ABIT AW9D/MAX (i975X) Sammelthread+ FAQ (Part 2)
9800ProZwerg
Semiprofi
Hamburg
Ich bin mal so frei und eröffne, da heute offiziell die ABIT AW9D Series vorgestellt wurde, einen Sammelthread:) !
Specs:
AW9D
Preis: http://www.geizhals.at/eu/a214105.html
Bios Downloads:
http://www.abit.com.tw/page/de/download/download_bios_detail.php?pFILE_TYPE=Bios&pMAIN_TYPE=Motherboard&pTITLE_ON_SCREEN=AW9D&pSOCKET_TYPE=LGA775
CPU
* Designed for Intel® LGA775 processors with1066/800MHz FSB
* Supports Intel® Core™ 2 Duo & Pentium® Extreme Edition & Pentium® D & Pentium® 4 Processors
* Supports Intel® Hyper-Threading / XD-bit / EM64T / EIST Technology / Virtualization Technology
* Intel® Quad Core ready.
Chipset
*Intel® 975X / Intel® ICH7R Express Chipset
Memory
* 4 X 240-pin DIMM sockets support max. memory capacity 8GB
* Supports Dual channel DDR2 800/667 Un-buffered / Non-ECC memory
Graphics
* Supports Dual PCI-Express X16 slots (dual ATI® CrossFire™ Graphics)
LAN
* On-board PCI-E Gigabit LAN controller supports 10/100/ 1000M Ethernet
Audio
* abit AudioMAX™ HD 7.1 CH
* Supports Jack Sensing and S/PDIF In/Out
* Dolby® Master Studio Certificated
Expansion Slots
* 2xPCI-EX16, 2xPCI-EX1, 1xPCI, 1xAudioMAX™
Internal I/O Connectors
* 1 x Floppy port, 1 x UDMA 100/66/33 connector,
* 4 x SATA 3Gb/s connectors
* 2 x USB 2.0 headers
* 1 x FP-Audio header, 1 x CD-IN
Back Panel I/O
* 1 x PS/2 Keyboard, 1 x PS/2 Mouse
* 4 x USB 2.0, 1 x RJ-45 LAN
Serial ATA
* ICH7R: 4 x SATA 3Gb/s supports Intel® Matrix Storage SATA RAID 0/1/0+1/5
* Support SATA AHCI, providing native command queuing and native hot plug
abit Engineered
* abit µGuru™ Technology
* abit OTES™ Technology
* Quick Power & Reset Buttons
* Low ESR and high ripple conductive polymer aluminum solid capacitors
RoHS
* RoHS Compliancy
Form Factor
* ATX form factor 305 x 245mm
* PCB Color: Black
AW9D-MAX
http://img208.imageshack.us/my.php?image=aw9dmaxangle500lz4.jpg
http://img209.imageshack.us/my.php?image=aw9dmaxtop500al3.jpg
http://img234.imageshack.us/my.php?image=maxof9.jpg
Preis: http://www.geizhals.at/eu/a214107.html
Lieferumfang:
- AudioMax HD 7.1 Soundkarte
- SLI Bridge
- Quick Setup Manual, ausführliches Manual, **** Manual
- Jumper Settings Aufkleber
- 7! SATA Kabel
- 3 SATA RAID Floppys (32 und 64 Bit Sil, Intel RAID)
- Treiber CD
- Optisches Audiokabel
- Je 1 IDE und Floppy Kabel, gerundet
- Bracket mit 2x USB und 1x Firewire
Bios Downloads:
http://www.abit.com.tw/page/de/download/download_bios_detail.php?pFILE_TYPE=Bios&pMAIN_TYPE=Motherboard&pTITLE_ON_SCREEN=AW9D-MAX&pSOCKET_TYPE=LGA775
CPU
* Supports Intel® Core™ 2 Duo(Extreme Edition) & Pentium® Extreme Edition & Pentium® D & Pentium® 4 Processors
Chipset
Memory
Graphics
LAN
* On-board Dual PCI-E Gigabit LAN controller supports 10/100/ 1000M Ethernet
Audio
Expansion Slots
* 2xPCI-EX16,2xPCI-EX1,1 xPCI, 1x AudioMAX™
* 7 x SATA 3Gb/s connectors
* 2 x USB 2.0 headers, 2 x IEEE1394 headers
Back Panel I/O
* 4 x USB 2.0, 2 x RJ-45 LAN,
* 1 x eSATA
Serial ATA
* ICH7R: Support SATA AHCI, providing native command queuing and native hot plug & play
* Silicon Image:3132: 4 x SATA 3Gb/s, two SATA connectors of the same area can support SATA RAID 0/1
IEEE 1394
* 2 ports IEEE1394a at 400 Mb/s transfer rate
abit Engineered
* abit Silent OTES™ 2 Technology
* Back-light Blue LED's
RoHS
* RoHS Compliancy
Form Factor
* PCB Color: Black & Blue
FAQ zum ABIT AW9D-MAX (Vielen Dank an Sicness):
Wichtige Links:
Produktseite bei abit
BIOS download
Manual download
abits interne Kompatibilitätstests
Thread @ XtremeSystems.org
Gelten die folgenden Angaben auch für das non-Max oder Fatality?
