[Sammelthread] ASRocks Fatal1ty P67 Professional
image.php
[/url]http://[/IMG]
  1. ASRock > Produkte > Fatal1ty P67 Professional
    *] Preise und Verfügbarkeit
    ASRock Fatal1ty P67 Professional, P67 (B3) (dual PC3-10667U DDR3) | Geizhals.at Deutschland
    ASRock Fatal1ty P67 Professional Sockel 1155 Mainboard: Mainboard Preisvergleich - Preise bei idealo.de
  2. Spezifikationen
    Sockel
    1155 Sandy Bridge​
    Prozessor
    Intel® Core™ i7-2600K/2600​
    Intel® Core™ i5-2300-2500/2500K​
    Intel® Core™i3-2100-2120​
    Chipsatz
    Intel® P67 Express​
    Steckplätze
    2x PCI 32 Bit Steckplätze
    32 Bit 5 Volt 33 Mhz
    2x PCIe 2.0 x1
    3x PCIe 2.0 x16 /1x16 oder 2 x8/x8 ; PCIE5: x4​
    BIOS
    64Mb AMI UEFI Legal BIOS with GUI support
    - Supports "Plug and Play"
    - ACPI 1.1 Compliance Wake Up Events
    - Supports jumperfree
    - SMBIOS 2.3.1 Support
    - DRAM, PCH, CPU PLL, VTT, VCCSA Voltage Multi-adjustment
    Arbeitsspeicher
    Dual Channel DDR3 memory technology
    4 x DDR3 DIMM slots Max. 32GB
    Supports DDR3 2133(OC)/1866(OC)/1600/1333/1066 non-ECC, un-buffered memory​
    Supports Intel® Extreme Memory Profile (XMP)​
    Audio
    7.1 CH HD Audio with Content Protection (Realtek ALC892 Audio Codec)
    - Premium Blu-ray audio support
    - Supports THX TruStudio PRO™​
    LAN
    - PCIE x1 Gigabit LAN 10/100/1000 Mb/s
    - Realtek RTL8111E
    - Supports Wake-On-LAN
    - Supports LAN Cable Detection
    - Supports Energy Efficient Ethernet 802.3az
    - Supports Dual LAN with Teaming function​
    SATA3
    2 x SATA3 6.0 Gb/s connectors, support RAID (RAID 0, RAID 1, RAID 10, RAID 5 and Intel® Rapid Storage), NCQ, AHCI and "Hot Plug" functions
    - 4 x SATA3 6.0 Gb/s connectors by Marvell SE9120, support NCQ, AHCI and "Hot Plug" functions (SATA3_M4 connector is shared with eSATA3 port)​
    USB 3.0
    - 4 x Rear USB 3.0 ports by Etron EJ168A, support USB 1.0/2.0/3.0 up to 5Gb/s
    - 1 x Front USB 3.0 header (supports 2 USB 3.0 ports) by Etron EJ168A, supports USB 1.0/2.0/3.0 up to 5Gb/s
    - 4 x SATA2 3.0 Gb/s connectors, support RAID (RAID 0, RAID 1, RAID 10, RAID 5 and Intel® Rapid Storage), NCQ, AHCI and Hot Plug functions​
    Anschlüsse Board
    - 6 x SATA3 6.0 Gb/s connectors
    - 1 x ATA133 IDE connector (supports 2 x IDE devices)
    - 1 x Floppy connector
    - 1 x IR header
    - 1 x COM port header
    - 1 x HDMI_SPDIF header
    - 1 x IEEE 1394 header
    - 1 x Power LED header
    - CPU/Chassis/Power FAN connector
    - 24 pin ATX power connector
    - 8 pin 12V power connector
    - CD in header
    - Front panel audio connector
    - 4 x USB 2.0 headers (support 8 USB 2.0 ports)
    - 1 x USB 3.0 header (supports 2 USB 3.0 ports)
    - 1 x Dr. Debug with LED​
    Anschlüsse ATX-Blende
    - 1 x PS/2 Mouse Port
    - 1 x PS/2 Keyboard Port
    - 1 x Coaxial SPDIF Out Port
    - 1 x Optical SPDIF Out Port
    - 3 x Ready-to-Use USB 2.0 Ports
    - 1 x Fatal1ty Mouse Port (USB 2.0)
    - 1 x eSATA3 Connector
    - 4 x Ready-to-Use USB 3.0 Ports
    - 2 x RJ-45 LAN Ports with LED (ACT/LINK LED and SPEED LED)
    - 1 x IEEE 1394 Port
    - 1 x Clear CMOS Switch with LED
    - HD Audio Jack: Side Speaker / Rear Speaker / Central / Bass / Line in / Front Speaker / Microphone​
    Mitgeliefertes Zubehör
    1 x SLI_Bridge
    1 x Drivers and Utilities CD
    1 x Front USB 3.0 Panel mit Aufnahme für 1.SSD !!
