[Sammelthread] Asus Crosshair IV Formula (AMD 890FX) [3]
Spezifikationen Spezifikationen
CPU
  • AMD Socket AM3 ;Phenom™II /Athlon™II /Sempron™ 100 Series Processors
  • AMD 140W CPU Support
  • AMD Cool 'n' Quiet™ Technology
  • Supports 45nm CPU
AMD Chipset
  • Northbridge:
    - AMD 890FX chipset
  • Southbridge:
    - AMD SB850
Memory
  • 4 x DIMM, Max. 16 GB, DDR3 2000(O.C.)/1800(O.C.)/1600(O.C.)/1333/1066 ECC,Non-ECC,Un-buffered Memory
    - Dual Channel memory architecture
Expansion Slots
  • 3 x PCIe 2.0 x16 ( dual @ x16, triple @x16 x8 x8 )
  • 1 x PCIe 2.0 x4
  • 2 x PCI 2.2
Multi-GPU Support
  • Support ATI CrossFire™X Technology graphics cards
Storage
  • SB850 Chipset
    - 6 xSATA 6.0 Gb/s ports Support RAID 0,1,5,10
  • JMicron® JMB363 PATA and SATA controller
    - 1 x SATA 3Gb/s port (Black)
    - 1 x External power SATA 3Gb/s port on rear (SATA On-the-Go)
Audio
  • SupremeFX X-Fi built-in 8-Channel High Definition Audio CODEC
    - EAX® Advanced™ HD 4.0
    - X-Fi CMSS®-3D
    - X-Fi Crystalizer™
    - Creative ALchemy
    - Supports Blu-ray audio layer content protection
    - Supports 1 Optical S/PDIF out port at back I/O
    - Supports 1 x S/PDIF out header
    - Supports Jack-detection, Multi-streaming, Front Panel Jack-retasking
LAN
  • Marvell 8059 Gigabit LAN controller
Internal I/O Connectors
  • 3 x USB 2.0 connectors supports additional 5 USB 2.0 ports
  • 6 x SATA 6Gb/s connectors (Red)
  • 1 x SATA 3Gb/s connectors (Black)
  • 8 x Fan connectors: 1 x CPU / 1 x PWR / 3 x Chassis / 3 x Optional
  • 7 x ProbeIt measurement points
  • 3 x Thermal sensor connectors
  • 1 x IEEE1394a connector
  • 1 x SPDIF_out connector
  • 1 x 24-pin ATX power connector
  • 1 x 8-pin ATX 12V power connector
  • 1 x En/Dis-able Clr CMOS switch
  • 1 x Core unlocker switch
  • 1 x Turbo key II switch
  • 1 x Power on switch
  • 1 x Reset switch
  • 1 x OC Station Header
  • 1 x Go Button
  • System panel connector
Back Panel I/O Ports
  • 1 x External SATA
  • 1 x S/PDIF Out (Optical)
  • 1 x IEEE 1394a
  • 1 x LAN(RJ45) port
  • 8 -Channel Audio I/O
  • 1 x PS/2 Keyboard port(purple)
  • 2 x USB 3.0/2.0 ports
  • 7 x USB 2.0/1.1 ports (1 port is also for ROG Connect)
  • 1 x ROG Connect On/Off switch
  • 1 x Clr CMOS switch
Special Features
  • Turbo Key II
  • Core Unlocker
  • ASUS Q-Connector
  • ASUS Q-Shield
  • ASUS Q-Fan 2
  • ASUS EZ Flash 2
  • ASUS CrashFree BIOS 3
  • ASUS MyLogo 3
Accessories
  • User's manual
  • 1 x I/O Shield
  • 1 x ROG Connect Cable
  • 1 x 2-in-1 ASUS Q-Connector Kit
  • 1 x 2-in-1 SATA 6.0Gb/s Cables
  • 2 x 2-in-1 SATA 3.0Gb/s Signal Cables
  • 1 x 2-port USB2.0 + ESATA Module
  • 1 x Crossfire Cable
  • 1 x Cable Ties Pack
  • 1 x ROG Theme Label
  • 1 x 12-in-1 ROG Cable Label
BilderBilder
Das Mainboard
(Quelle: AwardFabrik.de)
Die Verpackung und das Zubehör
Das BiosDas Bios
(Quelle: AwardFabrik.de)​
DownloadsDownloads
Bios Downloads
  • Bios 0505
    - First release Bios
  • Bios 0602
    - Update strings "CPB Control" to "AMD Turbo CORE technology" in BIOS.
  • Bios 0701
    - Improve the stability of certain hard drives.
  • Bios 0707 (BETA)
    - Enable SATA down mode support to fix the Samsung SATA2 HDD issue.
    - Enhance gaming performance.
    - Enable the support of DDRIII-2000 under full 4 DIMM configuration when using Thuban processor.
    - Enhance SATA6G performance
    - Enable fix CPU multiplier for 6-core processor when disabling [Cool and Quiet] in BIOS.
  • Bios 0801
    - Improve memory compatibility
  • Bios 0905 (BETA)
    - Fixed CPU/NB Voltage setting may be not be retained after pressing the reset button under OS.
    - Enable support of CPU ratio control for 6 core Thuban processor via OC Station
    - Enable ROG Connect and OC Station support under high HT Frequency.
    - Enable the support of CPU Level Up function for Phenom II X4 965
    - Enable the display of DRAM 1st Information and DRAM 2nd Information for the ease of DRAM Timing control
  • Bios 1005
    - Improve system stability
  • Bios 1102
    - Support new CPUs
    Das flashen geschieht auf eigene Gefahr!
