das mit Abstand schönste Board, wirkt so edel :)
Hoffentlich gelingt Abit endlich wieder ein IC7 Klasse Board und versenkt die Asus ;)
Offiziell 7950GX2 ready sinds wohl auch, bei Xtremesystems ist man drauf aufmerksam geworden:
Da hat jemand alle Hausaufgaben gemacht :)
Frage:
überall liest man von nur einem IDE Steckplatz, aber wenn ich das Board ansehe, dann sehe ich doch drei dieser alten Steckplätze, wobe einer für's Floppy ist und die anderen beiden eben IDE 1 und IDE 2...
Kann mir da mal jemand weiterhelfen...?
Wenn's gut ist, würde ich gerne bald vom IC7-MAX3 auf's neue MAX umsteigen...
Dr.Terror schrieb:
Frage:
ich geh mal nach deinen beschriftungen:
FDD = 24Pol 12v Stecker
IDE1 = IDE
IDE2 = FDD
Chris
Ah Mist, der 24Pol... an den habe ich echt nicht gedacht...
Danke...
du hast das AW9D-Fatality vergessen^^
Das AB9(965er Chipsatz)hat seine Probleme im BIOS. Ich hoffe das AW9 is da besser sonst sich ich schwarz für Abits Wiedergeburt.
Der MarketingText is mal voll der Dreck:
Mark, a bright new Star at Abit Engineering...blahblah
->preisen die sich selbst an WOW!
iLL
Das Fatality wurde noch nicht vorgestellt, nur das AW9D und die MAX Version.
Zum Text ... naja, sie haben halt einen jungen, aufstrebenden (und wahrscheinlich imaginären ;)) Ingineur hervorgehoben. Klar, Marketing, aber so schlimm ists auch nicht :)
iLL
Das Bios Problem hat auch dafpr gesorgt das sich so mancher Benutzer (mich eingeschlossen) von dem Board abgewendet hat.Der 975er sollte aber vom Bios her ausgereifter sein, da es ihn einfach schon länger gibt.
Aber der Preis von angepeilten 230 $ ist doch recht happig.
Eigentlich müsste Abit den Preis tiefer ansätzen, um verlorenen Boden gegenüber Asus mit deren P5WDH gut zu machen!
Fatality, wie bereits geschrieben, noch nicht vorgestellt!
Ich wage mal zu bezweifeln dass beide PCI-E x16 Slots tatsächlich mit 16 Lanes angebunden sind.
Schliesslich handelt es sich um eine Beschränkung des Chipsatzes von Intel - wie sollte die wohl von Abit beseitigt worden sein. No way imho.
Wo steht das beide PCI-E x16 Slots mit jeweils 16 Lanes angebunden sind?
Hier nirgends aber in nem anderen Forum.
Und ehrlich gesagt würd ich es als angebracht empfinden wenn die Hersteller diese Specs mal in die Produkt-Beschreibung aufnehmen würden.
Ist der 975X nicht auf 2x 8 Lanes im CF Betrieb limitiert? Reicht imho eh aus.
Im Abit Forum gibt es noch 2 Threads die was aktueller sind als der Verlinkte ...
AW9D MAX :
http://forum.abit-usa.com/showthread.php?t=111424
FP-A9D Fatal1ty :
http://forum.abit-usa.com/showthread.php?t=108016&page=2
Ich denk mal wenn das Fatal1ty offiziell vorgestellt wird sollte es auch hier rein - effektiv ist es ja nicht viel anders als die AW9D ...
Und bei den unterschieden zwischen MAX und non-MAX fehlt : Das MAX hat ne Blaue LED Rückseiten-beleuchtung :d das hatte ich komplett übersehen ...
Eigendlich war ich ja fest entschlossen das ASUS P5W DH Delux zu nehmen, aber jetzt wo ich das Mobo gesehen hab bin ich ins grübeln gekommen.......schaut echt geil aus......ich hoffe es leistet was, dann hol ich mir das MAX
Kommt spätestens in 2 Wochen, vllt. auch schon etwas früher. :)
Nujo, wir werden sehen wann die Boards verfügbar sind. Bis jetzt sind die Boards nirgends gelistet.
IcyRocket schrieb:
Hab nen Plausch mit nem seriösen Händler gehabt.
Mal wieder ... und vor wenigen Wochen haste gemeint dass die BOXEDconroes nicht vor Ende August kommen :hmm:
Naja - theoretisch reicht ein PCIslot schon aber was wenn man WLAN+Sound braucht? WLAN-USBsticks haben keine hohe Leistung - da kenn ich mich aus^^
iLL