    1 x Rear USB 3.0 Bracket , einfach nur umschrauben !
    1 x Floppy/ATA 133 Kabel
    6 x SATA Data Kabel
    2 x SATA 1 to 1 Powerkabel​
  3. Bilder uneingebaut und eingebaut
  4. Bilder Bios Übersicht
  5. Bilder Bios OC Tweaker und Advanced
  6. RAM Liste
    ASRock > Produkte > Fatal1ty P67 Professional > Speicher Support Liste
  7. Getesteter Ram
    Corsair XMS3 DIMM Kit 8GB PC3-12800U CL9-9-9-24 (DDR3-1600) (CMX8GX3M2A1600C9) | Geizhals.at Deutschland
    G.Skill RipJaws-X DIMM Kit 8GB PC3-12800U CL9-9-9-24 (DDR3-1600) (F3-12800CL9D-8GBXL)
    Corsair XMS3 DIMM Kit 8GB PC3-16000U CL9-10-9-27 (DDR3-2000) (CMX8GX3M2A2000C9)
    Corsair XMS3 Dominator GT DIMM Kit 4GB PC3-16000U CL8-9-8-24 (DDR3-2000) (CMT4GX3M2A2000C8)
    G.Skill ECO DIMM Kit 4GB PC3-10667U CL7-7-7-21 (DDR3-1333) (F3-10666CL7D-4GBECO)
  8. Download BIOS + Treiber
    ASRock > Produkte > Fatal1ty P67 Professional > Download
    Rest kommt nocht
    MfG
Also ich habs im fixed und offset probiert, geht bei beidem, momentan stehts auf offset.Musst halt bissl rumtesten wie du am wenigsten spannung brauchst, ist ja jede cpu da bissl anders.
brauche diese funktion nicht und den rest der asrock software auch nicht .
hab ne sharkoon firerglider als maus wo ich alles einstellen kann was
ich möchte ohne asrock software .
Also Funktioniert der Mouse Port eben nicht.
Ich kann mir der Microsoft Software auch alles einstellen., Meine Ursprüngliche Frage bleibt aber, bei wenn Funktioniert der Mouse Port mit den Mousen nicht in Verbindung mit der ASRock Software.
Sorry hatte ich oben überlesen.
Die X8 ist eine Funkmaus in eimen Asrock Faq (frag mich bitte nicht wo ich den gefunden habe) habe ich gelesen, dass nur eine handvoll Funkmäuse in Verbindung mit dem F- Mausport funktioniern. Das heisst sie gehen aber die Software lässt nicht zu das man die Abtastrate verändert.
Hab mal etwas Tante Google bemüht und im groß und ganzen geht nur ein Bruchteil der aktuellen Mäuse.
Die X8 ist eine Kombi Mouse. Ich kann sie auch per Kabel betreiben. Aber egal. Ich wollte ja auch nur wissen Welche Mouse mit der F- Mausport Software Funktionieren oder eben nicht funktionieren. Und ob ASRock was macht damit gängige Mouse wie z.B. Microsoft X8 damit geht
Hi Leute hab seit kurzem ein seltsames Problem.
Mein i5 lief von anfang an mit 1.26v bei 4.4 ghz und das Primestable ca 5 Std.
Und jetzt raucht mir ständig Core #2 ab bei Prime hab den auch schon auf 1.29 hochgestellt aber bringt nix.
Was seltsam ist sind die Temps
unter last:
Core 0 47C
Core 1 50C
Core 2 53C
Core 3 50C
hab den kühler schon mal runter und wieder drauf bringt aber nix.
WLP hab ich die Exteme von GelID
Ideen?
Soo, habe heute zugeschlagen...
