[Sammelthread] Asus Crosshair IV Formula (AMD 890FX) [3]
Spezifikationen Spezifikationen
CPU
  • AMD Socket AM3 ;Phenom™II /Athlon™II /Sempron™ 100 Series Processors
  • AMD 140W CPU Support
  • AMD Cool 'n' Quiet™ Technology
  • Supports 45nm CPU
AMD Chipset
  • Northbridge:
    - AMD 890FX chipset
  • Southbridge:
    - AMD SB850
Memory
  • 4 x DIMM, Max. 16 GB, DDR3 2000(O.C.)/1800(O.C.)/1600(O.C.)/1333/1066 ECC,Non-ECC,Un-buffered Memory
    - Dual Channel memory architecture
Expansion Slots
  • 3 x PCIe 2.0 x16 ( dual @ x16, triple @x16 x8 x8 )
  • 1 x PCIe 2.0 x4
  • 2 x PCI 2.2
Multi-GPU Support
  • Support ATI CrossFire™X Technology graphics cards
Storage
  • SB850 Chipset
    - 6 xSATA 6.0 Gb/s ports Support RAID 0,1,5,10
  • JMicron® JMB363 PATA and SATA controller
    - 1 x SATA 3Gb/s port (Black)
    - 1 x External power SATA 3Gb/s port on rear (SATA On-the-Go)
Audio
  • SupremeFX X-Fi built-in 8-Channel High Definition Audio CODEC
    - EAX® Advanced™ HD 4.0
    - X-Fi CMSS®-3D
    - X-Fi Crystalizer™
    - Creative ALchemy
    - Supports Blu-ray audio layer content protection
    - Supports 1 Optical S/PDIF out port at back I/O
    - Supports 1 x S/PDIF out header
    - Supports Jack-detection, Multi-streaming, Front Panel Jack-retasking
LAN
  • Marvell 8059 Gigabit LAN controller
Internal I/O Connectors
  • 3 x USB 2.0 connectors supports additional 5 USB 2.0 ports
  • 6 x SATA 6Gb/s connectors (Red)
  • 1 x SATA 3Gb/s connectors (Black)
  • 8 x Fan connectors: 1 x CPU / 1 x PWR / 3 x Chassis / 3 x Optional
  • 7 x ProbeIt measurement points
  • 3 x Thermal sensor connectors
  • 1 x IEEE1394a connector
  • 1 x SPDIF_out connector
  • 1 x 24-pin ATX power connector
  • 1 x 8-pin ATX 12V power connector
  • 1 x En/Dis-able Clr CMOS switch
  • 1 x Core unlocker switch
  • 1 x Turbo key II switch
  • 1 x Power on switch
  • 1 x Reset switch
  • 1 x OC Station Header
  • 1 x Go Button
  • System panel connector
Back Panel I/O Ports
  • 1 x External SATA
  • 1 x S/PDIF Out (Optical)
  • 1 x IEEE 1394a
  • 1 x LAN(RJ45) port
  • 8 -Channel Audio I/O
  • 1 x PS/2 Keyboard port(purple)
  • 2 x USB 3.0/2.0 ports
  • 7 x USB 2.0/1.1 ports (1 port is also for ROG Connect)
  • 1 x ROG Connect On/Off switch
  • 1 x Clr CMOS switch
Special Features
  • Turbo Key II
  • Core Unlocker
  • ASUS Q-Connector
  • ASUS Q-Shield
  • ASUS Q-Fan 2
  • ASUS EZ Flash 2
  • ASUS CrashFree BIOS 3
  • ASUS MyLogo 3
Accessories
  • User's manual
  • 1 x I/O Shield
  • 1 x ROG Connect Cable
  • 1 x 2-in-1 ASUS Q-Connector Kit
  • 1 x 2-in-1 SATA 6.0Gb/s Cables
  • 2 x 2-in-1 SATA 3.0Gb/s Signal Cables
  • 1 x 2-port USB2.0 + ESATA Module
  • 1 x Crossfire Cable
  • 1 x Cable Ties Pack
  • 1 x ROG Theme Label
  • 1 x 12-in-1 ROG Cable Label
BilderBilder
Das Mainboard
(Quelle: AwardFabrik.de)
Die Verpackung und das Zubehör
Das BiosDas Bios
(Quelle: AwardFabrik.de)​
DownloadsDownloads
Bios Downloads
  • Bios 0505
    - First release Bios
  • Bios 0602
    - Update strings "CPB Control" to "AMD Turbo CORE technology" in BIOS.
  • Bios 0701
    - Improve the stability of certain hard drives.
  • Bios 0707 (BETA)
    - Enable SATA down mode support to fix the Samsung SATA2 HDD issue.
    - Enhance gaming performance.
    - Enable the support of DDRIII-2000 under full 4 DIMM configuration when using Thuban processor.
