[Sammelthread] Asus Crosshair IV Formula (AMD 890FX) [3]
Spezifikationen Spezifikationen
CPU
  • AMD Socket AM3 ;Phenom™II /Athlon™II /Sempron™ 100 Series Processors
  • AMD 140W CPU Support
  • AMD Cool 'n' Quiet™ Technology
  • Supports 45nm CPU
AMD Chipset
  • Northbridge:
    - AMD 890FX chipset
  • Southbridge:
    - AMD SB850
Memory
  • 4 x DIMM, Max. 16 GB, DDR3 2000(O.C.)/1800(O.C.)/1600(O.C.)/1333/1066 ECC,Non-ECC,Un-buffered Memory
    - Dual Channel memory architecture
Expansion Slots
  • 3 x PCIe 2.0 x16 ( dual @ x16, triple @x16 x8 x8 )
  • 1 x PCIe 2.0 x4
  • 2 x PCI 2.2
Multi-GPU Support
  • Support ATI CrossFire™X Technology graphics cards
Storage
  • SB850 Chipset
    - 6 xSATA 6.0 Gb/s ports Support RAID 0,1,5,10
  • JMicron® JMB363 PATA and SATA controller
    - 1 x SATA 3Gb/s port (Black)
    - 1 x External power SATA 3Gb/s port on rear (SATA On-the-Go)
Audio
  • SupremeFX X-Fi built-in 8-Channel High Definition Audio CODEC
    - EAX® Advanced™ HD 4.0
    - X-Fi CMSS®-3D
    - X-Fi Crystalizer™
    - Creative ALchemy
    - Supports Blu-ray audio layer content protection
    - Supports 1 Optical S/PDIF out port at back I/O
    - Supports 1 x S/PDIF out header
    - Supports Jack-detection, Multi-streaming, Front Panel Jack-retasking
LAN
  • Marvell 8059 Gigabit LAN controller
Internal I/O Connectors
  • 3 x USB 2.0 connectors supports additional 5 USB 2.0 ports
  • 6 x SATA 6Gb/s connectors (Red)
  • 1 x SATA 3Gb/s connectors (Black)
  • 8 x Fan connectors: 1 x CPU / 1 x PWR / 3 x Chassis / 3 x Optional
  • 7 x ProbeIt measurement points
  • 3 x Thermal sensor connectors
  • 1 x IEEE1394a connector
  • 1 x SPDIF_out connector
  • 1 x 24-pin ATX power connector
  • 1 x 8-pin ATX 12V power connector
  • 1 x En/Dis-able Clr CMOS switch
  • 1 x Core unlocker switch
  • 1 x Turbo key II switch
  • 1 x Power on switch
  • 1 x Reset switch
  • 1 x OC Station Header
  • 1 x Go Button
  • System panel connector
Back Panel I/O Ports
  • 1 x External SATA
  • 1 x S/PDIF Out (Optical)
  • 1 x IEEE 1394a
  • 1 x LAN(RJ45) port
  • 8 -Channel Audio I/O
  • 1 x PS/2 Keyboard port(purple)
  • 2 x USB 3.0/2.0 ports
  • 7 x USB 2.0/1.1 ports (1 port is also for ROG Connect)
  • 1 x ROG Connect On/Off switch
  • 1 x Clr CMOS switch
Special Features
  • Turbo Key II
  • Core Unlocker
  • ASUS Q-Connector
  • ASUS Q-Shield
  • ASUS Q-Fan 2
  • ASUS EZ Flash 2
  • ASUS CrashFree BIOS 3
  • ASUS MyLogo 3
Accessories
  • User's manual
  • 1 x I/O Shield
  • 1 x ROG Connect Cable
  • 1 x 2-in-1 ASUS Q-Connector Kit
  • 1 x 2-in-1 SATA 6.0Gb/s Cables
  • 2 x 2-in-1 SATA 3.0Gb/s Signal Cables
  • 1 x 2-port USB2.0 + ESATA Module
  • 1 x Crossfire Cable
  • 1 x Cable Ties Pack
  • 1 x ROG Theme Label
  • 1 x 12-in-1 ROG Cable Label
BilderBilder
Das Mainboard
(Quelle: AwardFabrik.de)
Die Verpackung und das Zubehör
Das BiosDas Bios
(Quelle: AwardFabrik.de)​
DownloadsDownloads
Bios Downloads
  • Bios 0505
    - First release Bios
  • Bios 0602
    - Update strings "CPB Control" to "AMD Turbo CORE technology" in BIOS.
  • Bios 0701
    - Improve the stability of certain hard drives.
  • Bios 0707 (BETA)
    - Enable SATA down mode support to fix the Samsung SATA2 HDD issue.
    - Enhance gaming performance.
    - Enable the support of DDRIII-2000 under full 4 DIMM configuration when using Thuban processor.
    - Enhance SATA6G performance
    - Enable fix CPU multiplier for 6-core processor when disabling [Cool and Quiet] in BIOS.
  • Bios 0801
    - Improve memory compatibility
  • Bios 0905 (BETA)
    - Fixed CPU/NB Voltage setting may be not be retained after pressing the reset button under OS.
    - Enable support of CPU ratio control for 6 core Thuban processor via OC Station
    - Enable ROG Connect and OC Station support under high HT Frequency.
    - Enable the support of CPU Level Up function for Phenom II X4 965
    - Enable the display of DRAM 1st Information and DRAM 2nd Information for the ease of DRAM Timing control
  • Bios 1005
    - Improve system stability
  • Bios 1102
    - Support new CPUs
    Das flashen geschieht auf eigene Gefahr!
