[Sammelthread] Asus Crosshair IV Formula (AMD 890FX) [3]
Spezifikationen Spezifikationen
CPU
  • AMD Socket AM3 ;Phenom™II /Athlon™II /Sempron™ 100 Series Processors
  • AMD 140W CPU Support
  • AMD Cool 'n' Quiet™ Technology
  • Supports 45nm CPU
AMD Chipset
  • Northbridge:
    - AMD 890FX chipset
  • Southbridge:
    - AMD SB850
Memory
  • 4 x DIMM, Max. 16 GB, DDR3 2000(O.C.)/1800(O.C.)/1600(O.C.)/1333/1066 ECC,Non-ECC,Un-buffered Memory
    - Dual Channel memory architecture
Expansion Slots
  • 3 x PCIe 2.0 x16 ( dual @ x16, triple @x16 x8 x8 )
  • 1 x PCIe 2.0 x4
  • 2 x PCI 2.2
Multi-GPU Support
  • Support ATI CrossFire™X Technology graphics cards
Storage
  • SB850 Chipset
    - 6 xSATA 6.0 Gb/s ports Support RAID 0,1,5,10
  • JMicron® JMB363 PATA and SATA controller
    - 1 x SATA 3Gb/s port (Black)
    - 1 x External power SATA 3Gb/s port on rear (SATA On-the-Go)
Audio
  • SupremeFX X-Fi built-in 8-Channel High Definition Audio CODEC
    - EAX® Advanced™ HD 4.0
    - X-Fi CMSS®-3D
    - X-Fi Crystalizer™
    - Creative ALchemy
    - Supports Blu-ray audio layer content protection
    - Supports 1 Optical S/PDIF out port at back I/O
    - Supports 1 x S/PDIF out header
    - Supports Jack-detection, Multi-streaming, Front Panel Jack-retasking
LAN
  • Marvell 8059 Gigabit LAN controller
Internal I/O Connectors
  • 3 x USB 2.0 connectors supports additional 5 USB 2.0 ports
  • 6 x SATA 6Gb/s connectors (Red)
  • 1 x SATA 3Gb/s connectors (Black)
  • 8 x Fan connectors: 1 x CPU / 1 x PWR / 3 x Chassis / 3 x Optional
  • 7 x ProbeIt measurement points
  • 3 x Thermal sensor connectors
  • 1 x IEEE1394a connector
  • 1 x SPDIF_out connector
  • 1 x 24-pin ATX power connector
  • 1 x 8-pin ATX 12V power connector
  • 1 x En/Dis-able Clr CMOS switch
  • 1 x Core unlocker switch
  • 1 x Turbo key II switch
  • 1 x Power on switch
  • 1 x Reset switch
  • 1 x OC Station Header
  • 1 x Go Button
  • System panel connector
Back Panel I/O Ports
  • 1 x External SATA
  • 1 x S/PDIF Out (Optical)
  • 1 x IEEE 1394a
  • 1 x LAN(RJ45) port
  • 8 -Channel Audio I/O
  • 1 x PS/2 Keyboard port(purple)
  • 2 x USB 3.0/2.0 ports
  • 7 x USB 2.0/1.1 ports (1 port is also for ROG Connect)
  • 1 x ROG Connect On/Off switch
  • 1 x Clr CMOS switch
Special Features
  • Turbo Key II
  • Core Unlocker
  • ASUS Q-Connector
  • ASUS Q-Shield
  • ASUS Q-Fan 2
  • ASUS EZ Flash 2
  • ASUS CrashFree BIOS 3
  • ASUS MyLogo 3
Accessories
  • User's manual
  • 1 x I/O Shield
  • 1 x ROG Connect Cable
  • 1 x 2-in-1 ASUS Q-Connector Kit
  • 1 x 2-in-1 SATA 6.0Gb/s Cables
  • 2 x 2-in-1 SATA 3.0Gb/s Signal Cables
  • 1 x 2-port USB2.0 + ESATA Module
  • 1 x Crossfire Cable
  • 1 x Cable Ties Pack
  • 1 x ROG Theme Label
  • 1 x 12-in-1 ROG Cable Label
BilderBilder
Das Mainboard
(Quelle: AwardFabrik.de)
Die Verpackung und das Zubehör
Das BiosDas Bios
(Quelle: AwardFabrik.de)​
DownloadsDownloads
Bios Downloads
  • Bios 0505
    - First release Bios
  • Bios 0602
    - Update strings "CPB Control" to "AMD Turbo CORE technology" in BIOS.
  • Bios 0701
    - Improve the stability of certain hard drives.
  • Bios 0707 (BETA)
    - Enable SATA down mode support to fix the Samsung SATA2 HDD issue.
    - Enhance gaming performance.
    - Enable the support of DDRIII-2000 under full 4 DIMM configuration when using Thuban processor.
