[Sammelthread] Asus Crosshair IV Formula (AMD 890FX) [3]
Spezifikationen Spezifikationen
CPU
  • AMD Socket AM3 ;Phenom™II /Athlon™II /Sempron™ 100 Series Processors
  • AMD 140W CPU Support
  • AMD Cool 'n' Quiet™ Technology
  • Supports 45nm CPU
AMD Chipset
  • Northbridge:
    - AMD 890FX chipset
  • Southbridge:
    - AMD SB850
Memory
  • 4 x DIMM, Max. 16 GB, DDR3 2000(O.C.)/1800(O.C.)/1600(O.C.)/1333/1066 ECC,Non-ECC,Un-buffered Memory
    - Dual Channel memory architecture
Expansion Slots
  • 3 x PCIe 2.0 x16 ( dual @ x16, triple @x16 x8 x8 )
  • 1 x PCIe 2.0 x4
  • 2 x PCI 2.2
Multi-GPU Support
  • Support ATI CrossFire™X Technology graphics cards
Storage
  • SB850 Chipset
    - 6 xSATA 6.0 Gb/s ports Support RAID 0,1,5,10
  • JMicron® JMB363 PATA and SATA controller
    - 1 x SATA 3Gb/s port (Black)
    - 1 x External power SATA 3Gb/s port on rear (SATA On-the-Go)
Audio
  • SupremeFX X-Fi built-in 8-Channel High Definition Audio CODEC
    - EAX® Advanced™ HD 4.0
    - X-Fi CMSS®-3D
    - X-Fi Crystalizer™
    - Creative ALchemy
    - Supports Blu-ray audio layer content protection
    - Supports 1 Optical S/PDIF out port at back I/O
    - Supports 1 x S/PDIF out header
    - Supports Jack-detection, Multi-streaming, Front Panel Jack-retasking
LAN
  • Marvell 8059 Gigabit LAN controller
Internal I/O Connectors
  • 3 x USB 2.0 connectors supports additional 5 USB 2.0 ports
  • 6 x SATA 6Gb/s connectors (Red)
  • 1 x SATA 3Gb/s connectors (Black)
  • 8 x Fan connectors: 1 x CPU / 1 x PWR / 3 x Chassis / 3 x Optional
  • 7 x ProbeIt measurement points
  • 3 x Thermal sensor connectors
  • 1 x IEEE1394a connector
  • 1 x SPDIF_out connector
  • 1 x 24-pin ATX power connector
  • 1 x 8-pin ATX 12V power connector
  • 1 x En/Dis-able Clr CMOS switch
  • 1 x Core unlocker switch
  • 1 x Turbo key II switch
  • 1 x Power on switch
  • 1 x Reset switch
  • 1 x OC Station Header
  • 1 x Go Button
  • System panel connector
Back Panel I/O Ports
  • 1 x External SATA
  • 1 x S/PDIF Out (Optical)
  • 1 x IEEE 1394a
  • 1 x LAN(RJ45) port
  • 8 -Channel Audio I/O
  • 1 x PS/2 Keyboard port(purple)
  • 2 x USB 3.0/2.0 ports
  • 7 x USB 2.0/1.1 ports (1 port is also for ROG Connect)
  • 1 x ROG Connect On/Off switch
  • 1 x Clr CMOS switch
Special Features
  • Turbo Key II
  • Core Unlocker
  • ASUS Q-Connector
  • ASUS Q-Shield
  • ASUS Q-Fan 2
  • ASUS EZ Flash 2
  • ASUS CrashFree BIOS 3
  • ASUS MyLogo 3
Accessories
  • User's manual
  • 1 x I/O Shield
  • 1 x ROG Connect Cable
  • 1 x 2-in-1 ASUS Q-Connector Kit
  • 1 x 2-in-1 SATA 6.0Gb/s Cables
  • 2 x 2-in-1 SATA 3.0Gb/s Signal Cables
  • 1 x 2-port USB2.0 + ESATA Module
  • 1 x Crossfire Cable
  • 1 x Cable Ties Pack
  • 1 x ROG Theme Label
  • 1 x 12-in-1 ROG Cable Label
BilderBilder
Das Mainboard
(Quelle: AwardFabrik.de)
Die Verpackung und das Zubehör
Das BiosDas Bios
(Quelle: AwardFabrik.de)​
DownloadsDownloads
Bios Downloads
  • Bios 0505
    - First release Bios
  • Bios 0602
    - Update strings "CPB Control" to "AMD Turbo CORE technology" in BIOS.
  • Bios 0701
    - Improve the stability of certain hard drives.
  • Bios 0707 (BETA)
    - Enable SATA down mode support to fix the Samsung SATA2 HDD issue.
    - Enhance gaming performance.