WasserkühlerWasserkühler
Ich bin nur über den Raf Takt gegangen das ich mich mit K10Stat absolut nicht auskenne und C'n'Q nutzen möchte ansonsten hätte ich das auch wie Du gemacht.
Deine CPU ist auch keine schlechte wie ich gerade sehe.
BFBC2 also wenn das läuft kannst fast immer sicher sein deine Kiste läuft stabil.
Zur LLC, naja bei dem einen läuft es mit LLC an besser bei dem anderen wenn LLC aus ist. Bei mir läuft es aber mit LLC an besser deshalb lasse ich die auch an.
Muss mich aber noch ein wenig mit dem NB Takt befassen und zu sehen das der auch an die 3000'er Grenze kommt. Deine Einstellungen in Bios sind aber okay wie ich finde.
Nur im Moment hab ich nicht viel Zeit zum testen.
Danke für das Widget.
Genau das gleiche habe ich auch gemacht.... ich wollte C`n´Q nutzen und habe K10 und Phenom mrs tweaker versucht, aber es hat nicht richtig geklappt ;-)
deshalb auch den REf takt bisschen angehoben und multi auf 18 gesetzt
Danke, über meine CPU bin ich auch zufrieden. ( kein Montagsmodell)..
bitte bitte kannst die Farben anpassen wie du willst...
MfG
also meiner läuft bei 2930 oder so bei 1,18 ich glaub.... is halt bissl verquer bei 225 ref für 1800 aufm ram
@xxmkxx
dann haben wir einiges gemeinsam mit den tollen Tools die es gibt ;)
Jo meine CPU scheint auch kein Montagsmodell zu sein. Bei Multi 20x200 brauch ich sogar noch weniger als über den Ref Takt.
@Smokey
Ich habe aber Vollbestückung und da braucht man in der Regel ein wenig mehr Saft ;)
Das ist ne feine sache dann, weniger Spannung als über Ref takt ;-0
Ja von denn tools bin ich auch nicht der freund , lieber richtig übers Bios :-)
Teste heute abend mal andere Settings aber mit 1,2V auf der cpu/nb bei 3000MHz komme ich nicht hin leider :-)
Sent from my MB525 using Tapatalk
Jo ich schaff 2880 auf NB mit 1,231v, weil RAM @1920 und voll bestückt... Da muss die Spannung nachziehen, ansonsten Blauer. Wie man in Sig sieht hab ich auch ein wenig an den Timings rumgespielt. ;)
naja vollbestückung gibts bei mir schonma nich.... demnächst kommt ein 8gb 2000er kit rein, mal schaun wie's dann läuft...
Dann musste aber ref. auf 250 setzen und dann geht's mit allem Anderen in die Hose, weil dann NB entweder in deinen Augen zu niedrig oder fürs Board zu hoch ist. xD
nuja, ob 2930 oder glatt 3000 is doch nich so wild.... und alles andre passt auch, also da mach ich mir kein kopp :)
also hoff ich mal das mit dem ram alles klappt und dann läuft alles schön glatt :) wobei ich mich jetzt auch nich beschweren kann, siehe sig ;)
BIOS Einstellungen (ATK)
CPU Voltage 1237500 V
CPU/NB Voltage 1187500 V
DRAM Voltage 1.5000 V
HT Volt. 1.2000 V
NB 1.8V Volt. 1.80200 V
NB Voltage 1.1000 V
SB Volt. 1.11300 V
VDDA Volt. 2.5000 V
VDDPCIE Volt. 1.11300 V
VDDR Volt. 1.20575 V
DRAM Ctrl Vref 0.500 X
DRAM Data Vref 0.500 X
CPU Frequency 225.00 MHz
DRAM Frequency 1600 MHz
CPU Ratio 16.0x
Morgen Skull
Danke für die Werte. Ich habe gestern Abend noch versucht die CPyU/NB Spannung zu senken.
Ist auch etwas gegangen aber den Wert von unter 1,2V geht ums verrecken nicht.
Schade aber ist nun auch nicht weiter schlimm ;-)
MfG
muss ich halt meine frage hier erneut stellen:
Ist euch bekannt oder habt ihr das auch das beim booten oben links 5 blaue striche kommen die quasi n ladebalken darstelln sollen? hat das jemand? kann ja nicht sein das ich der einzigste bin damit.
Ich och nicht. ...
Wann ungefähr kommt der Ladebalken? ?
Welches Bios haste drauf.
vor allem welches board... weil in seiner sys-info steht crosshair III....
wat? omh is das immer noch das drin? lol nene hab das cf IV, aktuellestes bios drauf aber ich hab die seitdem ich das board seitdem es rauskam, so wenn das bild kommt wo man sieht was der pc fürn takt hat und geräte drann sind und dann eben bildschirm schwarz wird dann kommen die blauen ladebalken und danach kommt der win7 startbildschirm
nöp. kommt wahrscheinlich von deiner graka. ati, oder?
jup ati, aber was haben die ladebalken ganz am anfang vor win7 mit ner graka zu tun? naja is ja auch n amd board
haben nix miteinander zu tun, ist einfach von deiner graka ... frag mal bei amd nach. :shot:
ok also ich hab seitdem ich win7 sp1 drauf hab das problem das nach diesen ladebalken son pixelbrei an dessen stelle kommt und der pc nicht weiter bootet, lösungsvorschläge?
ah, das ist was anderes.
F8 und im abgesicherten modus booten geht?