    - Enhance SATA6G performance
    - Enable fix CPU multiplier for 6-core processor when disabling [Cool and Quiet] in BIOS.
  • Bios 0801
    - Improve memory compatibility
  • Bios 0905 (BETA)
    - Fixed CPU/NB Voltage setting may be not be retained after pressing the reset button under OS.
    - Enable support of CPU ratio control for 6 core Thuban processor via OC Station
    - Enable ROG Connect and OC Station support under high HT Frequency.
    - Enable the support of CPU Level Up function for Phenom II X4 965
    - Enable the display of DRAM 1st Information and DRAM 2nd Information for the ease of DRAM Timing control
  • Bios 1005
    - Improve system stability
  • Bios 1102
    - Support new CPUs
    Das flashen geschieht auf eigene Gefahr!
WasserkühlerWasserkühler
Also ich muss ja mal sagen ich hatte bis auf mein Crosshair IV mit Asus nur miese Erfahrung gehabt. Also von daher ist das für mich erst sicher wenns Schwarz auf Weiß ist. :d Das Bios hab ich aber auch schon geladen, ich flashe das aber erst wenns wirklich BD Support bringt und das auch bewiesen wird. Außer es bringt wieder noch anderes mit sich.
Moin allerseits ...
Ich hätte mal ne Frage.
Ich habe von einem Kollegen sein 4 Monate altes Crosshair 4 Formula für lau inklusive nem 1090T erhalten. Jetzt suche ich den richtigen Speicher ... Da ich auch ein wenig auf die Optik achten möchte, hätte ich mir folgenden rausgesucht :
link
Davon würde ich mir gerne 2 Kits einbauen also insgesamt 16 GB ... Geht sich das aus in Vollbestückung oder soll ich gleich auf 1333 oder andere Module ausweichen ?
Bitte um Antworten ...
Also muss BD doch mechanisch in den AM3 reinpassen.
ich hab das bios aber wieder runtergehaun, da blieb er nach nem neustart immmer hängen, als wären meine oc settings fehlerhaft
:banana: Sehr gute Nachrichten :d Mal schauen was der BD im gegensatz zu nem X6 leistet und vorallem was er kosten wird.
Komisch, mein Sys ist mit dem 3012 Bios sowohl beim POST als auch beim Booten und sonstewo flotter. 24/7 Setting geht auch noch. Super!
€dit: Auch 3000Mhz CPU/NB geht nun endlich. Gleich mal Prime durchlaufen lassen. :]
da steht ja auch, das diese Bios nur für AM3+ CPUs ist bitte nicht mit AM3 CPUs verwenden... nur wer hat denn schon eine AM3+ CPU ;)
Funktionieren tut's trotzdem. Ich hab mal geguckt konnte Ram Spannung von 1,625 bis auf 1,5875 senken, ohne Fehler. Weiter hab ich bis jetzt nicht probiert.
4 Module und 8GB.
Kann meinen nur empfehlen. A-Data XPG G v2.0 Series. Ich mein den gibts von 1600MHz bis 2200MHz, also viel Auswahl. ^^
Meine G.Skill 1600er (die günstigsten :fresse: ) laufen auch super - 4x 2GB :)
Ich werd heut abend auch mal das neue AM3+ BIOS flashen - mal schauen was es bei mir macht ...
XMP rein und gib ihm - 1,462v laut AIDA64. Bei weiterhin 2000MHz und 9-9-9-24-2T, Mensch der geht da derb runter was Undervolting betrifft. o_O
€dit: Memtest macht nur beim 5. Thread Probleme, alle anderen fehlerfrei bis jetzt.
Untestützt der Bulli nicht offiziel die 1866er? da würd ich mir von G.skill die für 128Euros holen...sind zwar nur cl9....
Ausgezeichnet, wenn das stimmt ist da ja für mich gar keine Einschränkung, ich benutz weder Turbo Core noch i-welche Energiesparoptionen. :)
Der Turbo-Modus ist mir auch Wumpe, da ich sowieso OC betreibe, bei der Stromsparfunktion bin ich vorsichtig.
Wer weiss, was und inwieweit sich damit Temperaturen und VCore beeinflussen lassen.
Doch noch abwarten ...
Quatsch, das einzige, was mich jetzt noch aufhalten würde, einen BD zu kaufen wäre der Preis. Der ist schließlich noch unbekannt und kann Intel-like ausfallen.
hmm...meno....+0,025 für CPU offset und bei Prime sind nach ner Stunde schon wieder 3 Kerne ausgestiegen....:(
Vcore lag unter last bei 1,336-1,343V LLC 100%
teste jetzt mal +0.05V Last liegt jetzt bei 1,363-1,382....und das bei 3,6Ghz.....
hab ich echt so eine Krücke man....