Nein, beide Boards sind bis heute nicht erhältlich. Daher gilt dieses FAQ ausschliesslich für die Max Version.
Passt meine PCI-Karte in den PCI Slot wenn ich CF/SLI nutze?
Wenn die GraKa nen Single Slot Kühler hat wird der PCI nicht blockiert, bei einer Flachen WaKü a la Inno oder AC ebenfalls nicht.
Hey, da ist ja ne SLI Bridge dabei. Wird SLI offiziell unterstützt?
Nein, SLI ist nur mit gehackten Treibern möglich.
Bei mir funzt µGuru nicht richtig! Was ist los?
Das Problem tritt beim Release Bios in Verbindung mit einem Raid auf!
Lösung ist das neue .12 Bios!
Laufen 7900/7950GX2 problemlos auf dem Board?
Ja, die 7900GX2 läuft absolut problemlos.
Meine 7950GX2 bringt nur die halbe Leistung! Was ist hier los?
Laut dem User Dr.Wakeman liegt das an der µGuru Software.
Es verträgt sich nicht mit den aktuellen Forceware Treibern!
Der SLI Algorithmus läuft weder mit SFR, AFR oder AFR2.
Gibt es bekannte Probleme mit irgendwelchen RAMs?
Bisher nur eine Meldung, OCZ XTC Gold PC6400 C5 mit Elpida Chips laufen nicht mit 1:1, mit anderen Teilern jedoch problemlos. Micron D9 laufen einwandfrei.
Kann ich die Heatpipe entfernen und die Passivkühler in Kombination mit meiner Chipsatzwakü nutzen?
Nein, die Heatpipes sind fest verlötet. Es müssten in diesem Fall seperate passive Kühlkörper besorgt werden.
Falsch! Turrican bestätigt dass die Heatpipe nicht verlötet ist!
Bilder:
Was taugt die Heatpipe Konstruktion?
Die Kühlung arbeitet überraschend effizient, einen gewissen Luftstrom vorrausgesetzt lassen sich moderate Übertaktungen ohne zusätzliche Kühlung bequem bewältigen.
Sehe ich richtig? Das Board hat Lochhalterungen? Ich dachte Intel benutzt Ösen.
Richtig, abit bildet hier eine Ausnahme.
Wie hoch geht denn nun der FSB?
Die bisher höchsten Meldungen liegen im Bereich 450-460MHz, jedoch sind hier wohl die Chipsatztimings straffer als bei anderen 975X Boards. Sicher ist aber wohl ~420 MHZ!
hipro5 schrieb:
I also would like to add that ABIT "played" my Fadbodies a bit tighter that ASUS or Bad Axe......In 2k5 I got about 80 to 100 points more with ABIT with the EXACT same config as with ASUS/INTEL.......No big deal especially on air BUT when you go for the max, it counts.....Those points will be 200 - 300 on LN2 so as for me it counts.....
Ist es besser als die anderen 975X Bretter?
Lässt sich bisher noch nicht sagen, das Board hat bisher noch kein offizielles BIOS Update erfahren und ist wesentlich kürzer am Markt als Asus & Co. Es ist in jedem Fall vielversprechend und scheinbar sein Geld wert.
Welche Spannungsoptionen sind vorhanden?
