[Sammelthread] Asus Crosshair IV Formula (AMD 890FX) [3]
Spezifikationen Spezifikationen
CPU
  • AMD Socket AM3 ;Phenom™II /Athlon™II /Sempron™ 100 Series Processors
  • AMD 140W CPU Support
  • AMD Cool 'n' Quiet™ Technology
  • Supports 45nm CPU
AMD Chipset
  • Northbridge:
    - AMD 890FX chipset
  • Southbridge:
    - AMD SB850
Memory
  • 4 x DIMM, Max. 16 GB, DDR3 2000(O.C.)/1800(O.C.)/1600(O.C.)/1333/1066 ECC,Non-ECC,Un-buffered Memory
    - Dual Channel memory architecture
Expansion Slots
  • 3 x PCIe 2.0 x16 ( dual @ x16, triple @x16 x8 x8 )
  • 1 x PCIe 2.0 x4
  • 2 x PCI 2.2
Multi-GPU Support
  • Support ATI CrossFire™X Technology graphics cards
Storage
  • SB850 Chipset
    - 6 xSATA 6.0 Gb/s ports Support RAID 0,1,5,10
  • JMicron® JMB363 PATA and SATA controller
    - 1 x SATA 3Gb/s port (Black)
    - 1 x External power SATA 3Gb/s port on rear (SATA On-the-Go)
Audio
  • SupremeFX X-Fi built-in 8-Channel High Definition Audio CODEC
    - EAX® Advanced™ HD 4.0
    - X-Fi CMSS®-3D
    - X-Fi Crystalizer™
    - Creative ALchemy
    - Supports Blu-ray audio layer content protection
    - Supports 1 Optical S/PDIF out port at back I/O
    - Supports 1 x S/PDIF out header
    - Supports Jack-detection, Multi-streaming, Front Panel Jack-retasking
LAN
  • Marvell 8059 Gigabit LAN controller
Internal I/O Connectors
  • 3 x USB 2.0 connectors supports additional 5 USB 2.0 ports
  • 6 x SATA 6Gb/s connectors (Red)
  • 1 x SATA 3Gb/s connectors (Black)
  • 8 x Fan connectors: 1 x CPU / 1 x PWR / 3 x Chassis / 3 x Optional
  • 7 x ProbeIt measurement points
  • 3 x Thermal sensor connectors
  • 1 x IEEE1394a connector
  • 1 x SPDIF_out connector
  • 1 x 24-pin ATX power connector
  • 1 x 8-pin ATX 12V power connector
  • 1 x En/Dis-able Clr CMOS switch
  • 1 x Core unlocker switch
  • 1 x Turbo key II switch
  • 1 x Power on switch
  • 1 x Reset switch
  • 1 x OC Station Header
  • 1 x Go Button
  • System panel connector
Back Panel I/O Ports
  • 1 x External SATA
  • 1 x S/PDIF Out (Optical)
  • 1 x IEEE 1394a
  • 1 x LAN(RJ45) port
  • 8 -Channel Audio I/O
  • 1 x PS/2 Keyboard port(purple)
  • 2 x USB 3.0/2.0 ports
  • 7 x USB 2.0/1.1 ports (1 port is also for ROG Connect)
  • 1 x ROG Connect On/Off switch
  • 1 x Clr CMOS switch
Special Features
  • Turbo Key II
  • Core Unlocker
  • ASUS Q-Connector
  • ASUS Q-Shield
  • ASUS Q-Fan 2
  • ASUS EZ Flash 2
  • ASUS CrashFree BIOS 3
  • ASUS MyLogo 3
Accessories
  • User's manual
  • 1 x I/O Shield
  • 1 x ROG Connect Cable
  • 1 x 2-in-1 ASUS Q-Connector Kit
  • 1 x 2-in-1 SATA 6.0Gb/s Cables
  • 2 x 2-in-1 SATA 3.0Gb/s Signal Cables
  • 1 x 2-port USB2.0 + ESATA Module
  • 1 x Crossfire Cable
  • 1 x Cable Ties Pack
  • 1 x ROG Theme Label
  • 1 x 12-in-1 ROG Cable Label
BilderBilder
Das Mainboard
(Quelle: AwardFabrik.de)
Die Verpackung und das Zubehör
Das BiosDas Bios
(Quelle: AwardFabrik.de)​
DownloadsDownloads
Bios Downloads
  • Bios 0505
    - First release Bios
  • Bios 0602
    - Update strings "CPB Control" to "AMD Turbo CORE technology" in BIOS.
