[Sammelthread] ASRocks Fatal1ty P67 Professional
image.php
[/url]http://[/IMG]
  1. ASRock > Produkte > Fatal1ty P67 Professional
    *] Preise und Verfügbarkeit
    ASRock Fatal1ty P67 Professional, P67 (B3) (dual PC3-10667U DDR3) | Geizhals.at Deutschland
    ASRock Fatal1ty P67 Professional Sockel 1155 Mainboard: Mainboard Preisvergleich - Preise bei idealo.de
  2. Spezifikationen
    Sockel
    1155 Sandy Bridge​
    Prozessor
    Intel® Core™ i7-2600K/2600​
    Intel® Core™ i5-2300-2500/2500K​
    Intel® Core™i3-2100-2120​
    Chipsatz
    Intel® P67 Express​
    Steckplätze
    2x PCI 32 Bit Steckplätze
    32 Bit 5 Volt 33 Mhz
    2x PCIe 2.0 x1
    3x PCIe 2.0 x16 /1x16 oder 2 x8/x8 ; PCIE5: x4​
    BIOS
    64Mb AMI UEFI Legal BIOS with GUI support
    - Supports "Plug and Play"
    - ACPI 1.1 Compliance Wake Up Events
    - Supports jumperfree
    - SMBIOS 2.3.1 Support
    - DRAM, PCH, CPU PLL, VTT, VCCSA Voltage Multi-adjustment
    Arbeitsspeicher
    Dual Channel DDR3 memory technology
    4 x DDR3 DIMM slots Max. 32GB
    Supports DDR3 2133(OC)/1866(OC)/1600/1333/1066 non-ECC, un-buffered memory​
    Supports Intel® Extreme Memory Profile (XMP)​
    Audio
    7.1 CH HD Audio with Content Protection (Realtek ALC892 Audio Codec)
    - Premium Blu-ray audio support
    - Supports THX TruStudio PRO™​
    LAN
    - PCIE x1 Gigabit LAN 10/100/1000 Mb/s
    - Realtek RTL8111E
    - Supports Wake-On-LAN
    - Supports LAN Cable Detection
    - Supports Energy Efficient Ethernet 802.3az
    - Supports Dual LAN with Teaming function​
    SATA3
    2 x SATA3 6.0 Gb/s connectors, support RAID (RAID 0, RAID 1, RAID 10, RAID 5 and Intel® Rapid Storage), NCQ, AHCI and "Hot Plug" functions
    - 4 x SATA3 6.0 Gb/s connectors by Marvell SE9120, support NCQ, AHCI and "Hot Plug" functions (SATA3_M4 connector is shared with eSATA3 port)​
    USB 3.0
    - 4 x Rear USB 3.0 ports by Etron EJ168A, support USB 1.0/2.0/3.0 up to 5Gb/s
    - 1 x Front USB 3.0 header (supports 2 USB 3.0 ports) by Etron EJ168A, supports USB 1.0/2.0/3.0 up to 5Gb/s
    - 4 x SATA2 3.0 Gb/s connectors, support RAID (RAID 0, RAID 1, RAID 10, RAID 5 and Intel® Rapid Storage), NCQ, AHCI and Hot Plug functions​
    Anschlüsse Board
    - 6 x SATA3 6.0 Gb/s connectors
    - 1 x ATA133 IDE connector (supports 2 x IDE devices)
    - 1 x Floppy connector
    - 1 x IR header
    - 1 x COM port header
    - 1 x HDMI_SPDIF header
    - 1 x IEEE 1394 header
    - 1 x Power LED header
    - CPU/Chassis/Power FAN connector
    - 24 pin ATX power connector
    - 8 pin 12V power connector
    - CD in header
    - Front panel audio connector
    - 4 x USB 2.0 headers (support 8 USB 2.0 ports)
    - 1 x USB 3.0 header (supports 2 USB 3.0 ports)
    - 1 x Dr. Debug with LED​
    Anschlüsse ATX-Blende
    - 1 x PS/2 Mouse Port
    - 1 x PS/2 Keyboard Port
    - 1 x Coaxial SPDIF Out Port
    - 1 x Optical SPDIF Out Port
    - 3 x Ready-to-Use USB 2.0 Ports
    - 1 x Fatal1ty Mouse Port (USB 2.0)
    - 1 x eSATA3 Connector
    - 4 x Ready-to-Use USB 3.0 Ports
    - 2 x RJ-45 LAN Ports with LED (ACT/LINK LED and SPEED LED)
    - 1 x IEEE 1394 Port
    - 1 x Clear CMOS Switch with LED
    - HD Audio Jack: Side Speaker / Rear Speaker / Central / Bass / Line in / Front Speaker / Microphone​
    Mitgeliefertes Zubehör
    1 x SLI_Bridge
    1 x Drivers and Utilities CD
    1 x Front USB 3.0 Panel mit Aufnahme für 1.SSD !!