VCore: 1,32V - 1,725V
VDIMM: 1,80V - 2,65V
MCH: 1,50V - 2,00V
Hat das Board auch das Shutdown Problem nach Übertaktung (vgl. Asus P5WDH)?
Nein.
Welche Straps und Teiler gibt es?
PSB533: 1:2
PSB800: 3:4, 3:5, 1:2
PSB1066: 1:1, 4:5, 2:3
Wieviele Lüfter kann ich anschliessen und was kann die Lüftersteuerung?
Das Board hat 7 Lüfteranschlüsse, jeder Lüfter ist zwischen 6 und 12V regelbar. Ausgenommen ist der CPU Lüfter, dieser kann nach Temperatur geregelt werden.
Was taugt die **** Software?
Die Software liest unter Windows Temperaturen, Spannungen, Lüftergeschwindigkeit und sogar Power Cycles aus. Übertakten in Windows ist hiermit kinderleicht möglich und funktioniert absolut einwandfrei, sofern man nicht die Grenzen der Hardware überschreitet ;)
Gibt es schon Alternativen zur **** Software?
W1zzard wird diese Woche (18.09.2006 ff) ein AW9D-Max bekommen und Support fürs Brett in SysTool einbauen.
Hilfe! Mein Board bootet einwandfrei aber ich habe trotzdem ein Piepkonzert! Ich benutze eine Wasserkühlung.
Sehr wahrscheinlich handelt es sich um das Notsignal des Boards zu Warnung vor 0 RPM am CPU Lüfter Anschluss. Das lässt sich im BIOS (abit EQ) deaktivieren.
Was hat es mit den LEDs auf sich?
Das Board besitzt blaue LEDs, die folgende Optionen besitzen: Alle LEDs an, aus oder verschieden blinkende Modi.
Ich habe von einem fehlerhaften 8 Pin EPS Stecker gelesen. Muss ich beim Board Kauf aufpassen?
Nein, ein solch fehlerhaftes Modell ist bisher weltweit nur ein einziges Mal aufgetaucht und der Fall wurde von abit direkt untersucht. Dies wird nicht mehr vorkommen.
Mein Netzteil hat nur einen 4 Pin 12V Stecker, kann ich das Board auch damit betreiben?
Ja.
Funktioniert EIST mit einem übertaktetem System?
Ja.
Hat abit auch ein BIOS Flashtool für Windows?
Ja, das abit Flashmenu ist im **** Softwarepaket enthalten und funktioniert problemlos.
Kann ich den Multi meiner CPU verstellen?
Ja, seit dem beta BIOS vom 15.09. ist es möglich, den Multi nach unten hin zu ändern. Dies gilt sowohl für ES als auch Retail CPUs.
Seit Alpha Bios 13 ist es auch möglich Multi nach oben zu verändern!
Wie gut ist der Support seitens abit für das Board?
Exzellent. abit ist bestrebt alle auftretenden Probleme so schnell wie möglich aus der Welt zu schaffen und arbeitetet dazu mit Speicherherstellern und einigen Leuten von Anandtech und XtremeSystems.org zusammen. Fortschritte werden umgehend in BIOS Updates umgesetzt.
Welche RAM Bänke soll ich nutzen? 1 und 3 oder 2 und 4?
Macht nach bisherigem Kenntnisstand keinen Unterschied.
Ein paar Bilder des Boards und der OVP bitte!
Die LEDs möcht ich auch mal sehen!
Das BIOS dann bitte auch noch.
Warum zum Teufel komme ich nur bis zu einem FSB von 350MHZ?
Fürs schnelle Testen (natürlich auf eigene Gefahr!!) am besten folgendes einstellen:
C1 und EIST disabled
VMCH: 1,75V-1,9V
DDR2 Voltage: 2,0-2,1V
Ram Timings by SPD / oder manuell
Vcore: 1,4V
Speicherteiler 1:1
Dann Testen und vorsichtig heran tasten! Gegebenfalls dann Spannungen nach unten senken!
Das ABIT ist anscheinend sehr abhängig vom richtigem RAM!
Deshalb nicht gleich aufgeben:)
WICHTIG:
Laut Hipro aus Xtremesystems undervoltet die MCH Spannung mit 0,2V!