  • Bios 0701
    - Improve the stability of certain hard drives.
  • Bios 0707 (BETA)
    - Enable SATA down mode support to fix the Samsung SATA2 HDD issue.
    - Enhance gaming performance.
    - Enable the support of DDRIII-2000 under full 4 DIMM configuration when using Thuban processor.
    - Enhance SATA6G performance
    - Enable fix CPU multiplier for 6-core processor when disabling [Cool and Quiet] in BIOS.
  • Bios 0801
    - Improve memory compatibility
  • Bios 0905 (BETA)
    - Fixed CPU/NB Voltage setting may be not be retained after pressing the reset button under OS.
    - Enable support of CPU ratio control for 6 core Thuban processor via OC Station
    - Enable ROG Connect and OC Station support under high HT Frequency.
    - Enable the support of CPU Level Up function for Phenom II X4 965
    - Enable the display of DRAM 1st Information and DRAM 2nd Information for the ease of DRAM Timing control
  • Bios 1005
    - Improve system stability
  • Bios 1102
    - Support new CPUs
    Das flashen geschieht auf eigene Gefahr!
WasserkühlerWasserkühler
Oho, muss ich gleich mal probieren. Damals mit den 8xxx Treibern erfolglos probiert und deshalb mit dem 9100 erst garnicht versucht. Wenn nun noch der Dolby/SRS Kram ginge wär ich zufrieden.
hmm,. nur passiert bei den einstellungen in dem deck nix.... weder beim EQ noch beim bassverstärker und so weiter....
Eq und Bassverstärkung gehen bei mir, nur Lautsprechersetup bzw Test und das SRS Zeuch nicht. Lautsprecher kann man aber in der Systemsteuerung einstellen.
moin zusammen,
ich versuch seit 3 tagen meinem X4 955 be die 3,6ghz schmackhaft zu machen!!
bekomme es aber nicht primstabiel hin!! wenn das board es automatisch macht geht es aber mir sind die temps(60grad) und die volts(1,42) zu hoch!!
cpu. wie oben X4 955 BE C2
ram: OCZ OCZ3BE1600C8LV2G
board: Asus Crosshair IV Formula @ bios 1304
wenn jemand rat weiss schon mal danke im vorraus!!
gruss lost boy
deine einstellungen wärn interessant und wie's auf automatisch ausschaut...
laut aida bei 3,4 ghz stabiel bei prime 95
Informationsliste Wert
BIOS Eigenschaften
BIOS Typ AMI
BIOS Version 1304
AGESA Version 3.7.1.0
Datum System BIOS 12/09/10
Datum Video BIOS 09/09/08
BIOS Einstellungen (ATK)
CPU Voltage 1353125 V
CPU/NB Voltage 1150000 V
DRAM Voltage 1.6375 V
HT Volt. 1.2000 V
NB 1.8V Volt. 1.80200 V
NB Voltage 1.1000 V
SB Volt. 1.11300 V
VDDA Volt. 2.5000 V
VDDPCIE Volt. 1.11300 V
VDDR Volt. 1.20575 V
DRAM Ctrl Vref 0.500 X
DRAM Data Vref 0.500 X
CPU Frequency 213.00 MHz
DRAM Frequency 1066 MHz
CPU Ratio 16.0x
und bei 3,6 ghz
BIOS Eigenschaften
BIOS Typ AMI
BIOS Version 1304
CPU Voltage 140000 V
CPU/NB Voltage 110000 V
HT Volt. 1.2000 V
NB Voltage 1.100 V
SB Volt. 1.11300 V
VDDA Volt. 2.5000 V
CPU Frequency 225.00 MHz
DRAM Frequency 800 MHz
CPU Ratio 16.0x
bei 3,6 friert der rechner ein auch im auto tunning
den multi erhöhen hatt bis dato auch nicht geholfen
Hey Jungs
Habe mal ne Frage: Hat von euch einer 2x SSD`s im RAID 0 betrieb laufen??
Danke im voraus
MfG
Bekommst du ein Bluescreen oder geht dann einfach nichts mehr??
Du kannst mal die CPU/NB Voltage erhöhen, die kommt mir a bissl zu wenig vor. ( eigene Gefahr )
Und deine Werte solltest du manuell setzten nicht auf Auto.