    1 x Rear USB 3.0 Bracket , einfach nur umschrauben !
    1 x Floppy/ATA 133 Kabel
    6 x SATA Data Kabel
    2 x SATA 1 to 1 Powerkabel​
  3. Bilder uneingebaut und eingebaut
  4. Bilder Bios Übersicht
  5. Bilder Bios OC Tweaker und Advanced
  6. RAM Liste
    ASRock > Produkte > Fatal1ty P67 Professional > Speicher Support Liste
  7. Getesteter Ram
    Corsair XMS3 DIMM Kit 8GB PC3-12800U CL9-9-9-24 (DDR3-1600) (CMX8GX3M2A1600C9) | Geizhals.at Deutschland
    G.Skill RipJaws-X DIMM Kit 8GB PC3-12800U CL9-9-9-24 (DDR3-1600) (F3-12800CL9D-8GBXL)
    Corsair XMS3 DIMM Kit 8GB PC3-16000U CL9-10-9-27 (DDR3-2000) (CMX8GX3M2A2000C9)
    Corsair XMS3 Dominator GT DIMM Kit 4GB PC3-16000U CL8-9-8-24 (DDR3-2000) (CMT4GX3M2A2000C8)
    G.Skill ECO DIMM Kit 4GB PC3-10667U CL7-7-7-21 (DDR3-1333) (F3-10666CL7D-4GBECO)
  8. Download BIOS + Treiber
    ASRock > Produkte > Fatal1ty P67 Professional > Download
    Rest kommt nocht
    MfG
Scheint stable zu sein, takte mal wieder hoch und setzte mal die Vcore ebenfalls ne stufe hoch.
meist liegt es auch an der vcore. Wenn man nen blauen bekommt ist es viel zu wenig. Steigt ein Kern aus reichen 1-2 Erhöhungen.
Das habe ich jetzt auch bemerkt. Vcore um eine stufe erhöht und er rennt nun brav vor sich hin und das seit ner halben stunde.
Habe wenn ich mich nicht irre, Prime Large laufen. Läuft aber mit 1,384. Springt auch ab und an runter auf 1,376. Schade das man LLC nicht komplett ausschalten kann.
so ich hab trotz stockj und bios updates immernoch diese freezes kann das durch das spread spectrum kommen?? wenn ich es deaktiviere komme ich aber nicht mehr zum boot o_O
ich hab jetzt mal andere settings ausprobiert also das gleiche nur mit 1.25v und 40er multi leuft endlich stabil *__* also bis jetzt stabil :d
wieso kauft ihr euch 1600 ram bei sb ??
MfG
ganz einfach weil man weiter denkt. Auf den Mainboard läuft später auch Intels Ivy-Bridge CPU und diese Unterstützt eben PC-DDR3 1600.
Ivy Bridge wird auf P67 Chipsätzen ganz klar laufen. Es muss nur das UEFI angepasst werden. Probleme haben nur reine Intel Boards. Bei ASRock mache ich mir da überhaupt keine Sorgen das da Ivy Bridge nicht laufen sollte. Es gibt somit gar keine Probleme mit Ivy Bridge und P67 Boards sofern das keine reinen Intel Boards sind.
noch ist es nicht amtlich das ivy auf 1155 läuft. Laut Intel kann das UEFI nur vom Hersteller angepaßt werden also abwarten.
---------- Beitrag hinzugefügt um 15:18 ---------- Vorheriger Beitrag war um 15:15 ----------
dein ganzes Setting paßt nicht was ich auf den Pics gesehen habe. Was für einen RAM hast du der mit 1,26v läuft ???
Wenn du den Multi manuell einstellst dann mußt du die Turbo Boost Power Limit auch manuell ändern. Da funktioniert die Auto Einstellung nicht.
Und da mache ich mir bei ASRock überhaupt keine Sorgen.
ehrlich gesagt ist mir ivy erst mal egal. Freu mich lieber auf die Kepler von NV ;)
Mir reicht einfach die CPU Leistung da brauche ich noch keine 6 oder 8 Kerne.
hab die schnauze voll bord geht warscheinlich zurück werde dann wohl bei asus bleiben leider :(
Ich hatte bisher nur einmal BS wegen zu wenig Vcore, ansonsten läuft meiner mit 5 GhZ stable inzwischen. Die Vcore muss aber noch etwas runter.