Das Board neu für 166€
Ich hoffe damit werde ich glücklicher als mit dem P8P67
Ob nun 12+2 oder 16+2 ist wohl nicht Kriegsentscheidend
Aber da es sowohl von der Leistung als auch von der Ausstattung am oberen Ende angesiedelt ist, werde ich wohl meinen Spaß haben :)
Hab ich das richtig mitbekommen, dass das Board wirklich so fix bootet? Also deutlich schneller als andere Boards ?
Habe jetzt nur den Vergleich mit meinem EVGA X58 und das war schon schnell aber das Asrock geht da noch ein wenig besser.
Es bootet echt superschnell, besonder wenn man eine SSD sein Eigen nennt.
hey leute,
ich habe jetzt meine hardware bekommen und installiert.
Intel Core i7 2600K
ASRock P67 Professional
Corsair Vengeance DIMM Kit 8GB PC3-12800U CL8-8-8-24 (DDR3-1600).
Cpu kühler is ein Noctua NH-U12P SE2.
Ich hab momentan das Bios P1.60 drauf.
CPu läuft standard auf 3,4 ghz mit 1,25 volt.
hab jetzt mal prime laufen lassen und bei last hab ich alle cores um 49 bis 52 grad.
jetzt wollte ich gerne die cpu mal übertakten. hab aber keine erfahrungen mit sandy bridge übertaktung.
Könntet ihr mir eventuell helfen ???
Was muss ich im bios alles einstellen ?
wäre sehr cool wenn ihr mir helfen könntet.
gruß
@Max
gehe mal auf Load Optimized CPU OC Setting, dort kannst du deine Wunsch GHz Auswählen. Würde erst mal mit 4 GHz Anfangen.
Bild: dsc00015b72g.jpg - abload.de
Dann stellst du deine vcore ein. Das geht über CPU Core Voltage. Dort solltest du mit dem Offset Wert arbeiten, das heißt das wenn du zu wenig oder zuviel vcore hast sie mit dem Offset anpassen kannst. Mußt ein wenig probieren bis du die richtige vcore hast aber das weißt du ja ;)
VCore braucht man doch garnicht einstellen.
Man muss nur das CPU OC Profil in Bios einstellen, den Rest macht doch ASRock von selber wenn alles sonstige auf Auto steht!
Bei mir läuft mit der Einstellung meine CPU auf 4,6Ghz stabil.
Ich habe da aber lieber so viel wie nötig und so wenig wie möglich ;)
Warum sollte ich mit der Auto vcore mehr Spannung zulassen?
Wenn du erstmal die spannungen auf auto belässt siehst du bei CPU-Z wieviel v-core dein 2600K braucht für X-MHz so als anhaltswert.Kannst dann immer noch etwas runtergehn wenn du dann alles auf manuell(fixed oder offset) stellst;)
Habe ja nicht das Gegenteil behauptet :fresse: nur mit der fixed Einstellung würde ich jetzt nicht arbeiten weil damit der Speedstep/Eist nicht funktioniert ;)
Wie Speedstep/Eist Funktionieren nicht, die CPU taktet doch runter. Gibt es einen Test wo man sehen kann das es nicht Funktioniert?
Die spannung geht im idl nur runter wenn du auto-oc mit auto-spannung belässt oder kommplett alles manuell mit offset arbeitest.Bei fixed geht zwar der multi-runter aber net die spannung.
ja genau der Multi senkt sich aber die vcore bleibt auf den gestellten fixed Wert stehen.
@Lord Wotan
Einfach CPU´z an machen. Da kannst du gut sehen das der Multi auf 16 steht aber die vcore für die vollen 4GHz(Beispiel) stehen bleibt.
Also unter CPU-Z springt das vCore zwischen 1.168V u. 1.334V in stufen hin und her. CPU Clock geht auf Multi 16. Somit dürfte sowohl Speedstep als auch EIST bei mir Funktionieren.
Ok, deshalb lasse ich ja alles auf Auto. Und ASRock macht das zufriedenstellend. So macht OC richtig Spaß.
Jeder wie er mag aber Asrock hat diesmal gute Arbeit mit den Boards geliefert. Bin richtig zufrieden mit dem Board :fresse2:
Ack
Wenn jetzt noch die ASRock F-Stream Tuning Mouse Port Software mit meiner Microsoft Sidewinder X8 Läufen würde, wäre ich wunschlos Glücklich.
Jo war fixed eingestellt, woran hast das bloß gemerkt?:d das ist gleichmal ein schönes beispiel wenn fixed eingestellt is das der multi runtergeht aber net die spannung;)