Hier der Link zum Statement und Mod:
http://www.forumdeluxx.de/forum/showpost.php?p=4447534&postcount=1118
Hier die Vcore Tabelle von w1zzard (THX):
MIPS Wasserkühler für das ABIT AW9D-MAX
Preise:
Freezer: 39,90€
Mosfet Bridge: 43,00€
Komplettset : 155,00€
die freezer sind wie immer aufgebaut, d.h. kupferboden 5mm, messingdeckel
5mm.
Unterschiede zwischen AW9D und AW9D MAX:
Das MAX hat ne Blaue LED Rückseitenbeleuchtung+
den angewinkelten IDE Port + Firewire
Links & Downloads:
Final Bios 12 (THX@Kabautermann):
http://www.hardwarextreme.de/dave/aw9d12.rar
BIOS Downloads vom ABIT ftp server:
ftp://ftp.abit.com.tw/pub/download/bios/
Die Biosversionen fürs Non-MAX und MAX sind anscheinend die gleichen, da nur ein
AW9D Verzeichnis vorhanden ist!
Thread zum Retail Board bei Xtremesystems (Sicness:):
http://www.xtremesystems.org/forums/showthread.php?t=115839
Thread zum Retail Board im ABIT Forum (Danke Sicness):
http://forum.abit-usa.com/showthread.php?t=112896
Vielen Dank an TuricanM3 und Latest für die Pics und Scines für die FAQ
Leute, ich hab ab und zu auch das Problem, das die Übertaktungs- und Lüfter-Einstellungen vergessen werden, wenn der Strom komplett weg ist, also Stromkabel abgezogen oder einfach nur der Schalter am Netzteil aus.
Gibbs dagegen ein Mittel?
Ich habe das selbe Problem!
Sobald eine neue Board Revision draussen ist, werde ich mein AW9D Max in die RMA schicken.:bigok:
dagegen hätte ich auch gern nen Mittel hatte jetzt 5 Tage Ruhe. Habe mich schon gefreut, aber heute morgen war es dann wieder da ^^ .
Noch was anderes... habe inzwischen meinen 6400er und natürlich auch paar übertaktungsversuche gemacht. Bis 350MhZ FSB läuft er ohne Probleme.
Alle Spannungen sind auf Standart also CPU ,MCH und RAM. Ab 350MHZ gibts dann Probleme und er läuft nicht mehr stabiel egal wieviel Volt ich gebe. Schade eigentlich aber glaube nicht das da die CPU schon am Ende ist.
Ram hab ich 667er MDT der im AW8 als PC 800 problemlos läuft.
MFG
die bilder geben mir zu denken und ich hätte gerne ein vernünftiges board... werde es daher montag zurückschicken und als austausch ein neues verlangen...
Und das wird höchstwarscheinlich genauso aussehen ... das sind produktionsrückstände vom Lösten und werden wohla auf allen Boards vorhanden sein, mein IC7 hatte auch scho ne fleckige unterseite ...
@Powerstrip -
Bei den Kupfertarbenden fehlt mal offensichtlich das Lot, aber das sollte nicht so eine extreme erhitzung verursachen - die Teile sollen angeblich das OC verhalten verbessern und nicht die SpaWas Kühlen ...
Dieses Phänomen hatten schon die Boards aus der AN8 & Fatality Serie und davon hatte ich einige, wurde allerdings nie 100% behoben.
Auch mein jetziges AW9D MAX ist davon wieder betroffen.
@Anarchy
ich mache auch nicht das fehlende Silberlot für den enormen Temperatursprung verantwortlich !
Nur wird dadurch offensichtlich das bei meinem Board bei der Produktion etwas schief gelaufen ist da in diesem Bereich auch der PWM2 Sensor sitzt.
Desweiteren ist bis jetzt noch kein zweites Board aufgetaucht mit diesen unterschiedlichen Powerstrips.
eben, das sieht nicht nach gebrauchsspuren, sondern nach produktionsverunreinigungen/rückständen aus. ich hatte das auch beim ic7 und auch schon vorher bei einigen abit-mainboards (bh7, be7 etc.). mal mehr, mal weniger, aber irgendein sichtbarer rückstand war eigentlich immer vorzufinden. ärgerlich, dass sich das nicht geändert hat, jetzt wo usi ja offensichtlich die mainboards produziert.
hipro5 schrieb:
Yes new bios.......Soon to be released in BETA.....This is an ALFA and it seems to be pretty good so far.....