    - Enhance SATA6G performance
    - Enable fix CPU multiplier for 6-core processor when disabling [Cool and Quiet] in BIOS.
  • Bios 0801
    - Improve memory compatibility
  • Bios 0905 (BETA)
    - Fixed CPU/NB Voltage setting may be not be retained after pressing the reset button under OS.
    - Enable support of CPU ratio control for 6 core Thuban processor via OC Station
    - Enable ROG Connect and OC Station support under high HT Frequency.
    - Enable the support of CPU Level Up function for Phenom II X4 965
    - Enable the display of DRAM 1st Information and DRAM 2nd Information for the ease of DRAM Timing control
  • Bios 1005
    - Improve system stability
  • Bios 1102
    - Support new CPUs
    Das flashen geschieht auf eigene Gefahr!
WasserkühlerWasserkühler
underclocking
Hey Leute,
was habt ihr denn so für Erfahrungen auf diesem Board mit Underclocking gemacht. Ich weiß das ist nicht gerade das, was man auf diesem Board normalerweise tut, aber im normalen office-/internetbetrieb benötigt man so viel power nunmal nicht. hab mir gedacht, ich könnte vielleicht etwas saft sparen.
wo setze ich denn da am besten an? hab damit noch nicht so die erfahrung gemacht.
nunja, eiegntlioch genauso wie beim übertakten.... lässt alle taktraten auf standard und schaust halt, mit welcher spannung das stabil läuft. fängst mit der cpu an, dann cpu/nb und zum schluss der ram
naja mit der spannung hab ich auch noch nicht gearbeitet. meine übertaktungserfahrungen basieren eher auf taktraten... an die spannungen trau ich mich nie ran^^
es gibt immer ein erstes mal.... ;) einfach schritt für schritt runter und immer wieder ins bios und auf stabilität testen
Ich habe gehofft, jemand hat schon Erfahrungswerte, die ich einfach übernehmen könnte :d
Das sind doch werte zum Übertakten, nicht zum untertakten :p
nee, lies mal genau, das ist höchstmöglicher wert bei niedrigst möglicher spannung
krass! mein rechner hängt sich auf wenn der jdownloader läuft. :hmm:
dabei steht alles auf stock, nichts undervolted oder übertaktet. :wtf:
---------- Beitrag hinzugefügt um 09:56 ---------- Vorheriger Beitrag war um 09:50 ----------
öhm, wer von euch hat schon das neue 1902er bios drauf? bringt es etwas für die ordinären X6?
Jo habe ich drauf bei mir das Bios 1902, kann ich nur empfeghlen. Soweit
keine Probleme mit meinem X6, konnte den auf 4Ghz stabil übertakten.
Kann ich nur empfehlen, auch meine alten OC-Profile funzen damit. ;)
Gruß :wink:
ich habs 1902er auch mal geflasht und bisher habe ich den eindruck, die bootzeit sei kürzer ..
mal die tage ausm kaltstart beobachten...
Hi
Mit der Bootzeit habe ich auch den Eindruck das das ganze nochmal optimiert worden
ist, also in den letzten Bios Versionen. Geht flott das ganze. :fresse2:
Habe mal heute mir einen Multimeter besorgt und dieses ProbeIT Feature getestet.
Ich bin doch überrascht das die angezeigten Werte von den Board-Dioden ungefähr
dem gemessenen Werten mit einem Multimeter sehr nahe stehen. ;)
z.B Vcore Bios eingestellt 1.466V | Aida64 1.4550V | Multimeter 1.45V
Also eine kleine Abweichung von ca. 0,1V. Nur wie sieht das mit den Temperaturen
aus, hat einer die reale CPU-Temp irgendwie messen können? Inwiefern
wird die reale CPU-Temp angezeigt btw inwiefern entsprechen die
angezeigten Werte mit den Überwachungs-Tools dem realen, also die
CPU-Temp und die restlichen Board Temps?
die LLC ist nicht so der hit, vielleicht für overclocker interessant, aber für den normalsterblichen unerheblich.
ich hab mir vor jahren schon mal die intel dokumentation zum vdrop durchgelesen und nutze sie daher nicht, nicht mal 50%.
geht um die spannungsspitzen die beim wechsel von lastzuständen entstehn, sind die oberen peaks zu hoch, kann man die cpu recht schnell fetzen. ^^
Zu dem Thema LLC...habe in einer Sonderausgabe der PCGH gelesen, das LLC Full
der CPU schaden würde, weil die CPU soll angeblich unter Last also die Spannung
ruhig etwas runterregeln. Würde der CPU gut tun, wie als wenn permanent über LLC Saft
gepresst wird, nur ganz ausschalten wollte ich das nicht, daher habe ich es auf 50% gestellt.