WasserkühlerWasserkühler
hmm seit der 1902 geht CnQ nicht mehr mit 18.5 multi.
ist es euch auch aufgefallen?
gruss
BUFU
---------- Beitrag hinzugefügt um 13:17 ---------- Vorheriger Beitrag war um 13:00 ----------
jop nochmal resetet kein CnQ mehr.........
---------- Beitrag hinzugefügt um 13:19 ---------- Vorheriger Beitrag war um 13:00 ----------
ach enerige einstellungen sind dran schuld gewesen
Mir nicht
Btw -> Das neue Bios ist hinsichtlich 1090T und OC Effizienz der Hammer! Brauche nur noch 1,405v für LinX unter Last @ 4GHz. ='O
hier hat sich doch jemand über das ständige ploppen des audio-ausgangs mokiert.
nach der neuinstallation hatte ich das auch, und ja, es nervt wie die sau.
ich hab ausm 9100er treiber für den via-chip einfach das vdeck in den programmordner auf
c: kopiert und eine verknüpfung im autostart angelegt, seit dem ist das ploppen weg. :)
Meint ihr mit ploppen das knacken wenn man die Lautsprecher leiser und lauter dreht? Oder liegt das an meinen Lautsprechern o_O
ich meine ein ploppen bevor man eine audio-ausgabe startet und nicht wenn man am lautstärkeregler dreht - das wäre dann ein kratzen.
Komisch. o_O ich hab das auch, aber einmal kurz während des Bootens. :fresse:
mit meiner alten installation hatte ich das problem auch nicht.
Ich möchte bitte, dass ihr mit dieser kindischen Unterhaltung aufhört. Wenn jemand das Bedürfnis verspürt, etwas zu klären, was nichts mit dem Board selbst zu tun hat, so möge er sich bitte mit einer anderen Kommunikationsart begnügen.
Die entsprechenden Beiträge wurden entfernt.;)
Ok es war sicherlich amüsant für Außenstehende, aber der Vergleich von Faktotum war auch, meiner Meinung nach, etwas ungerecht. Vor allem, weil der VT2020 nur onboard ist und die Fatal1ty 'ne teure Soundkarte. Na ja, ist gegessen.
Hallo Am3er
Habe von einem Forumsmitglied das Asus Crosshair IV Formula erworben,jenes auch bis gestern super lief.Alles lief auf Standardwerte wurde nichts übertaktet.Mittags wollte meine Tochter am Rechner und es ging nichts mehr!:wall:Hab noch ein Am3-System und konnte alle Komponente testen,leider liegt es am Asus.Cmos-Reset hat auch nichts gebracht,komme nich mal ins Cmos(Bios):wall:Einer ne Idee?Cmos-Reset indem ich die Batterie eine Minute entnommen habe,ist doch richtig,oder gibts noch nen Jumper?
MFG
zwischen den schwarzen und blauen usb anschlüssen gibt es einen cmos clear knopf und auf dem board selbst einen jumper mit dem man den knopf ein und ausschalten kann.
versuch das mal bitte.
Ist das dieser Go Button?Meine USB Anschlüsse sind alle schwarz^^
nöp ... hinten am board, da wo die ganzen usb anschlüsse sind, über den blauen usb 3.0 liegt der cmos clear knopf.
---------- Beitrag hinzugefügt um 11:32 ---------- Vorheriger Beitrag war um 11:29 ----------
ps: war das handbuch nicht dabei? wirf doch mal nen blick rein. :)
Habs versucht,geht nicht.CPU led geht an,dann kommen die Rams und dann will er nicht mehr.Speicher laufen aber,hab Sie gerade bei mir drin!(Post Led)Muss woll in die RMA.
RSOD - red spot of death ... sozusagen ... hatte ich mit meinem ersten CIVF leider auch nach einem bios update.
mein board blieb bei der cpu-led stehen und wollte nicht mehr.
sorry for that dude. :(
Hallo Am3er
MFG
Frauen und Technik. :fresse2:
Na ja, schade ums Board, hoffentlich krigst es ersetzt. :)
Btw -> Hat jmd von euch schon mal das 3017 Bios geladen?
ABER ACHTUNG!!
Es handelt sich um ein Beta - BIOS^^
Siehe:
Crosshair IV Formula 3017 Test BIOS
For testing AM3+ CPU Function only, do not update this BIOS while using AM3 or previous type CPUs!
grEEtz
fuzzy
Deswegen frag ich ja auch vorher nach ob sich das schon jmd. geladen hat. :P
ich habs grad getestet und bin nich zufrieden. c&q funktioniert nicht richtig. daher wieder das 19er drauf
ich muss gestehen, dass das ploppen immer noch da ist. scheint ein placebo gewesen zu sein dem ich da erlag.
vorher nutzte ich den 9100d treiber, jetzt den 9400a ... ich beobachte das mal noch 1-2 tage bevor ich nochn statement abgebe.
http://www.station-drivers.com/tele...IA_hd_audio_9400(www.station-drivers.com).exe
aber fakt ist, das ploppen kommt vom stromsparmodus der aktiviert sobald nichts läuft.
idle braucht mein sys 95w. wenn ich musik abspiele sind es fast 110w.
15w fürs musikabspielen? äh, hallo? ich glaub es hackt!
Komisch, ich hör nichtmal ein Ploppen, außer einmal beim Booten, wenn sich der Soundchip aktiviert.
wie gesagt, hatte ich das mit ner alten installation auch. werden wohl treiberreste von versionen vorm 9100d gewesen sein.
Ich hab V6018100 drauf.
daran wirds wohl liegen ... alerdings brauche ich mindestens v9100d um front & rear audio gleichzeitig nutzen zu können ...
Bei mir gehts auch so. o_O?
Hab einmal Front mic und Headphone glaub ich und einmal Lautsprecher Via HD Audio.