MfG
mal bluescreen mal geht nichts mehr u8nd wenn ich denn multi erhöhe auf 18x 200mhz mit den volts die das bios vorgiebt bluescreen
hab auch schon versucht denn cpu nb zu erhöhen aber meist nur 2-3 stufen hab mich nicht weiter getraut wegen unwissen was er abkann
In welchen schritten hast du die CPU/NB erhöht, was war der max- Wert bei deinen 3 Stufen, was du eigegeben hast??
MfG
Phenom II 1090t Black Edition mit Asus Formula IV
hi
ich kann im Bios den Multi nicht einstellen die Einstellung bleibt auf Auto.
Der multi bei dem prozz ist doch offen?
vll kann mir einer sagen was da falsch läuft.
danke
Sunnyville
Da es sich um die Black Edition handelt, ist der offene Multiplikator als Feature vorhanden. Ist das Bios aktuell? CMOS-Clear probiert?
also ich war
cpu 1.4000
cpu/nb 1.1625 bei auto und 3,6 ghz im bios 1.158
und wei gesagt 18x200mhz
Also auf die CPU/NB kannst mal 1,2000 V geben behälst aber zusätzlich deine NB Temperatur im Auge.:coolblue:
Bei mir musste ich 1.250V- 1.270 V anlegen damit alles stabil läuft
Bei ca. 1,3-1,35V wird es Kritisch.
Dann kannste dich ja mal herantasten und schauen ob er Stabiler wird.
MfG
jo Bios ist das neueste
hab die enter taste gedrückt hab noch keine erfahrung mit dem board hatte sonst immer 08/15 MB
also wert dann 20 einstellen oder 18,5 ich las das der multi blos bis 18,5 geht und den rest via htt
danke
---------- Beitrag hinzugefügt um 17:28 ---------- Vorheriger Beitrag war um 17:27 ----------
bin mal im Bios bis gleich
hm
multi auf 18.5 gestellt Cpu/NB auf 1.2000 gestellt gespeichert im Bios steht oben nun 3700 MHZ aber beim booten und im Windows hab ich den standart takt von 3.200 ghz
seltsam oder ich bin zu blöde
---------- Beitrag hinzugefügt um 18:27 ---------- Vorheriger Beitrag war um 17:48 ----------
nu hat er es 3.700 MHZ jetzt muss ich die Temps mal im Auge behalten bei 3.900 MHZ
war er bei prime bei 65 grad keine Ahnung wann der schlapp macht
danke @ xxmkxx
hab 3,6 ghz erreicht cpu 1,4v cpu/nb 1.2v und das 1,5 std. prime stabil bei 66grad
lüfter drehen alle im silent profil
nb hat 54grad
gruss
Freut mich aber versuch bitte mal noch die CPU Spannung zu senken denn dann wird er nicht zu warm..
1,4V brauchen manche für 4GHz
DieTemp für die NB ist noch okay
MfG
Sent from my MB525 using Tapatalk
ja dank, muss ich mal die tage testen
hab noch versucht 19x200mhz,da gab es wieder absturz bei prime
gruss
danke bleib erst mal bei 3,6 und versuch die volts etwas runter zu schrauben!!
wenn ich doch mal mehr leistung brauche,kann ich ja mal wieder die leistung erhöhen
gruss
@xxmkxx
Vielleicht hast du's ja übersehen aber warum soll Lost Boy die CPU/NB Spannung erhöhen???? Der hat eine BE CPU und hat diesen im letzten Beitrag auf 19x200 laufen, heisst die NB ist gar nicht übertaktet, das einzige was jetzt bei Lost Boy steigt ist die CPU Temp. Erst wenn die NB Übertaktet wird kann man diese erhöhen, also der ganz falsche Weg bisher.
Morgen Chaos
komischerweise nach erhöhung der CPU/NB schmierte sein PC nicht mehr ab.
Die Voltage was er vorgibt, 1,2V, ist dann nur der max Wert was sich die CPU/NB nimmt wenn es gebraucht wird.
Moin xxmkxx
ich wollte gerade noch Editieren aber du warst schneller, wollte sagen das Lost Boy mal sein Bioseinstellungen oder CPU-Z Bilder hochlädt damit man mal ansetzen kann. Wenn die NB nicht übertaketet ist braucht die auch nicht mehr Spannung, jedenfals nicht 1,2..V.