Nur wenn ich es jetzt ausschalten würde, würde dann die CPU mit den identischen
eingestellten Voltages im Bios stabil laufen, oder muß man dann gezwungenermaßen
mehr Spannung einstellen?
MfG
würde sie wohl nicht.
du müsstest etwas höher mit der vcore gehn, aber es würde sich praktisch nichts nehmen.
mein kern verhält sich folgender maßen:
ohne LLC: 1,3v bios - 1,27v idle und 1,23v load
mit 50% LLC: 1,3v bios - 1,29v idle 1,28v load
und mit 100%: 1,3v bios - 1,32v idle - 1,35v load
der vdrop, also das abfallen der spannung, ist dazu da die spannungsspitzen die beim wechsel von idle zu load und umgekehrt entstehen, abzufangen und die vcore nicht über ein kritisches maß steigen zu lassen.
Sehr ausführlich erklärt, alles klar Danke dir. ;)
Nur wie verhält sich das Board bei den Temperaturen, inwiefern sind die angezeigten
Temperaturen richtig, die mit Überwachungstools ausgelesen werden?
MfG
weiß nich genau wie du das meinst. das board hat nix zu melden. es hat zu funktionieren, selbst wenn alle sensoren 70°c anzeigen, ist die temperatur imho mehr als im rahmen, das ist silizium, kein wachs.
Wieviel war vorher nötig ?
CPU bleibt echt kühl habe wirklich ein gutes erwischt. Was denkt ihr was könnte ich für meinen X6 verlangen in AH ?.
Wird zeit das der Bully kommt Mensch.
Wer sein Board noch nicht mit dem neuen Bios geflasht hat kann nur dazu sagen tut das :)
Ich hab mal ne ganz dumme Frage. Ich wollte mir demnächst ne Soundkarte mit ner x1-Schnittstelle zulegen. Da das Board ja keine x1-Slots hat, muss ich die Karte ja dann in einen der "großen" Slots packen. Auf meinem Board steckt aktuell ne Grafikkarte im ersten PCI-Express Slot drin, die restlichen 3 sind frei.
In welchen Slot hau ich die Soundkarte am besten rein, dass ich da keine Probleme kriege (vor allem nicht irgendwelche Performanceinbrüche der Grafikkarte). Oder ist das egal?
Danke schonmal :)
Nimm Slot 2 oder 4, denn der dritte ist wie der erste x16.
Dann bist du auf der sicheren Seite. ;)
oki doki
fuzzy
Muss auch mal wieder takten ... Irgendwelche Erfahrungen mit dem 1055T?
Das 1902 hab ich schon länger drauf, meiner Meinung nach hat sich die Bootzeit verkürzt, wie oben ja auch schon beschrieben.
Danke @ bytefuzzy für den Hinweis das 1 und 3 x16 haben ... Ich hab da natürlich malwieder nicht drauf geachtet. Und da bald meine zweite HD6950 kommt :-)vrizz:) wäre es ja nur von Vorteil die über die 16er laufen zu lassen ;)
Allerdings muss ich dann wohl dem 1055T feuer unterm Hintern machen bis der Bulldozer reinkommt ... Sonst haut das nicht ganz so rein mit den Grakas glaub ich ...
Hat mich etwas gewundert, weil die Asus-Website das ganze etwas anders darstellt. Dort steht:
3 x PCIe 2.0 x16 (dual @ x16, triple @x16 x8 x8)
1 x PCIe 2.0 x4
Nach meinem Verständnis sähe das ja dann so aus:
Bei einer Grafikkarte => Slot 1@x16
Bei Dual-Crossfire => Slot 1@x16 + Slot 3@x16
Bei Triple-Crossfire => Slot 1@x16 + Slot 2@x8 + Slot3@x8
Und der vierte scheint ja dann wohl mechanisch ein x16, aber intern nur ein x4-Slot zu sein. Oder sehe ich das falsch?
Ich seh das genauso....
Was für Dich wichtig sein sollte:
Ich betreibe eine Sound Blaster X-Fi Titanium Fatal1ty Champion Series auf dem 4 PCIe Steckplatz völlig problemlos...
Aus diesem Grund dürfte Deine geplante Aufrüstung auf ein Modell mit x1 Schnittstelle völlig Problemlos sein
hmm seit der 1902 geht CnQ nicht mehr mit 18.5 multi.
ist es euch auch aufgefallen?
gruss
BUFU
---------- Beitrag hinzugefügt um 13:17 ---------- Vorheriger Beitrag war um 13:00 ----------
jop nochmal resetet kein CnQ mehr.........
---------- Beitrag hinzugefügt um 13:19 ---------- Vorheriger Beitrag war um 13:00 ----------
ach enerige einstellungen sind dran schuld gewesen
Vollkommen korrekt. Warum ist das 3102 laut ez flash eigentlich neuer als das 1902?