P.S. CellShock 2 x 1GHz 8000C4 Rams, gives me a latency of 36.8s, if I remember well in Everest..... 1:1 config and 3-3-3-1 at about 444MHz.....I'll try them tomorrow at higher frequency to see how they are doing.......;)
Höherer Multi klappt übrigens bei ihm mit dem neuen BIOS (und mit nem X6800).
Hy, diese grauschleier sind wohl rückstände vom waschen... nachdem die glötet wurden werden die normalerweise alle noch mal gereinigt. Zum Beispiel mit Isopropanol...
gruß
So ein rantziges Board ejj. Das Asus war soooo viel bequemer im Umgang. Das ABIT macht einen edlereren Eindruck, aber man merkt, dann ABIT lange nicht so viel Ressourchen in die Entwicklung für Hiflmittel, für die User verwendet hat.
Ich habe einiges Bugs zu berkämpfen. Am Ende läuft sogar windows wieder, aber nur mit einem Workaround -.-
Booten von Platte als 1 Bootpartition nicht möglich, nur wen man vom DVD LW bootet(von einer bootbaren dvd) und dann dort nichts macht..fmasofjpjpjfsaojfasjop son Rotz.
Wenn ich den IDE Mode auf "SATA only" stelle, weil ich nur 4 sata LW dran habe, dann wird keines erkannt oder nur 1 am 3 SATA port. im ahci mode wird zwar alles erkannt, aber warum er da normale ide "slots" anzeigt und eines mit einem virtuellem drive ausstattet, was angeblich 136GB groß is, kann ich nicht verstehen. ein flashen von usb ist auch nicht drin, oder nur mit umwegen...voll ätzend, seit 10 jahren verwendet ich keine floppy mehr ... legacy free, aber mit fdd rofl -.-
ziemliches kauderwelch und ohne systemhintergrund wissen nciht wirklich leicht zu verstehen. wollte nur kurz mal dampf ablassen...war noch längst nicht alles...
cpu untervolten ist im griff, ram gskill BHZ macht auch keine probleme. ganz ok, aber mit den platten nur ärger (kein raid gesocks).
Ich habe auch so ein komisches Phänomen:
Wenn ich den SATA-Modus auf "SATA only" stelle und dann auf AHCI, bootet Windows nicht. :mad:
Nur wenn ich "Auto" wähle (steht dann auf IDE), bootet Windows. Habe eine SATA-Platte und zwei SATA-Laufwerke dran.
Hat dieses Problem noch jemand?
Lege z.B. die bootfähige Windows CD ein.
Stelle im BIOS das CD als 1. Boot ein, danach HDD.
Starte den PC und drücke bei "Drücken Sie eine beliebige Taste....." nichts, dann startet Windows von HDD. (sogar im ahci) ^^
Also mein DDR2 1000 Speicher läuft max DDR2 950 auf meinem Max!
Auf dem P5W DH 1000MHz 4-4-4-8 @2,1V!!!!!!!
FSB 400 ist nur Prime95 stable (6h getestet) mit kleinem Teiler! (MCh1,7V)
FSB 400 mit 9er Teiler kann man vergessen.
Hoffentlich tut sich mit dem nächsten Bios Update was!
Ansonsten bye bye AW9D MAX, dann wirds ein 680i Lanparty.....
Wann soll das DFI kommen? Bis jetzt habe ich auch keine Probleme mit dem Abit, aber übertakten konnte ich noch nicht, da die S.775 Halterung noch auf sich warten lässt. Jedenfalls läuft schonmal mein Cellshock DDR2 800 mit den vorgegeben Timings 4-4-4-12 @ 2,1V. Prime habe ich noch nicht laufen lassen, der Boxedkühler ist einfach tierisch schlecht. Aber bis jetzt konnte ich ohne Abstürze etc. zocken. Mal schauen wie es dann beim OC geht. Ich hoffe mal ein 400er FSB ist drin.
