[Sammelthread] Assetto Corsa
Und wieder sucht man im Foto Mode die Taste um den Fokus einzustellen... WTF
Rechtsklick, Mausrad geht ne mehr...
Wenn die jemand findet bitte melden thx...
1.0
- AI now brakes better in the pitlane
- Fixed problems with remote car colliders not properly turned off when disconnected
- Fixed DRS triggered from wheels
- More robust session status sync between server and clients
- Improved feedback to the kicked or disconnected user
- Improved car height calculation for a more uniform setup validation
- New Alfa Romeo Giuletta Q.V. 2014 Launch Edition
- Eliminated FFB vibration at 30kmh
- Updated tyre model for all cars
- Corrected bug in F40 old and street tyres
- Modifications on Lotus 98T and F.Abarth Aero map
- Modifications in engine brake on some cars
- Improved post processing effects
S1-Dynamic
S1-Sport
S1-Movie
S2-Photographic
S2-Retro70s
S3-Vignette
- New post processing effects
S1-Evolution
S1-Expanded
S1-Filtered
S1-Soft
S2-B&W
S2-B&W - HI
S3-Sepia
- New and improved photomode feature. Photomode activates from the replay User Interface
- New carbonfibre shader for cockpits of: bmw z4 gt3, bmw m3 gt2, Ferrari f40, Ferrari 599xx, Ferrari 458 gt2, ktm xbow, lotus evora gtc, lotus evora gtx, mclaren mp4-12, mclaren mp4-12 gt3, p4/5, tatuus
- Dirt layer optimization
- New skins for some cars, more to follow
- Small bug and fixes on trento bondone, magione, Spa Francorchamps
- Fmod project updated: no critical changes, just check volumes and envelopment for each event and mixer groups
- New sounds for Lotus Type 49, Ferrari F40 and Ferrari 312T
- Audio latency level can now be set in the launcher: available options are Normal, Low and Very Low
- Fixed FMod bug in multiplayer mode causing FPS drops
- Fixed wind volume for both stereo and surround configurations (default value: 0.7)
- Fixed bodywork sound audible for some cars when standing still
- Improved exterior sounds spatialization for surround speakers configurations
- Improved and balanced gearshift, backfire and limiter sounds
- improved positional sound for surfaces
- Overall volume balance
- Other minor audio fixes and improvements
- Added cutscenes for some of the career series.
- Improved algorithm for AI level while racing should give closer racing
- Inverted steering wheels and negative camber corrected for multiplayer clients
- Multiplayer basic admin tools:
Added simple admin commands using the chat window. It is important to set the "ADMIN_PASSWORD" in the server_cfg.ini file, an empty ADMIN_PASSOWORD will disable admin commands.
/help: prints the list of the available commands
/admin: become administrator for the server. ex, if the password is "kunos" the command is "/admin kunos"
/next_session: moves to next session
/restart_session: restart the session
/kick: kick a user using the rules (blacklist etc) of the server. To kick a player named "The Player": /kick The Player
- GT2 and GT3 cars, F.Abarth, Exos and Exos S1, M3 E30 GrA and DTM have now the modified tyre model
- LaFerrari has modified active aero and tyre model
- BMW M3 E30 street car has modified tyres (all compounds) as an example of street tyres new model.
- GT2 and GT3 cars have now the "old" FFB gain settings in their physics. Obviously the min FFB slider still works on them too. Please try and report back
- Zonda R, Huayra, 599XX have now tyres that are more load sensitive and more speed sensitive. Laptimes should be slower. Please give feedback on driving feel. Keep in mind you're going to be slower, give it some time.
- Minimum FF force implemented. Can provoke STRONG vibrations in the center zone, use as low as possible!
- All cars have new FF gain values to eliminate FF clipping. You might need to raise your FF gain values on your configuration or add a bit of minimum. Advice 0.12 for logitech wheels, much lower for other wheels. Experiment and report on beta forums
- Difficulty level slider on career
- Much more laps possible on single player quick and weekend races when fuel consuption is off
- Added diffuser stall on low speed for tatuus formula Abarth.
1.0.10 RC
- Fixed excessive logging coming from mods accessing textures
- fix for FPS drops in multiplayer due to audio
- fixed wind volume for both stereo and surround configurations (default value: 0.7)
- overall volume balance
Cool. Da hat Kunos es doch noch geschafft. Sogar vor Weihnachten.
Fehlt nur noch das Nordschleifen-DLC :d
Das is ja lustig...
Ich seh nur 5 PS Unterschied zu dem anderen...
Gran Turismo Style :d
22 kg leichter ist der Alfa und eigentlich mit einem Getriebe wie im m3 e92 unterwegs
Die Werte passen allgemein bei einigen Fahrzeugen nicht
ffb fühlt sich anders an... hab den neuen Regler mal auf 0 gestellt
Die Reifen haben zwischen Übergang Grip und kein Grip Verbesserungen erhalten. Allgemein auch weniger griffig, bei Kälte sensibler als zuvor.
Sind gestern online gefahren.
Also man merkt beim Fahren deutliche Unterschiede.
MP4 GT3 untersteuert mittlerweile, SLS endlich balanciert :)
Bin gestern mal ne Weile gefahren... komme aber nimmer an meine alten Zeiten ran :-/
An die alten Zeiten kommt wohl keiner mehr ran, finde ich auch ehrlich gesagt ganz gut so.
Also der SLS hat mit meinem Setup auch untersteuert. Denke mal die Setups müsste man teilweise, oder vielleicht auch komplett überarbeiten.
Wurde der Z4 weiter verschlimmbessert und ist nun der ultimative tank-slapper? Hab irgendwie kein Händchen mehr für das Auto. Meine alten Setups scheinen nichts mehr zu bewirken :hmm:
Ich hab damit kein Problem... ein RSR Live Time Reset wär nicht schlecht bzw. Kunos könnte mal was eigenes machen :)
Sollen einfach das von RRRE kopieren ^^
Z4 fahre ich nicht, deswegen kann ich zum Fahrverhalten nichts sagen. Ich weiß nur, dass mein Setup vom 12C und vom SLS jetzt eher Richtung Instabilität und Untersteuern gehen. Die muss ich dann noch etwas überarbeiten.
Hoi Luxxer,
ich bin seit gestern Nacht auch Besitzer von Assetto Corsa :d, ich wollte fragen ob es erlaubt ist eurem TS Server zu joinen und sich für ein paar Ründchen einzuklinken?
Und ich hätte noch 1-2 Fragen zum Spiel, gobt es Pflichtdownloads die man braucht um bei euch ordentlich mitspielen zu können?
Ich denke mal man muss die grüne Hölle haben, auch habe ich hier im Thread gelesen, dass ihr auch auf Suzuka fahrt. Leider sind genau diese beiden Strecken nicht in meiner Steam Version enthalten ;(
Sind die Strecken sowas wie offizielle "Beta" Strecken vom original Entwicklerteam oder gibts andere Strecken "nur" von Fans?
greetz
IORI
... sie beißen nicht aber fahren dich in Grund und Boden xD
Habe mir eben gerade den Nürburgring gezogen, version 1.1 von Snoopy. Habe den Ordner wie beschrieben in die Trackliste kopiert, im Spiel bekomme ich die grüne Hölle auch in der Streckenauswahl angezeigt, jedoch lädt er sie leider nicht bzw, er "lädt" die Strecke, danach sagt das Spiel, dass es mein gewähltes Auto lädt jedoch passiert dann nix mehr. Jmd von auch Profis vielleicht ein Tip für mich?
greetz
IORI
Ähnliche Themen