    - Enable the support of DDRIII-2000 under full 4 DIMM configuration when using Thuban processor.
    - Enhance SATA6G performance
    - Enable fix CPU multiplier for 6-core processor when disabling [Cool and Quiet] in BIOS.
  • Bios 0801
    - Improve memory compatibility
  • Bios 0905 (BETA)
    - Fixed CPU/NB Voltage setting may be not be retained after pressing the reset button under OS.
    - Enable support of CPU ratio control for 6 core Thuban processor via OC Station
    - Enable ROG Connect and OC Station support under high HT Frequency.
    - Enable the support of CPU Level Up function for Phenom II X4 965
    - Enable the display of DRAM 1st Information and DRAM 2nd Information for the ease of DRAM Timing control
  • Bios 1005
    - Improve system stability
  • Bios 1102
    - Support new CPUs
    Das flashen geschieht auf eigene Gefahr!
WasserkühlerWasserkühler
Wie gesagt kann nur das sagen was ich aufjedenfall gesehen hab kann ja mal nen foto von machen
So isset. Erst abwarten würde ich und dann erst draufjagen, das Bios. :d
Danke für die Infos!
WTF? AM3 BD? :hmm:
Wieder was für die Gerüchteküche was BD angeht, es wird endlich Zeit das hier mal taschelis seitens AMD gesprochen wird, es :kotz: mich mittlerweile an.
Wäre schön wenn BD läuft, kann man wenigstens das Board behalten.
Mein Bioschip bleibt dann vorerst vom 3012 verschont.
Das wird eh nicht gehen, es wird wohl eine neue Revision mit AM3+ Sockel geben, meine Einschätzung.
Wenn das so ist, dann könnte ich mir vorstellen meinen 2500K + P67 Board gegen einen 1055T und das Asus Crosshair IV Formula zu tauschen. :)
Auf AMD oder mich bezogen :fresse:
Kurios und gleichzeitig genial. :stupid:
Das heißt für mich 3012 Bios flashen [sobald auf ASUS Page verfügbar] und auf BD warten aber vorher 'ne neue Grafikkarte. xD
Auf der letzten Seite ist der Link zum Bios.
Aber diese Sache wo da läuft ist nach meiner Meinung mehr als Merkwürdig !!
Seh ich genauso, erstmal abwarten. Da steht ja noch die mechanische inkompatibilität im Raum, auf die AMD beharrt. Ich lasse jedenfalls erstmal die Finger von dem neuen Bios.
Da musste aber noch was drauflegen, wer will den einen 2500k mit einem fehlerhaften Chipsatz auf dem Board.:d;)
Schön schön, es scheint sich doch noch zum Positiven zu entwickeln mit dem AM3, die Hoffnung stirbt zuletzt.
ist eh schon zu spät ist drauf... ins bios komm ich schon mal meld mich gleich mal
Festplatten werden endlich anstatt immer ide zu heissen SATA angezeigt fällt schonmal auf
Im Abschnitt Booten ist die Option CDROM Laufwerke dazu gekommen(kann man auswählen von welchem zu erst gebootet wird)
Gefühlt bootet er schneller
Lüftersteuerung könnte sein das sie besser regelt
Sonst ist mir bis jetzt nix aufgefallen
OC wird gleich getestet
also bei mir heißen die immernoch ide, auch mit dem neuen bios
Ich wusste immer das AMD die bessere Wahl ist, mit dem neuen Bios wird wohl BD Compliant auch gegeben sein und dann "BÄÄM!" AMD zieht an Intel vorbei aus die Maus. :]
@Smokey bei mir steht Sata hab aber auch sata 6gb und alles auf ahci gestellt vll liegts dadran??
Wenn es wirklich so sein soll dann kann ich ja doch noch mein Board unter wasser setzen :d haben denn die am3+ boards irgendwelche vorteile gegenüber dem am3?
Na ja, laut AMD eben die Bulldozer Unterstützung und die neuen Features werden wohl auch nur von dem unterstützt. Ich wette, dass Asus und co. diese Bios bald wieder löschen werden müssen weil AMD das nicht wollen wird das BD auf AM3 ohne Einschränkung läuft.
Sonst keine vorteile? einfach abwarten!
Und wenn die CPU's wirklich einen Pin mehr haben, dann müsste einer diesen Pin mal entfernen um zu sehen obs dann immernoch läuft. ;) AM3+ hat einen Pin mehr.
Bin mal gespannt ob das wirklich lübbt, wäre der Hammer und mein 1090T würde gleich rausfliegen wenn es ohne Probleme geht, und das CF4 würde dann bestimmt über 2jahre wieder alt werden der Traum.
Glaube auch nicht das Asus sowas zum Spass macht und es dann doch nicht geht.