Öhm, mein DDR2 800 Kit von Cellshock läuft auch nur mit 1.90V @ 4-4-4-12. ;)
Bin bis jetzt absolut zufrieden mit dem Mainboard. Bin zur Zeit nur am überlegen ob ich das 1.2er Bios draufhauen soll...weil momentan läuft ja alles bestens.
Bleib mal bitte ganz locker. Es gibt erst 1 Biosupdate und mit dem nächsten könnten schon ein paar Features Eiinzug erhalten, die ein besseres ocen ermöglichen.
Danke perfekt, wie ich mir schon gedacht habe alle komplett silber - wie es auch sein soll. ;)
Denke mal, da wird es langsam Zeit für einen verschärften Ton zwischen mir und ABIT NL :d
meine sind auch nicht alle silber, min drei waren bei mir auch ohne lötzinn oder was da drauf ist, wüste aber nicht was das ändern sollte.
das blanke küpfer wird nicht viel schlechter kühlen.
Hinzugefügter Post:
hm ich denke mal, dass sich da irgendwas abgesetzt hat...
sieht bei mir leider genauso aus, könnt aus dem säure bad vom ätzen oder von der nachbehandlung sein.da mein board aber gut läuft behalte ich es.
Wie schon mal hier erwähnt mache ich nicht das fehlende Lötzinn für die viel zu hohen PWM2 Werte verantwortlich, sondern sehe das als Indiz das dort bei der Produktion etwas schief gelaufen ist.
Bewegen sich bei dir alle 4 PWM Werte im selben Rahmen ? oder weicht der PWM2 extrem nach oben ab ~30°C zusätzlich
Sieht deine SN ähnlich aus ? AW9DMUDB0014XX die letzten 2 Ziffern sind unwichtig , daher XX ;)
Danke JCM900
Ich habe gestern für einen CPU-Tausch mein Netzteil ca. 3 Minuten ausgeschaltet, danach waren die Einstellungen auch futsch. Zusammen mit dem Problem, dass mein Speicher die 1000 nicht packt ist das das einzige was mich an dem Board stört.
Bei mir läuft es ohne Probleme mit 1.6v (vielleicht auch weniger) mit 9x400.
Das die Boards noch nichtmal die 400 nicht packen, ist ja erschreckend bei den Vorabberichten.
Es scheint ja nun schon bei mehreren der Fall zu sein das ein 1 : 1 Betrieb bei 400 nicht möglich ist.Ich finde es schwach von Abit das es noch kein Biosupdate gibt.
An all die, die keine 400MHz 1:1 schaffen:
Habt ihr die Ram Timings manuell eingestellt, oder auf Auto gelassen?
Manuell soll Probleme machen...
Ich habe die Speicher manuell eingestellt.
Hinzugefügter Post:
Auf Auto funktioniert es wohl ?
Hinzugefügter Post:
Ich hatte vorher Mushkin Speicher EM2 PC-6400 Cl5 und da waren die SPD-Timings vom Board Cl4-4-4-10 und das packen die Mushkin nicht.Ich werde dann nochmal mit meinen Cellshock testen.
bei mir gehts leider schon ab 360-370MHZ FSB los, es ist so ziehmlich egal welche Spannung.
Schade eigentlich.
GX22GB5300SDC 2x1 GB Riegel
Das sind die mit orangenen HS.
Weiss einer ob die mit dem board laufen ?
Vllt liegt da das Problem begraben!
Bei meinen G Skill die auch bei 400FSB mit 5-5-5-15 laufen sollen, liesst das Board bei SPD Timings 4-4-4-12 aus! Und das kann bei 400FSB nicht funktionieren...
Und wenn man halt die Timings manuell einstellt, soll es Probleme machen!
An alle die jetzt noch Probs mit dem Ram haben, wartet doch bitte mal das nächste Bios ab ;).
Wenn ich die uGuru SW nur als Viewer benutze verliere ich die Settings im Bios nach einem Power Off nicht. Veränder ich da was, sind die Settings nach einem Power Off futsch.
Dein Chipsatz (northbridge) ist aber auch wassergekühlt oder?
Btw. gerade 3h am primen mit 1,9VMCh :eek: Scheint zu funktionieren.
Werde wohl nicht drum rum kommen einen Wasserkühler fürs AW9D Max zu kaufen.
Muss man die southbridge auch extra kühlen?
